foo_scheduler, Plugin for scheduling actions like play, stop, system shutdown/wake up
andrew_smolko
post Oct 25 2006, 21:06
Version 4.11 (download)
Changelog:
  • 4.11
    • "Scheduler enabled" checkbox has been added.
  • 4.10
    • Removed useless stop reason in player stop event.
    • Dropped packing of executable to be able to analyze crash dumps.
    • Rebuild with more stable versions of internal libraries.
  • 4.09
    • Completely fixed keyboard shortcuts assignment problem.
  • 4.08
    • Fixed tab order in "Wait until N tracks played" configuration dialog.
    • Fixed a bug with menu items, when keyboard shortcuts couldn't be assigned to them correctly. Please recreate your menu item events!
  • 4.07
    • Added a new command "Stop all action lists" to the status window and to the main menu.
    • Header restyling to conform the style of preferences page.
    • New action "Wait until N tracks played".
  • 4.06
    • Next/previous track actions added.
  • 4.05
    • Preferences window fix due to changes in fb2k 1.1.
  • 4.04
    • Added items reordering in events list.
    • The width of each column in events list window is stored in configuration.
  • 4.03
    • Bug fix release.
  • 4.02
    • Added more detailed config of "On playback stop" event.
    • Remaining time of "Delay" and "Set volume" actions is now displayed in status window.
  • 4.01
    • Added keyboard context menu invocation in events list view and action lists view.
    • Volume fade out bug fix.
    • Volume fade in/out now uses logarithmic scale.
    • Final action combo-box has been returned in date/time event.
    • New "Mute/unmute" action.
  • 4.0
    The plugin is rewritten from scratch. Short list of changes:
    • New "OK, Cancel, Apply" preferences page style, introduced in fb2k 1.0.
    • "Reset page" button works correct now.
    • Scheduler isn't stopped while its preferences page is opened. It's running all the time.
    • Added new status window, where you can see pending date/time events and manage running action lists.
    • Fixed crash with concurrently running action lists.
    • Fixed incorrect handling of date/time events in some cases.
    • Date/time events: completely new configuration dialog, added title support, "remove/disable event" option removed.
    • No more annoying message boxes, now only balloons are used.
    • Menus, treeviews and listviews use native Windows Vista/7 style.
    • New player events: on playback start, stop, pause, unpause, track change.
    • New actions: Pause/Unpause, Change playlist, Launch application.
    • For "Delay" and "Set volume" actions duration units can be selected.
    • New File/Scheduler menu.
    • No more configuration reset during version upgrade.
This post has been edited by andrew_smolko: Dec 24 2012, 14:39
Andreasvb
post Oct 26 2006, 12:18
Well, you still need to enter an exact time for an action to start, don't you? wink.gif
Windows 8.1u3 Pro x64 Media Center // foobar2000 1.3.8
andrew_smolko
post Oct 26 2006, 12:37
QUOTE (Andreasvb @ Oct 26 2006, 14:18) *
Ok, understood.
- andrew_smolko   foo_scheduler   Oct 25 2006, 21:06
- - Shinsou   very useful features. Thanks a lot!   Oct 25 2006, 21:36
- - NeXT   Wow, I waited this so long! =) Thanks! Try...   Oct 25 2006, 22:32
|- - andrew_smolko   QUOTE (NeXT @ Oct 26 2006, 00:32) And, th...   Oct 26 2006, 11:35
|- - gren   QUOTE And now about the timer: IT'S ALREADY IM...   Oct 26 2006, 12:29
|- - andrew_smolko   QUOTE (gren @ Oct 26 2006, 14:29) Here is...   Oct 26 2006, 12:49
|- - foosion   QUOTE (andrew_smolko @ Oct 26 2006, 13:49...   Oct 26 2006, 13:57
|- - andrew_smolko   QUOTE (foosion @ Oct 26 2006, 15:57) QUOT...   Oct 26 2006, 14:08
- - Andreasvb   Yes, thank you I only miss a timer instead of us...   Oct 25 2006, 23:43
|- - 12zmcnvow1277   Nice work, i had a bulky freeware program that wok...   Oct 26 2006, 06:52
- - Andreasvb   Tried it this night and it worked perfectly, it st...   Oct 26 2006, 06:56
- - vbguy   A "resume playback" or "unpause...   Oct 26 2006, 07:12
- - pIv   It is very good if "Exit foobar" action ...   Oct 26 2006, 08:14
- - Matyas   I think the long wait for scheduler was worthy. An...   Oct 26 2006, 08:23
- - philipshu   i didn't see anything, what's wrong? i jus...   Oct 26 2006, 08:43
- - Andreasvb   When it's enabled, like in your screenshot, yo...   Oct 26 2006, 09:09
- - philipshu   thanks, i get it now maybe something like "ri...   Oct 26 2006, 09:41
|- - Melomane   QUOTE (philipshu @ Oct 26 2006, 10:41) th...   Oct 26 2006, 09:53
- - Melomane   2 requests: - shortcut to customise page - timer (...   Oct 26 2006, 10:13
- - gren   Great plugin. When I first saw it I was ambivalen...   Oct 26 2006, 11:03
- - Andreasvb   Well, you still need to enter an exact time for an...   Oct 26 2006, 12:18
|- - andrew_smolko   QUOTE (Andreasvb @ Oct 26 2006, 14:18) We...   Oct 26 2006, 12:37
- - pIv   Andrew! Do you know about russian Foobar foru...   Oct 26 2006, 13:42
- - Chaser   Would you please consider adding the possiblity to...   Oct 26 2006, 16:33
- - huythuy   thanks alot. I've been waiting for this one fo...   Oct 26 2006, 23:12
- - Sphix   Request: - Option to shutdown the machine after a ...   Oct 26 2006, 23:53
|- - mpioner   QUOTE (Sphix @ Oct 27 2006, 08:53) Reques...   Oct 27 2006, 01:46
|- - andrew_smolko   QUOTE (Sphix @ Oct 27 2006, 01:53) Reques...   Oct 27 2006, 16:02
|- - RogerG   QUOTE (andrew_smolko @ Oct 27 2006, 17:02...   Oct 29 2006, 07:13
- - vader897   Just thought of this, dunno if it will work... cou...   Oct 29 2006, 15:49
- - Matyas   Request: Besides setting the foobar2000 volume, se...   Oct 30 2006, 11:14
- - fabiospark   Is already there a way to create these actions I h...   Nov 1 2006, 18:02
|- - andrew_smolko   QUOTE (fabiospark @ Nov 1 2006, 20:02) Is...   Nov 1 2006, 19:08
|- - fabiospark   QUOTE (andrew_smolko @ Nov 1 2006, 20:08)...   Nov 1 2006, 22:03
|- - andrew_smolko   QUOTE (fabiospark @ Nov 2 2006, 00:03) QU...   Nov 2 2006, 11:55
- - Generalverdacht   thanks fot that great plugin !   Nov 1 2006, 18:44
- - TheTravis   Thank you very much andrew_smolko! Requests: ...   Nov 1 2006, 23:21
- - _eclectic_   Wow, just when I think there is nothing else that ...   Nov 2 2006, 06:37
- - Bobjua   Right now im just using 1 playlist all the time, (...   Nov 2 2006, 07:32
- - Spi   thanks man i waited long for this one, THANK YOU ...   Nov 3 2006, 12:36
- - trance   Oh lord, thank you! This the only componen...   Nov 4 2006, 17:56
- - andrew_smolko   3.05 is ready!   Nov 4 2006, 22:45
- - Andreasvb   Thanks, finally got the "timer" to work,...   Nov 5 2006, 13:33
- - neooffs   hello, can you make the plugin allow twice or more...   Nov 8 2006, 04:01
- - kalmark   Could you add a warning if the user tries to save ...   Nov 8 2006, 08:47
|- - andrew_smolko   QUOTE Unfortunately there's no way to see the ...   Nov 8 2006, 14:39
- - jackassbikeco   I can't seem to get a timer that I make to wor...   Nov 9 2006, 06:31
|- - andrew_smolko   QUOTE (jackassbikeco @ Nov 9 2006, 08:31)...   Nov 10 2006, 10:26
- - gren   QUOTE can you make the plugin allow twice or more ...   Nov 9 2006, 17:40
- - jackassbikeco   What he means is that if he wants to have the same...   Nov 9 2006, 19:28
- - 2Pacalypse   couple of question. how are people saying shut do...   Nov 9 2006, 23:48
- - gren   QUOTE Possibly you pressed one of these buttons st...   Nov 10 2006, 11:32
- - q-stankovic   QUOTE (gren @ Nov 10 2006, 11:32) QUOTE P...   Nov 10 2006, 12:29
|- - andrew_smolko   QUOTE (q-stankovic @ Nov 10 2006, 14...   Nov 10 2006, 16:04
- - 2Pacalypse   ignore my previous post, i found it all when i got...   Nov 10 2006, 12:36
- - neooffs   ty for the plugin andrew... really helped me out   Nov 10 2006, 16:53
- - q-stankovic   QUOTE Not a good idea, I prefer to stop fade in us...   Nov 10 2006, 16:56
- - andrew_smolko   3.06 with new "Set mixer volume" action...   Nov 12 2006, 23:55
|- - gren   QUOTE (andrew_smolko @ Nov 12 2006, 17:55...   Nov 13 2006, 06:28
|- - Matyas   QUOTE (andrew_smolko @ Nov 13 2006, 00:55...   Nov 13 2006, 11:05
- - eisteh   I have 2 small requests: 1. Couldn't you add...   Nov 13 2006, 13:21
|- - Matyas   QUOTE (eisteh @ Nov 13 2006, 14:21) 2. I ...   Nov 13 2006, 17:02
- - eisteh   QUOTE (Matyas @ Nov 13 2006, 17:02) QUOTE...   Nov 13 2006, 23:45
- - andrew_smolko   I missed an alarm That's bad news... 3.07 wit...   Nov 15 2006, 22:02
- - Andreasvb   Haha, thanks   Nov 15 2006, 22:03
- - wolfsong   Is there a way to use scheduler to refresh the med...   Nov 15 2006, 22:11
|- - andrew_smolko   QUOTE (wolfsong @ Nov 16 2006, 00:11) Is ...   Nov 16 2006, 10:22
|- - wolfsong   QUOTE (andrew_smolko @ Nov 16 2006, 03:22...   Nov 16 2006, 16:46
|- - andrew_smolko   QUOTE (wolfsong @ Nov 16 2006, 18:46) QUO...   Nov 16 2006, 18:39
- - roentgen   Request: possibility to sort menu items and maybe ...   Nov 16 2006, 18:56
- - C.Flam   I'm trying to script the automatic switch to t...   Nov 16 2006, 23:26
- - andrew_smolko   3.1 is here! See changelog.   Nov 18 2006, 16:59
|- - C.Flam   QUOTE (andrew_smolko @ Nov 18 2006, 16:59...   Nov 18 2006, 22:52
- - eisteh   The download link still refers to 3.07   Nov 18 2006, 17:12
|- - andrew_smolko   QUOTE (eisteh @ Nov 18 2006, 19:12) The d...   Nov 18 2006, 18:05
- - wolfsong   QUOTE (andrew_smolko @ Oct 25 2006, 14:06...   Nov 18 2006, 18:52
- - Andreasvb   Select the time and then rightclick your new entry...   Nov 18 2006, 19:18
|- - wolfsong   QUOTE (Andreasvb @ Nov 18 2006, 12:18) Se...   Nov 18 2006, 19:27
- - Andreasvb   Strange, sure you have the new version?   Nov 18 2006, 19:37
|- - wolfsong   QUOTE (Andreasvb @ Nov 18 2006, 12:37) St...   Nov 18 2006, 19:40
- - hal9001   Dl link for 3.1 brings a corrupt ZIPfile EDIT: c...   Nov 19 2006, 08:41
- - andrew_smolko   Seems to be the hosting problems. I've changed...   Nov 19 2006, 11:42
- - jaslr   This could be completely the wrong component to be...   Nov 20 2006, 03:23
|- - Melomane   QUOTE (jaslr @ Nov 20 2006, 03:23) This c...   Nov 22 2006, 11:41
- - francesco   and for 0.8 nothing of similar?   Nov 20 2006, 12:06
- - kalmark   I have a bug to report, I think. Not tested with 3...   Nov 20 2006, 12:24
|- - andrew_smolko   QUOTE (kalmark @ Nov 20 2006, 14:24) I ha...   Nov 20 2006, 20:34
|- - kalmark   QUOTE (andrew_smolko @ Nov 20 2006, 21:34...   Nov 22 2006, 08:55
- - eisteh   QUOTE (jaslr @ Nov 20 2006, 03:23) This c...   Nov 20 2006, 13:17
- - maxtail   Hello, sorry for my poor English, but I'd like...   Nov 22 2006, 14:59
|- - andrew_smolko   QUOTE (maxtail @ Nov 22 2006, 16:59) Hell...   Nov 22 2006, 15:58
- - Lexee   I create a scheduler event and when it starts Foob...   Nov 23 2006, 08:49
|- - andrew_smolko   QUOTE (Lexee @ Nov 23 2006, 10:49) I crea...   Nov 23 2006, 10:17
- - Lexee   Yes, you're right I created "once time...   Nov 23 2006, 13:43
- - andrew_smolko   3.5 RC! This is release candidate version. Eve...   Nov 23 2006, 14:27
- - eisteh   The new interface is a bit strange at first sight,...   Nov 23 2006, 16:08
- - fabiospark   Can we choose the IDs (menu and actions) from a li...   Nov 24 2006, 11:26
- - xhandler   Love this one.. use it instead of radio alarm.. wh...   Nov 24 2006, 12:13
- - LTourist   The return of foo_scheuler is a great news!...   Nov 24 2006, 12:29
- - gren   huythuy, your first request seems to me like it w...   Nov 25 2006, 11:53
6 Pages V   1 2 3 > »
RSS Lo-Fi Version Time is now: 30th May 2015 - 21:43
