What is "time resolution"?
Axon
post Oct 5 2006, 21:50
Group: Members (Donating)
So I've become involved in a rather colorful argument (I'm Publius in the thread) with somebody on stevehoffman.tv. The original thread revolved around shooting down an old audiophile canard, about how subsample delays cannot be represented in PCM. In the course of that debate, I've begun to question a couple things.
  • Is it ever accurate to use the term "time resolution" in any sort of technical context? To the best of my knowledge, it has no universally agreed upon technical definition. Most of the times I've seen it used are either for SACD/DVD-A marketing fluff, or to describe FFT window lengths. I'm tempted to just go quasi-logical-positivist on everybody and say that it is a completely meaningless phrase.
  • Is there any meaningful time-domain constraint on audio quality that is directly related to the sampling period? Subsample delays (as I've shown above) are not meaningfully related. Bandwidth is a frequency-domain attribute. Pre-echo potentially gets more audible at lower sampling rates, but this is not a concern with sigma-delta ADCs, and it is of debatable audibility at 44.1 to begin with. Some DSP operations may be harder to implement at lower sample rates, but most of the issues involve seem implementation-related. I'm suspecting that there are no clear general limits as to what can and cannot be accomplished in PCM, except with respect to very domain-specific or system-specific situations; and so any claims of 44khz always being limited in ways different from bandwidth may be regarded with skepticism.
2Bdecided
post Oct 6 2006, 10:30
ReplayGain developer
ChiGung,
You can prove sub-sample time domain accuracy using a simple single impulse (or conceptually, a Dirac Delta or Dirac pulse). In a correct system, you can show that the location of the inter-sample peak matches that of the original impulse, even though the pulse itself will be spread out (due to the band limiting).
The reference to periodic functions doesn't mean that sub-sample accuracy doesn't work for any other signal! The sub-sample inter-channel delay of sine waves is a nice example, but you can do just the same thing with a single impulse.
While we're avoiding mathematics, and getting by with examples and hand-waving concepts, consider this: since it works for theoretical infinitely long sine waves, and for theoretical infinitely short impulses, and for practical length "longish" sine waves and for practical length "shortish" impulses (i.e. both theoretical and practical extremes!), that should alert you to the fact that it probably works for any signal in between - including any real world signal.
This post has been edited by 2Bdecided: Oct 6 2006, 10:32
ChiGung
post Oct 6 2006, 16:32
We're assuming the signal is band limited, so we absolutely can exactly locate your spike.
You are all assuming that and confidently browbeating with resulting certainties.
It is not a valid assumption > for defining PCMs capabalities of accurately reproducing source.
The term 'source' is meaningless if it cannot differ in detail from 'record'
Of course if the source is known to be bandlimited suitably, the PCM record of it is perfectly complete - there is nothing to discuss in this case. With the precondition that the source is already suitably bandlimited, any samplerate can precisely store any such compliant source -that is not news to me.
I cant believe the loose reasoned, ignorance assuming flack Im taking here....
Corrections about whenever 'jitter' was first transiently refered to in the other thread? wacko.gif
Please gimme a break.
Its probably not worth it for me to explain anything again - cause it will be read with such presumption of error that any realisations possible will not make it from the readers page to their predisposed mind.
QUOTE (me)
...such 'delay' is no definite attribute of the undownsampled source, it is an attribute summed circumspectly from the phases of frequencies surviving the downsample. The frequencies which didnt survive the downsample, contained the information required to resolve the true subsample detail of 'time localised energy spikes'.
How stupid do you guys suppose I am if I was talking about a suitably bandlimited source there? Is it ambiguity about the term 'undownsampled?' -If I meant 'upsampled record' I would could have used that simpler term. Does 'undownsampled source' not translate to 'a source which was not downsampled' -therefore being capable of holding higher frequency detail than the downsampled one? I dont think there is any real ambiguity there, or too much following to figure out what I am actualy talking about.
I am talking about aspects of PCMs resolution of unassumable sources. Like how accurately 16kHz samplerate record could render localised details a 44~kHz record on a CD could render, or how accurately CDs format, could render details which the mastering formats used in production process could render. Why is that a strange interpratation of the term 'resolution' with regads to the capabilities of a digital format?
When you guys ponder the resolution of a digital camera, do you say it perfectly records what it is pointed at if you take pictures out of focus? Yes it might record the 'out of focus picture perfectly precisely', how in focus does the picture need to be before the digitised record of it neccessarily looses information and is therefore an imprecise record of? Most fundamentaly, how accurately can the digitised record be used to render the actual 'scene', with its near infinite complexety emergent from the natural universe?
You know Im obviously talking about somethings which many of you have not considered before. Then you might benefit from reading my points properly instead of the hypercritical attention shown so far.
Good luck with that'
edit: paranoid disambiguations
This post has been edited by ChiGung: Oct 6 2006, 16:37
no conscience > no custom
krabapple
post Oct 6 2006, 16:54
QUOTE (ChiGung @ Oct 6 2006, 11:32) *
Perhaps it's bias, but I don't see what was either poorly reasoned, or ignorant, about pointing out your mistake re: when jitter entered the SHtv thread.
All of those sources are bandwidth-limited, of course.
You flatter yourself.
You don't appear to take correction well. I suggest you get used it...particularly as you've implied, in the SHtv thread, and here, that Nyquist/Shannon is in need of significant revision. That constitutes an extraordinary claim, and you are going to have to present an extraordinarily well-supported case to back it up. And your writing is going to have to be much, much more clear. Good luck with that.
But perhaps for starters, you can describe in much more detail the attributes of the 'unassumable sources' you are talking about. In what sense are they NOT bandlimited?
This post has been edited by krabapple: Oct 6 2006, 16:55
ChiGung
post Oct 6 2006, 17:08
Im not taking criticism well at this point, because Ive been at this for many posts now.
Look. A 44kHz record is bandlimited at 22kHz right? A 22kHz record is bandlimited at 11kHz. A downsample from 44 to 22kHz looses the information for the band 22kHz to 11kHz.....r i g h t ?
If we could all assume that when we downsample, all the information information involved is already suitably bandlimited, that would be an easy world where we could make the claim that 'time resoltuion of PCM' is near as hey perfect -and make it stick. But it is for the very reason that that is an unrealistic assumption, that lowpassing (removing of high frequency energy) is required during good quality downsampling conversion.
Specificaly, yes you can say (and I have said it) that a records information is implicitly bandlimited. But you cannot say that it is therefore bandlimited enough to losslessly survive any following downsamples.
I said common reports and opinions drawn from it where.
Trying to get back to the topic>
Ask yourself:
"is there any meaningful space-domain constraint on visual quality that is directly related to the pixel width"
This post has been edited by ChiGung: Oct 6 2006, 17:23
MedO
post Oct 7 2006, 10:43
QUOTE (ChiGung @ Oct 6 2006, 18:08) *
Right.
Yes. Frequencies present above 11khz will have to be filtered out before downsampling and cannot be preserved in this case.
I don't think anyone here assumed downsampling is always lossless.
Ask yourself:
No, there isn't. You can have peaks in image data at any(*) position between the pixels.
*assuming arbitrary bitdepth.
This post has been edited by MedO: Oct 7 2006, 10:44
- Axon   What is "time resolution"?   Oct 5 2006, 21:50
- - benski   Subsample delays are relatively easy to implement ...   Oct 5 2006, 22:04
- - Axon   Well, duh. I showed in that thread that 1/20,000 ...   Oct 5 2006, 22:19
- - krabapple   QUOTE (Axon @ Oct 5 2006, 16:50) So I...   Oct 5 2006, 22:28
- - Mike Giacomelli   QUOTE (Axon @ Oct 5 2006, 13:50) Is it ev...   Oct 5 2006, 22:57
- - ChiGung   Yo, that was me (felimid) QUOTE Is there any meani...   Oct 5 2006, 23:07
|- - Axon   QUOTE (ChiGung @ Oct 5 2006, 17:07) Yo, t...   Oct 6 2006, 00:11
|- - legg   AFAIK, time resolution is most commonly used to re...   Oct 6 2006, 00:28
- - Woodinville   QUOTE (Axon @ Oct 5 2006, 13:50) So I...   Oct 5 2006, 23:20
|- - ChiGung   QUOTE ("woodinville")The first issue is ...   Oct 6 2006, 00:46
|- - Mike Giacomelli   QUOTE (ChiGung @ Oct 5 2006, 16:46) QUOTE...   Oct 6 2006, 02:10
||- - ChiGung   QUOTE (Mike Giacomelli @ Oct 6 2006, 02:1...   Oct 6 2006, 04:30
||- - Mike Giacomelli   QUOTE (ChiGung @ Oct 5 2006, 20:30) QUOTE...   Oct 6 2006, 06:27
|- - krabapple   QUOTE (ChiGung @ Oct 5 2006, 19:46) QUOTE...   Oct 6 2006, 06:21
|- - Woodinville   QUOTE (ChiGung @ Oct 5 2006, 16:46) Howev...   Oct 6 2006, 08:26
- - Woodinville   Well, considered for Guassian vs. Gaussian, dt * ...   Oct 6 2006, 00:35
- - kjoonlee   Does "higher sampling rates mean higher tempo...   Oct 6 2006, 00:47
|- - ChiGung   QUOTE (kjoonlee @ Oct 6 2006, 00:47) Does...   Oct 6 2006, 00:57
|- - kwwong   QUOTE (ChiGung @ Oct 5 2006, 18:57) QUOTE...   Oct 7 2006, 05:12
- - 2Bdecided   ChiGung, You can prove sub-sample time domain acc...   Oct 6 2006, 10:30
|- - ChiGung   QUOTE We're assuming the signal is band limite...   Oct 6 2006, 16:32
|- - krabapple   QUOTE (ChiGung @ Oct 6 2006, 11:32) I can...   Oct 6 2006, 16:54
||- - ChiGung   QUOTE But perhaps for starters, you can describe i...   Oct 6 2006, 17:08
||- - krabapple   QUOTE (ChiGung @ Oct 6 2006, 12:08) QUOTE...   Oct 6 2006, 21:11
||- - MedO   QUOTE (ChiGung @ Oct 6 2006, 18:08) Look....   Oct 7 2006, 10:43
|- - Mike Giacomelli   QUOTE (ChiGung @ Oct 6 2006, 08:32) QUOTE...   Oct 6 2006, 20:54
- - Axon   Okay, so this has gone completely f*cking off topi...   Oct 6 2006, 17:49
|- - krabapple   QUOTE (Axon @ Oct 6 2006, 12:49) Okay, so...   Oct 6 2006, 20:51
- - Canar   QUOTE Ask yourself: "is there any meaningful ...   Oct 6 2006, 21:20
- - Canar   Exactly, kwwong. ChiGung, consider this: In the co...   Oct 7 2006, 08:04
- - cabbagerat   QUOTE (MedO @ Oct 7 2006, 01:43) No, ther...   Oct 7 2006, 18:00
|- - MedO   QUOTE That assumption is a bit of a problem, in my...   Oct 7 2006, 18:42
- - cabbagerat   QUOTE (MedO @ Oct 7 2006, 09:42) Of cours...   Oct 7 2006, 20:57
|- - ChiGung   QUOTE (MedO @ Oct 7 2006, 09:42) Of cours...   Oct 7 2006, 23:18
|- - MedO   QUOTE (ChiGung @ Oct 8 2006, 00:18) the p...   Oct 8 2006, 00:13
|- - ChiGung   QUOTE (MedO @ Oct 8 2006, 00:13) QUOTE (C...   Oct 8 2006, 00:28
- - Canar   ChiGung, it is increasingly apparent you are not i...   Oct 8 2006, 00:26
- - Canar   I've provided a mathematical example of why yo...   Oct 8 2006, 01:05
- - cabbagerat   For your viewing pleasure, here's a quick demo...   Oct 8 2006, 08:07
|- - ChiGung   QUOTE (cabbagerat @ Oct 8 2006, 08:07) Fo...   Oct 8 2006, 15:02
- - Canar   So because sinc() interpolation is weird, PCM fail...   Oct 8 2006, 15:28
- - cabbagerat   QUOTE (ChiGung @ Oct 8 2006, 06:02) This ...   Oct 8 2006, 15:51
|- - ChiGung   QUOTE (cabbagerat @ Oct 8 2006, 15:51) I ...   Oct 8 2006, 16:10
- - KikeG   As others have said, time resolution of PCM is the...   Oct 8 2006, 17:59
|- - ChiGung   QUOTE (KikeG @ Oct 8 2006, 17:59) As othe...   Oct 8 2006, 18:14
|- - KikeG   QUOTE (ChiGung @ Oct 8 2006, 18:14) So yo...   Oct 8 2006, 18:24
||- - ChiGung   QUOTE (KikeG @ Oct 8 2006, 18:24) Resolut...   Oct 8 2006, 18:55
|- - Woodinville   QUOTE (ChiGung @ Oct 8 2006, 10:14) So yo...   Oct 8 2006, 19:37
|- - ChiGung   QUOTE (Woodinville @ Oct 8 2006, 19:37) Y...   Oct 8 2006, 19:57
|- - Woodinville   QUOTE (ChiGung @ Oct 8 2006, 11:57) Yeah ...   Oct 9 2006, 18:00
- - Canar   ChiGung, despite your frequent reassertions to the...   Oct 8 2006, 20:08
|- - ChiGung   QUOTE (Canar @ Oct 8 2006, 20:08) I would...   Oct 8 2006, 20:28
|- - ChiGung   I think that it is being claimed, almost unanimous...   Oct 8 2006, 21:44
|- - legg   QUOTE (ChiGung @ Oct 8 2006, 15:44) I hav...   Oct 9 2006, 01:32
||- - ChiGung   QUOTE (legg @ Oct 9 2006, 01:32) QUOTE (C...   Oct 9 2006, 02:16
|- - 2Bdecided   QUOTE (ChiGung @ Oct 8 2006, 21:44) The e...   Oct 9 2006, 15:08
- - legg   Fine forget about the code and do try to provide m...   Oct 9 2006, 03:27
|- - MedO   If I understand you right, you are saying that the...   Oct 9 2006, 09:35
|- - ChiGung   Hello all, I left this discussion in a tizz and ha...   Nov 15 2006, 01:16
|- - kwwong   QUOTE (ChiGung @ Nov 14 2006, 19:16) 44kH...   Nov 15 2006, 09:50
|- - kwwong   QUOTE (kwwong @ Nov 15 2006, 03:50) QUOTE...   Nov 16 2006, 10:24
- - 2Bdecided   Here are some nice pictures... I worked at 16-b...   Oct 9 2006, 15:24
- - cabbagerat   QUOTE (2Bdecided @ Oct 9 2006, 06:08) It...   Oct 9 2006, 16:54
- - Axon   So I was mainly pissed off in my earlier post beca...   Oct 9 2006, 17:30
|- - Woodinville   QUOTE (Axon @ Oct 9 2006, 09:30) The form...   Oct 9 2006, 18:41
- - 2Bdecided   ChiGung, Your experiment wouldn't work. By kn...   Nov 15 2006, 13:00
|- - ChiGung   QUOTE (2Bdecided @ Nov 15 2006, 12:00) .....   Nov 15 2006, 13:45
- - 2Bdecided   So, in short, you want to run an experiment to see...   Nov 15 2006, 14:29
|- - ChiGung   QUOTE (2Bdecided @ Nov 15 2006, 13:29) So...   Nov 15 2006, 14:45
|- - Woodinville   QUOTE (ChiGung @ Nov 15 2006, 05:45) QUOT...   Nov 15 2006, 19:42
|- - ChiGung   QUOTE (Woodinville @ Nov 15 2006, 18:39) ...   Nov 15 2006, 19:56
||- - Woodinville   QUOTE (ChiGung @ Nov 15 2006, 10:56) Nice...   Nov 15 2006, 20:01
||- - ChiGung   QUOTE (Woodinville @ Nov 15 2006, 19:01) ...   Nov 15 2006, 20:30
||- - AstralStorm   QUOTE (ChiGung @ Nov 15 2006, 20:30) It i...   Nov 15 2006, 22:43
||- - 2Bdecided   QUOTE (ChiGung @ Nov 15 2006, 20:30) Im f...   Nov 16 2006, 14:22
||- - ChiGung   QUOTE (2Bdecided @ Nov 16 2006, 13:22) My...   Nov 16 2006, 17:10
||- - SebastianG   QUOTE (ChiGung @ Nov 16 2006, 17:10) The ...   Nov 16 2006, 18:22
||- - ChiGung   QUOTE (SebastianG @ Nov 16 2006, 17:22) Q...   Nov 16 2006, 18:51
||- - Woodinville   QUOTE (ChiGung @ Nov 16 2006, 09:51) I be...   Nov 16 2006, 22:48
||- - ChiGung   QUOTE (Woodinville @ Nov 16 2006, 21:48) ...   Nov 16 2006, 23:32
||- - Woodinville   QUOTE (ChiGung @ Nov 16 2006, 14:32) ...   Nov 16 2006, 23:44
||- - ChiGung   QUOTE (Woodinville @ Nov 16 2006, 22:44) ...   Nov 17 2006, 00:15
|- - ChiGung   QUOTE (Woodinville @ Nov 15 2006, 18:42) ...   Nov 15 2006, 20:14
|- - Garf   QUOTE (ChiGung @ Nov 15 2006, 20:14) The ...   Nov 15 2006, 20:18
|- - Woodinville   QUOTE (ChiGung @ Nov 15 2006, 11:14) Im n...   Nov 15 2006, 23:35
|- - ChiGung   QUOTE (Woodinville @ Nov 15 2006, 22:35) ...   Nov 16 2006, 01:20
- - cabbagerat   QUOTE (ChiGung @ Nov 15 2006, 05:45) It i...   Nov 15 2006, 15:22
|- - ChiGung   QUOTE (cabbagerat @ Nov 15 2006, 14:22) T...   Nov 15 2006, 15:51
- - 2Bdecided   I wish you understood the theory CG, because witho...   Nov 15 2006, 16:18
|- - ChiGung   QUOTE (2Bdecided @ Nov 15 2006, 15:18) It...   Nov 15 2006, 17:01
|- - 2Bdecided   QUOTE (ChiGung @ Nov 15 2006, 17:01) QUOT...   Nov 15 2006, 18:06
|- - ChiGung   QUOTE (2Bdecided @ Nov 15 2006, 17:06) Yo...   Nov 15 2006, 18:31
- - SebastianG   I also don't see the point in checking the pos...   Nov 15 2006, 16:48
|- - ChiGung   QUOTE (SebastianG @ Nov 15 2006, 15:48) I...   Nov 15 2006, 17:16
- - SebastianG   I happened to code a subpixel detector for "x...   Nov 15 2006, 17:30
|- - ChiGung   QUOTE (SebastianG @ Nov 15 2006, 16:30) I...   Nov 15 2006, 17:53
|- - SebastianG   QUOTE (ChiGung @ Nov 15 2006, 17:53) It w...   Nov 15 2006, 17:59
|- - ChiGung   QUOTE (SebastianG @ Nov 15 2006, 16:59) Q...   Nov 15 2006, 18:21
- - MoSPDude   I've been trying to follow this as well, and e...   Nov 17 2006, 00:21
- - Woodinville   QUOTE (MoSPDude @ Nov 16 2006, 15:21) If ...   Nov 17 2006, 00:40
2 Pages V   1 2 >
RSS Lo-Fi Version Time is now: 6th March 2015 - 21:52
