foo_scheduler, Plugin for scheduling actions like play, stop, system shutdown/wake up
andrew_smolko
post Oct 25 2006, 21:06
Version 4.11 (download)
Changelog:
  • 4.11
    • "Scheduler enabled" checkbox has been added.
  • 4.10
    • Removed useless stop reason in player stop event.
    • Dropped packing of executable to be able to analyze crash dumps.
    • Rebuild with more stable versions of internal libraries.
  • 4.09
    • Completely fixed keyboard shortcuts assignment problem.
  • 4.08
    • Fixed tab order in "Wait until N tracks played" configuration dialog.
    • Fixed a bug with menu items, when keyboard shortcuts couldn't be assigned to them correctly. Please recreate your menu item events!
  • 4.07
    • Added a new command "Stop all action lists" to the status window and to the main menu.
    • Header restyling to conform the style of preferences page.
    • New action "Wait until N tracks played".
  • 4.06
    • Next/previous track actions added.
  • 4.05
    • Preferences window fix due to changes in fb2k 1.1.
  • 4.04
    • Added items reordering in events list.
    • The width of each column in events list window is stored in configuration.
  • 4.03
    • Bug fix release.
  • 4.02
    • Added more detailed config of "On playback stop" event.
    • Remaining time of "Delay" and "Set volume" actions is now displayed in status window.
  • 4.01
    • Added keyboard context menu invocation in events list view and action lists view.
    • Volume fade out bug fix.
    • Volume fade in/out now uses logarithmic scale.
    • Final action combo-box has been returned in date/time event.
    • New "Mute/unmute" action.
  • 4.0
    The plugin is rewritten from scratch. Short list of changes:
    • New "OK, Cancel, Apply" preferences page style, introduced in fb2k 1.0.
    • "Reset page" button works correct now.
    • Scheduler isn't stopped while its preferences page is opened. It's running all the time.
    • Added new status window, where you can see pending date/time events and manage running action lists.
    • Fixed crash with concurrently running action lists.
    • Fixed incorrect handling of date/time events in some cases.
    • Date/time events: completely new configuration dialog, added title support, "remove/disable event" option removed.
    • No more annoying message boxes, now only balloons are used.
    • Menus, treeviews and listviews use native Windows Vista/7 style.
    • New player events: on playback start, stop, pause, unpause, track change.
    • New actions: Pause/Unpause, Change playlist, Launch application.
    • For "Delay" and "Set volume" actions duration units can be selected.
    • New File/Scheduler menu.
    • No more configuration reset during version upgrade.
This post has been edited by andrew_smolko: Dec 24 2012, 14:39
Lexee
post Nov 23 2006, 08:49
I create a scheduler event and when it starts Foobar crashes. The bug report is as follows:
Illegal operation:
Code: C0000005h, flags: 00000000h, address: 010DFCDCh
Access violation, operation: read, address: 00000014h
Call path:
Code bytes (010DFCDCh):
010DFC9Ch: 8B 28 83 C7 04 8B F7 89 6C 24 14 89 74 24 10 EB
010DFCACh: 03 8D 49 00 85 F6 8B 5F 04 74 04 3B F7 74 05 E8
010DFCBCh: 2D D2 01 00 3B EB 74 30 85 F6 75 05 E8 20 D2 01
010DFCCCh: 00 3B 6E 04 75 05 E8 16 D2 01 00 8B 4D 10 8B 11
010DFCDCh: 8B 42 14 FF D0 8D 74 24 10 E8 F6 38 FF FF 8B 6C
010DFCECh: 24 14 8B 74 24 10 EB BC 5F 5E 5D 5B 83 C4 0C C3
010DFCFCh: CC CC CC CC 8B 50 04 8B 4A 04 83 EC 14 80 79 15
010DFD0Ch: 00 56 57 75 16 8B 33 39 71 0C 73 05 8B 49 08 EB
Stack (0258FE84h):
0258FE64h: 7C919B3F 7C97C0D8 7C919AEB 0111503C
0258FE74h: 011D3E80 0000FFFF 7FFDF000 00254678
0258FE84h: 011D5278 011D3B80 0258FEF4 011D51E0
0258FE94h: 011D526C 011D5668 0258FEF4 010DFC62
0258FEA4h: 8ED19C4D 011D5268 010D3D70 0012F384
0258FEB4h: 00000000 0258FE98 011D526C 011D5668
0258FEC4h: 011D3B40 7FFDC000 011D5278 011D56A8
0258FED4h: 010DF950 011D5268 011D56A8 7C8399F3
0258FEE4h: 0258FF34 01113430 FFFFFFFF 000000D4
0258FEF4h: 0258FF74 010D3D6A 011D5268 010F85B8
0258FF04h: 011D5268 8ED19DE9 0258FF74 7C90110A
0258FF14h: 011D5688 010F825F 011D5688 010F8557
0258FF24h: 8ED19DCD 010D3D70 0012F384 00000001
0258FF34h: 0258FF68 011103A8 FFFFFFFF 010F8649
0258FF44h: 8ED19D91 0012EFB8 0012F21C 011D3E80
0258FF54h: 010D3D70 011D5268 010D3D60 8ED19D91
0258FF64h: 0258FF44 0258FF9C 011103D8 00000001
0258FF74h: 0258FFAC 01101D1A 0012F384 8ED19D49
0258FF84h: 0012EFB8 0012F21C 011D3E80 C0000005
0258FF94h: 0258FF80 0258FAAC 0258FFDC 010FE230
Registers:
EAX: 011D5648, EBX: 011D5648, ECX: 011D51E0, EDX: 00000000
ESI: 011D526C, EDI: 011D526C, EBP: 011D5668, ESP: 0258FE84
Crash location: "foo_scheduler", loaded at 010D0000h - 01138000h
Loaded modules:
foobar2000 loaded at 00400000h - 004F3000h
ntdll loaded at 7C900000h - 7C9B0000h
kernel32 loaded at 7C800000h - 7C8F4000h
COMCTL32 loaded at 773D0000h - 774D2000h
msvcrt loaded at 77C10000h - 77C68000h
ADVAPI32 loaded at 77DD0000h - 77E6B000h
RPCRT4 loaded at 77E70000h - 77F01000h
GDI32 loaded at 77F10000h - 77F56000h
USER32 loaded at 77D40000h - 77DD0000h
SHLWAPI loaded at 77F60000h - 77FD6000h
SHELL32 loaded at 7C9C0000h - 7D1D4000h
ole32 loaded at 774E0000h - 7761C000h
shared loaded at 10000000h - 1002A000h
comdlg32 loaded at 763B0000h - 763F9000h
uxtheme loaded at 5AD70000h - 5ADA8000h
foo_abx loaded at 003C0000h - 003F4000h
foo_AdvancedControls loaded at 00A50000h - 00A80000h
foo_albumlist loaded at 00A90000h - 00AD7000h
OLEAUT32 loaded at 77120000h - 771AC000h
foo_audioscrobbler loaded at 00B00000h - 00B38000h
WS2_32 loaded at 71AB0000h - 71AC7000h
WS2HELP loaded at 71AA0000h - 71AA8000h
foo_cdda loaded at 00B60000h - 00B96000h
foo_converter loaded at 00BC0000h - 00C29000h
foo_dsp_std loaded at 00C50000h - 00C91000h
foo_freedb2 loaded at 00CC0000h - 00D00000h
foo_fullscreen loaded at 00D20000h - 00D3B000h
foo_infobox loaded at 00D60000h - 00DA0000h
foo_input_monkey loaded at 00DC0000h - 00E09000h
foo_input_std loaded at 00E30000h - 00F44000h
foo_masstag loaded at 00F70000h - 00FC0000h
foo_minimize_on_close loaded at 00FE0000h - 00FF6000h
foo_preview loaded at 01020000h - 01041000h
foo_rgscan loaded at 01060000h - 010A8000h
foo_scheduler loaded at 010D0000h - 01138000h
POWRPROF loaded at 74AD0000h - 74AD8000h
WINMM loaded at 76B40000h - 76B6D000h
serwvdrv loaded at 5CD70000h - 5CD77000h
umdmxfrm loaded at 5B0A0000h - 5B0A7000h
foo_shutdown loaded at 011E0000h - 011F8000h
foo_uie_albumart loaded at 01220000h - 01254000h
gdiplus loaded at 4EC50000h - 4EDF3000h
foo_ui_columns loaded at 01290000h - 0132A000h
foo_ui_std loaded at 01350000h - 013A7000h
foo_unpack loaded at 013D0000h - 013FE000h
correct loaded at 01720000h - 01726000h
dciman32 loaded at 73BC0000h - 73BC6000h
mswsock loaded at 71A50000h - 71A8F000h
DNSAPI loaded at 76F20000h - 76F47000h
winrnr loaded at 76FB0000h - 76FB8000h
WLDAP32 loaded at 76F60000h - 76F8C000h
rasadhlp loaded at 76FC0000h - 76FC6000h
hnetcfg loaded at 662B0000h - 66308000h
wshtcpip loaded at 71A90000h - 71A98000h
imagehlp loaded at 76C90000h - 76CB8000h
DBGHELP loaded at 59A60000h - 59B01000h
VERSION loaded at 77C00000h - 77C08000h
Stack dump analysis:
Address: 010DFC62h, location: "foo_scheduler", loaded at 010D0000h - 01138000h
Address: 010D3D70h, location: "foo_scheduler", loaded at 010D0000h - 01138000h
Address: 010DF950h, location: "foo_scheduler", loaded at 010D0000h - 01138000h
Address: 7C8399F3h, location: "kernel32", loaded at 7C800000h - 7C8F4000h
Symbol: "FindAtomW" (+00000094h)
Address: 01113430h, location: "foo_scheduler", loaded at 010D0000h - 01138000h
Address: 010D3D6Ah, location: "foo_scheduler", loaded at 010D0000h - 01138000h
Address: 010F85B8h, location: "foo_scheduler", loaded at 010D0000h - 01138000h
Address: 7C90110Ah, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "RtlLeaveCriticalSection" (+0000001Dh)
Address: 010F825Fh, location: "foo_scheduler", loaded at 010D0000h - 01138000h
Address: 010F8557h, location: "foo_scheduler", loaded at 010D0000h - 01138000h
Address: 011103A8h, location: "foo_scheduler", loaded at 010D0000h - 01138000h
Address: 010F8649h, location: "foo_scheduler", loaded at 010D0000h - 01138000h
Address: 010D3D60h, location: "foo_scheduler", loaded at 010D0000h - 01138000h
Address: 011103D8h, location: "foo_scheduler", loaded at 010D0000h - 01138000h
Address: 01101D1Ah, location: "foo_scheduler", loaded at 010D0000h - 01138000h
Address: 010FE230h, location: "foo_scheduler", loaded at 010D0000h - 01138000h
Address: 01101DBFh, location: "foo_scheduler", loaded at 010D0000h - 01138000h
Address: 7C80B50Bh, location: "kernel32", loaded at 7C800000h - 7C8F4000h
Symbol: "GetModuleFileNameA" (+000001B4h)
Address: 7C80B518h, location: "kernel32", loaded at 7C800000h - 7C8F4000h
Symbol: "GetModuleFileNameA" (+000001C1h)
Address: 01101D40h, location: "foo_scheduler", loaded at 010D0000h - 01138000h
Address: 00C80008h, location: "foo_dsp_std", loaded at 00C50000h - 00C91000h
Version info:
foobar2000 v0.9.4.1
UNICODE
Additional info:
Audioscrobbler 1.3.2 (foo_audioscrobbler)
foobar2000 core v0.9.4.1 (Core)
Masstagger 1.6 (foo_masstag)
Foo Shutdown 0.9 (foo_shutdown)
Minimize On Close 0.2 (foo_minimize_on_close)
ReplayGain Scanner 2.0.2 (foo_rgscan)
Album List 3.2.0 (foo_albumlist)
Standard Input Array 1.0 (foo_input_std)
Special file info box 2.0.4 (foo_infobox)
CD Audio Decoder 2.1.1 (foo_cdda)
Columns UI 0.1.3 beta 1v5 (foo_ui_columns)
ABX Comparator 1.3.1 (foo_abx)
freedb Tagger 0.5.2a (foo_freedb2)
Fullscreen 0.3.1 (foo_fullscreen)
ZIP/GZIP reader 1.0 (foo_unpack)
Standard DSP array 1.0 (foo_dsp_std)
Album Art Panel 0.2.0 (foo_uie_albumart)
RAR reader 1.1 (foo_unpack)
Preview 1.2 (foo_preview)
WMA Decoder 1.1 (foo_input_std)
Converter 1.0.1 (foo_converter)
Default User Interface 0.9acc (foo_ui_std)
FLAC Decoder 1.1.0 (foo_input_std)
Monkey's Audio decoder 2.1.1 (foo_input_monkey)
FooBar2000 Advanced Controls 0.5.9.0 (foo_AdvancedControls)
Scheduler 3.11 (foo_scheduler)
Can anybody tell me why does it happen? Thanks in advance.
andrew_smolko
post Nov 23 2006, 10:17
QUOTE (Lexee @ Nov 23 2006, 10:49) *
Possibly you've created "Once date/time event" with "Remove after done" or "Player event" with "Remove after done". There is a bug, it's already fixed, but I haven't uploaded new version yet.
- andrew_smolko   foo_scheduler   Oct 25 2006, 21:06
- - Shinsou   very useful features. Thanks a lot!   Oct 25 2006, 21:36
- - NeXT   Wow, I waited this so long! =) Thanks! Try...   Oct 25 2006, 22:32
|- - andrew_smolko   QUOTE (NeXT @ Oct 26 2006, 00:32) And, th...   Oct 26 2006, 11:35
|- - gren   QUOTE And now about the timer: IT'S ALREADY IM...   Oct 26 2006, 12:29
|- - andrew_smolko   QUOTE (gren @ Oct 26 2006, 14:29) Here is...   Oct 26 2006, 12:49
|- - foosion   QUOTE (andrew_smolko @ Oct 26 2006, 13:49...   Oct 26 2006, 13:57
|- - andrew_smolko   QUOTE (foosion @ Oct 26 2006, 15:57) QUOT...   Oct 26 2006, 14:08
- - Andreasvb   Yes, thank you I only miss a timer instead of us...   Oct 25 2006, 23:43
|- - 12zmcnvow1277   Nice work, i had a bulky freeware program that wok...   Oct 26 2006, 06:52
- - Andreasvb   Tried it this night and it worked perfectly, it st...   Oct 26 2006, 06:56
- - vbguy   A "resume playback" or "unpause...   Oct 26 2006, 07:12
- - pIv   It is very good if "Exit foobar" action ...   Oct 26 2006, 08:14
- - Matyas   I think the long wait for scheduler was worthy. An...   Oct 26 2006, 08:23
- - philipshu   i didn't see anything, what's wrong? i jus...   Oct 26 2006, 08:43
- - Andreasvb   When it's enabled, like in your screenshot, yo...   Oct 26 2006, 09:09
- - philipshu   thanks, i get it now maybe something like "ri...   Oct 26 2006, 09:41
|- - Melomane   QUOTE (philipshu @ Oct 26 2006, 10:41) th...   Oct 26 2006, 09:53
- - Melomane   2 requests: - shortcut to customise page - timer (...   Oct 26 2006, 10:13
- - gren   Great plugin. When I first saw it I was ambivalen...   Oct 26 2006, 11:03
- - Andreasvb   Well, you still need to enter an exact time for an...   Oct 26 2006, 12:18
|- - andrew_smolko   QUOTE (Andreasvb @ Oct 26 2006, 14:18) We...   Oct 26 2006, 12:37
- - pIv   Andrew! Do you know about russian Foobar foru...   Oct 26 2006, 13:42
- - Chaser   Would you please consider adding the possiblity to...   Oct 26 2006, 16:33
- - huythuy   thanks alot. I've been waiting for this one fo...   Oct 26 2006, 23:12
- - Sphix   Request: - Option to shutdown the machine after a ...   Oct 26 2006, 23:53
|- - mpioner   QUOTE (Sphix @ Oct 27 2006, 08:53) Reques...   Oct 27 2006, 01:46
|- - andrew_smolko   QUOTE (Sphix @ Oct 27 2006, 01:53) Reques...   Oct 27 2006, 16:02
|- - RogerG   QUOTE (andrew_smolko @ Oct 27 2006, 17:02...   Oct 29 2006, 07:13
- - vader897   Just thought of this, dunno if it will work... cou...   Oct 29 2006, 15:49
- - Matyas   Request: Besides setting the foobar2000 volume, se...   Oct 30 2006, 11:14
- - fabiospark   Is already there a way to create these actions I h...   Nov 1 2006, 18:02
|- - andrew_smolko   QUOTE (fabiospark @ Nov 1 2006, 20:02) Is...   Nov 1 2006, 19:08
|- - fabiospark   QUOTE (andrew_smolko @ Nov 1 2006, 20:08)...   Nov 1 2006, 22:03
|- - andrew_smolko   QUOTE (fabiospark @ Nov 2 2006, 00:03) QU...   Nov 2 2006, 11:55
- - Generalverdacht   thanks fot that great plugin !   Nov 1 2006, 18:44
- - TheTravis   Thank you very much andrew_smolko! Requests: ...   Nov 1 2006, 23:21
- - _eclectic_   Wow, just when I think there is nothing else that ...   Nov 2 2006, 06:37
- - Bobjua   Right now im just using 1 playlist all the time, (...   Nov 2 2006, 07:32
- - Spi   thanks man i waited long for this one, THANK YOU ...   Nov 3 2006, 12:36
- - trance   Oh lord, thank you! This the only componen...   Nov 4 2006, 17:56
- - andrew_smolko   3.05 is ready!   Nov 4 2006, 22:45
- - Andreasvb   Thanks, finally got the "timer" to work,...   Nov 5 2006, 13:33
- - neooffs   hello, can you make the plugin allow twice or more...   Nov 8 2006, 04:01
- - kalmark   Could you add a warning if the user tries to save ...   Nov 8 2006, 08:47
|- - andrew_smolko   QUOTE Unfortunately there's no way to see the ...   Nov 8 2006, 14:39
- - jackassbikeco   I can't seem to get a timer that I make to wor...   Nov 9 2006, 06:31
|- - andrew_smolko   QUOTE (jackassbikeco @ Nov 9 2006, 08:31)...   Nov 10 2006, 10:26
- - gren   QUOTE can you make the plugin allow twice or more ...   Nov 9 2006, 17:40
- - jackassbikeco   What he means is that if he wants to have the same...   Nov 9 2006, 19:28
- - 2Pacalypse   couple of question. how are people saying shut do...   Nov 9 2006, 23:48
- - gren   QUOTE Possibly you pressed one of these buttons st...   Nov 10 2006, 11:32
- - q-stankovic   QUOTE (gren @ Nov 10 2006, 11:32) QUOTE P...   Nov 10 2006, 12:29
|- - andrew_smolko   QUOTE (q-stankovic @ Nov 10 2006, 14...   Nov 10 2006, 16:04
- - 2Pacalypse   ignore my previous post, i found it all when i got...   Nov 10 2006, 12:36
- - neooffs   ty for the plugin andrew... really helped me out   Nov 10 2006, 16:53
- - q-stankovic   QUOTE Not a good idea, I prefer to stop fade in us...   Nov 10 2006, 16:56
- - andrew_smolko   3.06 with new "Set mixer volume" action...   Nov 12 2006, 23:55
|- - gren   QUOTE (andrew_smolko @ Nov 12 2006, 17:55...   Nov 13 2006, 06:28
|- - Matyas   QUOTE (andrew_smolko @ Nov 13 2006, 00:55...   Nov 13 2006, 11:05
- - eisteh   I have 2 small requests: 1. Couldn't you add...   Nov 13 2006, 13:21
|- - Matyas   QUOTE (eisteh @ Nov 13 2006, 14:21) 2. I ...   Nov 13 2006, 17:02
- - eisteh   QUOTE (Matyas @ Nov 13 2006, 17:02) QUOTE...   Nov 13 2006, 23:45
- - andrew_smolko   I missed an alarm That's bad news... 3.07 wit...   Nov 15 2006, 22:02
- - Andreasvb   Haha, thanks   Nov 15 2006, 22:03
- - wolfsong   Is there a way to use scheduler to refresh the med...   Nov 15 2006, 22:11
|- - andrew_smolko   QUOTE (wolfsong @ Nov 16 2006, 00:11) Is ...   Nov 16 2006, 10:22
|- - wolfsong   QUOTE (andrew_smolko @ Nov 16 2006, 03:22...   Nov 16 2006, 16:46
|- - andrew_smolko   QUOTE (wolfsong @ Nov 16 2006, 18:46) QUO...   Nov 16 2006, 18:39
- - roentgen   Request: possibility to sort menu items and maybe ...   Nov 16 2006, 18:56
- - C.Flam   I'm trying to script the automatic switch to t...   Nov 16 2006, 23:26
- - andrew_smolko   3.1 is here! See changelog.   Nov 18 2006, 16:59
|- - C.Flam   QUOTE (andrew_smolko @ Nov 18 2006, 16:59...   Nov 18 2006, 22:52
- - eisteh   The download link still refers to 3.07   Nov 18 2006, 17:12
|- - andrew_smolko   QUOTE (eisteh @ Nov 18 2006, 19:12) The d...   Nov 18 2006, 18:05
- - wolfsong   QUOTE (andrew_smolko @ Oct 25 2006, 14:06...   Nov 18 2006, 18:52
- - Andreasvb   Select the time and then rightclick your new entry...   Nov 18 2006, 19:18
|- - wolfsong   QUOTE (Andreasvb @ Nov 18 2006, 12:18) Se...   Nov 18 2006, 19:27
- - Andreasvb   Strange, sure you have the new version?   Nov 18 2006, 19:37
|- - wolfsong   QUOTE (Andreasvb @ Nov 18 2006, 12:37) St...   Nov 18 2006, 19:40
- - hal9001   Dl link for 3.1 brings a corrupt ZIPfile EDIT: c...   Nov 19 2006, 08:41
- - andrew_smolko   Seems to be the hosting problems. I've changed...   Nov 19 2006, 11:42
- - jaslr   This could be completely the wrong component to be...   Nov 20 2006, 03:23
|- - Melomane   QUOTE (jaslr @ Nov 20 2006, 03:23) This c...   Nov 22 2006, 11:41
- - francesco   and for 0.8 nothing of similar?   Nov 20 2006, 12:06
- - kalmark   I have a bug to report, I think. Not tested with 3...   Nov 20 2006, 12:24
|- - andrew_smolko   QUOTE (kalmark @ Nov 20 2006, 14:24) I ha...   Nov 20 2006, 20:34
|- - kalmark   QUOTE (andrew_smolko @ Nov 20 2006, 21:34...   Nov 22 2006, 08:55
- - eisteh   QUOTE (jaslr @ Nov 20 2006, 03:23) This c...   Nov 20 2006, 13:17
- - maxtail   Hello, sorry for my poor English, but I'd like...   Nov 22 2006, 14:59
|- - andrew_smolko   QUOTE (maxtail @ Nov 22 2006, 16:59) Hell...   Nov 22 2006, 15:58
- - Lexee   I create a scheduler event and when it starts Foob...   Nov 23 2006, 08:49
|- - andrew_smolko   QUOTE (Lexee @ Nov 23 2006, 10:49) I crea...   Nov 23 2006, 10:17
- - Lexee   Yes, you're right I created "once time...   Nov 23 2006, 13:43
- - andrew_smolko   3.5 RC! This is release candidate version. Eve...   Nov 23 2006, 14:27
- - eisteh   The new interface is a bit strange at first sight,...   Nov 23 2006, 16:08
- - fabiospark   Can we choose the IDs (menu and actions) from a li...   Nov 24 2006, 11:26
- - xhandler   Love this one.. use it instead of radio alarm.. wh...   Nov 24 2006, 12:13
- - LTourist   The return of foo_scheuler is a great news!...   Nov 24 2006, 12:29
- - gren   huythuy, your first request seems to me like it w...   Nov 25 2006, 11:53
6 Pages V   1 2 3 > »
RSS Lo-Fi Version Time is now: 2nd July 2015 - 14:12
