15 Pages V  < 1 2 3 4 5 > »
Closed TopicStart new topic
Updated in_mad Winamp MAD MP3 input plugin
MoSPDude
post Aug 4 2006, 17:46
Post #51
My bad with the MediaMonkey / DSP problem, I'd updated all the other code for the new buffer except the DSP processing section! Sorry, I'll put it up ASAP, just going to look into the pcutmp3 problem more.
EDIT: I've kind of "patched" the pcutmp3 problem, but I'm not happy with it, if anyone knows more about the libmad decoding delays and why,
LAME mp3s have 3 * 576 + 529 samples off the start when the tag only specifies 576 (by default in LAME encoder.h) from the beginning.
pmp3cut mp3s have (tag value) + 1151 + 529 samples off the start where (tag value) is specified.
Thanks in advanced
This post has been edited by MoSPDude: Aug 4 2006, 18:51
MoSPDude
post Aug 4 2006, 19:07
Post #52
Ok, I've uploaded an update to the usual.
Please if anyone has any extra information regarding the LAME gapless behaviour, I'd appreciate it.
This post has been edited by MoSPDude: Aug 4 2006, 19:08
Big_Berny
post Aug 4 2006, 19:14
Post #53
Well, I don't know the reason but 1151 is 576*2-1.
So:
Lame: 3*576+529
pmp3cut: tagvalue+2*576-1+529
It would be interesting to know what happens when you change the value in lame... Because maybe the "lame-formula" is tagvalue+2*576+529. Then we have only one sample left! wink.gif
Just some stupid ideas of a mathematician withoud any mp3-delay-knowledge. smile.gif
Big_Berny
MoSPDude
post Aug 4 2006, 19:20
Post #54
QUOTE (Big_Berny @ Aug 4 2006, 19:14) *
So:
Lame: 3*576+529
Big_Berny
You know, I might just go for that.....
I think the 529 is purely a libmad delay... as you said, just that 1 sample!
I'll just do another build, and upload another copy with that for ppl to test. I'll post again once its up.
Big_Berny, have you tested MediaMonkey with the build thats up at the moment?
Big_Berny
post Aug 4 2006, 19:27
Post #55
Maybe a Lame developer can give more informations?
Big_Berny
This post has been edited by Big_Berny: Aug 4 2006, 19:28
MoSPDude
post Aug 4 2006, 19:32
Post #56
I've put up the version, ignoring the 1 sample, and it sounds ok with pcutmp3 files - thanks Big_Berny for that fresh view, think I'd been looking at it for too long!! If odyssey could confirm its ok, that'd be great!
I'm going to get back finishing the ID3v2 tag editor now, then perhaps begin APEv2 tags.
Any other bugs etc, feel free to post and help!
odyssey
post Aug 5 2006, 00:19
Post #57
QUOTE (MoSPDude @ Aug 4 2006, 20:32) *
It works great now biggrin.gif (Please disregard the PM i sent you, I appearently did not update to the latest release)
MoSPDude
post Aug 5 2006, 01:38
Post #58
Another update has been uploaded, I think I've finished the look and basic behaviour of the ID3v2 tag editor. Opinions wanted! tongue.gif
I'll look into recursive tags, APEv2 tags and other suggestions now.
Thanks to all for your comments
EDIT: I've just had to re-upload, I'd left debug messages in still!
EDIT 2: Another minor update, fixed bug reading in ID3v1 to v2 tags in new editor
This post has been edited by MoSPDude: Aug 5 2006, 02:53
MoSPDude
post Aug 5 2006, 10:47
Post #59
In Winamp advanced title formatting, you can now read Helium, any TXXX key/value and ID3v2 text frames! It also scans recursively through the tag for multiple frames.
Just add for example, %#Helium Featured Artist% or %COMM% to the winamp preferences.
This post has been edited by MoSPDude: Aug 5 2006, 10:49
MedO
post Aug 5 2006, 11:08
Post #60
Wow, great work. Just another question:
What is the behaviour when LAME rg-Tags and other rg-tags are present together? Which one will be preferred?
MoSPDude
post Aug 5 2006, 12:11
Post #61
QUOTE (MedO @ Aug 5 2006, 11:08) *
The order of preference is foobar TXXX tags, the RVA2 tag, then the LAME tag.
MoSPDude
post Aug 5 2006, 12:38
Post #62
DON'T WRITE UPDATED ID3v2 TAGS!!
There appears to be a MAJOR bug that libid3tag written id3v2.4 tags, can't be read by anything else!!
odyssey
post Aug 5 2006, 14:13
Post #63
QUOTE (MoSPDude @ Aug 5 2006, 11:47) *
Doesn't seem to work for me. Also I have not been able to find ANY information about this anywhere! I even tried the latest Beta 5.25
This post has been edited by odyssey: Aug 5 2006, 14:28
MoSPDude
post Aug 5 2006, 14:55
Post #64
QUOTE (odyssey @ Aug 5 2006, 14:13) *
First, make sure you download the latest release, I've been putting up smaller minor releases.
You need to have Advanced Title Formatting enabled, the feature is a bit of hack. I'm using Winamp 5.24.
If you goto Winamp Preferences, under General Preferences select Titles. Then ensure, Use the advanced title formatting is checked on, and the format string I'm using is,
[%artist%$if2( %#Helium Featured Artist%,) - ]$if2(%title%,$filepart(%filename%))
and it seems to work on all the files I put the tags on.
Winamp passes all the tags contained within the %..% to in_mad, then in_mad finds the tag (artist, title, #Helium Featured Artist etc.) and reports if its there or not. If you can read C, look at "in_mad.c" and "tags.c" - for an idea of how to work it.
I'll add it eventually to the basic formatting.
I'm having a big problem with libid3tag writing tags that nothing else understands, so please bear with me.
Thanks for all help
This post has been edited by MoSPDude: Aug 5 2006, 14:59
MoSPDude
post Aug 5 2006, 15:09
Post #65
The problem does appear to be a long libid3tag problem, and the common solution is to patch libid3tag so it writes ID3v2.3 tags instead of v2.4.
For now, I'll follow the same solution.
An update will be available shortly.
odyssey
post Aug 5 2006, 15:36
Post #66
Edit: I REALLY need to learn to read before posting tongue.gif
This post has been edited by odyssey: Aug 5 2006, 15:38
MoSPDude
post Aug 5 2006, 16:46
Post #67
Does anyone use iTunes?? Can someone please see if iTunes reads the tags written by in_mad correctly?
The patch that audacity applied to write id3v2.3 tags, stops libid3tag reading the tags in. I have no idea why...
bubka
post Aug 5 2006, 16:48
Post #68
anyway to fix the visualization so that it's not all maxed out? I have both RG (radio) and clipping enabled. Also have id3v1 show by default. Thanks! i think the 24bit output adds quite a bit extra... keep up the work!
Chaintech AV-710
MoSPDude
post Aug 5 2006, 20:41
Post #69
I'm having a fair bit of trouble regarding ID3v2.3 and v2.4 tags, it seems like a lottery if they get read correctly by Winamp, Helium or a few others. Disabling CRC sometimes works, and it appears fields are getting scrambled.
I'll upload a new version once I've solved it.
MoSPDude
post Aug 5 2006, 21:28
Post #70
Eureka!! libid3tag breaks the rules. I'll fix it up, and get a new release up - I've got to undo all the work on adding id3v2.3 tags! Unless you want an option to write either id3v2.3 or id3v2.4 tags??
MoSPDude
post Aug 6 2006, 01:03
Post #71
I've finally uploaded another update. ID3v2.4 tags are now written properly, on all files I tested - and can be read properly by other taggers too.
@bubka, what do you mean by visualisation maxed out? Please can I have details of what visualisation etc. I think I will add a tag select box - probably once I've looked into APE tags. I'm also thinking of adding a preamp option for mp3s without replaygain info as suggested by bladecgn.
@hecatomber, I don't know about last.fm but I'll look into it eventually.
MoSPDude
post Aug 6 2006, 15:00
Post #72
Yet another update, APEv2 tags are now read. If mp3gain undo information is detected, then replaygain is disabled. The preference for replaygain data is APE tag, id3 tag then the lame tag. APE tag writing is not yet supported.
Download from the usual http://www.zen23652.zen.co.uk/in_mad.zip
MedO
post Aug 6 2006, 17:38
Post #73
QUOTE (MoSPDude @ Aug 6 2006, 16:00) *
This is not necessary IMO, because mp3gain adjusts the replaygain information in the APE tags when it changes a file. So if the RG tags are present before mp3gain is run, they are adjusted, and if they were created after mp3gain changed the files they are correct as well. So as long as you make sure only APE-tags are read when mp3gain undo information is present, everything should work fine.
Since APE-tags are the preferred RG-source anyway you don't have to worry at all. If mp3gain doesn't adjust the RG info because tag writing is disabled, then there will be no undo info in the tags either.
This post has been edited by MedO: Aug 6 2006, 17:39
MoSPDude
post Aug 6 2006, 18:01
Post #74
Ah right, I'll make the necessary changes. I think the config box is in need of an overhaul, then I can add tag preference options etc.
Anyone found any bugs in the APE tag reading, or ID3v2 tag read/writing? The latter has been giving me some grief.
Thanks,
odyssey
post Aug 7 2006, 10:02
Post #75
QUOTE (MoSPDude @ Aug 5 2006, 21:41) *
I suspect something in Winamp is correcting it... Maybe Nullsoft in_mp3? I tried playing a file i've updated, which was not recognized the first time, but afterwards I had no problems.
Btw, is this still an error or did you correct it by writing only ID3v2.3 tags ?
RSS Lo-Fi Version Time is now: 8th July 2015 - 03:48
