22 Pages V  < 1 2 3 4 > »
foo_scheduler, Plugin for scheduling actions like play, stop, system shutdown/wake up
Sphix
post Oct 26 2006, 23:53
Post #26
Request:
- Option to shutdown the machine after a period of time or songs played
-foobar2000 + Burrrn + EAC
-HD 80Gb using High QualityVBR MP3s
mpioner
post Oct 27 2006, 01:46
Post #27
QUOTE (Sphix @ Oct 27 2006, 08:53) *
Request:
+1
andrew_smolko
post Oct 27 2006, 16:02
Post #28
QUOTE (Sphix @ Oct 27 2006, 01:53) *
Request:
Why not to use such config:
[x] On playback end, disable after done
...some actions...
2 minutes delay
Shutdown
RogerG
post Oct 29 2006, 07:13
Post #29
QUOTE (andrew_smolko @ Oct 27 2006, 17:02) *
Request:
...some actions...
2 minutes delay
Shutdown
There is no playback end when listening to internet radio streams.
vader897
post Oct 29 2006, 15:49
Post #30
Just thought of this, dunno if it will work... could you just set the time to run the task in 1 min then have the task as something like
-delay for X minutes
-shutdown..
I agree that an option would be better but I think this should work as a temporary work around
Matyas
post Oct 30 2006, 11:14
Post #31
Request:
Besides setting the foobar2000 volume, setting the Windows MASTER volume would be very useful.
For example, you can end the day listening the music through your headphones, where a lower windows master volume is necessary, but want to be woken up the next morning - in which case a higher windows master volume is vital.
Of course, if you forget to unplug the headphones.... But that is something you can do even if the notebook is already off...
fabiospark
post Nov 1 2006, 18:02
Post #32
Is already there a way to create these actions I had with 0.8:
1) Shutdown on track end
2) Change playlist to "playlist_name" after 2h:00m
3) Change playlist to "playlist_name" on playback end
4) Change playlist to "playlist_name" at 10:30 AM
5) Exit Foobar (saving config and database files) after/on/at...
Generalverdacht
post Nov 1 2006, 18:44
Post #33
thanks fot that great plugin
andrew_smolko
post Nov 1 2006, 19:08
Post #34
QUOTE (fabiospark @ Nov 1 2006, 20:02) *
1) on playback end
2) yes
3) yes
4) yes
5) no (will be in the next version)
fabiospark
post Nov 1 2006, 22:03
Post #35
QUOTE (andrew_smolko @ Nov 1 2006, 20:08) *
1) on playback end
2) yes
3) yes
4) yes
Sorry, I had a look but, obviously, it had not been a careful one.
Anyway, I can't find the way to do the # 2 in the list above: which event should I start with?
In my post, I was meaning: "change to that playlist after two hours from when I check this command. At least, from when I close the settings window.
In the player list I can only see "On playback end" and in the date/time list I cant see a "delay"
time field. Yes, I saw there is a delay action but I have to start with an event first, so?
TheTravis
post Nov 1 2006, 23:21
Post #36
Thank you very much andrew_smolko!
Requests:
- Event: Track change
- Action: Foobar command
Then I can use foo_run with cwb_hooks to check wether i have album art for the album and run CoverDownloader if i haven't.
_eclectic_
post Nov 2 2006, 06:37
Post #37
Wow, just when I think there is nothing else that can be added, somebody creatively comes up with a fantastic idea! Thanks, I will put this to good use, esp. when on the road with my notebook, and one of those hotel alarm clocks that play fuzz and are impossible to set right.
Bobjua
post Nov 2 2006, 07:32
Post #38
Right now im just using 1 playlist all the time, (i have albums organized with .m3u files). how do i make it so it goes back to the first track of the playlist, its not very useful when it only plays the last song on the playlist. (its on the last song because i played the whole playlist when i fell asleep.
Edit: i kind of fixed it. i just made the last song a really long loud one.
This post has been edited by Bobjua: Nov 2 2006, 07:38
andrew_smolko
post Nov 2 2006, 11:55
Post #39
QUOTE (fabiospark @ Nov 2 2006, 00:03) *
2) yes
Oops smile.gif It can be done in my development build, not in public release 3.01. Wait for the next version. There it will be possible to start scheduler action lists from main menu. The configuration will look like this:
[x] On menu item "Item identifier"
  • 5 minutes delay
  • Shutdown
This post has been edited by andrew_smolko: Nov 2 2006, 13:44
Spi
post Nov 3 2006, 12:36
Post #40
thanks man i waited long for this one,
THANK YOU SO MUCH
trance
post Nov 4 2006, 17:56
Post #41
This the only components that keeping me from migrating to v.9.x!!
Sonic Rhythms -> http://www.sonicrhythms.com
My Online Playlist! -> http://www.audioscrobbler.com/user/trance
TranceAddict Forums -> http://www.tranceaddict.com/forums
andrew_smolko
post Nov 4 2006, 22:45
Post #42
3.05 is ready!
Andreasvb
post Nov 5 2006, 13:33
Post #43
Thanks, finally got the "timer" to work, thanks to the menu item addition =)
Unfortunately there's no way to see the remaining time, a title format would be good to use in e.g. Trackinfo or statusbar/caption.
Windows 8.1u3 Pro x64 Media Center // foobar2000 1.3.7
neooffs
post Nov 8 2006, 04:01
Post #44
hello,
can you make the plugin allow twice or more equal events?
I like to shutdown when the playback ends, but also like to close the player sometimes...
ty anyway
kalmark
post Nov 8 2006, 08:47
Post #45
Could you add a warning if the user tries to save an event for a past date? Maybe it could even be smart warning, meaning it would offer a correction, too. For example: user tries to save an event for 7am 2nd November on the 5th November, a warning window pops up saying "event date is in the past, would you like to save it for 7am 6th November (so the next day 7am)", and user would be able to either accept the change or go back and edit or even save it with the "useless" setting.
What do you think?
(I almost missed a wake up alarm because of not changing the date on a past event smile.gif )
A very good component, though, I never knew how much I was missing a scheduler until recently smile.gif
Life is Real...
(But not in audio :) )
andrew_smolko
post Nov 8 2006, 14:39
Post #46
Marked, as TODO for future versions.
QUOTE (kalmark @ Nov 8 2006, 10:47) *
Could you add a warning if the user tries to save an event for a past date? ...
No problem, added to TODO list.
This post has been edited by andrew_smolko: Nov 8 2006, 14:48
jackassbikeco
post Nov 9 2006, 06:31
Post #47
I can't seem to get a timer that I make to work. I make a new timer, I set a delay for say 5 min, then after that I have it shutdown foobar. I click the menu to run scheduler event click the timer, 5 min passes and nothing happens. Can someone post what they are using for their timer settings so I know if I am doing this right.
oh and i have version 3.05 if that makes a difference.
THanks,
Josh
This post has been edited by jackassbikeco: Nov 9 2006, 06:33
gren
post Nov 9 2006, 17:40
Post #48
What does that mean?
jackassbikeco... try it with stopping play (just because I know that has worked for me)... I have 60minute delay and then stop play. The reason I suggest using a more simple function is because I think in the past I have had timers not turn off... and alarms not go on. I haven't verified it because.... normally I'm half asleep and I can't tell if it's a software problem or me not being fully awake ~_~
jackassbikeco
post Nov 9 2006, 19:28
Post #49
What he means is that if he wants to have the same event twice. He wants it to allow him to setup say two identical alarms. I think that is what he means. Oh and i will try it to make a new timer again, i was kinda tired when i was playing around with it so maybe i missed something.
Thanks,
Josh
2Pacalypse
post Nov 9 2006, 23:48
Post #50
couple of question.
how are people saying shut down the computer in x mins. i can only seem to have it on playback end. i want it to shut down on a timer dont care if it is playing. your talking about the timer but i cant find it
I would like to request a fade in & fade out volume. Also being able to set the playback order would be cool.
RSS Lo-Fi Version Time is now: 29th March 2015 - 17:11
