LAME 3.97: different binaries produce differente results!, bizarre: different LAME 3.97 binaries produce differente results!
Adriano
post Oct 4 2006, 02:33
Hi.
I was VERY surprised to find out that different binaries for LAME 3.97, namely Rarewaves [1] and Mitiok [2], produce differente results, i.e, different mp3 files.
[1] http://www.rarewares.org/dancer/dancer.php?f=109
[2] http://mitiok.maresweb.org/dancer/dancer.php?f=3
Maybe that has something to do with "Recompiled to include mp2 decoding which was omitted, in error, in the original compile", which relates to Rarewaves link? Well, anyway it's not how it was supposed to be. I am currently using Mitiok binary, which is smaller and seems to be slightly faster.
Any clarification is very welcome.
Regards,
Adriano
Only to exemplify...
Mitiok:
LAME 3.97 32bits (http://www.mp3dev.org/)
CPU features: MMX (ASM used), 3DNow! (ASM used), SSE (ASM used), SSE2
Using polyphase lowpass filter, transition band: 18671 Hz - 19205 Hz
Encoding Filū Machado - Tema pro Macumbinha [116-1100 Hz].wav
to Filū Machado - Tema pro Macumbinha [116-1100 Hz].wav.mp3
Encoding as 44.1 kHz VBR(q=2) single-ch MPEG-1 Layer III (ca. 7.3x) qval=3
Frame | CPU time/estim | REAL time/estim | play/CPU | ETA
2846/2846 (100%)| 0:03/ 0:03| 0:04/ 0:04| 18.884x| 0:00
32 [ 6] *
40 [ 0]
48 [ 0]
56 [ 11] *
64 [ 63] ****
80 [ 697] **************************************
96 [1264] ********************************************************************
112 [ 551] ******************************
128 [ 162] *********
160 [ 90] *****
192 [ 2] *
224 [ 0]
256 [ 0]
320 [ 0]
kbps mono % long switch short %
98.1 100.0 91.4 3.3 5.3
Writing LAME Tag...done
ReplayGain: -3.4dB
vs. Rarewaves:
2846/2846 (100%)| 0:03/ 0:03| 0:03/ 0:03| 18.656x| 0:00
32 [ 6] *
40 [ 0]
48 [ 0]
56 [ 10] *
64 [ 60] ****
80 [ 696] **************************************
96 [1272] ********************************************************************
112 [ 549] ******************************
128 [ 163] *********
160 [ 87] *****
192 [ 3] *
224 [ 0]
256 [ 0]
320 [ 0]
ReplayGain: -3.4dB
This post has been edited by db1989: Sep 8 2011, 15:39
Reason for edit: adding codeboxes
kjoonlee
post Oct 4 2006, 14:03
Because it happens all the time with floating-point calculations and nobody is complaining, usually?
Look at the real results. 3703 vs. 3691 192kbps frames.
http://blacksun.ivyro.net/vorbis/vorbisfaq.htm
RSS Lo-Fi Version Time is now: 4th August 2015 - 20:05
