2 Pages V   1 2 >
foo_removeplayed, Removes played tracks from the playlist
Chronial
post Nov 19 2006, 02:18
As requested by a friend, I made this quite simple component. It removes tracks from the playlist once they've been played (or skipped). So every time playback advances, the previously played track will disappear from the playlist.
This is a very basic component at the moment (with just an option to switch it on and off), but if people are interested in something like that, I might extend it.
If you have any feature requests, here's the right place to make them public and to allow me to know about them wink.gif
Current Version: v 1.4 (2007-09-02)
Download:
http://chron.visiondesigns.de/foobar2000/f...played_v1.4.zip
Feature Requests
  • Apply only to playlists matching a pattern
  • Apply only to tracks matching a pattern
  • Options to define when you see a track as "played"
  • Send deleted tracks to a special playlist
  • - Keyboard shortcut to do this manualy
  • Option for delete on stop
  • Option for deleting playlist after it hast been played empty
Changelog:
v1.4
- Added "remove when skipped" functionality (has toggle in the menu)
v1.3
- Added a toggle to the menu (Playback->Remove played tracks)
v1.2
- Using another way to find out if a song has been played
v1.1
Fixed some bugs:
- Tracks are removed instantly instead of with 1 sec. delay
- Tracks are also removed if they are the last item of the playlist
v1.0
- Initial Release
This post has been edited by Chronial: Sep 2 2007, 12:31
vkeios
post Nov 19 2006, 04:41
Thank you, I've got a playlist or two, this would be perfect for.
luckycatfu
post Nov 19 2006, 07:06
This is a great idea- i would use it if it could be applied to certain playlists only, or better yet as a check/uncheck like Stop After Current.
This could effectively replace the playback queue i think, and yet still allow it to be re-ordered, add/remove songs etc as the queue should have been originally.
fabiospark
post Nov 19 2006, 09:07
QUOTE (Chronial @ Nov 19 2006, 03:18) *
Maybe:
1 - ability to set it to remove only if played track matches a criteria. For instance, a certain value in a certain tag. I have this "To tag" playlist where I load currently untagged tracks. I'm usually tagging them (rating, tempo and situations) with a remote control while they are playing. Sometimes, I fail to do it because I'm involved in something else. It would be useful (for me, at least) if the untagged ones would stay in the playlist even if they have already been played. The tagged ones should disappear, instead.
2 - ability to set when a track must be removed. If I'm previewing some tracks, manually or with the preview plugin, I could consider "played" a track even if it has not been played to the end.
3 - ability to send the removed tracks to another (existing or not) playlist as a sort of "bin playlist"
4 - make averything above avalaible in the keyboard shortcut configurator
Chronial
post Nov 19 2006, 11:43
Could you explain this further?
If a certain percentage of the track has been played?
Chronial
post Nov 19 2006, 15:02
QUOTE (luckycatfu @ Nov 19 2006, 08:06) *
fabiospark
post Nov 19 2006, 17:29
QUOTE (Chronial @ Nov 19 2006, 12:43) *
Yes.
Another way could be something like this:
IF (elapsed time seconds > x) OR (end of track) OR (percentage > y) THEN remove.
The seconds could be more precise than the % when you're using the Preview mode.
Another thing would be a "remove" command on the shortcuts list working only on the now playing track.
I'm not sure but I think the existent "remove from playlist" works on the selected one.
Edit: sorry, I read the first post after sending my reply. Of course, ignore the things you have already done.
This post has been edited by fabiospark: Nov 19 2006, 17:31
nightfishing
post Nov 19 2006, 19:36
great plugin (thanks).
It doesn't seem to work with playlsts generated by "autoplaylist" though.
Other than that it is working beautifully.
Frank Bicking
post Nov 19 2006, 19:44
Not a bug. Autoplaylists are supposed to behave this way.
If you were able to remove tracks from an autoplaylist, it wouldn't contain the tracks specified by its query anymore.
nightfishing
post Nov 19 2006, 19:56
Wasn't inferring that it was a bug, sorry if that's the way the post came off.
black92
post Nov 19 2006, 20:34
q-stankovic
post Nov 20 2006, 14:17
Nice plugin!
I took a look in Dro's file removal plugin for Winamp to see which good ideas he already implemented. So here are some ideas:
1. Option for "Remove on next" and "Remove on stop"
2. Option for "Load played playlist after last file was removed"
What i would like to have is a variable to display in trackinfo if file removal is activated or not.
Another idea: Make the option for removal in main menu independent for each playlist so that you can switch from playlist to playlist and check this option fot just that playlist you like to have the removal (to avoid confusion the option could be greyed out for read only or autoplaylists)
This post has been edited by q-stankovic: Nov 20 2006, 14:22
metal_termite
post Nov 20 2006, 18:00
I think you forgot to change the version number; it reads 1.2.0
tool++
post Nov 20 2006, 18:06
hi
Chronial
post Nov 20 2006, 19:35
Post #15
QUOTE (metal_termite @ Nov 20 2006, 19:00) *
Thx, fixed
QUOTE (tool++ @ Nov 20 2006, 19:06) *
Too late ^^
This post has been edited by Chronial: Nov 20 2006, 19:36
q-stankovic
post Nov 21 2006, 16:31
Post #16
I think it would also be useful to have in main menu an additional toggle option to remove skipped tracks (on next or stop). So that you at whole have three modes: remove played, remove skipped or remove both. Sometimes you like just to remove that tracks that are not worth being heard in full length. That wouldn't touch a possible option to consider tracks as played wich was played f.e. 80%
Remedial Sound
post Nov 21 2006, 19:27
Post #17
Thanks for the very nice plugin Chronial.
I'm wondering how feasible it would be to...
add a user option to remove files from the playlist only after the all songs of the album (i.e., all songs matching %album% in the playlist) are played? I mainly listen to music in "album mode," it would be nice to keep the entire album's tracks in the playlist until it's done. Thanx for considering this feature!
Chronial
post Nov 21 2006, 19:51
Post #18
QUOTE (Remedial Sound @ Nov 21 2006, 20:27) *
Why do you want that?
Remedial Sound
post Nov 21 2006, 20:05
Post #19
I'd just be interested in having the option to remove albums after they're played (rather than tracks after they're played). If it's too strange/bizarre of a request then fughettaboutit.
Chronial
post Nov 21 2006, 20:07
Post #20
I understood that - I just wanted to ask, what would be the use of such a feature?
Only for visual pleasure? (having full albums in the playlist just looks better ^^)
Remedial Sound
post Nov 21 2006, 21:49
Post #21
QUOTE (Chronial @ Nov 21 2006, 14:07) *
Hmm, I suppose it is just a visual thing. I just like being able to see all the tracks of the album I'm currently listening to. Thanks for listening, but don't bother if I'm the only person interested in this feature.
GeSomeone
post Nov 23 2006, 21:41
Post #22
I have use for this. Now I should just remember to disable it when I don't want to remove played tracks dry.gif
BTW. When I first started up with this dll, the remove function was enabled. I don't think that's a good idea. The other users on this computer will wonder where their tracks went unsure.gif
In theory, there is no difference between theory and practice.
Chronial
post Nov 23 2006, 21:46
Post #23
QUOTE (GeSomeone @ Nov 23 2006, 22:41) *
Well, wouldn't you enable it anyway after installation?
I just wanted to prevent those "can't find the component after installing it" questions I've seen alot around here wink.gif
fabiospark
post Dec 26 2006, 18:26
Post #24
Killmaster
post Feb 6 2007, 02:03
Post #25
bump because I'd really like to see some kind of playlist-specific options added
2 Pages V   1 2 >
RSS Lo-Fi Version Time is now: 30th March 2015 - 15:58
