foo_title, new version for 0.9
Quiark
post Jul 17 2006, 19:20
Hi, I'm back with my foo_title component. This component shows a small window with some track info and buttons so that you can have your main foobar window minimized. Something like Winamp's windowshade mode.
I have ported it to 0.9 and changed a lot of things. It now has extended skin support and is hopefully more stable.
.NET Framework 2.0 is needed, download here (22.4 MB): http://msdn.microsoft.com/netframework/dow...es/default.aspx (".NET Framework Version 2.0 Redistributable Package")
Current version: 0.7.1 (Vista compatible)
foo_title is now open source, under LGPL (I hope it doesn't interfere with foobar2000).
Screenshots:
Download:
https://sourceforge.net/project/showfiles.p...group_id=178279
Documentation and Changelog:
http://foo-title.sourceforge.net/
Alternative docs on the wiki:
http://wiki.hydrogenaudio.org/index.php?ti...%28foo_title%29
Skins thread:
http://www.hydrogenaudio.org/forums/index....showtopic=46619
This post has been edited by Quiark: Aug 4 2008, 17:09
Bachi-Bouzouk
post Jul 17 2006, 22:03
I think that roentgen suggested to call at least one of two dll foo_title, Just a matter of name. All plugins are called foo_whatever.dll and it would "mark" your plugin as a foobar plugin, it's true that it has become a standard (if not an obligation ??)
Something as lightweight as you component without any optimization is ohmy.gif really great. Because usually graphic elements are greedy.
My father told me a couple of days ago that a minimized mode was the only good thing in WMP, now foobar has something similar smile.gif
@roentgen you should see something like one of the two pictures posted in the first post.
This post has been edited by Bachi-Bouzouk: Jul 17 2006, 22:05
Foobar 0.9.X manual - http://eolindel.free.fr/foobar0.9/
roentgen
post Jul 17 2006, 22:14
QUOTE (Bachi-Bouzouk @ Jul 18 2006, 00:03) *
Well... it seems that one foobar restart is not enough. After second restart is working as expected.
roentgen
post Jul 17 2006, 22:40
QUOTE (roentgen @ Jul 18 2006, 00:14) *
Definitely there is problem....
I removed the dll's (just for testing), I also removed the settings when foobar asked.
Re-added the dll's but the plugin did not load after 9-10 foobar restarts, although 'foo_managedWrapper.dll' was listed under loaded components. Also there was no foo_title page in configuration.
After 11-th restart things worked... without me doing anything special.
- Quiark   foo_title, new version for 0.9   Jul 17 2006, 19:20
- - tomthomson   thanks for that one I've used the advanced c...   Jul 17 2006, 19:57
- - Generalverdacht   hm. im not a real noob, but this time i dont get t...   Jul 17 2006, 19:59
- - tomthomson   you are able to display track infos or even contro...   Jul 17 2006, 20:07
- - fabiospark   QUOTE (Quiark @ Jul 17 2006, 20:20) Hi, I...   Jul 17 2006, 20:38
|- - Quiark   Well, that would need to be created in a different...   Jul 17 2006, 20:51
- - Bachi-Bouzouk   it seems very promising, but I feel very stupid, I...   Jul 17 2006, 20:58
- - Lycox   Can you add a feature that only shows the plugin w...   Jul 17 2006, 21:10
- - roentgen   QUOTE edit2 It was that: putting the foo_title fol...   Jul 17 2006, 21:32
|- - Bachi-Bouzouk   QUOTE (roentgen @ Jul 17 2006, 22:32) Aha...   Jul 17 2006, 21:37
- - roentgen   CODEdotnet_title.dll foo_managedWrapper.dll These ...   Jul 17 2006, 21:42
- - Quiark   roentgen: there's no foo_title.dll, there is o...   Jul 17 2006, 21:56
|- - roentgen   QUOTE (Quiark @ Jul 17 2006, 23:56) roent...   Jul 17 2006, 22:02
|- - Lycox   QUOTE (Quiark @ Jul 17 2006, 21:56) I...   Jul 17 2006, 22:06
- - Bachi-Bouzouk   I think that roentgen suggested to call at least...   Jul 17 2006, 22:03
|- - roentgen   QUOTE (Bachi-Bouzouk @ Jul 18 2006, 00...   Jul 17 2006, 22:14
|- - roentgen   QUOTE (roentgen @ Jul 18 2006, 00:14) QUO...   Jul 17 2006, 22:40
- - Quiark   There is a reason for having the files called this...   Jul 17 2006, 22:21
- - Bachi-Bouzouk   I second the bug report, It worked once, but now, ...   Jul 17 2006, 23:09
- - Quiark   Uhh, i'll try to reproduce and fix this bug. I...   Jul 18 2006, 09:15
- - Quiark   Bachi-Bouzouk could you please make an archive of ...   Jul 18 2006, 10:26
- - Lycox   After a restart of foobar the position of the comp...   Jul 18 2006, 10:41
- - Bachi-Bouzouk   @Quiark PM sent for fb2K folders I am writing a p...   Jul 18 2006, 16:35
- - Quiark   foo_title works in your foobar just fine on my com...   Jul 18 2006, 18:19
- - Bachi-Bouzouk   Incredible, I just restarted my foobar to see the ...   Jul 18 2006, 18:54
- - Quiark   I tried both versions you sent me and they still w...   Jul 18 2006, 21:28
- - Bachi-Bouzouk   The link in the last PM was with foobar crashing (...   Jul 18 2006, 21:39
- - Nova5000   CODEFailed to load DLL: foo_managedWrapper.dll...   Jul 18 2006, 21:55
- - Quiark   This seems like you only have .NET Framework 1. Li...   Jul 18 2006, 22:16
- - Bachi-Bouzouk   http://eolindel.free.fr/images/net2.png I have Mi...   Jul 18 2006, 22:38
- - Quiark   That was for Nova5000 that he doesn't have .NE...   Jul 18 2006, 23:04
- - Nova5000   I installed .NET Framework 2.0 from the link you p...   Jul 18 2006, 23:04
- - Quiark   Do you have foo_title in the preferences ? Anythin...   Jul 18 2006, 23:08
- - Nova5000   Nope. No foo_title in the preferences and nothing ...   Jul 18 2006, 23:11
- - Bachi-Bouzouk   Not sure that you saw my edits: edit Bad news: it...   Jul 18 2006, 23:12
- - Nova5000   Yeah, I'm using 0.9.2, btw   Jul 18 2006, 23:18
- - Quiark   QUOTE (Nova5000 @ Jul 19 2006, 00:18) Yea...   Jul 18 2006, 23:30
- - Nova5000   That's how I understand it yes, I'm gettin...   Jul 18 2006, 23:35
- - tool++   I second the fact that nothing happens :/   Jul 19 2006, 11:48
- - Quiark   I have created a debug version which logs some of ...   Jul 19 2006, 13:42
- - Nova5000   I downloaded your debug version and installed it, ...   Jul 19 2006, 13:59
- - foosion   QUOTE I downloaded your debug version and installe...   Jul 19 2006, 14:12
- - Quiark   Please try to download it again. It was probably b...   Jul 19 2006, 14:12
- - Bachi-Bouzouk   Crashlog with the debugging version, I can't g...   Jul 19 2006, 14:36
- - Nova5000   The skin finally worked with the debug version.. H...   Jul 19 2006, 14:36
- - Quiark   Bachi-Bouzouk: Yes, it crashes, but you should hav...   Jul 19 2006, 14:57
- - Nova5000   Nope, seems to be working fine..   Jul 19 2006, 15:39
- - Bachi-Bouzouk   I don't have any foo_title.log in my directory...   Jul 19 2006, 18:19
- - Nova5000   With the debug version, foo_title only loads when ...   Jul 19 2006, 18:29
- - Quiark   Hmm I see, when you don't start foobar from it...   Jul 19 2006, 19:11
- - Nova5000   Just a quick question related to making skins. Ho...   Jul 19 2006, 19:43
- - Quiark   Hmm.. wait for the next release /me writing a new...   Jul 19 2006, 19:54
- - Nova5000   In that case, I suggest italics as well Just mad...   Jul 19 2006, 20:19
- - tool++   oooh, it finally worked when I started fb2k by dou...   Jul 19 2006, 20:57
- - Bachi-Bouzouk   Congratulations, it works now, I started in anothe...   Jul 19 2006, 21:36
- - joeblow1102   QUOTE (tool++ @ Jul 19 2006, 13...   Jul 20 2006, 03:28
- - Quiark   Remembering position will be in the next release w...   Jul 20 2006, 10:15
- - joeblow1102   always on top is a setting where say i minimize fo...   Jul 20 2006, 14:40
- - Quiark   Well it should work like this (that foo_title is a...   Jul 20 2006, 15:32
- - Nova5000   I think it could be good, that if you have a skin ...   Jul 20 2006, 16:31
- - Quiark   Well it is possible but I don't think it's...   Jul 20 2006, 16:45
- - vonmeth   Just wanted to say thanks! I'm loving this...   Jul 20 2006, 17:12
- - joeblow1102   QUOTE (Quiark @ Jul 20 2006, 08:32) Well ...   Jul 20 2006, 18:49
- - Quiark   QUOTE i drag it to the top of my screen, and it st...   Jul 20 2006, 19:00
- - 1stdayonthejob   is there going to be support for non English folde...   Jul 20 2006, 19:04
- - joeblow1102   QUOTE (Quiark @ Jul 20 2006, 12:00) QUOTE...   Jul 20 2006, 19:17
- - djet   Nice one! Bug: It shows up as a Form1 windo...   Jul 20 2006, 19:34
- - Nova5000   QUOTE (djet @ Jul 20 2006, 20:34) Nice on...   Jul 20 2006, 19:55
- - Quiark   QUOTE (djet @ Jul 20 2006, 20:34) Nice on...   Jul 21 2006, 00:33
|- - djet   QUOTE (Quiark @ Jul 21 2006, 03:33) Well ...   Jul 21 2006, 16:55
- - Quiark   QUOTE (joeblow1102 @ Jul 20 2006, 19:49) ...   Jul 21 2006, 01:12
- - tool++   Just tried making my own skin. Text rendering is ...   Jul 21 2006, 12:19
- - Quiark   Yes, ClearType is turned off, because of a bug in ...   Jul 21 2006, 12:25
- - EpS   I was wondering if theres any way to add a basic f...   Jul 22 2006, 13:28
- - Nova5000   You could I suppose, make an animation following t...   Jul 22 2006, 19:15
- - BenniP   First of all, thank you for this great plugin...   Jul 23 2006, 11:20
- - Faust   **sorry, just needed a restart ^^' ** One add...   Jul 23 2006, 19:26
- - Quiark   As for the not working always on top problem: Coul...   Jul 25 2006, 13:17
- - joeblow1102   well, it works in foo_prettypop and also in YAPP i...   Jul 25 2006, 14:56
- - Matt Schuette   This is a plugin I have been wanting for a while n...   Aug 1 2006, 17:45
- - Quiark   I'm using the new C++/CLI syntax for the wrapp...   Aug 1 2006, 17:56
- - Quiark   New 0.6 version released. Changelog: * suppor...   Aug 1 2006, 19:48
- - vingtdeux   great update! thanks a lot & keep the good...   Aug 1 2006, 20:15
- - joeblow1102   Ok, i figured out why it doesn't stay always o...   Aug 1 2006, 20:33
- - Quiark   It's a limitation of windows. The only thing I...   Aug 1 2006, 20:40
- - joeblow1102   yeah it's ok, i just decided to put foo_title ...   Aug 1 2006, 20:54
- - FrDelefortrie   it could be very good, a bit like a foo_pretty pop...   Aug 1 2006, 21:21
- - 1stdayonthejob   thanks Quiark for the unicode folder name support   Aug 1 2006, 23:02
- - Hedin   Is there any way to assign masstagger script to fo...   Aug 3 2006, 09:29
|- - Quiark   QUOTE (Hedin @ Aug 3 2006, 10:29) Is ther...   Aug 5 2006, 16:38
- - Quiark   QUOTE (joeblow1102 @ Aug 1 2006, 21:54) y...   Aug 3 2006, 16:35
- - Hedin   QUOTE This command depends on the context - which ...   Aug 5 2006, 21:40
- - gob   nice plugin! just installed it. though next cl...   Aug 6 2006, 05:53
- - dmber   thanks for the plugin! really trying to get i...   Aug 6 2006, 18:03
- - rendom   Can you make please option, to show this plugin wh...   Aug 9 2006, 21:23
- - joeblow1102   QUOTE (rendom @ Aug 9 2006, 14:23) Can yo...   Aug 10 2006, 00:21
- - Quiark   dmber: Could you please make a screenshot of the f...   Aug 12 2006, 22:10
|- - jon.schaffer   Is there a way to display an 'ellipsized' ...   Aug 15 2006, 15:09
- - Ken-chan   I'd suggest using a fixed-widt font for that, ...   Aug 15 2006, 15:31
- - onur   Thankyou for this plugin, I really like it. I hav...   Aug 15 2006, 15:36
4 Pages V   1 2 3 > »
RSS Lo-Fi Version Time is now: 29th January 2015 - 11:37
