Updated in_mad Winamp MAD MP3 input plugin
MoSPDude
post Jul 24 2006, 14:51
Hi, i've just finished updating the Winamp MAD input plugin 0.14.1b with,
* libmad 0.15.1b
* libid3tag 0.15.1b
* zlib 1.23
* Gaussian dither and noise shaping routines from SSRC 1.30
* Working ID3v2 editor
* APEv2 editor
* LAME gapless playback support
* Non-LAME tagged gap skip/removal feature
* ReplayGain support
* Winamp 5 advanced formatting support
* Shoutcast streaming title support
I'd like some other people to try it, and possible fix any remaining bugs etc. that I've probably missed.
I've included source code, it was compiled in Dev-C++ using the MinGW tools. Thanks for any and all feedback in advance.
*** The LATEST bugfixed DLL can be download from http://www.zen23652.zen.co.uk/in_mad.zip ***
This post has been edited by MoSPDude: Aug 22 2006, 14:31
odyssey
post Jul 27 2006, 11:31
QUOTE (Big_Berny @ Jul 27 2006, 08:21) *
In the mediamonkey-forum someone posted a gapless mad-version: http://www.mediamonkey.com/forum/viewtopic.php?t=10051
Maybe this feature can be ported?
This plugin actually REMOVES silence, and does not benefit from the LAME tags actually containing the missing samples:
This version examines the beginning and the end of each track for silence, and can remove up to approximately 78ms of silence from each end (3 frames). The unwanted silence is typically 50ms or less. If more than 78ms of silence is found - as is the case with normal albums - then the track will not be altered in any way. Therefore, only continuous live or mix type albums are altered.
I'd really like to have gapless playback, and maybe it can be ported from the in_mpg123 plugin?
MoSPDude
post Jul 31 2006, 16:06
I'm back from my short holiday now, ready to do some more to the plugin.
I've fixed the unknown internet stream hogging problem after looking at in_mpg123. It all relies on the user specified default extension for unknown file types. Another way to cure the hogging problem would be to change this from "mp3" to "aac" (or another file type supported by in_mp3 and NOT in_mad) in winamp preferences.
I'd like to add ReplayGain and the LAME gapless playback features. As for APEv2 tags, I'll add once I've cleaned up the ID3v2 code and am happy with that.
An updated file will be available shortly, I'll post again once its up.
Cheers for all comments :-)
- MoSPDude   Updated in_mad Winamp MAD MP3 input plugin   Jul 24 2006, 14:51
- - Garf   QUOTE (MoSPDude @ Jul 24 2006, 15:51) * G...   Jul 24 2006, 14:57
|- - MoSPDude   Perhaps so, I might make it so you can choose betw...   Jul 24 2006, 15:08
- - Garf   It's extremely interesting they can hear a dif...   Jul 24 2006, 15:24
- - MoSPDude   I thought it odd too, though I did agree - without...   Jul 24 2006, 15:37
- - adamjk   So, at first I should compile it? Thank you very m...   Jul 24 2006, 18:00
- - MoSPDude   There is a ready compiled DLL in there called ...   Jul 24 2006, 18:44
|- - adamjk   QUOTE (MoSPDude @ Jul 24 2006, 18:44) The...   Jul 24 2006, 19:53
|- - MedO   All running, but opening the file info box crashes...   Jul 24 2006, 20:38
|- - MoSPDude   Will try and track it down, initial tests point to...   Jul 24 2006, 21:15
- - amano   Is there media library support now?   Jul 24 2006, 19:41
- - MoSPDude   In the test file, do you know what the ID3v2 tag f...   Jul 24 2006, 21:43
|- - MoSPDude   Media library support will be in the next build ho...   Jul 24 2006, 22:00
||- - MoSPDude   I've added media library support, its probably...   Jul 24 2006, 22:52
|- - MedO   QUOTE (MoSPDude @ Jul 24 2006, 22:43) In ...   Jul 24 2006, 23:42
- - niktheblak   Holy dead decoder resurrection, Batman! How m...   Jul 25 2006, 08:01
- - odyssey   Wow, I LOVE the way you show the original tagfield...   Jul 25 2006, 09:08
- - MoSPDude   Making the ID3v2 editor friendly is on the to-do l...   Jul 25 2006, 22:18
- - odyssey   QUOTE (MoSPDude @ Jul 25 2006, 22:18) I...   Jul 26 2006, 08:12
- - john33   @MoSPDude, we'd be happy to host this at Rarew...   Jul 26 2006, 08:37
|- - MoSPDude   QUOTE (john33 @ Jul 26 2006, 08:37) @MoSP...   Jul 26 2006, 09:11
|- - john33   QUOTE (MoSPDude @ Jul 26 2006, 09:11) Tha...   Jul 26 2006, 09:40
- - MoSPDude   This is going to be that last update for next 5 da...   Jul 26 2006, 18:41
- - Mr_Rabid_Teddybear   Sorry I can't test this myself (I'm in the...   Jul 26 2006, 21:59
- - gameplaya15143   QUOTE (Mr_Rabid_Teddybear @ Jul 26 2006, 16...   Jul 26 2006, 23:47
- - Big_Berny   In the mediamonkey-forum someone posted a gapless ...   Jul 27 2006, 08:21
- - odyssey   QUOTE (Big_Berny @ Jul 27 2006, 08:21) In...   Jul 27 2006, 11:31
|- - MoSPDude   Hi, I'm back from my short holiday now, ready ...   Jul 31 2006, 16:06
- - odyssey   QUOTE (MoSPDude @ Jul 31 2006, 16:06) I...   Jul 31 2006, 16:25
- - MoSPDude   I've updated http://www.zen23652.zen.co.uk/in_...   Jul 31 2006, 23:13
- - gameplaya15143   YAY! I do hope you leave access to the advanc...   Jul 31 2006, 23:35
- - MoSPDude   Another update, I've added gapless playback f...   Aug 1 2006, 22:39
|- - MedO   Great work MoSPDude! Is this, then, the first ...   Aug 2 2006, 10:58
|- - haregoo   QUOTE (MedO @ Aug 2 2006, 18:58) Great wo...   Aug 2 2006, 11:39
- - odyssey   QUOTE Keep in mind that LAME tag replaygain adjust...   Aug 2 2006, 11:56
- - MoSPDude   Good point, I hadn't thought of that. I could ...   Aug 2 2006, 21:35
|- - haregoo   QUOTE (MoSPDude @ Aug 3 2006, 05:35) Anyo...   Aug 2 2006, 22:18
- - MoSPDude   Ok, after reading through LAME source and a few he...   Aug 3 2006, 00:04
|- - haregoo   QUOTE (MoSPDude @ Aug 3 2006, 08:04) Ok, ...   Aug 3 2006, 00:29
- - bladecgn   Hey MoSPDude! I had been experimenting with v...   Aug 3 2006, 19:11
|- - TrNSZ   QUOTE (bladecgn @ Aug 3 2006, 14:11) I ha...   Aug 3 2006, 19:35
- - odyssey   QUOTE (MoSPDude @ Aug 3 2006, 01:04) Ok, ...   Aug 3 2006, 19:15
- - MoSPDude   I'll have a look into why pcutmp3 files aren...   Aug 3 2006, 19:57
- - MoSPDude   Another update, download from the usual. I've...   Aug 4 2006, 10:11
- - Big_Berny   Hi, I just tried the the mad-plugin with MediaMonk...   Aug 4 2006, 11:05
|- - MoSPDude   QUOTE (Big_Berny @ Aug 4 2006, 11:05) Hi,...   Aug 4 2006, 11:28
|- - MedO   QUOTE (Big_Berny @ Aug 4 2006, 12:05) Hi,...   Aug 4 2006, 11:31
- - Big_Berny   Thanks! By the way, I have no DSP plugin acti...   Aug 4 2006, 11:55
- - hecatomber   After using this input plugin, I have some problem...   Aug 4 2006, 12:08
- - odyssey   QUOTE (MoSPDude @ Aug 4 2006, 11:11) I...   Aug 4 2006, 16:32
- - MoSPDude   My bad with the MediaMonkey / DSP problem, I'd...   Aug 4 2006, 17:46
- - MoSPDude   Ok, I've uploaded an update to the usual. Ple...   Aug 4 2006, 19:07
- - Big_Berny   Well, I don't know the reason but 1151 is 576*...   Aug 4 2006, 19:14
|- - MoSPDude   QUOTE (Big_Berny @ Aug 4 2006, 19:14) Wel...   Aug 4 2006, 19:20
|- - MoSPDude   I've put up the version, ignoring the 1 sample...   Aug 4 2006, 19:32
- - Big_Berny   Maybe a Lame developer can give more informations?...   Aug 4 2006, 19:27
- - odyssey   QUOTE (MoSPDude @ Aug 4 2006, 20:32) I...   Aug 5 2006, 00:19
- - MoSPDude   Another update has been uploaded, I think I've...   Aug 5 2006, 01:38
|- - MoSPDude   Another update uploaded, this time for odyssey to ...   Aug 5 2006, 10:47
|- - MedO   Wow, great work. Just another question: What is th...   Aug 5 2006, 11:08
|- - MoSPDude   QUOTE (MedO @ Aug 5 2006, 11:08) Wow, gre...   Aug 5 2006, 12:11
- - MoSPDude   DON'T WRITE UPDATED ID3v2 TAGS!! Ther...   Aug 5 2006, 12:38
- - odyssey   QUOTE (MoSPDude @ Aug 5 2006, 11:47) In W...   Aug 5 2006, 14:13
|- - MoSPDude   QUOTE (odyssey @ Aug 5 2006, 14:13) QUOTE...   Aug 5 2006, 14:55
|- - MoSPDude   The problem does appear to be a long libid3tag pro...   Aug 5 2006, 15:09
- - odyssey   Edit: I REALLY need to learn to read before postin...   Aug 5 2006, 15:36
- - MoSPDude   Does anyone use iTunes?? Can someone please see if...   Aug 5 2006, 16:46
- - bubka   anyway to fix the visualization so that it's n...   Aug 5 2006, 16:48
- - MoSPDude   I'm having a fair bit of trouble regarding ID3...   Aug 5 2006, 20:41
- - MoSPDude   Eureka!! libid3tag breaks the rules. I...   Aug 5 2006, 21:28
- - MoSPDude   I've finally uploaded another update. ID3v2.4 ...   Aug 6 2006, 01:03
- - MoSPDude   Yet another update, APEv2 tags are now read. If mp...   Aug 6 2006, 15:00
|- - MedO   QUOTE (MoSPDude @ Aug 6 2006, 16:00) If m...   Aug 6 2006, 17:38
- - MoSPDude   Ah right, I'll make the necessary changes. I t...   Aug 6 2006, 18:01
- - odyssey   QUOTE (MoSPDude @ Aug 5 2006, 21:41) it s...   Aug 7 2006, 10:02
|- - MedO   QUOTE (odyssey @ Aug 7 2006, 11:02) Btw, ...   Aug 7 2006, 10:35
- - MoSPDude   The tags that are written are ID3v2.4 , there is s...   Aug 8 2006, 00:45
- - gameplaya15143   remember that crashing problem? I haven't got...   Aug 8 2006, 01:09
- - MoSPDude   Ah right, do you have a test file that can reprodu...   Aug 8 2006, 09:42
- - odyssey   QUOTE (MoSPDude @ Aug 8 2006, 01:45) I th...   Aug 8 2006, 09:48
- - MoSPDude   Ok, I've done some more bug fixing. A new rele...   Aug 8 2006, 18:00
- - odyssey   QUOTE (MoSPDude @ Aug 8 2006, 19:00) I ho...   Aug 8 2006, 18:21
- - bladecgn   Hi Craig... I installed MiniLyrics yesterday (cool...   Aug 9 2006, 08:17
|- - MoSPDude   QUOTE (bladecgn @ Aug 9 2006, 08:17) Hi C...   Aug 9 2006, 20:23
- - MoSPDude   I've uploaded a version that should work with ...   Aug 9 2006, 22:15
- - MoSPDude   Ok, after another look, I've fixed a problem w...   Aug 11 2006, 07:32
|- - MedO   QUOTE (MoSPDude @ Aug 11 2006, 08:32) Ok,...   Aug 11 2006, 10:00
- - gameplaya15143   QUOTE (MoSPDude @ Aug 11 2006, 02:32) Any...   Aug 11 2006, 20:53
- - MoSPDude   Slight delay on the update, I don't want to le...   Aug 11 2006, 22:06
|- - MedO   QUOTE (MoSPDude @ Aug 11 2006, 23:06) @Me...   Aug 12 2006, 01:10
- - MoSPDude   Another update has been uploaded, download from th...   Aug 11 2006, 23:36
- - gameplaya15143   MoSPDude I just downloaded the latest.. Absolu...   Aug 12 2006, 05:42
- - bladecgn   First off, thank you MoSPDude for correcting the l...   Aug 12 2006, 05:47
- - MoSPDude   Yeah, the thought had crossed my mind to call it ...   Aug 12 2006, 09:49
- - gameplaya15143   Did a feature get lost? I thought that previously...   Aug 12 2006, 20:20
- - MoSPDude   I haven't properly got round to adding the pre...   Aug 13 2006, 00:06
- - MoSPDude   I've fixed some more problems relating to the ...   Aug 13 2006, 12:10
- - bladecgn   Hi... got another idea: In the Preferences, you c...   Aug 13 2006, 13:17
- - MoSPDude   Another update, I've fixed ID3 to APE tag read...   Aug 13 2006, 15:18
- - MoSPDude   For the next update, I've added streaming titl...   Aug 14 2006, 23:05
4 Pages V   1 2 3 > »
RSS Lo-Fi Version Time is now: 2nd June 2015 - 21:05
