foo_uie_tabs [NOTMYRELEASE]
Meez
post Jul 2 2006, 16:15
http://foobar.s53.xrea.com/up/files/up199.zip
Not even sure who made it, but it annoyed me that it took me so long of searching the forum to find it again that I had to post it here for ease of finding, and also for the ease of other users.
If the author could come forward and post some more info or?
ayana
post Sep 15 2006, 17:05
foo_uie_tabs_0.2.4.zip
It is the unofficial version that gave personal modifying.
* Would be able to hide tabs
* Set limit MinHeight per tabs
* Operate tabs from mainmenu
(notice: GUID of mainmenu commands is created from tab names, so I'll recommend that you change tab names)
and some fixes by an original porter to 0.9:
* Fix unnecessary dynamic_cast<>
* Fix that would be able to add some panel types into the tab from "Add Tab" menu (playlist, splitter)
* Improve stability of reading configure
ex. changing panels and tool buttons from customized buttons
I'm not an original author of foo_uie_tabs, or a porter to 0.9. Thanks to them.
mazy
post Sep 29 2006, 16:35
ayana, that feature to hide tab-bar and switch between tabs using commands is great.
i have another request that would make me really happy, but i'm not sure if it's possible (and it would be definitely better as build-in feature in columns ui layout's system):
way to toggle visibility of the whole tab panel.
info about my tag guesser script for foo_lua (preview version available):
http://www.hydrogenaudio.org/index.php?showtopic=16987
Stuart60611
post Sep 29 2006, 16:56
I wanted to report a bug I discovered in this version. I tried to create a tabbed panel stack consisting of a playlist tab and thereunder single column playlist view and another playlist tab and thereunder mutliple column playlist. I then tried to create buttons to switch between each playlist view. However, because each there are now two items under the main menu for button configuration showing playlist tab (one with single column playlist thereunder and one for mutliple column playlist), the button configuration menu only allows me to assign a button to the first playlist tab and not the second. As such, I can only assign a button to one of the playlist tabs under tabbed panel stack even though I can see the other under the main menu for button configuration. I think the fix that needs to be employed is when you have a panel stack with two of the same components thereunder they need to be named differently for purposes of placing them in the main menu, such as playlist tab(1) and playlist tab(2) so that foobar does not get confused as to which one should be assigned to a particular button.
This post has been edited by Stuart60611: Sep 29 2006, 17:10
- Meez   foo_uie_tabs [NOTMYRELEASE]   Jul 2 2006, 16:15
- - Betse   http://www.hydrogenaudio.org/forums/index....ndpos...   Jul 2 2006, 16:50
- - Hakubo   Considering how tanka posted the link without a wo...   Jul 2 2006, 17:06
- - Meez   QUOTE (Betse @ Jul 2 2006, 16:50) http://...   Jul 2 2006, 18:16
|- - Betse   QUOTE (Meez @ Jul 2 2006, 19:16) QUOTE (B...   Jul 2 2006, 19:50
- - Bl@ck_warrior   very good   Jul 2 2006, 19:07
- - Generalverdacht   yeah thanks to who ever did it. so much requsts bu...   Jul 2 2006, 19:53
- - Zimdgre   QUOTE (tanka) http://foobar.s53.xrea.com/up/files/...   Jul 3 2006, 10:04
- - david_dl   Try this. I think the server's in Auckland.   Jul 3 2006, 10:07
|- - Zimdgre   QUOTE (david_dl @ Jul 3 2006, 17:07) Try ...   Jul 3 2006, 12:18
- - Squeller   One of the few most important ports! Good news...   Jul 3 2006, 12:06
- - tool++   Bah, I was to late with ze email.   Jul 3 2006, 12:41
- - Sphix   Nice release, thanks   Jul 3 2006, 17:47
- - rouge   In your face, Chinese censors.   Jul 4 2006, 22:19
- - RavenSoft   The previous release was not the final release app...   Jul 9 2006, 06:00
|- - Zimdgre   QUOTE (RavenSoft @ Jul 9 2006, 13:00) The...   Jul 12 2006, 04:19
- - acedriver   changelog * fixed display of the splitter panel i...   Jul 9 2006, 09:45
- - tool++   Yay, I'm sure some config had been lost !   Jul 9 2006, 16:43
- - musosticky   I have a serious problem using foo_uie_tabs. When...   Jul 9 2006, 17:54
- - cosmosis   You are very welcome.   Jul 12 2006, 07:41
- - Zimdgre   You're my angel cosmosis. Your link works for ...   Jul 12 2006, 20:50
|- - SurfTranquille   QUOTE (Zimdgre @ Jul 12 2006, 13:50) You...   Jul 15 2006, 12:58
- - tusk   All links that are on this forum are currently bro...   Jul 16 2006, 02:15
|- - SurfTranquille   QUOTE (tusk @ Jul 15 2006, 19:15) Enjoy m...   Jul 16 2006, 08:52
- - pepoluan   Um, if you open the readme.txt in the last zipped ...   Jul 17 2006, 15:25
|- - Hakubo   QUOTE (pepoluan @ Jul 17 2006, 18:25) Um,...   Jul 17 2006, 16:44
- - pepoluan   Ahh, that's a great relief for my conscience. ...   Jul 17 2006, 19:15
- - ...Just Elliott   Horrible bump, but is there a way to change the ti...   Sep 4 2006, 21:18
|- - pepoluan   QUOTE (...Just Elliott @ Sep 5 2006, 03:1...   Sep 4 2006, 21:29
- - Yotsuya   Right click on the tab and choose "Rename tab...   Sep 4 2006, 22:01
- - ayana   foo_uie_tabs_0.2.4.zip It is the unofficial versi...   Sep 15 2006, 17:05
|- - mazy   ayana, that feature to hide tab-bar and switch bet...   Sep 29 2006, 16:35
|- - Stuart60611   I wanted to report a bug I discovered in this vers...   Sep 29 2006, 16:56
- - Yotsuya   Excellent! Linking buttons to tabs has been so...   Sep 15 2006, 20:07
|- - andro77   Very nice, thank you! I have a request... don...   Sep 20 2006, 20:08
- - Superunknown   (oops, post in the wrong topic)   Sep 26 2006, 09:51
- - Slourte   I don't know if this has been talked about ear...   Sep 27 2006, 00:32
|- - spex04   QUOTE (Slourte @ Sep 27 2006, 00:32) I do...   Sep 27 2006, 00:38
|- - cartman(2vd)   (useless post) sry spex already answered it.   Sep 27 2006, 00:38
- - Slourte   w00t, thanks Spex.   Sep 27 2006, 00:46
- - DeepDose   thank you, working good in foo 0.9.4   Sep 27 2006, 04:36
- - Yotsuya   You can rename the tabs to anything you'd like...   Sep 29 2006, 17:16
|- - Stuart60611   QUOTE (Yotsuya @ Sep 29 2006, 11:16) You ...   Sep 29 2006, 17:29
- - Ken-chan   QUOTE (andro77 @ Sep 20 2006, 21:08) Very...   Sep 30 2006, 12:52
|- - andro77   QUOTE (Ken-chan @ Sep 30 2006, 13:52...   Sep 30 2006, 13:19
- - ayana   foo_uie_tabs 0.2.5 release. * add: Circulate forwa...   Oct 17 2006, 16:01
|- - Hamallainen   QUOTE (ayana @ Oct 17 2006, 16:01) * add:...   Oct 17 2006, 16:38
- - musosticky   thank you very much for the update   Oct 17 2006, 20:15
- - Melomane   i notice problem if i use splitter inside tab and...   Oct 21 2006, 12:11
|- - Stuart60611   I have been experimenting with creating a turn key...   Oct 27 2006, 22:59
|- - Raclo   >Stuart60611 Hi, I already managed to "cl...   Oct 28 2006, 15:54
|- - Stuart60611   QUOTE (Raclo @ Oct 28 2006, 09:54) >St...   Oct 28 2006, 15:58
- - ema nymton   another new user here - tried searching/browsing f...   Oct 28 2006, 19:31
- - gob   the new options on this plugin are priceless. i c...   Nov 11 2006, 05:13
|- - fabiospark   QUOTE (gob @ Nov 11 2006, 06:13) the new ...   Nov 12 2006, 20:43
- - q-stankovic   These new versions became incredible and very usef...   Nov 12 2006, 18:12
- - shakey_snake   How Do I unhide the Tabbar?   Nov 12 2006, 21:05
- - aliendesaster   View->tabbed panel stack mod->show/hide   Nov 12 2006, 21:25
- - shakey_snake   gracias.   Nov 12 2006, 21:40
- - Squeller   I want to create a layout with uie_tabs as the roo...   Dec 17 2006, 16:13
|- - BlindSeer   QUOTE (Squeller @ Dec 17 2006, 07:13) I w...   Dec 17 2006, 16:24
- - Yotsuya   Squeller: Interesting bug I played around with th...   Dec 17 2006, 16:18
- - Squeller   Yes, I found the solution myself and made a vert. ...   Dec 17 2006, 16:28
- - Yotsuya   Has anyone discovered a way to programatically det...   Feb 8 2007, 23:07
|- - shakey_snake   QUOTE (Yotsuya @ Feb 8 2007, 17:07) Has a...   Feb 9 2007, 01:17
- - O-pos   I've put this plugin for tabs in the component...   Mar 17 2007, 18:50
|- - Squeller   QUOTE (O-pos @ Mar 17 2007, 09:50) I...   Mar 17 2007, 18:52
- - O-pos   How can I do that? I kind of added "tabbed pa...   Mar 18 2007, 13:36
- - aliendesaster   You can add or remove tabs by using the menu which...   Mar 18 2007, 13:59
|- - O-pos   QUOTE (aliendesaster @ Mar 18 2007, 06:59...   Mar 18 2007, 15:04
- - aliendesaster   Well, then move up the tabbed panel stack mod once...   Mar 18 2007, 16:02
- - O-pos   Wow, now it works. I unlocked everything and it he...   Mar 18 2007, 17:12
- - O-pos   Ok, I've managed it. I've just removed it ...   Mar 18 2007, 17:37
- - aliendesaster   Certainly "possible", yes, but no one ha...   Mar 18 2007, 21:32
- - daniel86   hello i use quicksearch and tab playlist. foobar 0...   Apr 17 2007, 21:25
- - Paine-   Sorry for the bump, but does anyone have a mirror ...   Jun 7 2007, 18:21
- - Keikonium   LINK 0.2.5 Here you go   Jun 7 2007, 18:29
- - JadeElephant   Thanks a lot Keikonium.   Jun 13 2007, 05:34
- - John n' y   really useful and essential plugin- thx   Jul 4 2007, 09:38
- - Verbal Kint   This plugin doesn't work with Windows 7. Is th...   Nov 7 2009, 20:38
|- - qwertz   QUOTE (Verbal Kint @ Nov 7 2009, 20:38) T...   Nov 8 2009, 08:49
- - chiwou   Columns ui has a built in tab splitter, no need fo...   Nov 7 2009, 21:54
- - Verbal Kint   Ahh... Im using foobar just for a few weeks and di...   Nov 7 2009, 22:14
- - chiwou   if you want to use a graphical tabbed interface I ...   Nov 7 2009, 23:25
- - tedgo   This version should work: http://foobar2000.com.cn...   Nov 8 2009, 09:14
|- - gcogger   QUOTE (tedgo @ Nov 8 2009, 08:14) This ve...   Mar 5 2010, 23:23
- - tedgo   No, theres no fix for it. You need to click at lea...   Mar 6 2010, 01:23
|- - gcogger   QUOTE (tedgo @ Mar 6 2010, 00:23) No, the...   Mar 6 2010, 19:10
- - tedgo   No, you can't switch panels in PSS with keyboa...   Mar 6 2010, 20:48
- - gcogger   QUOTE (tedgo @ Mar 6 2010, 19:48) No, you...   Mar 6 2010, 22:50
RSS Lo-Fi Version Time is now: 1st February 2015 - 10:13
