CUE Tools, Convert between different CUE sheet styles
Moitah
post Nov 12 2006, 07:48
Converts between different audio CUE sheet styles. This includes the audio data which means it can split, join, add silence to fill gaps, or remove gaps where necessary. WAV, FLAC, and WavPack are supported for input and output. Output can be optionally offset to compensate for burner write offset. See the ReadMe.txt file included with the binary for help with the options.
Change Log:
1.9.1 (2007-Sep-19):
* Added: Configurable WavPack compression mode and extra mode.
* Added: Option to preprocess CUE sheets with filename corrector during normal
and batch mode.
* Settings and Filename Corrector windows are now centered inside main window
when opened.
* Updated FLAC library to 1.2.1 and cleaned up callback code.
1.9.0 (2007-Aug-04):
* Added: Batch mode.
* Added: Option to generate output path based on a custom format string.
* Added: Tool to correct the filenames within CUE sheets based on the audio
files present in the same folder.
* Added: Option to preserve HTOA when outputting gaps appended CUE sheets.
* Added: Advanced settings window. Write offset has been moved here, and the
FLAC settings can be changed here without having to manually edit the
settings file.
* Compiled with platform target = x86. Allows FLAC and WavPack DLLs to be
loaded in 64-bit Windows but requires the x86 version of the .NET
Framework 2.0.
1.8.0 (2007-Jul-30):
* Added: Option to offset the output audio.
* Fixed: Error when stopping with FLAC/WavPack output.
* Now accepts files that don't end on a CD frame boundary, shows warning.
* Updated FLAC library to 1.2.0, uses set_compression_level, and changed
padding to 8k.
1.7.1 (2007-Jul-19):
* Updated FLAC library to 1.1.4.
* Updated WavPack library to 4.41.
1.7.0 (2006-Nov-03):
* Added: WavPack support, both read and write.
1.6.0 (2006-Nov-01):
* Added: Option to output FLAC files.
* Fixed: "Index length cannot be 0" error.
* Fixed: Couldn't handle CUE sheets with data tracks.
* It's now possible to stop/cancel when writing audio files.
1.5.1 (2006-Mar-01):
* Fixed: FLAC files weren't being closed completely.
* Fixed: Possible problem opening FLAC files with strange characters in the
filename.
* Optimized FLAC sample copy loop.
1.5.0 (2006-Feb-28):
* Added: Support for reading audio from FLAC files.
1.4.3 (2006-Feb-27):
* Fixed: Small range of extended ASCII characters were being changed for
filename creation.
1.4.2 (2006-Feb-27):
* Fixed: Extended ASCII characters weren't working properly.
* Rejects CUE sheets with POSTGAP command.
1.4.1 (2006-Feb-26):
* Added: Hidden option to write PREGAP instead of INDEX 00 for the first
track of a single file CUE sheet (only when the "Create CUE sheet only"
option is used).
1.4.0 (2006-Feb-26):
* Added: Converts the WAV files as well by splitting, joining, adding silence
to fill gaps, or removing gaps where necessary.
* Added: Option to place the output file(s) in a new subdirectory.
1.3.0 (2006-Feb-25):
* Added: Conversion to the other 3 CUE sheet styles.
* Added: Generates audio filenames inside the CUE sheets from the TITLE and
PERFORMER information based on user-specifiable patterns and settings.
* ReplayGain information is now removed since it doesn't translate between
all the CUE sheet styles.
1.2.0 (2006-Feb-22):
* Fixes a bug with writing timestamps over an hour.
* Option to generate output filename by appending something to the input
filename.
* Single WAV filename in the output CUE sheet can be customized.
1.1.0 (2006-Feb-21):
* Uses the directory information inside the CUE if it can't find the audio
file in the same directory as the CUE.
* Able to read the length of FLAC files.
1.0.0 (2006-Feb-18):
* First release.
Download: Binary, Source (incl. FLACDotNet and WavPackDotNet)
IMPORTANT: .NET Framework 2.0 (x86) required. If you get a "could not load file or assembly" error message for FLACDotNet or WavPackDotNet, make sure the Visual C++ 2005 SP1 runtime files (x86) are installed.
This post has been edited by Moitah: Sep 19 2007, 22:16
batagy
post Mar 25 2008, 20:03
Hi Moitah!
Is your "Wav Tools" now included in "Cue Tools"? I mean I can't find Wav Tools at your homepage anymore. I didn't follow here in recent times, so I don't know, but I guess that functionaliy of Wav Tools is in Cue Tools now. Am I right?
Great tool indeed!
- Moitah   CUE Tools   Nov 12 2006, 07:48
- - bobbel   just what I was looking for Thanks a lot! b...   Jan 5 2007, 21:07
- - christopher   Ace stuff, thanks.   Jan 25 2007, 17:59
- - eXecutioner   why is it that i get this error??   Mar 15 2007, 03:17
- - Moitah   On a CD each track is required to be a multiple of...   Mar 15 2007, 03:36
|- - eXecutioner   QUOTE (Moitah @ Mar 15 2007, 10:36) On a ...   Mar 15 2007, 03:48
- - Moitah   You will have to add some silence yourself in a WA...   Mar 15 2007, 04:16
- - M   You could also attempt one of the following lines ...   Mar 15 2007, 04:45
- - Moitah   Released CUE Tools 1.7.1 to update FLAC to 1.1.4, ...   Jul 19 2007, 21:39
- - Fandango   An update! Btw, are there "hidden sett...   Jul 19 2007, 22:00
- - Moitah   Nope, it always uses the default WavPack encoder s...   Jul 19 2007, 22:16
- - Societal Eclipse   What was the problem here? I was trying to split ...   Jul 22 2007, 17:47
- - Moitah   First make sure FLACDotNet.dll is in the same fold...   Jul 22 2007, 19:17
|- - Societal Eclipse   QUOTE (Moitah @ Jul 22 2007, 14:17) The p...   Jul 22 2007, 23:29
- - Moitah   CUE Tools 1.8.0 is released. It adds a feature I...   Jul 31 2007, 04:35
- - greynol   Very nice. What would be cool is the ability to s...   Jul 31 2007, 05:02
|- - Moitah   QUOTE (greynol @ Jul 31 2007, 00:02) What...   Jul 31 2007, 05:17
- - Moitah   Here's a quick build I did with that feature. ...   Jul 31 2007, 05:36
- - Fandango   QUOTE Added: Option to offset the output audio. He...   Aug 1 2007, 15:21
- - Moitah   1.9.0 released, lots of new stuff, see the change ...   Aug 5 2007, 05:01
- - Fandango   ...even more good features! Is it planned to a...   Aug 5 2007, 16:15
|- - Moitah   @Fandango: Glad everything is working well for you...   Aug 5 2007, 17:50
- - Bill O   Any chance you can add the following features? I ...   Sep 12 2007, 00:05
- - saltaslt   Hello there. Why I am getting "External compo...   Sep 12 2007, 17:32
|- - Moitah   QUOTE (saltaslt @ Sep 12 2007, 12:32) Hel...   Sep 19 2007, 00:07
- - saltaslt   I tested various formats with 1.9.0 and theres res...   Sep 19 2007, 09:40
- - Moitah   I don't know what could be going wrong because...   Sep 19 2007, 19:52
- - Moitah   1.9.1 released. Adds settings for WavPack compres...   Sep 19 2007, 22:19
- - saltaslt   Still same as 1.9.0 cant output anything from fla...   Sep 19 2007, 23:51
|- - hanswurst   QUOTE (saltaslt @ Sep 19 2007, 14:51) Sti...   Sep 30 2007, 07:17
- - Fandango   QUOTE Added: Configurable WavPack compression mode...   Sep 21 2007, 18:42
|- - Moitah   QUOTE (Bill O @ Sep 11 2007, 19:05) Any c...   Sep 21 2007, 19:03
- - Grey   CUE Tools won't convert my single-file cue to ...   Sep 22 2007, 02:06
- - Moitah   @Grey: It would be possible to do cuesheet-only c...   Sep 22 2007, 02:25
|- - Grey   QUOTE (Moitah @ Sep 21 2007, 20:25) @Grey...   Sep 22 2007, 02:43
- - greynol   I wrote a batch script a while back that can do wh...   Sep 22 2007, 02:49
|- - Grey   QUOTE (greynol @ Sep 21 2007, 20:49) I wr...   Sep 22 2007, 03:58
- - Moitah   I was able to track down the FLAC crashing issue, ...   Sep 24 2007, 05:25
- - saltaslt   Thanks for fixing it Moitah. Now it works flawless...   Sep 24 2007, 13:30
- - martin2048   What is wavpack 'extra mode' here? asymmet...   Sep 25 2007, 06:55
- - Moitah   It's the same as WavPack's -x switch, whic...   Sep 25 2007, 07:25
- - NachoMan77   Great program, moitah, congratulations ! Coul...   Oct 14 2007, 16:14
- - thinkum dinkum   File corrector works perfectly, thank you very muc...   Jan 12 2008, 19:08
- - m_l   Moitah Thank You for a great program   Jan 20 2008, 01:02
- - Bill O   This is a GREAT tool. I sent the author money: e...   Jan 20 2008, 03:40
- - madmaxhu   Hi! I split a wav image to FLAC tracks accordi...   Mar 15 2008, 12:56
- - batagy   Hi Moitah! Is your "Wav Tools" now ...   Mar 25 2008, 20:03
|- - Moitah   @madmaxhu: CUE Tools isn't able to read or wr...   Mar 25 2008, 23:08
|- - torben   I need to just edit drive offsets. I don't hav...   Apr 9 2008, 07:10
|- - Synthetic Soul   QUOTE (torben @ Apr 9 2008, 07:10) I need...   Apr 9 2008, 08:16
|- - torben   QUOTE (Synthetic Soul @ Apr 9 2008, 10:16...   Apr 10 2008, 07:56
|- - Synthetic Soul   QUOTE (torben @ Apr 10 2008, 07:56) QUOTE...   Apr 10 2008, 08:59
|- - torben   QUOTE (Synthetic Soul @ Apr 10 2008, 10:5...   Apr 10 2008, 09:07
- - greynol   I think CUE tools will do what you want. I still ...   Apr 10 2008, 08:07
|- - torben   QUOTE (greynol @ Apr 10 2008, 10:07) I th...   Apr 10 2008, 08:09
- - greynol   I wrote a very simple batch script that could do t...   Apr 10 2008, 08:22
|- - torben   QUOTE (greynol @ Apr 10 2008, 10:22) I wr...   Apr 10 2008, 08:32
- - greynol   @Synthetic Soul, I'm not sure if you've se...   Apr 10 2008, 17:40
- - Synthetic Soul   Yeah, I just though that (a) WAVTools had all the ...   Apr 10 2008, 19:16
- - greynol   I think the guy wants to end with one file per tra...   Apr 10 2008, 19:27
- - Synthetic Soul   I know nothing of ARFlac or ARCue. I see your poi...   Apr 10 2008, 22:33
- - NachoMan77   Hi Moitah, dunno if you're still interested i...   Jul 10 2008, 02:53
- - Fandango   Moitah, I have a hunch that the Wavpack decompress...   Jul 13 2008, 16:16
- - Gregory S. Chudov   Greetings. I have updated CUETools recently. Trie...   Oct 2 2008, 12:10
|- - odyssey   QUOTE (Gregory S. Chudov @ Oct 2 2008, 13...   Oct 2 2008, 12:33
- - Gregory S. Chudov   Please, update to the newest version, some bugs we...   Oct 8 2008, 00:21
- - birdie   Can you please add a possibility of joining audio ...   Nov 22 2008, 12:41
- - rjalex   Sorry to ask something stupid but despite Googling...   Dec 7 2010, 14:10
- - Porcus   You got into an old thread. A new one: http://www....   Dec 7 2010, 14:13
Closed TopicStart new topic
RSS Lo-Fi Version Time is now: 28th July 2015 - 23:43
