22 Pages V   1 2 3 > »
foo_scheduler, Plugin for scheduling actions like play, stop, system shutdown/wake up
andrew_smolko
post Oct 25 2006, 21:06
Version 4.11 (download)
Changelog:
  • 4.11
    • "Scheduler enabled" checkbox has been added.
  • 4.10
    • Removed useless stop reason in player stop event.
    • Dropped packing of executable to be able to analyze crash dumps.
    • Rebuild with more stable versions of internal libraries.
  • 4.09
    • Completely fixed keyboard shortcuts assignment problem.
  • 4.08
    • Fixed tab order in "Wait until N tracks played" configuration dialog.
    • Fixed a bug with menu items, when keyboard shortcuts couldn't be assigned to them correctly. Please recreate your menu item events!
  • 4.07
    • Added a new command "Stop all action lists" to the status window and to the main menu.
    • Header restyling to conform the style of preferences page.
    • New action "Wait until N tracks played".
  • 4.06
    • Next/previous track actions added.
  • 4.05
    • Preferences window fix due to changes in fb2k 1.1.
  • 4.04
    • Added items reordering in events list.
    • The width of each column in events list window is stored in configuration.
  • 4.03
    • Bug fix release.
  • 4.02
    • Added more detailed config of "On playback stop" event.
    • Remaining time of "Delay" and "Set volume" actions is now displayed in status window.
  • 4.01
    • Added keyboard context menu invocation in events list view and action lists view.
    • Volume fade out bug fix.
    • Volume fade in/out now uses logarithmic scale.
    • Final action combo-box has been returned in date/time event.
    • New "Mute/unmute" action.
  • 4.0
    The plugin is rewritten from scratch. Short list of changes:
    • New "OK, Cancel, Apply" preferences page style, introduced in fb2k 1.0.
    • "Reset page" button works correct now.
    • Scheduler isn't stopped while its preferences page is opened. It's running all the time.
    • Added new status window, where you can see pending date/time events and manage running action lists.
    • Fixed crash with concurrently running action lists.
    • Fixed incorrect handling of date/time events in some cases.
    • Date/time events: completely new configuration dialog, added title support, "remove/disable event" option removed.
    • No more annoying message boxes, now only balloons are used.
    • Menus, treeviews and listviews use native Windows Vista/7 style.
    • New player events: on playback start, stop, pause, unpause, track change.
    • New actions: Pause/Unpause, Change playlist, Launch application.
    • For "Delay" and "Set volume" actions duration units can be selected.
    • New File/Scheduler menu.
    • No more configuration reset during version upgrade.
This post has been edited by andrew_smolko: Dec 24 2012, 14:39
Shinsou
post Oct 25 2006, 21:36
very useful features. Thanks a lot!
NeXT
post Oct 25 2006, 22:32
Wow, I waited this so long! =) Thanks! Trying to migrate from foo_scheduler for 0.8.. smile.gif
Will there be any significant interface modifications? Most of all I miss quick access to events via Components -> Scheduler and current inability to use once-defined action to multiple events (and lack of choosing exact track of playlist to play wink.gif)..
And, there' s the first founded bug smile.gif :
Andreasvb
post Oct 25 2006, 23:43
I only miss a timer instead of using exact time.
Good work!
Windows 8.1u3 Pro x64 Media Center // foobar2000 1.3.8
12zmcnvow1277
post Oct 26 2006, 06:52
Nice work, i had a bulky freeware program that woke from standby but now i can rely on this thanks a lot man.
Would be fantastic if you could intergrate a shutdown timer into it aswell, but I do understand that this is in it's early stages.
Andreasvb
post Oct 26 2006, 06:56
Tried it this night and it worked perfectly, it started fade the volume and play in the morning. happy.gif
vbguy
post Oct 26 2006, 07:12
A "resume playback" or "unpause" option would be nice. Currently, the "Start playback" option restarts to the beginning of the file if it is paused.
Other than that, this is a nice plugin.
This post has been edited by vbguy: Oct 26 2006, 07:13
pIv
post Oct 26 2006, 08:14
It is very good if "Exit foobar" action will be added.
By example, when Foobar reach the end of playlist - it must close, but not system shutdown as made in action "Shutdown".
Matyas
post Oct 26 2006, 08:23
I think the long wait for scheduler was worthy. And knowing the development progress^quality of foo_alarm, this will also be a fantastic plugin! Keep up the good work!
philipshu
post Oct 26 2006, 08:43
i didn't see anything,
what's wrong?
i just reinstalled foobar and it's still not working
This post has been edited by philipshu: Oct 26 2006, 08:45
Andreasvb
post Oct 26 2006, 09:09
When it's enabled, like in your screenshot, you just rightclick somewhere on the white =)
This post has been edited by Andreasvb: Oct 26 2006, 09:10
philipshu
post Oct 26 2006, 09:41
thanks,
i get it now
maybe something like "right click here" when it's empty next update?
Melomane
post Oct 26 2006, 09:53
QUOTE (philipshu @ Oct 26 2006, 10:41) *
thanks,
i get it now
you can see this: "use context menu to customise the task tree".
context menu mean "right click"
nobody born sage
please buy a book and learn
This post has been edited by Melomane: Oct 26 2006, 09:57
Music is my first love.
Melomane
post Oct 26 2006, 10:13
2 requests:
- shortcut to customise page
- timer ( action after xx time)
thank you for your plugin, now i can delete my autohotkey script...
gren
post Oct 26 2006, 11:03
Post #15
Great plugin. When I first saw it I was ambivalent about the design--and I still can't tell whether its cleanliness is a great advantage or a disadvantage smile.gif It's most likely because I've been using this Winamp plugin for the past three plus years until a few months ago I started using foo_alarm. So, my reluctance is meaningless--in fact, it took me quite some time to get me used to foobar and now I look at Winamp and wonder how I used it.
Request: I would second the request for a "timer". While you can do it by setting a one time schedule for a certain time that is not preferable. What I think would be ideal is a third option, the timer, added to date/time event and player event. It would be a one time event of X minutes and it would start counting down whenever you enabled it. So, whenever I want my music on before I go to bed I just click the check box and it goes on for 60 minutes. Then, that same event will be ready for me to click for tomorrow night (unless I chose the remove after done option).
The ability to check the same event night after night and have it count down is what makes it useful since if it was a one time 60 minute event you could very well set a one time alarm. But being able to check the box and get the same 60 minutes would be very useful (to me).
Two less important issues: When you add new events should the be checked by default (I almost didn't check it)? and, would anyone else find it useful to be able to add a label to each event? Such as "class alarm", "shutdown for the weekend" or whatever. It could be right aligned or whatnot. and I think it might provide an easier way to navigate many events rather than reading the times.
andrew_smolko
post Oct 26 2006, 11:35
Post #16
QUOTE (NeXT @ Oct 26 2006, 00:32) *
Windows version please and language settings. Something is wrong with GetTimeFormat...
And now about the timer: IT'S ALREADY IMPLEMENTED!!! smile.gif See "Delay" action. It pauses action list for a certain amount of time.
Andreasvb
post Oct 26 2006, 12:18
Post #17
Well, you still need to enter an exact time for an action to start, don't you? wink.gif
gren
post Oct 26 2006, 12:29
Post #18
But... that's only under a player event or a date/time event. What I think is useful is delay from right now. Did what I was saying make sense? Having a timer of 60 minutes with events under it and whenever you checked the box it would start the timer going? While I see that it's possible to do timer actions now... you first have to create a date/time that goes off right away to enact the delay which will lead to whatever other actions you schedule. It assumes that a timer must be started at a certain time event instead of starting a timer 'now'.
Here is what I envisioned:
The event waits there until you want to click on it... and when you do the timer for those actions starts. Maybe this is laziness... but using your delay you create a date/time event for one minute from now with those actions and then delay X minutes and each time you want to use this you have to change the time to being a minute from now to get the delay timer started.
andrew_smolko
post Oct 26 2006, 12:37
Post #19
QUOTE (Andreasvb @ Oct 26 2006, 14:18) *
Ok, understood.
andrew_smolko
post Oct 26 2006, 12:49
Post #20
QUOTE (gren @ Oct 26 2006, 14:29) *
It will be impossible to start timer after click. While you edit options scheduler is stopped. It starts when the preferences window of scheduler is closed.
As for the idea... I'll think about it.
pIv
post Oct 26 2006, 13:42
Post #21
Andrew!
Do you know about russian Foobar forum (http://www.foobar2000.ru/forum/)?
If you want joint to this forum, we can discussed with you on russian.
foosion
post Oct 26 2006, 13:57
Post #22
Group: FB2K Moderator (Donating)
QUOTE (andrew_smolko @ Oct 26 2006, 13:49) *
Why not introduce named events that can be triggered by main menu commands (one command for each named event)?
andrew_smolko
post Oct 26 2006, 14:08
Post #23
QUOTE (foosion @ Oct 26 2006, 15:57) *
Great idea! Thanks, foosion!
Chaser
post Oct 26 2006, 16:33
Post #24
Would you please consider adding the possiblity to add a event like "Do xxx on start of foobar?"
Thank you for you effort!
huythuy
post Oct 26 2006, 23:12
Post #25
I have 2 requests:
- is it possible to have an option : On playback end -> Proceed to the next playlist. I have many playlists for single artists or albums and it would be great if scheduler simply rolls to next playlist. With the current settings, it seems I could only specify 1 next playlist.
- An option to specify which track should be played would be very nice smile.gif
RSS Lo-Fi Version Time is now: 26th April 2015 - 11:29
