22 Pages V  « < 2 3 4 5 6 > »
foo_scheduler, Plugin for scheduling actions like play, stop, system shutdown/wake up
Andreasvb
post Nov 18 2006, 19:18
Post #76
Select the time and then rightclick your new entry and choose Add action > Rescan media library
Windows 8.1u3 Pro x64 Media Center // foobar2000 1.3.8
wolfsong
post Nov 18 2006, 19:27
Post #77
QUOTE (Andreasvb @ Nov 18 2006, 12:18) *
ermm.gif that action isn't there
[url="http://www.last.fm/user/wolfsong/"]Last.fm Profile[/url]
Andreasvb
post Nov 18 2006, 19:37
Post #78
Strange, sure you have the new version?
wolfsong
post Nov 18 2006, 19:40
Post #79
QUOTE (Andreasvb @ Nov 18 2006, 12:37) *
hmmm you're right... I must have downloaded before he fixed the link
EDIT: problem was actually a cached download
This post has been edited by wolfsong: Nov 18 2006, 20:30
C.Flam
post Nov 18 2006, 22:52
Post #80
QUOTE (andrew_smolko @ Nov 18 2006, 16:59) *
3.1 is here! See changelog.
Thanks for the new "Select track" feature!
What about saving (and loading) scripts into text-formatted files?
It would be a great idea too
EDIT:
Some sort of HTML-like based scripting language, might be an easy way to describe actions:
<on playback end, re-enable after done>
next playlist
select_track = 1
start playback
</on playback end, re-enable after done>
This post has been edited by C.Flam: Nov 18 2006, 23:45
hal9001
post Nov 19 2006, 08:41
Post #81
EDIT: can't download:
ERROR
The requested URL could not be retrieved
While trying to retrieve the URL: http://asmo.at.tut.by/foo_scheduler.zip
The following error was encountered:
* Access Denied.
Access control configuration prevents your request from being allowed at this time. Please contact your service provider if you feel this is incorrect.
Your cache administrator is [send email to webmaster via gmail] webmaster.
Generated Sun, 19 Nov 2006 10:15:43 GMT by public-vh.spameater.tutby.com (squid/2.5.STABLE9)
This error appears on IE/FF alike. tried it several times over the past few hours.
This post has been edited by hal9001: Nov 19 2006, 11:22
andrew_smolko
post Nov 19 2006, 11:42
Post #82
Seems to be the hosting problems. I've changed the link.
jaslr
post Nov 20 2006, 03:23
Post #83
This could be completely the wrong component to be discussing this but, how can I do the following?
I have 3 different Music Folder destinations that are updated quite regularly with new stuff added and older stuff being removed.
How can I both:
a) Update my Media Library automatically (say every 2 hours) to reflect these changes?
b) Overwrite my current playlist with my entire Media Library?
This post has been edited by jaslr: Nov 20 2006, 03:24
francesco
post Nov 20 2006, 12:06
Post #84
and for 0.8 nothing of similar?
kalmark
post Nov 20 2006, 12:24
Post #85
I have a bug to report, I think. Not tested with 3.1, but existed with some previous versions.
Say, I have one Daily action to stop playback and then shutdown/hibernate my computer, and then one Daily action, which includes waking up from hibernation, changing volume and starting playback.
Now, if I change the time of the second action to a later time (say, from 7am to 8am), the computer still wakes up from hibernation at 7am, but does not do any of the set actions (no volume change, no playback start). It does, though, wake up at 8am again, and does everything it was set to do. (I woke up at 7am for the "power up" sound and hibernated my computer again)
I did reproduce this twice, even with saving everything in foobar. I did not try quitting and starting foobar again.
Just ask if what I'm saying is not clear smile.gif Thanks for looking into this, the plugin is really very good otherwise smile.gif
Life is Real...
(But not in audio :) )
eisteh
post Nov 20 2006, 13:17
Post #86
QUOTE (jaslr @ Nov 20 2006, 03:23) *
How can I both:
a) With 3.1 you can add an action to refresh ML.
b) I don't know if you can do it actually, but i guess not.
andrew_smolko
post Nov 20 2006, 20:34
Post #87
QUOTE (kalmark @ Nov 20 2006, 14:24) *
Thanks for your report! I hope I've fixed this. Download 3.11 version and test once more please.
This post has been edited by andrew_smolko: Nov 21 2006, 07:43
kalmark
post Nov 22 2006, 08:55
Post #88
QUOTE (andrew_smolko @ Nov 20 2006, 21:34) *
Works fine, thanks for the quick fix!
Life is Real...
Melomane
post Nov 22 2006, 11:41
Post #89
autoplaylist
Music is my first love.
maxtail
post Nov 22 2006, 14:59
Post #90
Hello, sorry for my poor English, but I'd like to make a suggestion for the next version.
Could you add something like this in the options:
"After 20 minutes, Stop the playback."
I usually continue listening to music until I fall asleep, so it'd be more convenient to use if this option is possible.
Thanks a lot!!!
andrew_smolko
post Nov 22 2006, 15:58
Post #91
QUOTE (maxtail @ Nov 22 2006, 16:59) *
Thanks a lot!!!
You can create something like this:
[x] On menu item "Sleep time"
* Start playback
* 20 minutes delay
* Stop playback
Then use "File/Run scheduler action list/Sleep time" menu item to start action list execution. Playback will be started and after 20 minutes it will be stopped.
Lexee
post Nov 23 2006, 08:49
Post #92
I create a scheduler event and when it starts Foobar crashes. The bug report is as follows:
Illegal operation:
Code: C0000005h, flags: 00000000h, address: 010DFCDCh
Access violation, operation: read, address: 00000014h
Call path:
Code bytes (010DFCDCh):
010DFC9Ch: 8B 28 83 C7 04 8B F7 89 6C 24 14 89 74 24 10 EB
010DFCACh: 03 8D 49 00 85 F6 8B 5F 04 74 04 3B F7 74 05 E8
010DFCBCh: 2D D2 01 00 3B EB 74 30 85 F6 75 05 E8 20 D2 01
010DFCCCh: 00 3B 6E 04 75 05 E8 16 D2 01 00 8B 4D 10 8B 11
010DFCDCh: 8B 42 14 FF D0 8D 74 24 10 E8 F6 38 FF FF 8B 6C
010DFCECh: 24 14 8B 74 24 10 EB BC 5F 5E 5D 5B 83 C4 0C C3
010DFCFCh: CC CC CC CC 8B 50 04 8B 4A 04 83 EC 14 80 79 15
010DFD0Ch: 00 56 57 75 16 8B 33 39 71 0C 73 05 8B 49 08 EB
Stack (0258FE84h):
0258FE64h: 7C919B3F 7C97C0D8 7C919AEB 0111503C
0258FE74h: 011D3E80 0000FFFF 7FFDF000 00254678
0258FE84h: 011D5278 011D3B80 0258FEF4 011D51E0
0258FE94h: 011D526C 011D5668 0258FEF4 010DFC62
0258FEA4h: 8ED19C4D 011D5268 010D3D70 0012F384
0258FEB4h: 00000000 0258FE98 011D526C 011D5668
0258FEC4h: 011D3B40 7FFDC000 011D5278 011D56A8
0258FED4h: 010DF950 011D5268 011D56A8 7C8399F3
0258FEE4h: 0258FF34 01113430 FFFFFFFF 000000D4
0258FEF4h: 0258FF74 010D3D6A 011D5268 010F85B8
0258FF04h: 011D5268 8ED19DE9 0258FF74 7C90110A
0258FF14h: 011D5688 010F825F 011D5688 010F8557
0258FF24h: 8ED19DCD 010D3D70 0012F384 00000001
0258FF34h: 0258FF68 011103A8 FFFFFFFF 010F8649
0258FF44h: 8ED19D91 0012EFB8 0012F21C 011D3E80
0258FF54h: 010D3D70 011D5268 010D3D60 8ED19D91
0258FF64h: 0258FF44 0258FF9C 011103D8 00000001
0258FF74h: 0258FFAC 01101D1A 0012F384 8ED19D49
0258FF84h: 0012EFB8 0012F21C 011D3E80 C0000005
0258FF94h: 0258FF80 0258FAAC 0258FFDC 010FE230
Registers:
EAX: 011D5648, EBX: 011D5648, ECX: 011D51E0, EDX: 00000000
ESI: 011D526C, EDI: 011D526C, EBP: 011D5668, ESP: 0258FE84
Crash location: "foo_scheduler", loaded at 010D0000h - 01138000h
Loaded modules:
foobar2000 loaded at 00400000h - 004F3000h
ntdll loaded at 7C900000h - 7C9B0000h
kernel32 loaded at 7C800000h - 7C8F4000h
COMCTL32 loaded at 773D0000h - 774D2000h
msvcrt loaded at 77C10000h - 77C68000h
ADVAPI32 loaded at 77DD0000h - 77E6B000h
RPCRT4 loaded at 77E70000h - 77F01000h
GDI32 loaded at 77F10000h - 77F56000h
USER32 loaded at 77D40000h - 77DD0000h
SHLWAPI loaded at 77F60000h - 77FD6000h
SHELL32 loaded at 7C9C0000h - 7D1D4000h
ole32 loaded at 774E0000h - 7761C000h
shared loaded at 10000000h - 1002A000h
comdlg32 loaded at 763B0000h - 763F9000h
uxtheme loaded at 5AD70000h - 5ADA8000h
foo_abx loaded at 003C0000h - 003F4000h
foo_AdvancedControls loaded at 00A50000h - 00A80000h
foo_albumlist loaded at 00A90000h - 00AD7000h
OLEAUT32 loaded at 77120000h - 771AC000h
foo_audioscrobbler loaded at 00B00000h - 00B38000h
WS2_32 loaded at 71AB0000h - 71AC7000h
WS2HELP loaded at 71AA0000h - 71AA8000h
foo_cdda loaded at 00B60000h - 00B96000h
foo_converter loaded at 00BC0000h - 00C29000h
foo_dsp_std loaded at 00C50000h - 00C91000h
foo_freedb2 loaded at 00CC0000h - 00D00000h
foo_fullscreen loaded at 00D20000h - 00D3B000h
foo_infobox loaded at 00D60000h - 00DA0000h
foo_input_monkey loaded at 00DC0000h - 00E09000h
foo_input_std loaded at 00E30000h - 00F44000h
foo_masstag loaded at 00F70000h - 00FC0000h
foo_minimize_on_close loaded at 00FE0000h - 00FF6000h
foo_preview loaded at 01020000h - 01041000h
foo_rgscan loaded at 01060000h - 010A8000h
foo_scheduler loaded at 010D0000h - 01138000h
POWRPROF loaded at 74AD0000h - 74AD8000h
WINMM loaded at 76B40000h - 76B6D000h
serwvdrv loaded at 5CD70000h - 5CD77000h
umdmxfrm loaded at 5B0A0000h - 5B0A7000h
foo_shutdown loaded at 011E0000h - 011F8000h
foo_uie_albumart loaded at 01220000h - 01254000h
gdiplus loaded at 4EC50000h - 4EDF3000h
foo_ui_columns loaded at 01290000h - 0132A000h
foo_ui_std loaded at 01350000h - 013A7000h
foo_unpack loaded at 013D0000h - 013FE000h
correct loaded at 01720000h - 01726000h
dciman32 loaded at 73BC0000h - 73BC6000h
mswsock loaded at 71A50000h - 71A8F000h
DNSAPI loaded at 76F20000h - 76F47000h
winrnr loaded at 76FB0000h - 76FB8000h
WLDAP32 loaded at 76F60000h - 76F8C000h
rasadhlp loaded at 76FC0000h - 76FC6000h
hnetcfg loaded at 662B0000h - 66308000h
wshtcpip loaded at 71A90000h - 71A98000h
imagehlp loaded at 76C90000h - 76CB8000h
DBGHELP loaded at 59A60000h - 59B01000h
VERSION loaded at 77C00000h - 77C08000h
Stack dump analysis:
Address: 010DFC62h, location: "foo_scheduler", loaded at 010D0000h - 01138000h
Address: 010D3D70h, location: "foo_scheduler", loaded at 010D0000h - 01138000h
Address: 010DF950h, location: "foo_scheduler", loaded at 010D0000h - 01138000h
Address: 7C8399F3h, location: "kernel32", loaded at 7C800000h - 7C8F4000h
Symbol: "FindAtomW" (+00000094h)
Address: 01113430h, location: "foo_scheduler", loaded at 010D0000h - 01138000h
Address: 010D3D6Ah, location: "foo_scheduler", loaded at 010D0000h - 01138000h
Address: 010F85B8h, location: "foo_scheduler", loaded at 010D0000h - 01138000h
Address: 7C90110Ah, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "RtlLeaveCriticalSection" (+0000001Dh)
Address: 010F825Fh, location: "foo_scheduler", loaded at 010D0000h - 01138000h
Address: 010F8557h, location: "foo_scheduler", loaded at 010D0000h - 01138000h
Address: 011103A8h, location: "foo_scheduler", loaded at 010D0000h - 01138000h
Address: 010F8649h, location: "foo_scheduler", loaded at 010D0000h - 01138000h
Address: 010D3D60h, location: "foo_scheduler", loaded at 010D0000h - 01138000h
Address: 011103D8h, location: "foo_scheduler", loaded at 010D0000h - 01138000h
Address: 01101D1Ah, location: "foo_scheduler", loaded at 010D0000h - 01138000h
Address: 010FE230h, location: "foo_scheduler", loaded at 010D0000h - 01138000h
Address: 01101DBFh, location: "foo_scheduler", loaded at 010D0000h - 01138000h
Address: 7C80B50Bh, location: "kernel32", loaded at 7C800000h - 7C8F4000h
Symbol: "GetModuleFileNameA" (+000001B4h)
Address: 7C80B518h, location: "kernel32", loaded at 7C800000h - 7C8F4000h
Symbol: "GetModuleFileNameA" (+000001C1h)
Address: 01101D40h, location: "foo_scheduler", loaded at 010D0000h - 01138000h
Address: 00C80008h, location: "foo_dsp_std", loaded at 00C50000h - 00C91000h
Version info:
foobar2000 v0.9.4.1
UNICODE
Additional info:
Audioscrobbler 1.3.2 (foo_audioscrobbler)
foobar2000 core v0.9.4.1 (Core)
Masstagger 1.6 (foo_masstag)
Foo Shutdown 0.9 (foo_shutdown)
Minimize On Close 0.2 (foo_minimize_on_close)
ReplayGain Scanner 2.0.2 (foo_rgscan)
Album List 3.2.0 (foo_albumlist)
Standard Input Array 1.0 (foo_input_std)
Special file info box 2.0.4 (foo_infobox)
CD Audio Decoder 2.1.1 (foo_cdda)
Columns UI 0.1.3 beta 1v5 (foo_ui_columns)
ABX Comparator 1.3.1 (foo_abx)
freedb Tagger 0.5.2a (foo_freedb2)
Fullscreen 0.3.1 (foo_fullscreen)
ZIP/GZIP reader 1.0 (foo_unpack)
Standard DSP array 1.0 (foo_dsp_std)
Album Art Panel 0.2.0 (foo_uie_albumart)
RAR reader 1.1 (foo_unpack)
Preview 1.2 (foo_preview)
WMA Decoder 1.1 (foo_input_std)
Converter 1.0.1 (foo_converter)
Default User Interface 0.9acc (foo_ui_std)
FLAC Decoder 1.1.0 (foo_input_std)
Monkey's Audio decoder 2.1.1 (foo_input_monkey)
FooBar2000 Advanced Controls 0.5.9.0 (foo_AdvancedControls)
Scheduler 3.11 (foo_scheduler)
Can anybody tell me why does it happen? Thanks in advance.
andrew_smolko
post Nov 23 2006, 10:17
Post #93
QUOTE (Lexee @ Nov 23 2006, 10:49) *
Possibly you've created "Once date/time event" with "Remove after done" or "Player event" with "Remove after done". There is a bug, it's already fixed, but I haven't uploaded new version yet.
Lexee
post Nov 23 2006, 13:43
Post #94
Yes, you're right I created "once time" event with "remove after done. Thanks for explaining, I'll wait for next release of Scheduler =))
andrew_smolko
post Nov 23 2006, 14:27
Post #95
3.5 RC!
This is release candidate version. Everyone is welcome to test and report about bugs.
Configuration format has been changed, so after update your configuration will be erased.
eisteh
post Nov 23 2006, 16:08
Post #96
The new interface is a bit strange at first sight, but a great improvement smile.gif
fabiospark
post Nov 24 2006, 11:26
Post #97
Can we choose the IDs (menu and actions) from a list instead of having to write them, please?
xhandler
post Nov 24 2006, 12:13
Post #98
Love this one.. use it instead of radio alarm.. who wants to wake up to "the hits of yesterday" when you can wake up to tomorrows hits on your computer!
http://www.last.fm/user/reld/
LTourist
post Nov 24 2006, 12:29
Post #99
The return of foo_scheuler is a great news!!! That"s the only component that missed in my configuration...Continue on this way, great job!!!
gren
post Nov 25 2006, 11:53
Post #100
huythuy,
your first request seems to me like it would be better implemented as a playback order feature and then you could enable that playback order with the scheduler. But, it's probably more difficult to get them to add it to the player
Your second request can be done in a roundabout way. You need to know where the song is on a playlist... and then choose its entry number with the "select track" action. If you don't have a playlist for it then it won't work (one nice thing about the winamp plugin is that you can specify the patch of a song).
I think the new interface is... interesting... I'm not fully sure whether or not it's an improvement. It probably will help me make multiple alarms for differen times (since they all use full volum + alarm playlist) but... it make it redundant createing sleep timers since I have the event of 30 minute sleep (menu item) and the action list of 30 minute sleep (delay 30 min, stop playback)... If there were an option for maybe menu item timer where in the action list you set your delay time... then I could have my stop playback action... and the different events that had the timer in them. So, just wanted to show the up side and the downside of 3.5 RC.
RSS Lo-Fi Version Time is now: 7th May 2015 - 09:18
