3 Pages V   1 2 3 >
foobar2000 v0.9.4, Final
Andreasvb
post Sep 23 2006, 18:11
Properties dialog improvements
Startup/shutdown speed optimizations
Added LAME version and partial settings detection for MP3 files
Replaced old “Fix MP3 Header” command with a new set of MP3-related utility commands
“ID3v2 Writer Compatibility Mode” with workarounds for common bugs in other software’s ID3v2 implementations
“Copy” button in components list
freedb support now included with the installer
Rewritten embedded cuesheet metadata handling
Rewritten ReplayGain info editor dialog
ABX bugfixes
Added WMA tag editing support
Get it: http://www.foobar2000.org
Windows 8.1u3 Pro x64 Media Center // foobar2000 1.3.7
Cutter
post Sep 23 2006, 18:14
lextune
post Sep 23 2006, 18:46
<----dumb.
(ie: Figured it out. tongue.gif )
This post has been edited by lextune: Sep 24 2006, 16:00
foobar2000 + EAC + Burrrn = Happiness
SwiftBass
post Sep 23 2006, 19:48
just DLed it, and sry if I missed it but it seems like I cant use the album list as a panel anymore. do i have to DL something else or is it something I I missed?
Yotsuya
post Sep 23 2006, 19:55
lextune:
My trackinfomod panels still appear to be functioning properly, can you be more specific about what you mean by broken
SwiftBass:
My albumlist panel also still appears to work. In fact I just recently started using it because foo_browser was having a devistating affect on my startup times.
This post has been edited by Yotsuya: Sep 23 2006, 19:57
http://www.ubuntu.com
sitemap
post Sep 23 2006, 20:02
- r3mix recognition does not work (tested with Lame 3.91 & 3.92)
- on some live mp3s I have cut off the end applause; codec_profile is not available for those
- enc_delay and enc_padding in 0.9.1:
in 0.9.4:
Northpole
post Sep 23 2006, 21:54
Is it just me...But v0.9.4 continues to run after exiting the program. I am running winxp on P4. Foobar shows up in the task manager list after quiting program. If you run foobar again, it seams to start a new instance. So when you check task manager after exiting the second time, there are two listing for foobar.
v0.9.3.1 works OK.
jonpb
post Sep 24 2006, 00:00
Does the installer upgrade from 0.9.3.1? or should I uninstall first? If I uninstall, do I lose all my configs?
Purple Monkey
post Sep 24 2006, 01:06
I didn't have any adverse problems installing over 0.9.3.1 so its probably ok. As always though make sure all your components are updated.
Paws
post Sep 24 2006, 01:09
I install over the current version that i had... 0.9.4 beta 3 and i didnt uninstall i just put the final 0.9.4 and installed that with no porblems lost nothing.
Sphix
post Sep 24 2006, 01:51
-foobar2000 + Burrrn + EAC
-HD 80Gb using High QualityVBR MP3s
zmur
post Sep 24 2006, 01:55
thanks for new version biggrin.gif everything works perfectly
thuan
post Sep 24 2006, 03:33
Just wanna say thanks works great here.
DeepDose
post Sep 24 2006, 06:29
@ jonpb, you can just install right over it, just make sure "enable per-user settings" is not checked, it'll save your settings then. But it's always good to just backup anyways, you can do that by copying the foobar2000 program file folder and putting it somewhere else. Install and updated working fine for me, thx.
Zelphar
post Sep 24 2006, 08:07
Post #15
It semms some times foobar will crash when edit tags on Properties dialog
CR1M1N4L
post Sep 24 2006, 08:23
Post #16
QUOTE (Zelphar @ Sep 24 2006, 09:07) *
Yes, I also noticed that. When I edit tags and song changes, foobar crashes crying.gif
david_dl
post Sep 24 2006, 08:34
Post #17
QUOTE (Zelphar @ Sep 24 2006, 20:07) *
You should post this in a new thread, with specifics, such as exactly what you did to cause the crash, and the crashlog.
Squeller
post Sep 24 2006, 09:52
Post #18
QUOTE (Northpole @ Sep 23 2006, 12:54) *
I've seen this exactly the same on a win2000 computer/ fb2k 0.94b3. But I didn't hunt it down (it's also possible this was caused by a plugin, as I added some new of them). After a restart everything was fine...
Infernus
post Sep 24 2006, 11:25
Post #19
Group: Banned
QUOTE (Northpole @ Sep 23 2006, 22:54) *
v0.9.3.1 works OK.
lifesinger
post Sep 24 2006, 13:21
Post #20
QUOTE (Northpole @ Sep 24 2006, 04:54) *
v0.9.3.1 works OK.
maybe foo_dsp_headphones.dll causes it
Squeller
post Sep 24 2006, 13:30
Post #21
I haven't both.
Core (2006-09-23 16:18:46)
foobar2000 core v0.9.4
foo_abx.dll (2006-09-23 16:17:38)
ABX Comparator 1.3.1
foo_autoplaylist.dll (2006-08-04 21:56:56)
Autoplaylist Manager 1.0
foo_cdda.dll (2006-09-23 16:17:20)
CD Audio Decoder 2.1.1
foo_cmd_playlist.dll (2006-08-05 13:17:08)
Playlist Commandline Tools 0.0.1
foo_common.dll (2006-03-11 19:23:54)
Common services 0.1
foo_converter.dll (2006-09-23 16:17:02)
Converter 1.0.1
foo_cwb_hooks.dll (2006-09-22 17:02:26)
cwbowron's title format hooks 1.0.11 [Sep 22 2006 - 17:01:48]
foo_dsp_continuator.dll (2006-04-14 19:18:20)
Continuator 0.4.0
foo_dsp_delta.dll (2006-03-21 18:16:22)
LPCM <--> delta-PCM converter 0.1.1
foo_dsp_std.dll (2006-09-23 16:17:30)
Standard DSP array 1.0
foo_dsp_vlevel.dll (2006-04-25 11:17:44)
VLevel 20060324.0
foo_freedb2.dll (2006-08-29 20:43:04)
freedb Tagger 0.5.2a
foo_fullscreen.dll (2006-04-01 23:10:14)
Fullscreen 0.3.1
foo_input_monkey.dll (2006-08-04 21:57:00)
Monkey's Audio decoder 2.1.1
foo_input_std.dll (2006-09-23 16:17:02)
FLAC decoder 1.1.0
Standard Input Array 1.0
WMA Decoder 1.1
foo_masstag.dll (2006-09-23 16:16:28)
Masstagger 1.6
foo_menu_addons.dll (2006-09-23 07:52:00)
Menu Addons 0.3.4
foo_playlist_bind.dll (2006-04-06 15:52:24)
Playlist Bind 2.2
foo_playlist_manager.dll (2006-03-13 00:25:14)
Playlist Manager 1.0
foo_pqview.dll (2006-03-13 00:23:28)
foo_random.dll (2006-03-13 11:35:02)
Randomized playlist entry 1.2.3
foo_rgscan.dll (2006-09-23 16:16:14)
ReplayGain Scanner 2.0.2
foo_runcmd.dll (2006-07-25 11:38:00)
Run Command 1.0 beta 1
foo_sic.dll (2006-08-22 12:55:00)
foosic music database 1.0 beta 11
foo_ui_columns.dll (2006-09-08 13:14:31)
Columns UI 0.1.3 beta 1v6 TEST
foo_ui_std.dll (2006-09-23 16:16:08)
Default User Interface 0.9acc
foo_uie_bookmarks.dll (2006-09-15 00:26:00)
Bookmarks 0.0.5.2
foo_uie_explorer.dll (2006-07-06 22:43:30)
Explorer Tree 1.04.6b
foo_uie_queuemanager.dll (2006-08-26 09:16:58)
Queue manager panel 0.2.1
foo_uie_quicksearch.dll (2006-08-27 15:13:00)
Quick Search Toolbar 2.8h
foo_uie_tabs.dll (2006-07-08 04:18:32)
Tabbed panel modifyed 0.2.1
foo_uie_trackinfo.dll (2006-07-25 04:30:16)
Track info panel 0.82
foo_uie_trackinfo_mod.dll (2006-08-30 16:36:18)
Track info panel mod 0.5 beta [Aug 30 2006 - 16:35:44]
foo_unpack.dll (2006-09-23 16:17:50)
RAR reader 1.1
ZIP/GZIP reader 1.0
foo_utils.dll (2006-04-27 12:37:32)
Playlist tools 0.5.7
Northpole
post Sep 24 2006, 15:02
Post #22
QUOTE (Infernus @ Sep 24 2006, 05:25) *
I do have foo_dsp_atsurround installed but not foo_dsp_headphones. I'll try it again later without and post back. Thanks.
SwiftBass
post Sep 24 2006, 18:41
Post #23
silly me. all of my uodates have left my components intact so i guess that albumlist.dll was not a default. it was the first dll i downloaded and i guess i forgot to DL one. sry bout that
evil_hacler
post Sep 24 2006, 20:28
Post #24
I lost everything. No I have to redo hours of work. :(
EDIT
WOOHO!!
SYSTEM RESTORE + deleting user_profiles_enabled.
This post has been edited by evil_hacler: Sep 21 2007, 14:20
4nt1
post Sep 24 2006, 23:04
Post #25
works like a charm here - great work peter as usual - any idea whats installed for 0.9.5?
3 Pages V   1 2 3 >
RSS Lo-Fi Version Time is now: 21st April 2015 - 08:09
