16 bit vs 24 bit, any samples that work?
AndyH-ha
post Nov 3 2006, 03:19
There are real differences between 16 bit and 24 bit files, just as there are real differences between uncompressed and mp3. As with the differences between wav and mp3, 16 bit vs 24 bit is often difficult to identify by listening.
Test signals are one thing, but has anyone found any 24 bit music recording that can be successfully identified via ABX testing against a properly resample to 16 bit version of same?
2Bdecided
post Jan 23 2009, 17:25
ReplayGain developer
Here you go...
http://rapidshare.de/files/43321357/16-hpt-24-n.wav.html
Your 16 bit file, converted back to 24-bits, with a little high-pass noise added to make sure the bottom 8 bits are moving.
Is it better or worse than your 16-bit version?
(where better = closer to the 24-bit original!)
Martin Kantola
post Jan 24 2009, 07:13
QUOTE (2Bdecided @ Jan 23 2009, 11:25) *
Here you go...
Hi David,
took a different approach with these two, hopefully you will find it useful.
Not exactly sure what that 'little high-pass noise' you added would do, so I just started out listening and guessing. This was my one and only attempt at the files, and hopefully you can see how the guessing slowly gets better in the log file. Tried not to think too much, just go by feel and keep going (with some breaks in between). By the time I had reached 100 attempts, the probability of guessing was down to 1% according to the computer.
This time it was much more random as I didn't have the energy to focus properly. It's one thing to stay sharp for 10 attempts, a different story with 100. Even after I found something to pay attention to, my concentration failed and I made many mistakes. It is very hard to do this on the laptop.
Here's the complete log:
foo_abx 1.3.3 report
foobar2000 v0.9.6.1
2009/01/23 22:20:10
File A: C:\Documents and Settings\Valued Customer\Desktop\TEST\samples\16-hpt-24-n.wav
File B: C:\Documents and Settings\Valued Customer\Desktop\TEST\samples\24.wav
22:20:10 : Test started.
22:37:01 : 01/01 50.0%
22:37:45 : 01/02 75.0%
22:38:28 : 02/03 50.0%
22:39:19 : 03/04 31.3%
22:40:15 : 04/05 18.8%
22:42:27 : 05/06 10.9%
22:47:28 : 05/07 22.7%
22:48:01 : 06/08 14.5%
22:50:24 : 06/09 25.4%
22:50:51 : 07/10 17.2%
22:51:23 : 07/11 27.4%
22:58:36 : 07/12 38.7%
22:59:43 : 07/13 50.0%
23:03:40 : 08/14 39.5%
23:03:59 : 08/15 50.0%
23:04:17 : 08/16 59.8%
23:04:25 : 08/17 68.5%
23:04:39 : 09/18 59.3%
23:04:53 : 09/19 67.6%
23:05:04 : 10/20 58.8%
23:05:28 : 10/21 66.8%
23:05:46 : 10/22 73.8%
23:06:45 : 11/23 66.1%
23:07:01 : 12/24 58.1%
23:07:13 : 13/25 50.0%
23:07:46 : 14/26 42.3%
23:07:59 : 14/27 50.0%
23:08:19 : 14/28 57.5%
23:09:20 : 14/29 64.4%
23:09:33 : 15/30 57.2%
23:11:16 : 16/31 50.0%
23:11:30 : 16/32 57.0%
23:32:28 : 17/33 50.0%
23:32:51 : 18/34 43.2%
23:33:21 : 19/35 36.8%
23:33:45 : 20/36 30.9%
23:34:27 : 21/37 25.6%
23:35:06 : 21/38 31.4%
23:35:35 : 22/39 26.1%
23:35:46 : 22/40 31.8%
23:36:04 : 22/41 37.8%
23:36:16 : 23/42 32.2%
23:36:25 : 24/43 27.1%
23:36:41 : 25/44 22.6%
23:37:59 : 26/45 18.6%
23:38:33 : 27/46 15.1%
23:38:40 : 28/47 12.1%
23:38:50 : 29/48 9.7%
23:40:29 : 30/49 7.6%
23:41:12 : 31/50 5.9%
23:42:28 : 31/51 8.0%
23:42:51 : 32/52 6.3%
23:43:03 : 33/53 4.9%
23:43:56 : 34/54 3.8%
23:46:56 : 35/55 2.9%
23:48:04 : 36/56 2.2%
23:48:59 : 36/57 3.1%
23:49:54 : 37/58 2.4%
23:50:23 : 37/59 3.4%
23:50:53 : 38/60 2.6%
23:51:51 : 38/61 3.6%
23:52:01 : 39/62 2.8%
23:53:02 : 39/63 3.8%
23:54:50 : 40/64 3.0%
23:55:01 : 40/65 4.1%
23:55:31 : 41/66 3.2%
23:55:42 : 42/67 2.5%
23:58:10 : 43/68 1.9%
00:00:02 : 43/69 2.7%
00:00:53 : 43/70 3.6%
00:01:34 : 44/71 2.8%
00:02:14 : 44/72 3.8%
00:02:32 : 45/73 3.0%
00:02:41 : 45/74 4.0%
00:02:53 : 46/75 3.2%
00:03:16 : 47/76 2.5%
00:03:32 : 48/77 2.0%
00:03:54 : 49/78 1.5%
00:05:15 : 50/79 1.2%
00:06:28 : 50/80 1.6%
00:06:38 : 51/81 1.3%
00:07:45 : 51/82 1.8%
00:08:06 : 52/83 1.4%
00:08:36 : 52/84 1.9%
00:10:12 : 52/85 2.5%
00:10:23 : 52/86 3.3%
00:10:50 : 53/87 2.7%
00:11:06 : 54/88 2.1%
00:11:25 : 54/89 2.8%
00:11:57 : 55/90 2.2%
00:12:35 : 56/91 1.8%
00:13:14 : 56/92 2.4%
00:13:40 : 57/93 1.9%
00:14:03 : 58/94 1.5%
00:14:51 : 59/95 1.2%
00:15:14 : 59/96 1.6%
00:15:51 : 60/97 1.2%
00:16:29 : 60/98 1.7%
00:16:41 : 61/99 1.3%
00:17:31 : 62/100 1.0%
00:18:38 : Test finished.
Total: 62/100 (1.0%)
Martin
- AndyH-ha   16 bit vs 24 bit   Nov 3 2006, 03:19
- - Mike Giacomelli   I'd imagine ABX would be possible if you found...   Nov 3 2006, 03:25
- - pdq   I recall a test here some years back to try to see...   Nov 3 2006, 05:33
- - Aetmos   If the clip is properly dithered, this doesn't...   Nov 3 2006, 06:22
- - cabbagerat   QUOTE (Aetmos @ Nov 2 2006, 21:22) If the...   Nov 3 2006, 07:31
|- - Aetmos   QUOTE Welcome to HA. I see this is your first post...   Nov 3 2006, 16:17
- - AndyH-ha   I agree that a good sample, if it exist in music, ...   Nov 3 2006, 09:36
- - cabbagerat   QUOTE (AndyH-ha @ Nov 3 2006, 00:36)...   Nov 3 2006, 16:25
- - Axon   I suppose it's quite easy to construct a track...   Nov 3 2006, 17:48
- - Axon   Also, how contrived can the listening environment ...   Nov 3 2006, 18:03
- - AndyH-ha   The question isn't whether or not it is possib...   Nov 3 2006, 20:18
- - Axon   Well.. how much dynamic range can you coax out of ...   Nov 3 2006, 20:38
- - AndyH-ha   I'm sorry, that went over my head. What is the...   Nov 3 2006, 21:21
- - outscape   haha nothing.. see 24 bits is purist technology. i...   Nov 3 2006, 22:23
- - greynol   I'd wager that in order to distinguish the dif...   Nov 3 2006, 22:41
- - Axon   OSHA's recommendations for 120db is that it sh...   Nov 4 2006, 01:11
- - AndyH-ha   But are you talking about real music or, effective...   Nov 4 2006, 01:56
- - Axon   My point is that you don't need a "test s...   Nov 4 2006, 02:21
- - AndyH-ha   OK, you need more than the dynamic range of 16 bit...   Nov 4 2006, 04:09
- - Iain   I think the best volume for the test would be ...   Nov 12 2006, 17:14
- - AndyH-ha   Without cryogenic cooling the intrinsic noise of e...   Nov 12 2006, 19:23
- - SebastianG   I think it's a good idea to mention the import...   Nov 13 2006, 13:30
- - AndyH-ha   QUOTE I think it's a good idea to mention the ...   Nov 14 2006, 03:43
|- - SebastianG   QUOTE (AndyH-ha @ Nov 14 2006, 03:43...   Nov 15 2006, 14:16
- - SirChristof   If you have decent equipment and a quiet environme...   Feb 15 2007, 09:40
|- - Kees de Visser   QUOTE (SirChristof @ Feb 15 2007, 09:40) ...   Feb 15 2007, 22:15
- - AndyH-ha   Yes, it is easy to create test tones that demonstr...   Feb 15 2007, 11:52
- - SirChristof   The vast majority of all music most of us have acc...   Feb 15 2007, 20:17
|- - krabapple   QUOTE (SirChristof @ Feb 15 2007, 14:17) ...   Feb 16 2007, 06:07
- - SometimesWarrior   These articles on ff123's website may be of in...   Feb 15 2007, 21:41
- - greynol   QUOTE (SirChristof @ Feb 15 2007, 00:40) ...   Feb 15 2007, 21:48
- - SirChristof   Greynol, What I meant to imply by "at low le...   Feb 15 2007, 22:02
- - AndyH-ha   As far as I can see, the ff123 page does not provi...   Feb 16 2007, 08:17
|- - Kees de Visser   At least one of the engineers I've asked seems...   Feb 16 2007, 11:01
- - muaddib   IMO it is better to keep samples much shorter: 10-...   Feb 16 2007, 11:54
- - 2Bdecided   There are a few 24/96 and 24/44.1 files here: http...   Feb 16 2007, 12:07
- - AndyH-ha   Setting aside for the moment whether this donated ...   Feb 16 2007, 12:22
|- - Kees de Visser   QUOTE (AndyH-ha @ Feb 16 2007, 12:22...   Feb 16 2007, 15:10
|- - Kees de Visser   An ABX test to compare 16 and 24 bit dithered audi...   Feb 19 2007, 23:00
- - AndyH-ha   I believe the resampling is more important than th...   Feb 20 2007, 00:30
- - MLXXX   Hi everyone. A year has passed since the previous...   Feb 25 2008, 16:52
- - AndyH-ha   "sounding better" is a subjective evalua...   Feb 26 2008, 00:52
- - MLXXX   I am new to ABXing but I think that for playing 24...   Feb 26 2008, 15:25
- - .halverhahn   Even it is comparing apples with oranges: Do you ...   Feb 26 2008, 17:28
- - digital   Wow: Nov 2nd 2006 to Feb 27th, 2008 and still wai...   Feb 27 2008, 10:37
- - knutinh   Since DVD-A can now be ripped, having 24/96 stereo...   Feb 27 2008, 10:43
|- - Kees de Visser   QUOTE (knutinh @ Feb 27 2008, 10:43) Caut...   Feb 27 2008, 11:51
|- - bubbleguuum   QUOTE (Kees de Visser @ Feb 27 2008, 11:5...   Feb 27 2008, 20:32
|- - MLXXX   QUOTE (volvme+ @ Feb 28 2008, 04:27)...   Feb 28 2008, 10:11
- - GeSomeone   I remember remarks (don't know where) that ind...   Feb 27 2008, 12:10
- - knutinh   I think that the difference between 12 bits and 16...   Feb 27 2008, 15:00
|- - MLXXX   QUOTE (knutinh @ Feb 28 2008, 00:00) I th...   Feb 27 2008, 16:59
- - volvme+   Sorry for interrupting your conversation, but I do...   Feb 27 2008, 19:27
- - MLXXX   AndyH, perhaps you might be kind enough to answer ...   Mar 3 2008, 07:27
- - cabbagerat   QUOTE (MLXXX @ Mar 2 2008, 22:27) Being a...   Mar 3 2008, 10:43
|- - MLXXX   QUOTE (cabbagerat @ Mar 3 2008, 19:43) ~ ...   Mar 3 2008, 13:48
|- - Soap   QUOTE (MLXXX @ Mar 3 2008, 07:48) When I ...   Mar 3 2008, 14:11
|- - MLXXX   Thanks, Soap. I should have been more precise. Wh...   Mar 3 2008, 15:06
- - SebastianG   Hi! I'd like to remind you that there...   Mar 3 2008, 11:02
- - AndyH-ha   I know this isn't the only time I raised the t...   Mar 3 2008, 12:03
- - cabbagerat   QUOTE (SebastianG @ Mar 3 2008, 02:02) I...   Mar 3 2008, 13:25
- - cabbagerat   QUOTE (MLXXX @ Mar 3 2008, 04:48) If I am...   Mar 3 2008, 15:23
|- - MLXXX   QUOTE (cabbagerat @ Mar 4 2008, 00:23) Wi...   Mar 3 2008, 15:35
- - cabbagerat   QUOTE (MLXXX @ Mar 3 2008, 06:35) QUOTE (...   Mar 3 2008, 16:17
|- - MLXXX   QUOTE (cabbagerat @ Mar 4 2008, 01:17) ~ ...   Mar 4 2008, 16:25
- - AndyH-ha   I generally issue this type of challenge when some...   Mar 4 2008, 19:45
- - MLXXX   I've a added a 24-bit 48KHz original, and 16-b...   Mar 10 2008, 16:00
- - Pio2001   Hello, In september, I did an ABX between a 96 kHz...   Nov 26 2008, 22:25
|- - Canar   QUOTE (Pio2001 @ Nov 26 2008, 13:25) Voxe...   Nov 27 2008, 00:27
||- - Dynamic   QUOTE (Canar @ Nov 27 2008, 00:27) QUOTE ...   Nov 27 2008, 05:27
|- - Kees de Visser   QUOTE (Pio2001 @ Nov 26 2008, 22:25) I go...   Nov 27 2008, 10:32
- - Pio2001   Thank you for the precisions about dither. This is...   Nov 27 2008, 19:48
- - Canar   I fully recognize that, and want to thank you agai...   Nov 27 2008, 21:18
- - solive   QUOTE (AndyH-ha @ Nov 2 2006, 18:19)...   Jan 5 2009, 01:28
- - greynol   http://www.hydrogenaudio.org/forums/index....showt...   Jan 5 2009, 01:38
|- - Martin Kantola   Greetings, found your forum recently, so here...   Jan 21 2009, 22:04
|- - Kees de Visser   QUOTE (Martin Kantola @ Jan 21 2009, 22:0...   Jan 22 2009, 07:37
- - 2Bdecided   I can't ABX it. I agree it's a perfectly g...   Jan 22 2009, 13:45
- - AndyH-ha   I m going to see if I can borrow a fast connectio...   Jan 22 2009, 22:12
|- - Martin Kantola   QUOTE (AndyH-ha @ Jan 22 2009, 16:12...   Jan 23 2009, 05:01
|- - Ron Jones   QUOTE (Martin Kantola @ Jan 22 2009, 20:0...   Jan 23 2009, 05:58
||- - Martin Kantola   QUOTE (Ron Jones @ Jan 22 2009, 23:58) As...   Jan 23 2009, 06:23
|- - 2Bdecided   QUOTE (Martin Kantola @ Jan 23 2009, 04:0...   Jan 23 2009, 11:47
|- - Martin Kantola   QUOTE (2Bdecided @ Jan 23 2009, 05:47) I ...   Jan 23 2009, 16:11
- - Axon   18/32 - there's a harshness in the left channe...   Jan 23 2009, 07:56
- - 2Bdecided   Found it... http://www.gearslutz.com/board/so-muc...   Jan 23 2009, 16:30
|- - Martin Kantola   QUOTE (2Bdecided @ Jan 23 2009, 10:30) My...   Jan 23 2009, 18:41
|- - krabapple   QUOTE (2Bdecided @ Jan 23 2009, 10:30) Fo...   Jan 24 2009, 01:01
|- - Martin Kantola   QUOTE (krabapple @ Jan 23 2009, 19:01) Bu...   Jan 24 2009, 03:11
|- - krabapple   QUOTE (Martin Kantola @ Jan 23 2009, 21:1...   Jan 25 2009, 00:08
||- - Martin Kantola   QUOTE (krabapple @ Jan 24 2009, 18:08) An...   Jan 25 2009, 00:28
|- - MLXXX   QUOTE (Martin Kantola @ Jan 24 2009, 12:1...   Jan 27 2009, 10:16
|- - krabapple   QUOTE (MLXXX @ Jan 27 2009, 04:16) The ef...   Jan 27 2009, 18:57
|- - MLXXX   QUOTE (krabapple @ Jan 28 2009, 03:57) Is...   Jan 28 2009, 14:14
- - 2Bdecided   Here you go... http://rapidshare.de/files/4332135...   Jan 23 2009, 17:25
|- - Martin Kantola   QUOTE (2Bdecided @ Jan 23 2009, 11:25) He...   Jan 24 2009, 07:13
- - 2Bdecided   Thank you Martin. Putting noise in the last 8 bit...   Jan 24 2009, 21:09
- - 2Bdecided   Remember those stats are only true for the situati...   Jan 25 2009, 17:38
|- - Martin Kantola   Thanks for the info David, I'm completely new ...   Jan 25 2009, 17:59
- - AndyH-ha   This was asked more than once but there was no res...   Jan 29 2009, 11:05
3 Pages V   1 2 3 >
RSS Lo-Fi Version Time is now: 3rd June 2015 - 09:44
