REACT 2 Released, New version of this popular ripping tool
Synthetic Soul
post Nov 17 2006, 08:53
REACT 2.0 is not backward compatible with version 1.0. This version is more powerful, easier to use and configure. It uses only two configuration scripts: REACT-image.cfg, and REACT-track.cfg. Image mode (F10) is recommended, as it may be used for creating both an image and tracks, and is a little more robust. With Nyaochi's excellent ACDIR, it will split the image to tracks while encoding. You can pick and choose from which formats you want by only editing a few characters in the .cfg file. See examples below.
NEWS
  • Only one configuration file for each mode (image/track).
  • Simpler user-configuration, located in first section of .cfg file (Alt-F3).
  • Built-in support for CoverDownloader (albumart.exe). Runs when hitting F10/F4. Alt-F10 for CoverDownloader only.
  • Adds cover pictures to FLAC (with 1.1.3beta) and MP3 by using my new tool, metamp3.exe
  • Optionally scans and tags ReplayGain for all formats. May also apply album gain on MP3/AAC files.
  • Writes ID3v2.3 ReplayGain tags on MP3's (Winamp/Foobar compatible), via metamp3.exe
  • Should fix random REACT exiting, reported by some users.
  • User may now minimize EAC while ripping (EAC will auto-restore when ripping done, and save log).
  • Accepts both "Various" and "Various Artists" as compilation disk.
  • If CreateAllCuesheets=1 is set in INI file, and EAC is set up to extract to a fixed directory, REACT will save all types of cuesheets when hitting F4/F10. Cuesheets can be accessed from scripts by @albumfile@ variable. E.g. "@albumfile@.[mg].cue"
  • The (unsafe) @islast@ variable for track mode is not supported anymore. Use @track@==@numtracks@ test instead, or image mode.
FEATURES
The wiki has more info : http://wiki.hydrogenaudio.org/index.php?title=REACT
More information and download in the thread REACT 2, EAC plugin
I'm on a horse.
tycho
post Nov 22 2006, 15:22
Ah. The cover is embeded in the tracks for flac, mp3 and m4a files, so they are not copied to the directory by default. You may extract them using metaflac, metamp3 and neroaactag correspondingly. If you want to have the cover files in the directory as standard, remove the REM from the line:
REM IF %add_cover%==1 COPY "@cover@" "folder.jpg"
for the format in question.
- Synthetic Soul   REACT 2 Released   Nov 17 2006, 08:53
- - Xenion   i'm new to this tool. is it possible to rip as...   Nov 17 2006, 11:39
- - tycho   If you rip as image, you may encode to either a wa...   Nov 17 2006, 12:26
- - drbeachboy   Hi Tycho, With embedded cuesheets (Especially wit...   Nov 17 2006, 18:12
|- - Synthetic Soul   QUOTE (drbeachboy @ Nov 17 2006, 17:12) H...   Nov 17 2006, 18:34
- - valnar   You know, I never had to uninstall REACT v1.0. Ho...   Nov 17 2006, 21:32
- - Keykey   I am a total newbie to REACT, sorry. How do I get...   Nov 17 2006, 21:39
- - Gow   Awesome release. Keep up the good work.   Nov 17 2006, 23:34
- - wolfsong   Can't wait to try this release tonight when I ...   Nov 18 2006, 00:38
- - HbG   Just set it up to work with flake and metaflac for...   Nov 18 2006, 02:03
- - hanning   It seems that the following section in REACT-image...   Nov 18 2006, 04:56
- - wolfsong   So I just tried it out and like the new config but...   Nov 18 2006, 07:54
- - Synthetic Soul   QUOTE (Keykey @ Nov 17 2006, 20:39) I am ...   Nov 18 2006, 10:49
|- - wolfsong   QUOTE (Synthetic Soul @ Nov 18 2006, 03:4...   Nov 18 2006, 19:09
- - drbeachboy   I also found the tag lines for embedding the cuesh...   Nov 18 2006, 18:32
- - tycho   Thanks for all the great feedback. I have uploaded...   Nov 19 2006, 02:08
|- - wolfsong   QUOTE (tycho @ Nov 18 2006, 19:08) @wolfs...   Nov 19 2006, 05:12
|- - wolfsong   QUOTE (tycho @ Nov 18 2006, 19:08) Thanks...   Nov 25 2006, 07:57
- - tycho   AFAIK, there is no explicit ID stored on the CD, b...   Nov 19 2006, 11:15
|- - wolfsong   QUOTE (tycho @ Nov 19 2006, 04:15) AFAIK,...   Nov 19 2006, 13:42
|- - bhoar   QUOTE (wolfsong @ Nov 19 2006, 08:42) hmm...   Nov 19 2006, 20:40
- - spoon   There is ISRC (International Standards Recoding Co...   Nov 19 2006, 20:47
- - sdgenxr   Thanks for the great release tycho! This vers...   Nov 20 2006, 05:44
|- - tycho   QUOTE (sdgenxr @ Nov 19 2006, 20:44) My q...   Nov 20 2006, 08:52
- - TomGroove   excellent, I like the new version. Struggled a lit...   Nov 20 2006, 16:23
- - wolfsong   I'm having a problem with CoverArtDownloader. ...   Nov 20 2006, 17:41
- - tycho   The coverdownloader will fill in a name <destdi...   Nov 20 2006, 19:48
|- - wolfsong   QUOTE (tycho @ Nov 20 2006, 12:48) The co...   Nov 20 2006, 21:00
|- - wolfsong   QUOTE (tycho @ Nov 20 2006, 12:48) The de...   Nov 21 2006, 14:02
|- - Synthetic Soul   QUOTE (wolfsong @ Nov 21 2006, 13:02) Als...   Nov 21 2006, 14:24
|- - wolfsong   QUOTE (Synthetic Soul @ Nov 21 2006, 07:2...   Nov 21 2006, 14:48
|- - tycho   QUOTE (wolfsong @ Nov 21 2006, 05:48) QUO...   Nov 21 2006, 16:02
|- - wolfsong   QUOTE (tycho @ Nov 21 2006, 09:02) Conclu...   Nov 21 2006, 21:01
- - countryman   Hi, I have downloaded REACT 2 but cannot get it t...   Nov 22 2006, 00:36
- - drbeachboy   Try pressing the "F10" key on your keybo...   Nov 22 2006, 02:36
- - wolfsong   @tycho Even when I leave out this extra bit of cod...   Nov 22 2006, 06:34
|- - tycho   QUOTE (wolfsong @ Nov 21 2006, 21:34) @ty...   Nov 22 2006, 09:39
|- - wolfsong   QUOTE (tycho @ Nov 22 2006, 02:39) QUOTE ...   Nov 22 2006, 12:53
- - tycho   Ah. The cover is embeded in the tracks for flac, m...   Nov 22 2006, 15:22
|- - wolfsong   QUOTE (tycho @ Nov 22 2006, 08:22) Ah. Th...   Nov 22 2006, 16:13
|- - wolfsong   QUOTE (tycho @ Nov 22 2006, 08:22) If you...   Nov 23 2006, 19:26
- - Synthetic Soul   It is basic DOS commands BTW. http://www.ss64.com...   Nov 22 2006, 16:44
- - sdgenxr   Image creation assistance needed. For some reason...   Nov 25 2006, 06:33
|- - wolfsong   QUOTE (sdgenxr @ Nov 24 2006, 23:33) How ...   Nov 25 2006, 06:42
- - Martin H   @tycho 1. Would you please add an option for addi...   Nov 26 2006, 18:10
|- - wolfsong   QUOTE (Martin H @ Nov 26 2006, 11:10) 2. ...   Nov 26 2006, 18:59
- - tycho   Again, Thanks for all feedback. @sdgenxr: You mus...   Nov 26 2006, 22:48
|- - wolfsong   QUOTE (tycho @ Nov 26 2006, 15:48) @wolfs...   Nov 27 2006, 01:08
|- - tycho   QUOTE (wolfsong @ Nov 26 2006, 16:08) QUO...   Nov 27 2006, 09:39
|- - wolfsong   QUOTE (tycho @ Nov 27 2006, 02:39) The li...   Nov 27 2006, 15:07
- - Martin H   @wolfsong Thank's for your reply Btw, the ...   Nov 26 2006, 23:31
- - tycho   Correct.   Nov 27 2006, 15:23
- - mogorp   I have found React 2 to work flawlessly. I just h...   Nov 27 2006, 21:15
|- - wolfsong   QUOTE (mogorp @ Nov 27 2006, 14:15) 2. W...   Nov 27 2006, 21:20
- - tycho   QUOTE 1. Can you explain the default settings for ...   Nov 28 2006, 07:37
- - wolfsong   I keep running into issues and I think it's so...   Nov 28 2006, 15:30
|- - Synthetic Soul   QUOTE (wolfsong @ Nov 28 2006, 14:30) Las...   Nov 28 2006, 16:38
||- - tycho   QUOTE (Synthetic Soul @ Nov 28 2006, 07:3...   Nov 28 2006, 16:47
||- - wolfsong   QUOTE (Synthetic Soul @ Nov 28 2006, 07:3...   Nov 28 2006, 17:52
|||- - Synthetic Soul   QUOTE (wolfsong @ Nov 28 2006, 16:52) I...   Nov 29 2006, 15:26
|||- - wolfsong   QUOTE (Synthetic Soul @ Nov 29 2006, 08:2...   Nov 30 2006, 20:26
||- - Martin H   QUOTE (tycho @ Nov 28 2006, 16:47) [...] ...   Nov 29 2006, 15:13
|- - awnm   Thanks for the new version - it's great. The n...   Dec 10 2006, 12:29
- - Synthetic Soul   It should work, unless your variable AlbumArtist c...   Nov 30 2006, 21:12
|- - wolfsong   QUOTE (Synthetic Soul @ Nov 30 2006, 14:1...   Dec 1 2006, 00:58
|- - Synthetic Soul   QUOTE (wolfsong @ Nov 30 2006, 23:58) I...   Dec 1 2006, 10:09
|- - wolfsong   QUOTE (Synthetic Soul @ Dec 1 2006, 03:09...   Dec 1 2006, 17:12
|- - Synthetic Soul   QUOTE (wolfsong @ Dec 1 2006, 16:12) I ju...   Dec 1 2006, 19:17
|- - wolfsong   QUOTE (Synthetic Soul @ Dec 1 2006, 12:17...   Dec 1 2006, 19:41
- - Synthetic Soul   I'm sorry, I should have been more clear: you ...   Dec 1 2006, 20:15
|- - wolfsong   QUOTE (Synthetic Soul @ Dec 1 2006, 13:15...   Dec 1 2006, 20:53
- - Dondo   Thanks Tycho for creating REACT. I'm finding i...   Dec 1 2006, 21:02
- - Synthetic Soul   QUOTE (wolfsong @ Dec 1 2006, 19:53) YEAH...   Dec 2 2006, 10:34
|- - Dondo   QUOTE (Synthetic Soul @ Dec 2 2006, 05:34...   Dec 2 2006, 22:53
- - SpiceWeasel   I've installed REACT 2 several times on Window...   Dec 3 2006, 00:28
|- - wolfsong   QUOTE (SpiceWeasel @ Dec 2 2006, 17:28) I...   Dec 3 2006, 00:48
|- - SpiceWeasel   QUOTE (wolfsong @ Dec 2 2006, 19:48) Are ...   Dec 3 2006, 20:14
- - FauDrei   Hi, Perhaps this information will spare someone...   Dec 4 2006, 00:44
|- - Mangix   QUOTE (FauDrei @ Dec 3 2006, 15:44) You c...   Dec 4 2006, 03:59
- - Synthetic Soul   It's down to how Windows creates directories. ...   Dec 4 2006, 11:35
- - tycho   Thanks for making me aware of this. Release 2.0 wi...   Dec 5 2006, 09:27
- - Synthetic Soul   Slightly OT, but, I had to upgrade to 3.2.1.10 (be...   Dec 5 2006, 10:20
|- - bhoar   QUOTE (Synthetic Soul @ Dec 5 2006, 04:20...   Dec 5 2006, 19:05
- - schnittlich   Just started using REACT 2 (been using the older v...   Dec 6 2006, 01:30
- - tycho   schnittlich: I can't see why this version shou...   Dec 11 2006, 13:35
|- - phaedra   QUOTE (tycho @ Dec 11 2006, 04:35) ... I ...   Dec 12 2006, 00:31
- - Meddler   First of all let me say thank you tycho. I've...   Dec 12 2006, 04:28
- - tycho   Meddler: You're welcome. 1) metamp3/mp3gain a...   Dec 12 2006, 10:28
|- - Meddler   QUOTE (tycho @ Dec 12 2006, 09:28) 1) met...   Dec 12 2006, 23:15
- - Synthetic Soul   Ooh. I did it already. I was reading the new wi...   Dec 12 2006, 11:46
- - drbeachboy   Hi tycho, Would you please explain to me why thes...   Dec 12 2006, 16:04
- - Synthetic Soul   If I understand correctly @AddCuesheetAG@ represen...   Dec 12 2006, 16:09
- - tycho   Yep, because of limitations in DOS scripting langu...   Dec 12 2006, 16:37
- - drbeachboy   tycho & SS, Thank you for the explanations.   Dec 12 2006, 18:04
- - robwade   tycho, Hello from a longtime enthusiast and first...   Dec 13 2006, 02:34
- - Ahmet   Hi everyone, First of all I have to express my ap...   Dec 13 2006, 10:14
- - tycho   @Meddler: You are correct. ApplyAlbumGain should p...   Dec 13 2006, 10:19
- - Ahmet   Thanks Tycho for your prompt answer!! I k...   Dec 13 2006, 10:55
- - tycho   I've just found a small glitch in the REACT-im...   Dec 13 2006, 13:05
- - Martin H   I would just like to say many thanks to the great ...   Dec 14 2006, 12:39
19 Pages V   1 2 3 > »
RSS Lo-Fi Version Time is now: 7th March 2015 - 06:20
