16 bit vs 24 bit, any samples that work?
AndyH-ha
post Nov 3 2006, 03:19
There are real differences between 16 bit and 24 bit files, just as there are real differences between uncompressed and mp3. As with the differences between wav and mp3, 16 bit vs 24 bit is often difficult to identify by listening.
Test signals are one thing, but has anyone found any 24 bit music recording that can be successfully identified via ABX testing against a properly resample to 16 bit version of same?
Pio2001
post Nov 26 2008, 22:25
Moderator
Hello,
In september, I did an ABX between a 96 kHz 24 bits file and a 44.1 kHz 16 bits one, made by Voxengo R8brain from a 192 kHz 24 bits file from 2L (the Mozart one) : http://www.2l.no/hires/index.html (you can even download a 352 kHz 24 bits DXD version and a 2.8 MHz DSD version !)
Voxengo's software says that 8-, 16- and 24 bit output is dithered with a gaussian noise and a slight noise-shaping. I have no idea if it is the proper way to do it.
The original account is here : http://www.homecinema-fr.com/forum/viewtop...59&start=60
It's part of an epic 24/96 ABX challenge in which a forumer fell from an "obvious, huge, unmissable" difference just before the ABX test, to a complete failure !
I got 10/10 in the ABX test, with closed headphones, listening to the initial fade-in. Comparing the playback level to speakers, and using a sonometer, I think that the listening level was such that the 0dB of the digital scale was at 113 dB(A) on a white noise. Since the track has a peak level of -1 dB and an RMS level of -23 dB, the listening level of my ABX test is something like 90 dB RMS, with peaks at 112 dB.
The use of closed headphones, that isolate from the environment, especially the computer noise, is useful. I also had to "release" the internal pressure in my ears (like divers) several times in order to stay at the top of my sensitivity.
What is interesting is to compare the quantization noise to the file content. By ascending order, there is :
-The 16 bits noise. Without this ABX test, I would never have thought that it was audible
-The background noise of the microphones and of the recording location. The 16 bits noise doesn't seem to be completely masked.
-The breathing and movements of the musicians, far above the previous
-The music, still far above.
Playback system : Foobar2000 v0.8 in 24 bits mode (note that this version used to equalize the RMS levels of files to be ABXed).
Marian Marc 2 soundcard, analog output, MME drivers, Windows XP (Waveout, MME device in Foobar).
Superex Pro-B VI headphones.
Canar
post Nov 27 2008, 00:27
QUOTE (Pio2001 @ Nov 26 2008, 13:25) *
The shape of the dither is quite significant. I'm not sure a "slight" noise-shaping is sufficient. I respect the difficulty in obtaining these results. However, I am afraid that all they show is that this dithering algorithm is discernible from the high-resolution original. If I were to perform this test, I'd try it with foobar2000's dither.
Nonetheless, thank you for the results. As I've always considered 24/96 to be excessive, you've given me a point to ponder.
This post has been edited by Canar: Nov 27 2008, 00:28
2. Assume good faith.
Dynamic
post Nov 27 2008, 05:27
QUOTE (Canar @ Nov 27 2008, 00:27) *
I guess your listening conditions are pretty extreme and uncomfortable in terms of overall loudness, Pio, but roughly as loud as you'd need to have any chance of ABXing 16-bit from 24-bit. i.e. you need to have the programme peaks about as loud as a petrol (gasoline) chainsaw at arm's length without ear defenders (113-116 dBa is typical) to be able to come close to picking up quantization, dither noise or noise modulation at the LSB level without noise shaping while you listen to the fade-in. With optimal dither and strong ATH noise shaping, you probably need to near the pain threshold.
Gaussian pdf dither isn't optimal. Triangular dither -1 to +1 peak to peak (sum of two independent rectangular dithers of -0.5 to +0.5 peak to peak) is optimal for the first and second moments, which prevents quantization distortions and noise modulation - the only two effects (moments) of bad dither that are considered audible. Gaussian might be more audible (higher energy) while failing to completely eliminate both effects.
I'd agree that foobar2000's dither options, esp on older versions, should allow a better test of theoretically valid dither. Versions around 0.8 allowed:
  • no dither (i.e. rounding/truncation quantization)
  • flat dither (no noise shaping) - i.e. triangular pdf,
  • dither with soft ATH noise shaping (less HF boost),
  • dither with strong ATH noise shaping (recommended setting in fb2k).
I think the range of dither/shaping options has been reduced and simplified in the 0.9 versions of fb2k.
From calculations based on commonly-accepted figures for human audition (difficult for me to test in practice with my equipment and noise environment) I'd expect flat dither (triangular pdf) to be inaudible in comfortable listening but near the borderline of audibility/ABXability at extreme but bearable loudness.
I'd expect good valid dither with noise shaping (not noise shaping alone) to be practically inaudible unless you selectively turn up the fade-in to extreme levels and turn it down to avoid painfully loud peaks during the main programme material. This would probably remain the case for tracks with replay gain values as positive as +12 dB or even a little greater (i.e. 77 dB SPL calibrated, or 6 dB below the 83 dB SPL reference pink noise specified in the Replay Gain calibration spec and used in movie theatre loudness calibration). Such quietly-recorded tracks could typically be increased by about 12 to 15 dB without clipping, but their noise-shaped dither is probably about 15 dB or so below the level of spectrally-flat (triangular pdf) dither.
I'd be very interested to see disconfirming evidence (ABX) from you or anyone else and to know how the results vary with different dither and noise shaping options.
- AndyH-ha   16 bit vs 24 bit   Nov 3 2006, 03:19
- - Mike Giacomelli   I'd imagine ABX would be possible if you found...   Nov 3 2006, 03:25
- - pdq   I recall a test here some years back to try to see...   Nov 3 2006, 05:33
- - Aetmos   If the clip is properly dithered, this doesn't...   Nov 3 2006, 06:22
- - cabbagerat   QUOTE (Aetmos @ Nov 2 2006, 21:22) If the...   Nov 3 2006, 07:31
|- - Aetmos   QUOTE Welcome to HA. I see this is your first post...   Nov 3 2006, 16:17
- - AndyH-ha   I agree that a good sample, if it exist in music, ...   Nov 3 2006, 09:36
- - cabbagerat   QUOTE (AndyH-ha @ Nov 3 2006, 00:36)...   Nov 3 2006, 16:25
- - Axon   I suppose it's quite easy to construct a track...   Nov 3 2006, 17:48
- - Axon   Also, how contrived can the listening environment ...   Nov 3 2006, 18:03
- - AndyH-ha   The question isn't whether or not it is possib...   Nov 3 2006, 20:18
- - Axon   Well.. how much dynamic range can you coax out of ...   Nov 3 2006, 20:38
- - AndyH-ha   I'm sorry, that went over my head. What is the...   Nov 3 2006, 21:21
- - outscape   haha nothing.. see 24 bits is purist technology. i...   Nov 3 2006, 22:23
- - greynol   I'd wager that in order to distinguish the dif...   Nov 3 2006, 22:41
- - Axon   OSHA's recommendations for 120db is that it sh...   Nov 4 2006, 01:11
- - AndyH-ha   But are you talking about real music or, effective...   Nov 4 2006, 01:56
- - Axon   My point is that you don't need a "test s...   Nov 4 2006, 02:21
- - AndyH-ha   OK, you need more than the dynamic range of 16 bit...   Nov 4 2006, 04:09
- - Iain   I think the best volume for the test would be ...   Nov 12 2006, 17:14
- - AndyH-ha   Without cryogenic cooling the intrinsic noise of e...   Nov 12 2006, 19:23
- - SebastianG   I think it's a good idea to mention the import...   Nov 13 2006, 13:30
- - AndyH-ha   QUOTE I think it's a good idea to mention the ...   Nov 14 2006, 03:43
|- - SebastianG   QUOTE (AndyH-ha @ Nov 14 2006, 03:43...   Nov 15 2006, 14:16
- - SirChristof   If you have decent equipment and a quiet environme...   Feb 15 2007, 09:40
|- - Kees de Visser   QUOTE (SirChristof @ Feb 15 2007, 09:40) ...   Feb 15 2007, 22:15
- - AndyH-ha   Yes, it is easy to create test tones that demonstr...   Feb 15 2007, 11:52
- - SirChristof   The vast majority of all music most of us have acc...   Feb 15 2007, 20:17
|- - krabapple   QUOTE (SirChristof @ Feb 15 2007, 14:17) ...   Feb 16 2007, 06:07
- - SometimesWarrior   These articles on ff123's website may be of in...   Feb 15 2007, 21:41
- - greynol   QUOTE (SirChristof @ Feb 15 2007, 00:40) ...   Feb 15 2007, 21:48
- - SirChristof   Greynol, What I meant to imply by "at low le...   Feb 15 2007, 22:02
- - AndyH-ha   As far as I can see, the ff123 page does not provi...   Feb 16 2007, 08:17
|- - Kees de Visser   At least one of the engineers I've asked seems...   Feb 16 2007, 11:01
- - muaddib   IMO it is better to keep samples much shorter: 10-...   Feb 16 2007, 11:54
- - 2Bdecided   There are a few 24/96 and 24/44.1 files here: http...   Feb 16 2007, 12:07
- - AndyH-ha   Setting aside for the moment whether this donated ...   Feb 16 2007, 12:22
|- - Kees de Visser   QUOTE (AndyH-ha @ Feb 16 2007, 12:22...   Feb 16 2007, 15:10
|- - Kees de Visser   An ABX test to compare 16 and 24 bit dithered audi...   Feb 19 2007, 23:00
- - AndyH-ha   I believe the resampling is more important than th...   Feb 20 2007, 00:30
- - MLXXX   Hi everyone. A year has passed since the previous...   Feb 25 2008, 16:52
- - AndyH-ha   "sounding better" is a subjective evalua...   Feb 26 2008, 00:52
- - MLXXX   I am new to ABXing but I think that for playing 24...   Feb 26 2008, 15:25
- - .halverhahn   Even it is comparing apples with oranges: Do you ...   Feb 26 2008, 17:28
- - digital   Wow: Nov 2nd 2006 to Feb 27th, 2008 and still wai...   Feb 27 2008, 10:37
- - knutinh   Since DVD-A can now be ripped, having 24/96 stereo...   Feb 27 2008, 10:43
|- - Kees de Visser   QUOTE (knutinh @ Feb 27 2008, 10:43) Caut...   Feb 27 2008, 11:51
|- - bubbleguuum   QUOTE (Kees de Visser @ Feb 27 2008, 11:5...   Feb 27 2008, 20:32
|- - MLXXX   QUOTE (volvme+ @ Feb 28 2008, 04:27)...   Feb 28 2008, 10:11
- - GeSomeone   I remember remarks (don't know where) that ind...   Feb 27 2008, 12:10
- - knutinh   I think that the difference between 12 bits and 16...   Feb 27 2008, 15:00
|- - MLXXX   QUOTE (knutinh @ Feb 28 2008, 00:00) I th...   Feb 27 2008, 16:59
- - volvme+   Sorry for interrupting your conversation, but I do...   Feb 27 2008, 19:27
- - MLXXX   AndyH, perhaps you might be kind enough to answer ...   Mar 3 2008, 07:27
- - cabbagerat   QUOTE (MLXXX @ Mar 2 2008, 22:27) Being a...   Mar 3 2008, 10:43
|- - MLXXX   QUOTE (cabbagerat @ Mar 3 2008, 19:43) ~ ...   Mar 3 2008, 13:48
|- - Soap   QUOTE (MLXXX @ Mar 3 2008, 07:48) When I ...   Mar 3 2008, 14:11
|- - MLXXX   Thanks, Soap. I should have been more precise. Wh...   Mar 3 2008, 15:06
- - SebastianG   Hi! I'd like to remind you that there...   Mar 3 2008, 11:02
- - AndyH-ha   I know this isn't the only time I raised the t...   Mar 3 2008, 12:03
- - cabbagerat   QUOTE (SebastianG @ Mar 3 2008, 02:02) I...   Mar 3 2008, 13:25
- - cabbagerat   QUOTE (MLXXX @ Mar 3 2008, 04:48) If I am...   Mar 3 2008, 15:23
|- - MLXXX   QUOTE (cabbagerat @ Mar 4 2008, 00:23) Wi...   Mar 3 2008, 15:35
- - cabbagerat   QUOTE (MLXXX @ Mar 3 2008, 06:35) QUOTE (...   Mar 3 2008, 16:17
|- - MLXXX   QUOTE (cabbagerat @ Mar 4 2008, 01:17) ~ ...   Mar 4 2008, 16:25
- - AndyH-ha   I generally issue this type of challenge when some...   Mar 4 2008, 19:45
- - MLXXX   I've a added a 24-bit 48KHz original, and 16-b...   Mar 10 2008, 16:00
- - Pio2001   Hello, In september, I did an ABX between a 96 kHz...   Nov 26 2008, 22:25
|- - Canar   QUOTE (Pio2001 @ Nov 26 2008, 13:25) Voxe...   Nov 27 2008, 00:27
||- - Dynamic   QUOTE (Canar @ Nov 27 2008, 00:27) QUOTE ...   Nov 27 2008, 05:27
|- - Kees de Visser   QUOTE (Pio2001 @ Nov 26 2008, 22:25) I go...   Nov 27 2008, 10:32
- - Pio2001   Thank you for the precisions about dither. This is...   Nov 27 2008, 19:48
- - Canar   I fully recognize that, and want to thank you agai...   Nov 27 2008, 21:18
- - solive   QUOTE (AndyH-ha @ Nov 2 2006, 18:19)...   Jan 5 2009, 01:28
- - greynol   http://www.hydrogenaudio.org/forums/index....showt...   Jan 5 2009, 01:38
|- - Martin Kantola   Greetings, found your forum recently, so here...   Jan 21 2009, 22:04
|- - Kees de Visser   QUOTE (Martin Kantola @ Jan 21 2009, 22:0...   Jan 22 2009, 07:37
- - 2Bdecided   I can't ABX it. I agree it's a perfectly g...   Jan 22 2009, 13:45
- - AndyH-ha   I m going to see if I can borrow a fast connectio...   Jan 22 2009, 22:12
|- - Martin Kantola   QUOTE (AndyH-ha @ Jan 22 2009, 16:12...   Jan 23 2009, 05:01
|- - Ron Jones   QUOTE (Martin Kantola @ Jan 22 2009, 20:0...   Jan 23 2009, 05:58
||- - Martin Kantola   QUOTE (Ron Jones @ Jan 22 2009, 23:58) As...   Jan 23 2009, 06:23
|- - 2Bdecided   QUOTE (Martin Kantola @ Jan 23 2009, 04:0...   Jan 23 2009, 11:47
|- - Martin Kantola   QUOTE (2Bdecided @ Jan 23 2009, 05:47) I ...   Jan 23 2009, 16:11
- - Axon   18/32 - there's a harshness in the left channe...   Jan 23 2009, 07:56
- - 2Bdecided   Found it... http://www.gearslutz.com/board/so-muc...   Jan 23 2009, 16:30
|- - Martin Kantola   QUOTE (2Bdecided @ Jan 23 2009, 10:30) My...   Jan 23 2009, 18:41
|- - krabapple   QUOTE (2Bdecided @ Jan 23 2009, 10:30) Fo...   Jan 24 2009, 01:01
|- - Martin Kantola   QUOTE (krabapple @ Jan 23 2009, 19:01) Bu...   Jan 24 2009, 03:11
|- - krabapple   QUOTE (Martin Kantola @ Jan 23 2009, 21:1...   Jan 25 2009, 00:08
||- - Martin Kantola   QUOTE (krabapple @ Jan 24 2009, 18:08) An...   Jan 25 2009, 00:28
|- - MLXXX   QUOTE (Martin Kantola @ Jan 24 2009, 12:1...   Jan 27 2009, 10:16
|- - krabapple   QUOTE (MLXXX @ Jan 27 2009, 04:16) The ef...   Jan 27 2009, 18:57
|- - MLXXX   QUOTE (krabapple @ Jan 28 2009, 03:57) Is...   Jan 28 2009, 14:14
- - 2Bdecided   Here you go... http://rapidshare.de/files/4332135...   Jan 23 2009, 17:25
|- - Martin Kantola   QUOTE (2Bdecided @ Jan 23 2009, 11:25) He...   Jan 24 2009, 07:13
- - 2Bdecided   Thank you Martin. Putting noise in the last 8 bit...   Jan 24 2009, 21:09
- - 2Bdecided   Remember those stats are only true for the situati...   Jan 25 2009, 17:38
|- - Martin Kantola   Thanks for the info David, I'm completely new ...   Jan 25 2009, 17:59
- - AndyH-ha   This was asked more than once but there was no res...   Jan 29 2009, 11:05
3 Pages V   1 2 3 >
RSS Lo-Fi Version Time is now: 28th February 2015 - 18:50
