foo_scheduler, Plugin for scheduling actions like play, stop, system shutdown/wake up
andrew_smolko
post Oct 25 2006, 21:06
Version 4.11 (download)
Changelog:
  • 4.11
    • "Scheduler enabled" checkbox has been added.
  • 4.10
    • Removed useless stop reason in player stop event.
    • Dropped packing of executable to be able to analyze crash dumps.
    • Rebuild with more stable versions of internal libraries.
  • 4.09
    • Completely fixed keyboard shortcuts assignment problem.
  • 4.08
    • Fixed tab order in "Wait until N tracks played" configuration dialog.
    • Fixed a bug with menu items, when keyboard shortcuts couldn't be assigned to them correctly. Please recreate your menu item events!
  • 4.07
    • Added a new command "Stop all action lists" to the status window and to the main menu.
    • Header restyling to conform the style of preferences page.
    • New action "Wait until N tracks played".
  • 4.06
    • Next/previous track actions added.
  • 4.05
    • Preferences window fix due to changes in fb2k 1.1.
  • 4.04
    • Added items reordering in events list.
    • The width of each column in events list window is stored in configuration.
  • 4.03
    • Bug fix release.
  • 4.02
    • Added more detailed config of "On playback stop" event.
    • Remaining time of "Delay" and "Set volume" actions is now displayed in status window.
  • 4.01
    • Added keyboard context menu invocation in events list view and action lists view.
    • Volume fade out bug fix.
    • Volume fade in/out now uses logarithmic scale.
    • Final action combo-box has been returned in date/time event.
    • New "Mute/unmute" action.
  • 4.0
    The plugin is rewritten from scratch. Short list of changes:
    • New "OK, Cancel, Apply" preferences page style, introduced in fb2k 1.0.
    • "Reset page" button works correct now.
    • Scheduler isn't stopped while its preferences page is opened. It's running all the time.
    • Added new status window, where you can see pending date/time events and manage running action lists.
    • Fixed crash with concurrently running action lists.
    • Fixed incorrect handling of date/time events in some cases.
    • Date/time events: completely new configuration dialog, added title support, "remove/disable event" option removed.
    • No more annoying message boxes, now only balloons are used.
    • Menus, treeviews and listviews use native Windows Vista/7 style.
    • New player events: on playback start, stop, pause, unpause, track change.
    • New actions: Pause/Unpause, Change playlist, Launch application.
    • For "Delay" and "Set volume" actions duration units can be selected.
    • New File/Scheduler menu.
    • No more configuration reset during version upgrade.
This post has been edited by andrew_smolko: Dec 24 2012, 14:39
NeXT
post Oct 25 2006, 22:32
Wow, I waited this so long! =) Thanks! Trying to migrate from foo_scheduler for 0.8.. smile.gif
Will there be any significant interface modifications? Most of all I miss quick access to events via Components -> Scheduler and current inability to use once-defined action to multiple events (and lack of choosing exact track of playlist to play wink.gif)..
And, there' s the first founded bug smile.gif :
andrew_smolko
post Oct 26 2006, 11:35
QUOTE (NeXT @ Oct 26 2006, 00:32) *
Windows version please and language settings. Something is wrong with GetTimeFormat...
And now about the timer: IT'S ALREADY IMPLEMENTED!!! smile.gif See "Delay" action. It pauses action list for a certain amount of time.
gren
post Oct 26 2006, 12:29
But... that's only under a player event or a date/time event. What I think is useful is delay from right now. Did what I was saying make sense? Having a timer of 60 minutes with events under it and whenever you checked the box it would start the timer going? While I see that it's possible to do timer actions now... you first have to create a date/time that goes off right away to enact the delay which will lead to whatever other actions you schedule. It assumes that a timer must be started at a certain time event instead of starting a timer 'now'.
Here is what I envisioned:
The event waits there until you want to click on it... and when you do the timer for those actions starts. Maybe this is laziness... but using your delay you create a date/time event for one minute from now with those actions and then delay X minutes and each time you want to use this you have to change the time to being a minute from now to get the delay timer started.
andrew_smolko
post Oct 26 2006, 12:49
QUOTE (gren @ Oct 26 2006, 14:29) *
It will be impossible to start timer after click. While you edit options scheduler is stopped. It starts when the preferences window of scheduler is closed.
As for the idea... I'll think about it.
- andrew_smolko   foo_scheduler   Oct 25 2006, 21:06
- - Shinsou   very useful features. Thanks a lot!   Oct 25 2006, 21:36
- - NeXT   Wow, I waited this so long! =) Thanks! Try...   Oct 25 2006, 22:32
|- - andrew_smolko   QUOTE (NeXT @ Oct 26 2006, 00:32) And, th...   Oct 26 2006, 11:35
|- - gren   QUOTE And now about the timer: IT'S ALREADY IM...   Oct 26 2006, 12:29
|- - andrew_smolko   QUOTE (gren @ Oct 26 2006, 14:29) Here is...   Oct 26 2006, 12:49
|- - foosion   QUOTE (andrew_smolko @ Oct 26 2006, 13:49...   Oct 26 2006, 13:57
|- - andrew_smolko   QUOTE (foosion @ Oct 26 2006, 15:57) QUOT...   Oct 26 2006, 14:08
- - Andreasvb   Yes, thank you I only miss a timer instead of us...   Oct 25 2006, 23:43
|- - 12zmcnvow1277   Nice work, i had a bulky freeware program that wok...   Oct 26 2006, 06:52
- - Andreasvb   Tried it this night and it worked perfectly, it st...   Oct 26 2006, 06:56
- - vbguy   A "resume playback" or "unpause...   Oct 26 2006, 07:12
- - pIv   It is very good if "Exit foobar" action ...   Oct 26 2006, 08:14
- - Matyas   I think the long wait for scheduler was worthy. An...   Oct 26 2006, 08:23
- - philipshu   i didn't see anything, what's wrong? i jus...   Oct 26 2006, 08:43
- - Andreasvb   When it's enabled, like in your screenshot, yo...   Oct 26 2006, 09:09
- - philipshu   thanks, i get it now maybe something like "ri...   Oct 26 2006, 09:41
|- - Melomane   QUOTE (philipshu @ Oct 26 2006, 10:41) th...   Oct 26 2006, 09:53
- - Melomane   2 requests: - shortcut to customise page - timer (...   Oct 26 2006, 10:13
- - gren   Great plugin. When I first saw it I was ambivalen...   Oct 26 2006, 11:03
- - Andreasvb   Well, you still need to enter an exact time for an...   Oct 26 2006, 12:18
|- - andrew_smolko   QUOTE (Andreasvb @ Oct 26 2006, 14:18) We...   Oct 26 2006, 12:37
- - pIv   Andrew! Do you know about russian Foobar foru...   Oct 26 2006, 13:42
- - Chaser   Would you please consider adding the possiblity to...   Oct 26 2006, 16:33
- - huythuy   thanks alot. I've been waiting for this one fo...   Oct 26 2006, 23:12
- - Sphix   Request: - Option to shutdown the machine after a ...   Oct 26 2006, 23:53
|- - mpioner   QUOTE (Sphix @ Oct 27 2006, 08:53) Reques...   Oct 27 2006, 01:46
|- - andrew_smolko   QUOTE (Sphix @ Oct 27 2006, 01:53) Reques...   Oct 27 2006, 16:02
|- - RogerG   QUOTE (andrew_smolko @ Oct 27 2006, 17:02...   Oct 29 2006, 07:13
- - vader897   Just thought of this, dunno if it will work... cou...   Oct 29 2006, 15:49
- - Matyas   Request: Besides setting the foobar2000 volume, se...   Oct 30 2006, 11:14
- - fabiospark   Is already there a way to create these actions I h...   Nov 1 2006, 18:02
|- - andrew_smolko   QUOTE (fabiospark @ Nov 1 2006, 20:02) Is...   Nov 1 2006, 19:08
|- - fabiospark   QUOTE (andrew_smolko @ Nov 1 2006, 20:08)...   Nov 1 2006, 22:03
|- - andrew_smolko   QUOTE (fabiospark @ Nov 2 2006, 00:03) QU...   Nov 2 2006, 11:55
- - Generalverdacht   thanks fot that great plugin !   Nov 1 2006, 18:44
- - TheTravis   Thank you very much andrew_smolko! Requests: ...   Nov 1 2006, 23:21
- - _eclectic_   Wow, just when I think there is nothing else that ...   Nov 2 2006, 06:37
- - Bobjua   Right now im just using 1 playlist all the time, (...   Nov 2 2006, 07:32
- - Spi   thanks man i waited long for this one, THANK YOU ...   Nov 3 2006, 12:36
- - trance   Oh lord, thank you! This the only componen...   Nov 4 2006, 17:56
- - andrew_smolko   3.05 is ready!   Nov 4 2006, 22:45
- - Andreasvb   Thanks, finally got the "timer" to work,...   Nov 5 2006, 13:33
- - neooffs   hello, can you make the plugin allow twice or more...   Nov 8 2006, 04:01
- - kalmark   Could you add a warning if the user tries to save ...   Nov 8 2006, 08:47
|- - andrew_smolko   QUOTE Unfortunately there's no way to see the ...   Nov 8 2006, 14:39
- - jackassbikeco   I can't seem to get a timer that I make to wor...   Nov 9 2006, 06:31
|- - andrew_smolko   QUOTE (jackassbikeco @ Nov 9 2006, 08:31)...   Nov 10 2006, 10:26
- - gren   QUOTE can you make the plugin allow twice or more ...   Nov 9 2006, 17:40
- - jackassbikeco   What he means is that if he wants to have the same...   Nov 9 2006, 19:28
- - 2Pacalypse   couple of question. how are people saying shut do...   Nov 9 2006, 23:48
- - gren   QUOTE Possibly you pressed one of these buttons st...   Nov 10 2006, 11:32
- - q-stankovic   QUOTE (gren @ Nov 10 2006, 11:32) QUOTE P...   Nov 10 2006, 12:29
|- - andrew_smolko   QUOTE (q-stankovic @ Nov 10 2006, 14...   Nov 10 2006, 16:04
- - 2Pacalypse   ignore my previous post, i found it all when i got...   Nov 10 2006, 12:36
- - neooffs   ty for the plugin andrew... really helped me out   Nov 10 2006, 16:53
- - q-stankovic   QUOTE Not a good idea, I prefer to stop fade in us...   Nov 10 2006, 16:56
- - andrew_smolko   3.06 with new "Set mixer volume" action...   Nov 12 2006, 23:55
|- - gren   QUOTE (andrew_smolko @ Nov 12 2006, 17:55...   Nov 13 2006, 06:28
|- - Matyas   QUOTE (andrew_smolko @ Nov 13 2006, 00:55...   Nov 13 2006, 11:05
- - eisteh   I have 2 small requests: 1. Couldn't you add...   Nov 13 2006, 13:21
|- - Matyas   QUOTE (eisteh @ Nov 13 2006, 14:21) 2. I ...   Nov 13 2006, 17:02
- - eisteh   QUOTE (Matyas @ Nov 13 2006, 17:02) QUOTE...   Nov 13 2006, 23:45
- - andrew_smolko   I missed an alarm That's bad news... 3.07 wit...   Nov 15 2006, 22:02
- - Andreasvb   Haha, thanks   Nov 15 2006, 22:03
- - wolfsong   Is there a way to use scheduler to refresh the med...   Nov 15 2006, 22:11
|- - andrew_smolko   QUOTE (wolfsong @ Nov 16 2006, 00:11) Is ...   Nov 16 2006, 10:22
|- - wolfsong   QUOTE (andrew_smolko @ Nov 16 2006, 03:22...   Nov 16 2006, 16:46
|- - andrew_smolko   QUOTE (wolfsong @ Nov 16 2006, 18:46) QUO...   Nov 16 2006, 18:39
- - roentgen   Request: possibility to sort menu items and maybe ...   Nov 16 2006, 18:56
- - C.Flam   I'm trying to script the automatic switch to t...   Nov 16 2006, 23:26
- - andrew_smolko   3.1 is here! See changelog.   Nov 18 2006, 16:59
|- - C.Flam   QUOTE (andrew_smolko @ Nov 18 2006, 16:59...   Nov 18 2006, 22:52
- - eisteh   The download link still refers to 3.07   Nov 18 2006, 17:12
|- - andrew_smolko   QUOTE (eisteh @ Nov 18 2006, 19:12) The d...   Nov 18 2006, 18:05
- - wolfsong   QUOTE (andrew_smolko @ Oct 25 2006, 14:06...   Nov 18 2006, 18:52
- - Andreasvb   Select the time and then rightclick your new entry...   Nov 18 2006, 19:18
|- - wolfsong   QUOTE (Andreasvb @ Nov 18 2006, 12:18) Se...   Nov 18 2006, 19:27
- - Andreasvb   Strange, sure you have the new version?   Nov 18 2006, 19:37
|- - wolfsong   QUOTE (Andreasvb @ Nov 18 2006, 12:37) St...   Nov 18 2006, 19:40
- - hal9001   Dl link for 3.1 brings a corrupt ZIPfile EDIT: c...   Nov 19 2006, 08:41
- - andrew_smolko   Seems to be the hosting problems. I've changed...   Nov 19 2006, 11:42
- - jaslr   This could be completely the wrong component to be...   Nov 20 2006, 03:23
|- - Melomane   QUOTE (jaslr @ Nov 20 2006, 03:23) This c...   Nov 22 2006, 11:41
- - francesco   and for 0.8 nothing of similar?   Nov 20 2006, 12:06
- - kalmark   I have a bug to report, I think. Not tested with 3...   Nov 20 2006, 12:24
|- - andrew_smolko   QUOTE (kalmark @ Nov 20 2006, 14:24) I ha...   Nov 20 2006, 20:34
|- - kalmark   QUOTE (andrew_smolko @ Nov 20 2006, 21:34...   Nov 22 2006, 08:55
- - eisteh   QUOTE (jaslr @ Nov 20 2006, 03:23) This c...   Nov 20 2006, 13:17
- - maxtail   Hello, sorry for my poor English, but I'd like...   Nov 22 2006, 14:59
|- - andrew_smolko   QUOTE (maxtail @ Nov 22 2006, 16:59) Hell...   Nov 22 2006, 15:58
- - Lexee   I create a scheduler event and when it starts Foob...   Nov 23 2006, 08:49
|- - andrew_smolko   QUOTE (Lexee @ Nov 23 2006, 10:49) I crea...   Nov 23 2006, 10:17
- - Lexee   Yes, you're right I created "once time...   Nov 23 2006, 13:43
- - andrew_smolko   3.5 RC! This is release candidate version. Eve...   Nov 23 2006, 14:27
- - eisteh   The new interface is a bit strange at first sight,...   Nov 23 2006, 16:08
- - fabiospark   Can we choose the IDs (menu and actions) from a li...   Nov 24 2006, 11:26
- - xhandler   Love this one.. use it instead of radio alarm.. wh...   Nov 24 2006, 12:13
- - LTourist   The return of foo_scheuler is a great news!...   Nov 24 2006, 12:29
- - gren   huythuy, your first request seems to me like it w...   Nov 25 2006, 11:53
6 Pages V   1 2 3 > »
RSS Lo-Fi Version Time is now: 27th April 2015 - 07:36
