Track Info Panel with ability to change font, Split from foo_uie_trackinfo
terrestrial
post Jul 24 2006, 20:48
This is a modified foo_uie_trackinfo which uses a differet display function, which allows for different fonts / alignment.
Example screenshot:
and the code from the example:
$if(%_trackinfo_notrack%,
Stopped,
$align(left,top)
$font(forte,15,shadow,255-255-255)%title%$char(10)
$font(,12,,64-0-0)%album% ['['%date%']']$char(10)
$rgb(0,64,0)%artist%$char(10)
$rgb(64,0,0)%composer%test$char(10)
$align(right,bottom)
$font(Verdana,10,,0-0-0)%__codec%@%__bitrate%$char(10)
[%playback_time% / ]%length%
$align(left,bottom)
$font(Wingdings 2,13,,)
$if(%rating%,
$select(%rating%,
$rgb(155,0,0)κ,
κκ,
κκκ,
κκκκ,
$rgb(0,155,0)κκκκκ),
$rgb(155,155,155)κ)
This is very much still a beta, so please beware of bugs.
Download here.
For documentation, please refer to the wiki. (thanks to FofR, Sw!ng, and the other contributors).
Requires:
MS Visual C++ 2005 Runtime Library
GDI+ - only needed for Windows 2000
This post has been edited by terrestrial: Nov 21 2006, 03:03
mazy
post Jul 31 2006, 23:28
ok, so here goes the 'align' post wink.gif. formatting:
text$char(10)
// first block
$align(left,)$rgb(200,50,50)left$char(10)l
$align(center,)$rgb(50,200,50)center$char(10)c
$align(right,)$rgb(50,50,200)right$char(10)r
// this has no effect to the second block
$align(,bottom)
// second block
$align(left,)$rgb(100,0,0)left
$align(right,)$rgb(0,0,100)right
$align(center,)$rgb(0,100,0)center
// third block
$align(left,bottom)$rgb(200,50,50)left
$align(right,bottom)$rgb(50,50,200)right
$align(center,bottom)$rgb(50,200,50)center
result:
explanation (?):
let's look at the first block. it's result is on the first line in the screenshot, rendered with light colors. you can see only dark-green "center" in there, as it got over the light one.
"left" got put after "text", as the latter was already there and "left" was not allowed to draw over it. then we have "center", which was correctly put in the center.
now "right" (the light one) is interesting. it's not on the right side as it should be, but rather at what seems to be right edge of the center column. strange. these "l", "c" and "r" letters are just new lines of the sub-blocks of the first block; they show more precisely where the alignment line is.
now the second block. that's the one resulting to words rendered with darker colors. as you can see, that $align(,bottom) has no effect to it and $align functions in the second block assume "top" for the missing vertical alignment parameter (which is fine by me, it wasn't said to be "relative" or anything like that).
they show in the left, right and center columns on the first line respectively. they do not overdraw the existing texts (as they are not allowed to) with the only exception being "center" - it seems that center of a center is again the same center wink.gif.
it gets interesting again for the last, third block. i've only changed the order in which i specify texts for corresponding columns. i put right in front of center - and the result is what one would expect in the other blocks too - right column has adjustment line on the right edge of the panel.
This post has been edited by mazy: Jul 31 2006, 23:45
info about my tag guesser script for foo_lua (preview version available):
http://www.hydrogenaudio.org/index.php?showtopic=16987
- terrestrial   Track Info Panel with ability to change font   Jul 24 2006, 20:48
- - pepoluan   QUOTE (cvax @ Jul 18 2006, 00:08) Is it p...   Jul 25 2006, 00:28
- - Yotsuya   Would it be possible for you to change your font c...   Jul 25 2006, 10:30
- - terrestrial   made a couple of bug fixes, and other changes: ex...   Jul 28 2006, 22:19
|- - Squeller   QUOTE (terrestrial @ Jul 28 2006, 13:19) ...   Jul 30 2006, 12:10
- - Yotsuya   First off I'd like to thank you for continuing...   Jul 28 2006, 22:58
|- - terrestrial   Thanks for your comments QUOTE (Yotsuya @ J...   Jul 28 2006, 23:27
- - pepoluan   2 suggestions: 1. Please provide a readme.txt too...   Jul 29 2006, 02:41
- - mazy   terrestrial - amazing work, thank you so much for ...   Jul 29 2006, 23:33
|- - terrestrial   QUOTE (mazy @ Jul 29 2006, 16:33) [*]i wo...   Jul 30 2006, 22:11
- - mil3s   Bug In the latest foobar beta multiple trackinfo f...   Jul 30 2006, 21:11
- - mil3s   Thanks for fixing the multiple fields bug so quick...   Jul 30 2006, 22:41
- - Yotsuya   Wow thanks for the quick update and thank you for ...   Jul 31 2006, 02:48
- - takt   Is this version of trackinfo a branch or just a up...   Jul 31 2006, 09:20
- - mazy   Yotsuya 1) the way $align works right now is...   Jul 31 2006, 15:11
|- - Andrea   QUOTE (mazy @ Jul 31 2006, 11:11) i would...   Jul 31 2006, 15:20
- - terrestrial   Ok, new version with bug fixes and some additions....   Jul 31 2006, 17:05
- - drbeachboy   I received this failure notice from FB2K_v0.9.3b4:...   Jul 31 2006, 17:53
|- - terrestrial   QUOTE (drbeachboy @ Jul 31 2006, 10:53) I...   Jul 31 2006, 20:15
|- - Schinkentoni   Thank you very much for your development efforts. ...   Jul 31 2006, 21:15
- - mil3s   I know someone said that the font sizes where all ...   Jul 31 2006, 18:01
- - pepoluan   @terrestrial: Now that you have your own thread ....   Jul 31 2006, 18:42
- - mazy   terrestrial, thanks for fixes! that shadow stu...   Jul 31 2006, 18:49
- - Yotsuya   Nice to see this component is continuing to evolve...   Jul 31 2006, 20:14
- - terrestrial   are you guys running the latest version of foobar ...   Jul 31 2006, 21:26
|- - Schinkentoni   the latest stable, yes (0.9.2)   Jul 31 2006, 21:31
|- - drbeachboy   QUOTE (terrestrial @ Jul 31 2006, 16:26) ...   Jul 31 2006, 23:05
- - mazy   i've been playing with the new version and fou...   Jul 31 2006, 22:41
- - mazy   ok, so here goes the 'align' post . format...   Jul 31 2006, 23:28
- - rouge   Can this be made into a seperate component from fo...   Aug 1 2006, 04:06
- - year98   Great works! Some suggestions...somewhat irre...   Aug 1 2006, 04:36
- - thuan   I second the configurable double click behavior.   Aug 1 2006, 06:13
- - terrestrial   QUOTE I've been playing with the new version a...   Aug 1 2006, 07:36
- - year98   Oh! Can you do everything? I'll wait forer...   Aug 1 2006, 07:44
- - Hamallainen   Thanks a lot for your work CODE$alignabs...   Aug 1 2006, 09:42
- - Generalverdacht   just wanted to thank you (creator of new features)...   Aug 1 2006, 11:22
- - mazy   terrestrial, i can confirm that $rgb() works ...   Aug 1 2006, 12:04
- - Yotsuya   Thank you terrestrial for your dedication, this co...   Aug 1 2006, 18:13
- - terrestrial   QUOTE first start with 3. using the new measuremen...   Aug 1 2006, 18:21
- - FrDelefortrie   Another feature request: Can you create $font...   Aug 1 2006, 18:58
- - Yotsuya   I stumbled upon a small inconsistency. $alig...   Aug 1 2006, 19:05
- - Yotsuya   I know a lot of people out there are using trackin...   Aug 1 2006, 19:21
- - terrestrial   QUOTE 1) I would like to be able to use $font...   Aug 1 2006, 19:41
- - FrDelefortrie   QUOTE (terrestrial @ Aug 1 2006, 20:41) Q...   Aug 1 2006, 19:55
- - Hamallainen   Hi, I have a problem with the $align(H,V) fo...   Aug 1 2006, 23:22
|- - mazy   QUOTE (Hamallainen @ Aug 2 2006, 00:22) I...   Aug 1 2006, 23:58
- - Shakedown   This may be a stupid question, but I'm fairly ...   Aug 1 2006, 23:30
- - Yotsuya   Shakedown I believe the function you are looking f...   Aug 1 2006, 23:49
- - Hamallainen   @ mazy thanks for your explanations   Aug 2 2006, 07:37
- - mobyduck   Ok, my turn for a stupid question: how do I add a ...   Aug 2 2006, 08:01
|- - mobyduck   QUOTE (mobyduck @ Aug 1 2006, 23:01) Ok, ...   Aug 2 2006, 12:05
- - Squeller   I also do not see how to insert a blank line. I us...   Aug 2 2006, 09:01
- - mazy   QUOTE (mobyduck @ Aug 2 2006, 09:01) Ok, ...   Aug 2 2006, 10:08
- - stalnation   QUOTE (drbeachboy @ Jul 31 2006, 18:53) I...   Aug 2 2006, 11:00
|- - mazy   QUOTE (stalnation @ Aug 2 2006, 12:00) so...   Aug 2 2006, 11:41
|- - foosion   QUOTE (stalnation @ Aug 2 2006, 12:00) It...   Aug 2 2006, 12:02
- - stalnation   QUOTE (mazy @ Aug 2 2006, 12:41) you coul...   Aug 2 2006, 11:46
- - stalnation   @foosion I compared the msvcr80.dll from the websi...   Aug 2 2006, 12:19
- - thuan   It's just need this. If you've already in...   Aug 2 2006, 14:02
- - FrDelefortrie   Bug report CODE Illegal operation: Code: C0000005...   Aug 3 2006, 17:55
|- - terrestrial   QUOTE (FrDelefortrie @ Aug 3 2006, 11:55)...   Aug 3 2006, 23:29
- - madorangepanda   Is there any chance something like the titleformat...   Aug 3 2006, 18:33
- - ChaosBladE   Not sure if i'll use it right now, But as a pr...   Aug 3 2006, 22:57
- - unabatedshagie   Could people post examples of their trackinfo stri...   Aug 4 2006, 16:00
|- - Yotsuya   QUOTE (unabatedshagie @ Aug 4 2006, 11:00...   Aug 4 2006, 19:44
- - FrDelefortrie   CODE $puts(color3,079AE9) //35B5F9) //...   Aug 4 2006, 17:44
- - Yotsuya   It occured to me that you could use a 1pt font ...   Aug 4 2006, 21:24
- - mazy   nice examples, Yotsuya! i have managed to draw...   Aug 4 2006, 21:29
- - Masahiko   with the code : CODE$align(center,)Ta...   Aug 5 2006, 11:19
- - PonasX   Maybe $align(center,)Tags$char(10) ...   Aug 5 2006, 12:21
- - eisteh   $align(center,top)Tags$char(10) $al...   Aug 5 2006, 12:32
- - rouge   Installing this component still converts all of my...   Aug 5 2006, 13:28
- - metal_termite   Feature request: A checkbox option in the settings...   Aug 5 2006, 13:55
- - Andrew_TA   another feature request, anyway i can get like, c...   Aug 5 2006, 15:06
- - Masahiko   QUOTE (PonasX @ Aug 5 2006, 13:21) Maybe ...   Aug 5 2006, 17:33
|- - Yotsuya   QUOTE (eisteh @ Aug 5 2006, 13:32) ...   Aug 5 2006, 20:19
- - FrDelefortrie   from the read-me QUOTE Before the first $alig...   Aug 5 2006, 17:41
- - Masahiko   QUOTE (Yotsuya @ Aug 5 2006, 21:19) I thi...   Aug 6 2006, 10:50
- - Generalverdacht   im not quite sure what i missed but it only says ...   Aug 7 2006, 17:38
- - LL-Hell   here's what I managed to pull so far with the ...   Aug 7 2006, 18:51
- - Neural_Overload   Is there a way to terminate the alignment in a sim...   Aug 9 2006, 03:39
- - Yotsuya   The broken $char(10) appears to have somethin...   Aug 9 2006, 05:36
- - thuan   I have a crash by this plugin here's the crash...   Aug 13 2006, 05:43
- - metal_termite   I have a problem. One of my track info panels keep...   Aug 14 2006, 19:35
- - Sw!ng   Is this the full code your problem goes around ......   Aug 14 2006, 21:15
- - thuan   It seems putting tht $font function in the br...   Aug 15 2006, 00:24
- - Yotsuya   1) The code has no close bracket ']' as Sw...   Aug 15 2006, 00:40
|- - metal_termite   QUOTE (Yotsuya @ Aug 14 2006, 19:40) 1) T...   Aug 15 2006, 02:47
- - Yotsuya   In general I do not like using brackets. Both the ...   Aug 15 2006, 03:21
- - gob   any plans for adding scrolling/elipsed test in thi...   Aug 15 2006, 04:56
- - rouge   If strings are going over the edge, I suggest usin...   Aug 15 2006, 09:14
- - Sw!ng   w00t ?? realy ?? so I didnt need to work out my ow...   Aug 15 2006, 10:51
- - Sw!ng   BTW, anyone of you guys have an explanation, why t...   Aug 15 2006, 16:35
- - Russell777   The only thing stopping me from using this wonderf...   Aug 15 2006, 18:05
|- - Sw!ng   Yes, using the same name for the coponent is realy...   Aug 15 2006, 23:12
- - mazy   you can set line spacing, Russell777, but only for...   Aug 15 2006, 18:14
- - Russell777   Do you meen by using the $alignabs() function...   Aug 15 2006, 18:20
- - Russell777   2 Sw!ng: Well if you want you'll get it ju...   Aug 15 2006, 23:28
- - terrestrial   sorry guys... things are a bit on hold for a momen...   Aug 16 2006, 00:52
- - Sw!ng   @ russell777 2.1 would be nice ... !!   Aug 16 2006, 01:18
13 Pages V   1 2 3 > »
RSS Lo-Fi Version Time is now: 21st April 2015 - 02:46
