2 crash logs, 0.9.4.b1 @ foo_input_std.dll
roentgen
post Sep 11 2006, 23:17
Illegal operation:
Code: C0000005h, flags: 00000000h, address: 013613C1h
Access violation, operation: read, address: FFFFFFFFh
Call path:
queued_process=>input_decoder::run
Code bytes (013613C1h):
01361381h: E7 08 0B F8 C1 EA 08 33 D0 33 C0 8A E1 83 C5 01
01361391h: 83 EB 08 66 33 04 55 48 C7 3F 01 83 6C 24 0C 01
013613A1h: 66 89 46 20 89 6E 14 75 C6 8B 6C 24 18 85 DB 76
013613B1h: 1B 8B 4E 14 8B 16 0F B6 04 11 B9 08 00 00 00 2A
013613C1h: CB D3 E8 8B CB D3 E7 89 5E 18 0B F8 01 6E 1C B9
013613D1h: 20 00 00 00 2B CD 74 44 D3 E7 B8 01 00 00 00 D3
013613E1h: FF 8B 4C 24 14 89 39 5F 5D 5B 59 C3 5F 5D 33 C0
013613F1h: 5B 59 C3 0F B6 3C 39 8B C8 BB FF 00 00 00 D3 FB
Stack (018BF728h):
018BF708h: 00000000 00000000 00000000 00000000
018BF718h: F748EB28 00000004 00000001 F748F000
018BF728h: 04C63AA8 00000005 04C48DA8 000000B5
018BF738h: 0135D932 018BF758 00000005 04C48DA8
018BF748h: 04C48DA8 00000000 00000000 00000005
018BF758h: 00000576 00000005 0000001C 0135D5D3
018BF768h: 00000000 00000010 0000000B 0000001C
018BF778h: 04C48DA8 00000000 018BF7B4 00000048
018BF788h: 00000000 0135CAC3 00000000 00000010
018BF798h: 04C48DA8 04C48D48 018BF7BC 017B22E4
018BF7A8h: 0135B7D9 018BF7B4 04C27BE8 00000000
018BF7B8h: 018BF900 018BF808 0130CB3F 04C27BF0
018BF7C8h: 04C27BE8 0130C6A9 017B22E4 04C45848
018BF7D8h: 018BF900 7C9106EB 0175E949 00000000
018BF7E8h: 04C27BF0 00168650 01775274 10002D87
018BF7F8h: 00168668 018BF840 013C1DA8 00000000
018BF808h: 018BF9B0 0130A0E7 018BF93C 017B22E4
018BF818h: 018BF8F8 0174D5E3 018BF93C 017B22E4
018BF828h: CF14A055 018BF900 0000000E 01742F5E
018BF838h: 018BF840 018BF97C 018BF9A4 0176EFC9
Registers:
EAX: 0000007B, EBX: 00000001, ECX: 00000B39, EDX: 04C73FF8
ESI: 0143B9C8, EDI: 00000005, EBP: 00000005, ESP: 018BF728
Crash location: "foo_input_std", loaded at 01300000h - 01412000h
Loaded modules:
foobar2000 loaded at 00400000h - 004F3000h
ntdll loaded at 7C900000h - 7C9B0000h
kernel32 loaded at 7C800000h - 7C8F4000h
COMCTL32 loaded at 773D0000h - 774D2000h
msvcrt loaded at 77C10000h - 77C68000h
ADVAPI32 loaded at 77DD0000h - 77E6B000h
RPCRT4 loaded at 77E70000h - 77F01000h
GDI32 loaded at 77F10000h - 77F57000h
USER32 loaded at 77D40000h - 77DD0000h
SHLWAPI loaded at 77F60000h - 77FD6000h
SHELL32 loaded at 7C9C0000h - 7D1D5000h
ole32 loaded at 774E0000h - 7761D000h
shared loaded at 10000000h - 10029000h
comdlg32 loaded at 763B0000h - 763F9000h
uxtheme loaded at 5AD70000h - 5ADA8000h
UnlockerHook loaded at 00A40000h - 00A44000h
foo_2hyperim loaded at 00A50000h - 00A6F000h
foo_abx loaded at 00A80000h - 00AB3000h
foo_ac3 loaded at 00AE0000h - 00B0B000h
foo_albumlist loaded at 00B30000h - 00B70000h
foo_audioscrobbler loaded at 00B90000h - 00BC7000h
WS2_32 loaded at 71AB0000h - 71AC7000h
WS2HELP loaded at 71AA0000h - 71AA8000h
foo_autoplaylist loaded at 00BF0000h - 00C20000h
foo_bitcompare loaded at 00C40000h - 00C66000h
foo_burninate loaded at 00C90000h - 00CC7000h
VERSION loaded at 77C00000h - 77C08000h
foo_cdda loaded at 00CF0000h - 00D26000h
foo_channel_mixer loaded at 00D50000h - 00D8A000h
foo_common loaded at 00DA0000h - 00DDA000h
foo_converter loaded at 00E00000h - 00E69000h
foo_cuesheet_creator loaded at 00E90000h - 00EBD000h
foo_cwb_hooks loaded at 00EE0000h - 00F08000h
foo_dbsearch loaded at 00F30000h - 00FA5000h
OLEAUT32 loaded at 77120000h - 771AC000h
foo_dsp_bs2b loaded at 00FD0000h - 00FEE000h
foo_dsp_delta loaded at 01010000h - 0102E000h
foo_dsp_skip_silence loaded at 01050000h - 0105A000h
MSVCR80 loaded at 78130000h - 781CB000h
foo_dsp_std loaded at 01080000h - 010C1000h
foo_freedb2 loaded at 010F0000h - 01130000h
foo_input_dts loaded at 01150000h - 011B5000h
foo_input_matroska loaded at 011E0000h - 01266000h
foo_input_monkey loaded at 01290000h - 012D9000h
foo_input_std loaded at 01300000h - 01412000h
foo_lyricsdb loaded at 01440000h - 0145E000h
MSVCP80 loaded at 7C420000h - 7C4A7000h
WININET loaded at 771B0000h - 77256000h
CRYPT32 loaded at 77A80000h - 77B14000h
MSASN1 loaded at 77B20000h - 77B32000h
foo_masstag loaded at 01470000h - 014C0000h
foo_menu_addons loaded at 014E0000h - 014EE000h
foo_out_ks loaded at 01530000h - 0155A000h
SETUPAPI loaded at 77920000h - 77A13000h
foo_playcount loaded at 01560000h - 01588000h
foo_playlist_manager loaded at 015B0000h - 015F7000h
foo_random loaded at 01620000h - 0165F000h
foo_rgscan loaded at 01680000h - 016C8000h
foo_run loaded at 016F0000h - 0171B000h
foo_sic loaded at 01740000h - 01797000h
foo_skip loaded at 018C0000h - 018DB000h
foo_uie_albumart loaded at 01900000h - 01983000h
gdiplus loaded at 4EC50000h - 4EDF3000h
foo_uie_lyrics_panel loaded at 019C0000h - 01A28000h
foo_uie_quicksearch loaded at 01A50000h - 01A98000h
foo_uie_single_column_playlist loaded at 01AC0000h - 01B0E000h
foo_uie_trackinfo_mod loaded at 01B20000h - 01B6A000h
foo_ui_columns loaded at 01B80000h - 01C1B000h
foo_unpack loaded at 01C40000h - 01C6E000h
foo_utils loaded at 01C90000h - 01CC9000h
foo_verifier loaded at 01CF0000h - 01D20000h
mswsock loaded at 71A50000h - 71A8F000h
DNSAPI loaded at 76F20000h - 76F47000h
rasadhlp loaded at 76FC0000h - 76FC6000h
hnetcfg loaded at 662B0000h - 66308000h
wshtcpip loaded at 71A90000h - 71A98000h
DSOUND loaded at 73F10000h - 73F6C000h
WINMM loaded at 76B40000h - 76B6D000h
WINTRUST loaded at 76C30000h - 76C5E000h
IMAGEHLP loaded at 76C90000h - 76CB8000h
wdmaud loaded at 72D20000h - 72D29000h
msacm32 loaded at 72D10000h - 72D18000h
MSACM32 loaded at 77BE0000h - 77BF5000h
midimap loaded at 77BD0000h - 77BD7000h
KsUser loaded at 73EE0000h - 73EE4000h
dciman32 loaded at 73BC0000h - 73BC6000h
idle loaded at 60300000h - 60307000h
MSVCR71 loaded at 7C340000h - 7C396000h
ieview loaded at 04B80000h - 04B9F000h
DBGHELP loaded at 59A60000h - 59B01000h
Stack dump analysis:
Address: 0135D932h, location: "foo_input_std", loaded at 01300000h - 01412000h
Address: 0135D5D3h, location: "foo_input_std", loaded at 01300000h - 01412000h
Address: 0135CAC3h, location: "foo_input_std", loaded at 01300000h - 01412000h
Address: 0135B7D9h, location: "foo_input_std", loaded at 01300000h - 01412000h
Address: 0130CB3Fh, location: "foo_input_std", loaded at 01300000h - 01412000h
Address: 0130C6A9h, location: "foo_input_std", loaded at 01300000h - 01412000h
Address: 7C9106EBh, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Address: 0175E949h, location: "foo_sic", loaded at 01740000h - 01797000h
Address: 01775274h, location: "foo_sic", loaded at 01740000h - 01797000h
Address: 10002D87h, location: "shared", loaded at 10000000h - 10029000h
Symbol: "uPrintCrashInfo_SetDumpPath" (+000000A7h)
Address: 013C1DA8h, location: "foo_input_std", loaded at 01300000h - 01412000h
Address: 0130A0E7h, location: "foo_input_std", loaded at 01300000h - 01412000h
Address: 0174D5E3h, location: "foo_sic", loaded at 01740000h - 01797000h
Address: 01742F5Eh, location: "foo_sic", loaded at 01740000h - 01797000h
Address: 0176EFC9h, location: "foo_sic", loaded at 01740000h - 01797000h
Address: 01743C5Bh, location: "foo_sic", loaded at 01740000h - 01797000h
Address: 0044E382h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 00447BDBh, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 0040362Bh, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 0044EA1Ah, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 7C910732h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "RtlAllocateHeap" (+0000015Eh)
Address: 7C90EE18h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "strchr" (+00000117h)
Address: 7C910738h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "RtlAllocateHeap" (+00000164h)
Address: 01773FC0h, location: "foo_sic", loaded at 01740000h - 01797000h
Address: 7C910700h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "RtlAllocateHeap" (+0000012Ch)
Address: 01774638h, location: "foo_sic", loaded at 01740000h - 01797000h
Address: 7C91056Dh, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "RtlFreeHeap" (+00000130h)
Address: 7C917CB7h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "RtlReAllocateHeap" (+000002BAh)
Address: 7C917BF5h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "RtlReAllocateHeap" (+000001F8h)
Address: 017712AFh, location: "foo_sic", loaded at 01740000h - 01797000h
Address: 01775700h, location: "foo_sic", loaded at 01740000h - 01797000h
Address: 017442A8h, location: "foo_sic", loaded at 01740000h - 01797000h
Address: 01783564h, location: "foo_sic", loaded at 01740000h - 01797000h
Address: 01774620h, location: "foo_sic", loaded at 01740000h - 01797000h
Address: 0040A5F9h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 01774700h, location: "foo_sic", loaded at 01740000h - 01797000h
Address: 017873ECh, location: "foo_sic", loaded at 01740000h - 01797000h
Address: 01771434h, location: "foo_sic", loaded at 01740000h - 01797000h
Address: 0174409Dh, location: "foo_sic", loaded at 01740000h - 01797000h
Address: 0176F078h, location: "foo_sic", loaded at 01740000h - 01797000h
Address: 01746722h, location: "foo_sic", loaded at 01740000h - 01797000h
Address: 017746DCh, location: "foo_sic", loaded at 01740000h - 01797000h
Address: 01774D14h, location: "foo_sic", loaded at 01740000h - 01797000h
Address: 01770898h, location: "foo_sic", loaded at 01740000h - 01797000h
Address: 01747B89h, location: "foo_sic", loaded at 01740000h - 01797000h
Address: 71AB3B91h, location: "WS2_32", loaded at 71AB0000h - 71AC7000h
Symbol: "socket" (+00000000h)
Address: 71AB1384h, location: "WS2_32", loaded at 71AB0000h - 71AC7000h
Symbol: "Ordinal496" (+00001384h)
Address: 71A54AD4h, location: "mswsock", loaded at 71A50000h - 71A8F000h
Address: 01774D20h, location: "foo_sic", loaded at 01740000h - 01797000h
Address: 01774694h, location: "foo_sic", loaded at 01740000h - 01797000h
Address: 01774CC4h, location: "foo_sic", loaded at 01740000h - 01797000h
Address: 7C910570h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "RtlFreeHeap" (+00000133h)
Address: 71AC24AFh, location: "WS2_32", loaded at 71AB0000h - 71AC7000h
Address: 71AB3A98h, location: "WS2_32", loaded at 71AB0000h - 71AC7000h
Symbol: "WSASocketW" (+000000CDh)
Address: 71AB3A91h, location: "WS2_32", loaded at 71AB0000h - 71AC7000h
Symbol: "WSASocketW" (+000000C6h)
Address: 71AB3BE1h, location: "WS2_32", loaded at 71AB0000h - 71AC7000h
Symbol: "socket" (+00000050h)
Address: 01770E56h, location: "foo_sic", loaded at 01740000h - 01797000h
Address: 01747F74h, location: "foo_sic", loaded at 01740000h - 01797000h
Address: 01774D28h, location: "foo_sic", loaded at 01740000h - 01797000h
Address: 7C90E9ABh, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "ZwWaitForMultipleObjects" (+0000000Ch)
Address: 7C8094E2h, location: "kernel32", loaded at 7C800000h - 7C8F4000h
Symbol: "CreateFileMappingA" (+00000086h)
Address: 7C809524h, location: "kernel32", loaded at 7C800000h - 7C8F4000h
Symbol: "CreateFileMappingA" (+000000C8h)
Address: 7C809512h, location: "kernel32", loaded at 7C800000h - 7C8F4000h
Symbol: "CreateFileMappingA" (+000000B6h)
Address: 0175E860h, location: "foo_sic", loaded at 01740000h - 01797000h
Address: 01770176h, location: "foo_sic", loaded at 01740000h - 01797000h
Address: 017496F6h, location: "foo_sic", loaded at 01740000h - 01797000h
Address: 01760B60h, location: "foo_sic", loaded at 01740000h - 01797000h
Address: 0176F020h, location: "foo_sic", loaded at 01740000h - 01797000h
Address: 0174C817h, location: "foo_sic", loaded at 01740000h - 01797000h
Address: 0176F338h, location: "foo_sic", loaded at 01740000h - 01797000h
Address: 0174C67Eh, location: "foo_sic", loaded at 01740000h - 01797000h
Address: 017706E3h, location: "foo_sic", loaded at 01740000h - 01797000h
Address: 7C80B683h, location: "kernel32", loaded at 7C800000h - 7C8F4000h
Symbol: "GetModuleFileNameA" (+000001B4h)
Address: 7C839AA8h, location: "kernel32", loaded at 7C800000h - 7C8F4000h
Symbol: "ValidateLocale" (+000002B0h)
Address: 7C80B690h, location: "kernel32", loaded at 7C800000h - 7C8F4000h
Symbol: "GetModuleFileNameA" (+000001C1h)
Address: 0174C630h, location: "foo_sic", loaded at 01740000h - 01797000h
Address: 10000000h, location: "shared", loaded at 10000000h - 10029000h
Version info:
foobar2000 v0.9.4 beta 1
UNICODE
Additional info:
ReplayGain Scanner 2.0.2 (foo_rgscan)
Quick Search Toolbar 2.8h (foo_uie_quicksearch)
DTS decoder 0.1.7 (foo_input_dts)
Audioscrobbler 1.3.4 (foo_audioscrobbler)
foosic music database 1.0 beta 11 (foo_sic)
Binary comparator 1.0 (foo_bitcompare)
cwbowron's title format hooks 1.0.6 [Aug 23 2006 - 15:57:33] (foo_cwb_hooks)
freedb Tagger 0.5.2a (foo_freedb2)
CD Audio Decoder 2.1.1 (foo_cdda)
Kernel Streaming Output 1.2.2 (foo_out_ks)
Matroska Plugin 0.9.1.2 (foo_input_matroska)
ABX comparator 1.3 (foo_abx)
RAR reader 1.1 (foo_unpack)
Lyrics panel 0.34.1 (foo_uie_lyrics_panel)
Single Column Playlist Display 0.1 beta [Aug 30 2006 - 19:56:34] (foo_uie_single_column_playlist)
Playlist tools 0.5.8 (foo_utils)
Album List 3.2.0 (foo_albumlist)
ZIP/GZIP reader 1.0 (foo_unpack)
foo_skip 0.2 (foo_skip)
Playlist Manager 1.0.2 (foo_playlist_manager)
Channel Mixer 0.9.4 (foo_channel_mixer)
FLAC decoder 1.1.0 (foo_input_std)
Converter 1.0.1 (foo_converter)
foobar2000 core v0.9.4 beta 1 (Core)
Database Search 1.4 beta 4 (foo_dbsearch)
AC3 decoder 0.7 (foo_ac3)
HyperIM Bridge 2.0 (foo_2hyperim)
Autoplaylist Manager 1.0 (foo_autoplaylist)
Audio CD Writer 2.0.1 (foo_burninate)
LPCM <--> delta-PCM converter 0.1.1 (foo_dsp_delta)
Standard Input Array 1.0 (foo_input_std)
Randomized playlist entry 1.2.3 (foo_random)
Menu Addons 0.1 (foo_menu_addons)
File Integrity Verifier 1.0.1 (foo_verifier)
Skip silence 0.1 (foo_dsp_skip_silence)
Run services 0.3.2 (foo_run)
Monkey's Audio decoder 2.1.1 (foo_input_monkey)
bs2b 2.0.0b2 (foo_dsp_bs2b)
Track info panel mod 0.5 beta [Aug 30 2006 - 16:35:44] (foo_uie_trackinfo_mod)
Cuesheet Creator 0.4.5 (foo_cuesheet_creator)
Common services 0.1 (foo_common)
Album Art Panel feat. Matroska 0.1763 (foo_uie_albumart)
Standard DSP array 1.0 (foo_dsp_std)
Columns UI 0.1.3 beta 1v5 (foo_ui_columns)
foo_lyricsdb 0.0.7 beta 4 (foo_lyricsdb)
Masstagger 1.6 (foo_masstag)
Playback Statistics 1.3.1 (foo_playcount)
Illegal operation:
Call path:
This is your 2-nd crash. When reporting the problem to a developer, please try to post info about the first crash instead.
Stack (018BF728h):
Registers:
Loaded modules:
netapi32 loaded at 5B860000h - 5B8B4000h
Apphelp loaded at 77B40000h - 77B62000h
Version info:
UNICODE
Additional info:
RSS Lo-Fi Version Time is now: 7th May 2015 - 04:28
