foo_dsp_centercut, Cut centre channel/isolate sides óoró cut side channels/isolate centre
Moitah
post Jul 18 2006, 08:14
foo_dsp_centercut v1.0.1 [link is dead and was foobar2000 v 0.9–only anyway—Ed.]
The classic "vocal cut" filter, except that the output is stereo instead of mono. This is accomplished through FFT phase analysis.
This version includes recently discovered algorithm improvements to reduce echo and eliminate clicking.
foobar2000 v 1.x–compatible compile, by mudlord, reuploaded by db1989:
QUOTE (db1989 @ May 19 2012, 19:18) *
Information on the algorithm, as implemented in VirtualDub:
QUOTE (xnor @ Nov 25 2011, 13:12) *
Old threads:
• Original Winamp version: ‘Winamp "Center Cut" DSP Plugin released
• First release by Chun-Yu: ‘Center Cut DSP
This post has been edited by db1989: May 19 2012, 19:22
Reason for edit: I previously added everything after the —, and I just reuploaded mudlord’s compile.
Moitah
post Aug 3 2006, 06:26
Actually it works pretty well. I can't make a preference section so I would have to add 2 more items in the Available DSP list, and the crossover frequency wouldn't be configurable. I'll see about it when I get time.
david_dl
post Aug 3 2006, 06:36
QUOTE (Moitah @ Aug 3 2006, 18:26) *
Why can't you create a preferences page?
Moitah
post Aug 3 2006, 07:37
QUOTE (david_dl @ Aug 3 2006, 01:36) *
I've never done GUI in C++ and don't really care to learn.
- Moitah   foo_dsp_centercut   Jul 18 2006, 08:14
- - PredUK   What does this do? Does it play just vocals from a...   Jul 18 2006, 11:56
- - kjoonlee   Yay! Thank you. With this DSP, you can play ...   Jul 18 2006, 14:02
- - dv1989   Cool! Continued development and improvement, p...   Jul 18 2006, 14:26
- - Moitah   1.0.1 released, minor changes (renamed to foo_dsp_...   Jul 18 2006, 21:41
- - Eclipsed Moon   THANK you, REALLY been waiting for this one.   Jul 19 2006, 08:11
- - mdhare007   Moitah- Would it be possible to add a lowpass fil...   Aug 3 2006, 03:00
- - Moitah   Actually it works pretty well. I can't make a...   Aug 3 2006, 06:26
|- - david_dl   QUOTE (Moitah @ Aug 3 2006, 18:26) Actual...   Aug 3 2006, 06:36
|- - Moitah   QUOTE (david_dl @ Aug 3 2006, 01:36) Why ...   Aug 3 2006, 07:37
- - dv1989   This plugin is really good. If you could figure ou...   Aug 3 2006, 21:18
- - Davide-NYC   First off, Thank you so much for this great plugin...   Oct 21 2007, 22:06
- - Octopus   ta muchly for this!   Sep 2 2008, 18:43
|- - lctm   Awesome! Thanks a lot. And having this in foo...   Oct 6 2008, 12:12
- - drbeachboy   Moitah, I was wondering if you had any plans on u...   Oct 21 2008, 02:38
- - McFrog   I recompiled this plugin for foobar 0.9.6, don...   Apr 9 2009, 10:41
- - microZ   It doesn't work in windows 7 build 7068 64-bit...   Apr 9 2009, 13:29
- - drbeachboy   Sure, it would be great to have an updated version...   Apr 9 2009, 14:03
- - McFrog   As a temporary solution you can download my build ...   Apr 9 2009, 14:46
- - drbeachboy   Thanks, McFrog! It is working well on my XP ma...   Apr 9 2009, 15:22
|- - Yirkha   QUOTE (drbeachboy @ Apr 9 2009, 16:22) Th...   Apr 9 2009, 15:30
- - McFrog   It's not a rar, its 7z. i used the php wrapper...   Apr 9 2009, 15:35
- - Moitah   Fine with me. I just don't use foobar2000 tha...   Apr 9 2009, 15:40
- - drbeachboy   @Yirkha, Because, this .php extension thing has p...   Apr 9 2009, 15:58
|- - amdx2   can anyone have foo_entercut for foobar v1.? its e...   Feb 10 2011, 08:43
- - mudlord   RE: foo_dsp_centercut   Feb 10 2011, 10:31
|- - amdx2   QUOTE (mudlord @ Feb 10 2011, 16:31) th...   Feb 10 2011, 10:50
- - mudlord   Only one way to find out I guess.   Feb 10 2011, 10:54
- - dv1989   I should have said this back when I downloaded it:...   Apr 27 2011, 11:34
|- - absinthe33   Hi, I don't know if this plugin is still being...   Oct 11 2011, 05:16
- - Dexter_prog   I'm bumping this because this is the best comp...   Nov 25 2011, 13:30
- - xnor   the center-cut algorithm   Nov 25 2011, 14:12
- - db1989   Wow, thanks for that! I was especially amused ...   Nov 26 2011, 15:31
- - xnor   Well, I don't think you need much audio/DSP kn...   Nov 26 2011, 20:36
- - db1989   Yeah, Iím sure youíre correct. Itís just that it s...   Nov 26 2011, 20:40
|- - Yakumo   Thread necromancy I know, but it's a real sham...   May 19 2012, 18:54
- - db1989   Actually, following the trail showed me that the l...   May 19 2012, 19:18
- - goodiesguy   The latest foobar is saying this is unsupported wh...   Feb 20 2014, 08:30
- - mudlord   Loads fine here.   Feb 20 2014, 12:52
- - goodiesguy   That's odd, it's working fine here now too...   Feb 21 2014, 07:23
- - stephan_g   This one is handy! It cleans up a crackly mono...   Oct 4 2014, 23:30
RSS Lo-Fi Version Time is now: 2nd July 2015 - 06:30
