foo_input_awma, WMA decoder with tagging support
Acropolis
post Sep 11 2006, 03:56
Group: Banned
now version 0.1.5 is considered to be mature
but beware that I don't know all the attributes, so there maybe some readonly data shown as meta data or editable data shown as readonly still.
Download
change log
0.1.5
fixed: comment was not shown as meta data
0.1.4
fixed: date was not shown as meta data
0.1.3
fixed: replaygain could not be removed
fixed: readonly tags incorrectly shown as meta data and vice versa
fixed: unseen tags will be erased (now private tags will be reserved)
0.1.2
minor bug fixed
0.1.1
added replaygain support
added vbr display support (though it's inaccurate due to the api available from WMSDK)
I've been waiting for the tagging support for wma files since the first day of using 0.9, but quite frustrated until I make it with my hands.
this is a wma decoder component that supports tagging. I take it as the replacement of the wma decoder in foo_input_std, which doesn't support tagging.
the lacking functionality was almost the only reason to keep me still using 0.8.3 sometimes. now I can delete my 0.8.3 directory....
to be able to use it, please read here carefully
there is a little problem to use this plugin to handle wma over the foo_input_std, to be able to use it, the name of the dll must be alphabetically lower order than foo_input_std (that's why I use foo_input_awma instead of foo_input_wma), generally this will work.
but if not, you can try to move away foo_input_std from the component directory, then start foobar, let it remove the setting, then put it back again, and do it again with this dll. should work.
the best method is of course to remove the internal support of foo_input_std, a simple way is to patch it, but I think I can't provide the patched foo_input_std, but the above method should work, I tried that way while writing this component.
* All of my components need the VC8 runtime libraries *
cheers
This post has been edited by Acropolis: Oct 30 2006, 16:34
kalmark
post Sep 11 2006, 18:49
Acropolis, have you considered opening the source of your component? Not necessarily for everyone, but for the core FB2K devs? I have no idea if they'd be interested, but that way maybe your code could be included in the official release? Might be worth a question?
Life is Real...
(But not in audio :) )
- Acropolis   foo_input_awma   Sep 11 2006, 03:56
- - machekku   My test story: I have some files tagged by 0.8.3....   Sep 11 2006, 07:31
- - Zimdgre   Now this is the greatest news of this month, thank...   Sep 11 2006, 07:51
- - ...Just Elliott   Hooray! Watch the foobar user count double.   Sep 11 2006, 08:50
- - Acropolis   QUOTE (machekku @ Sep 11 2006, 16:31) My ...   Sep 11 2006, 11:10
- - musosticky   Just tested tagging one one of the 2 wma files I h...   Sep 11 2006, 11:39
- - foosion   Relying on service enumeration order is a bug. foo...   Sep 11 2006, 12:39
|- - Mike Giacomelli   QUOTE (foosion @ Sep 11 2006, 04:39) Rely...   Sep 11 2006, 15:19
|- - Peter   QUOTE (Mike Giacomelli @ Sep 11 2006, 16...   Sep 11 2006, 16:47
- - Acropolis   I know relying on service enumeration order is a v...   Sep 11 2006, 17:14
- - Yotsuya   Perhaps a more elegant solution would be if the fo...   Sep 11 2006, 17:31
|- - pepoluan   QUOTE (Yotsuya @ Sep 11 2006, 23:31) Perh...   Sep 11 2006, 17:34
|- - Acropolis   QUOTE (Yotsuya @ Sep 12 2006, 02:31) Perh...   Sep 11 2006, 17:35
|- - Peter   QUOTE (Yotsuya @ Sep 11 2006, 18:31) Perh...   Sep 11 2006, 18:07
|- - FrozenSpoon   QUOTE (Peter @ Sep 11 2006, 13:07) Standa...   Sep 11 2006, 18:35
|- - pepoluan   QUOTE (Peter @ Sep 12 2006, 00:07) QUOTE ...   Sep 11 2006, 18:48
|- - Peter   QUOTE (Zimdgre @ Sep 14 2006, 15:03) In W...   Sep 14 2006, 14:10
- - Earthworm   i just waited for this. great plugin! thank y...   Sep 11 2006, 17:45
- - kalmark   Acropolis, have you considered opening the source ...   Sep 11 2006, 18:49
|- - Acropolis   QUOTE (kalmark @ Sep 12 2006, 03:49) Acro...   Sep 11 2006, 21:17
- - Zimdgre   Does every official plugin necessarily have the na...   Sep 14 2006, 14:03
- - midgezr   QUOTE (Yotsuya @ Sep 11 2006, 10:31) Perh...   Sep 15 2006, 05:00
- - tobamai   Just a heads up for acropolis and anyone downloadi...   Apr 4 2007, 00:06
- - nbarzgar   PLEASE provide a valid download link!! Th...   Jan 4 2008, 14:07
- - Hakubo   Why would you need it? foobar2000 natively support...   Jan 4 2008, 14:22
- - nbarzgar   Isn't it neccessary for streaming wma-content?...   Jan 4 2008, 21:58
Closed TopicStart new topic
RSS Lo-Fi Version Time is now: 25th April 2015 - 12:21
