foo_uie_single_column_playlist, single column playlist viewer
terrestrial
post Aug 29 2006, 03:40
I have made a plugin that displays the playlist in a single column with "headers", which I find useful for creating a narrower and smaller layout.
This is a beta so user beware. Download
For documentation, please refer to the wiki. (thanks to FofR, and the other contributors).
Requires:
MS Visual C++ 2005 Runtime Library
GDI+ - only needed for Windows 2000
This post has been edited by terrestrial: Nov 21 2006, 03:02
Yotsuya
post Aug 31 2006, 20:32
$imageabs(,,images\backdrop.png,)
If you would like to place the image at a specific place you can put the x,y coordinates in the first two parameters:
$imageabs(10,5,images\backdrop.png,)
As mentioned before, the images are currently restricted to .png format and if I am not mistaken they must reside relative to the main foobar directory (in the above example x:\path\to\foobar2000\images). Also I do not believe there is currently any way to resize images from their original dimensions.
I havnt played around with images yet but I would suspect you may also be limited to fitting the image inside the current row.
EDIT: I did a little exprimenting and any image is indeed clipped so that it only appears in the current row.
This post has been edited by Yotsuya: Aug 31 2006, 20:35
- terrestrial   foo_uie_single_column_playlist   Aug 29 2006, 03:40
- - vonmeth   Oooo, great idea. =)   Aug 29 2006, 04:42
- - year98   It's good idea... But It doesn't work for ...   Aug 29 2006, 04:46
- - terrestrial   there were supposed to be some defaults loaded, bu...   Aug 29 2006, 04:54
- - year98   It's not working as ever... Only shows black ...   Aug 29 2006, 05:05
- - terrestrial   did you set the "row height"? maybe rest...   Aug 29 2006, 05:08
- - year98   Yes, I changed row height, but result was same. li...   Aug 29 2006, 05:13
- - vonmeth   Try changing the height to 40, and I'm sure so...   Aug 29 2006, 05:29
- - year98   Oh, thx it works...^^ Then, why edge style is alwa...   Aug 29 2006, 05:39
- - terrestrial   edge style isn't implemented yet.   Aug 29 2006, 05:47
- - Anas   Thanks, I like it. Looks very promising! I als...   Aug 29 2006, 07:43
- - unknownllama   Great Plugin! Perfect for my new mini foobar s...   Aug 29 2006, 08:25
- - Strictly4me   Perfect for my sidebarconfig! - Thanks. ((...   Aug 29 2006, 09:05
- - FofR   Are those album headers tracks?   Aug 29 2006, 10:26
- - foosion   Some first (negative) impressions:The playlist vie...   Aug 29 2006, 10:50
- - Andreasvb   Great idea, will try it. I really like the groupi...   Aug 29 2006, 11:34
- - Hamallainen   Hi, Thanks a lot, really good idea that's v...   Aug 29 2006, 12:37
- - vlada   How can I display it? I don't see it anywhere ...   Aug 29 2006, 20:14
|- - vonmeth   I am encountering the same problem with the ctrl+p...   Aug 29 2006, 21:49
- - skelly831   Thanks terrestrial, I can see this plugin becoming...   Aug 29 2006, 23:44
- - vonmeth   "No focus rectangle for the active item. I re...   Aug 30 2006, 01:26
- - mazy   i really like this plugin, quick try with it: a...   Aug 30 2006, 03:14
|- - skelly831   QUOTE (mazy @ Aug 29 2006, 19:14) i reall...   Aug 30 2006, 03:57
|- - alphaex32   QUOTE (mazy @ Aug 29 2006, 22:14) i reall...   Aug 31 2006, 15:05
- - mazy   skelly831, thanks, but it's terrestrial who ma...   Aug 30 2006, 03:59
|- - kanak   QUOTE (mazy @ Aug 30 2006, 08:59) skelly8...   Aug 31 2006, 14:05
- - 4nt1   terrestrial please listen to foosion, he knows wha...   Aug 30 2006, 06:40
- - Yotsuya   Is there a way to define the color for the backgro...   Aug 30 2006, 21:38
- - terrestrial   QUOTE Thanks, I like it. Looks very promising...   Aug 31 2006, 06:50
- - terrestrial   QUOTE separate height for group display and item d...   Aug 31 2006, 07:31
|- - Yotsuya   QUOTE (terrestrial @ Aug 31 2006, 02:31) ...   Aug 31 2006, 08:05
- - Yotsuya   This isnt specific to this plugin, but can anyone ...   Aug 31 2006, 08:39
- - mazy   just a test using the track info mod and foo_uie_s...   Aug 31 2006, 15:18
- - terrestrial   looks good, mazy could you do me a favor and che...   Aug 31 2006, 16:08
|- - mazy   QUOTE (terrestrial @ Aug 31 2006, 17:08) ...   Aug 31 2006, 16:16
- - FofR   My request: Collapsible headers. Im going to play ...   Aug 31 2006, 16:14
- - 4nt1   i second collapsable headers   Aug 31 2006, 17:19
- - FofR   Upon install, with no modification I get something...   Aug 31 2006, 18:01
- - terrestrial   a restart should fix it. There are still some sett...   Aug 31 2006, 19:30
- - alphaex32   I'm not very familiar with the modified tracki...   Aug 31 2006, 20:18
- - Yotsuya   $imageabs(,,images\backdrop.png,) If yo...   Aug 31 2006, 20:32
- - alphaex32   Oh, ok. I just remembered that the group headers n...   Aug 31 2006, 20:35
- - FofR   QUOTE (Yotsuya @ Aug 31 2006, 20:32) EDIT...   Aug 31 2006, 22:24
- - Yotsuya   So basically each row automatically offsets the im...   Aug 31 2006, 23:31
- - RevivalofHonor   I'm having quite a bit of fun with this plug-i...   Sep 1 2006, 01:31
- - Yotsuya   Using FofR's idea for embedding images beyond ...   Sep 1 2006, 04:40
- - FofR   Nice idea using the %list_index%, I hadn't tho...   Sep 1 2006, 08:27
- - FofR   I want to add some details about $drawrect to...   Sep 1 2006, 10:04
- - Jensen   Great plugin! But why don't you allow us ...   Sep 1 2006, 10:33
- - Xerion   Why doesn't this component have an every secon...   Sep 1 2006, 11:30
- - FofR   QUOTE (Xerion @ Sep 1 2006, 11:30) Why do...   Sep 1 2006, 11:32
- - Xerion   QUOTE (FofR @ Sep 1 2006, 12:32) QUOTE (X...   Sep 1 2006, 11:58
- - mazy   QUOTE (FofR @ Sep 1 2006, 11:04) I want t...   Sep 1 2006, 18:06
- - alphaex32   I love this plugin. I'd like to request a song...   Sep 1 2006, 21:01
|- - mazy   QUOTE (alphaex32 @ Sep 1 2006, 22:01) I l...   Sep 2 2006, 10:53
- - Blitzmeister   Has any tryed to get the album art in the tracks?   Sep 2 2006, 05:20
- - RevivalofHonor   I have a new question, which is probably related t...   Sep 2 2006, 17:57
- - SwiftBass   EDIT: nevermind problem solved   Sep 2 2006, 18:42
- - FofR   QUOTE (RevivalofHonor @ Sep 2 2006, 17:57...   Sep 2 2006, 19:00
- - RevivalofHonor   Thank you, FofR. I guess I did something wrong wi...   Sep 2 2006, 19:09
- - tool++   Stuff keeps disappearing   Sep 2 2006, 19:53
- - zackorah   QUOTE (Blitzmeister @ Sep 1 2006, 22:20) ...   Sep 2 2006, 20:39
- - sHsIkuA   Hi there, thanks for this great plugin theres som...   Sep 2 2006, 21:41
|- - cartman(2vd)   QUOTE (sHsIkuA @ Sep 2 2006, 22:41) Hi th...   Sep 2 2006, 23:06
|- - sHsIkuA   QUOTE (cartman(2vd) @ Sep 2 2006, 16...   Sep 3 2006, 11:42
|- - cartman(2vd)   QUOTE (sHsIkuA @ Sep 3 2006, 12:42) QUOTE...   Sep 3 2006, 17:02
- - vonmeth   QUOTE (zackorah @ Sep 2 2006, 13:39) CODE...   Sep 2 2006, 22:06
- - upNorth   @terrestrial: IMHO, this is the most exciting plug...   Sep 2 2006, 22:33
- - mazy   terrestrial, seeing all the posts about other form...   Sep 2 2006, 22:43
- - zackorah   QUOTE (upNorth @ Sep 2 2006, 15:33) @zack...   Sep 2 2006, 23:42
|- - david_dl   QUOTE (zackorah @ Sep 3 2006, 11:42) OT...   Sep 3 2006, 23:04
- - FofR   Can I see your code for that? I'd like to play...   Sep 3 2006, 00:46
- - tool++   That would be ridiculously insane. Sorta WMP11 st...   Sep 3 2006, 01:03
|- - sicutero   QUOTE (tool++ @ Sep 3 2006, 03...   Sep 3 2006, 15:15
|- - tool++   QUOTE (sicutero @ Sep 3 2006, 15:15) QUOT...   Sep 3 2006, 21:01
|- - sicutero   QUOTE (tool++ @ Sep 3 2006, 23...   Sep 3 2006, 21:12
- - zackorah   QUOTE (FofR @ Sep 2 2006, 17:46) Can I se...   Sep 3 2006, 01:15
- - tool++   That is fricken sweet. How would I adapt my curre...   Sep 3 2006, 01:40
- - alphaex32   I've got a few more ideas: First, variable lin...   Sep 3 2006, 06:56
- - SwiftBass   May I recommend a mouse activated inline metafield...   Sep 3 2006, 07:33
- - shane 4 sure   Beat me to death but placing this plug-in in the c...   Sep 3 2006, 08:23
|- - vonmeth   QUOTE (shane 4 sure @ Sep 3 2006, 01:23) ...   Sep 3 2006, 09:28
- - shane 4 sure   @ vonmeth Thanks a lot for the hint.   Sep 3 2006, 09:59
- - FofR   QUOTE (mazy @ Sep 1 2006, 18:06) there...   Sep 3 2006, 13:07
- - 4nt1   ok I am sure someone has said this before but ther...   Sep 3 2006, 15:29
- - Comwan   QUOTE (terrestrial @ Aug 29 2006, 03:40) ...   Sep 3 2006, 15:56
- - sHsIkuA   heh we all just have to wait its up to the develo...   Sep 3 2006, 18:08
- - Superunknown   I've put the component in the right folder, it...   Sep 3 2006, 19:03
- - kanak   @superunknown Go to Column UI layout options and ...   Sep 3 2006, 19:50
- - Superunknown   it has !! thank you soo much !   Sep 3 2006, 20:12
- - tool++   Aww don't apologize, makes me feel mean I...   Sep 3 2006, 22:06
- - BlindSeer   Nice component. It would be very useful to have a ...   Sep 3 2006, 23:00
|- - acedriver   QUOTE (BlindSeer @ Sep 4 2006, 06:00) Nic...   Sep 4 2006, 00:06
|- - david_dl   QUOTE (acedriver @ Sep 4 2006, 12:06) QUO...   Sep 4 2006, 00:30
- - zackorah   QUOTE (FofR @ Sep 2 2006, 17:46) (obviou...   Sep 3 2006, 23:04
- - skelly831   This plugin is sweet.   Sep 4 2006, 00:56
- - terrestrial   QUOTE (RevivalofHonor @ Aug 31 2006, 19:3...   Sep 4 2006, 04:18
|- - alphaex32   QUOTE (terrestrial @ Sep 3 2006, 23:18) M...   Sep 4 2006, 05:42
- - carmenm   QUOTE (zackorah @ Sep 3 2006, 16:04) Figu...   Sep 4 2006, 08:12
- - Yotsuya   I would like to request the ability to disable, hi...   Sep 4 2006, 10:16
14 Pages V   1 2 3 > »
RSS Lo-Fi Version Time is now: 3rd June 2015 - 22:58
