Nero AAC, listening test :-)
Ivan Dimkovic
post Nov 27 2002, 13:19
Nero MPEG4 developer
Hi, - before releasing final version I would like to hear audiophiles opinion about two noise allocation strategies we can use.
These two versions will be called "build_a" and "build_b"
I've packed some of the essential "codec killers" samples in build_a.zip and build_b.zip - originals could be easily found on hydrogenaduio and mp3dev smile.gif
http://www.psytel-research.co.yu/test/
BUILD A:
http://www.psytel-research.co.yu/test/build_a.zip
BUILD B:
http://www.psytel-research.co.yu/test/build_b.zip
Files are CBR - 80, 96 and 128 kbps - 32 and 44.1 kHz sampling rate - ADIF AAC format
This post has been edited by Ivan Dimkovic: Nov 27 2002, 13:21
smok3
post Dec 1 2002, 04:32
A/V Moderator
Group: Moderator
tnx johnV i found most, which one is 41_30s ? (this isnt easy via dialup wink.gif )
- Ivan Dimkovic   Nero AAC, listening test :-)   Nov 27 2002, 13:19
- - Dibrom   I moved the thread to the news section.. it'll...   Nov 27 2002, 15:23
- - Dibrom   Result So Far: Castanets - 44.1khz@128kbps - Buil...   Nov 27 2002, 15:33
- - SK1   OH YEAH! OK, starting to test. This thread wil...   Nov 27 2002, 17:57
- - guruboolez   иии gURuBoOleZZ results (work in progress) иии I...   Nov 27 2002, 18:40
- - SK1   Forget ABXing, what's the use?? It's not l...   Nov 27 2002, 19:07
- - guruboolez   QUOTE (SK1 @ Nov 27 2002 - 07:07 PM)Forget AB...   Nov 27 2002, 19:13
- - SK1   Fair enough ...   Nov 27 2002, 19:14
- - Mac   I wish I could help more, I don't have the ear...   Nov 28 2002, 11:55
- - JohnV   What bothers me is the NIN-becoming sample and its...   Nov 28 2002, 13:08
- - Mac   I noticed the start of the NIN sample was horrible...   Nov 28 2002, 16:15
- - wildboar   The beginning of the NIN clip should have a consta...   Nov 28 2002, 18:45
- - JohnV   QUOTE (Mac @ Nov 28 2002 - 05:15 PM)I noticed...   Nov 28 2002, 22:21
- - smok3   44 khz/128 kbit: ----------- velvet_44khz_128_aac...   Dec 1 2002, 03:45
- - JohnV   As Ivan said, all the originals can be found in th...   Dec 1 2002, 04:19
- - smok3   tnx johnV i found most, which one is 41_30s ? (thi...   Dec 1 2002, 04:32
- - JohnV   QUOTE (smok3 @ Dec 1 2002 - 05:32 AM)tnx john...   Dec 1 2002, 07:58
- - Ivan Dimkovic   Ok, attack issues with NIN_becoming.wav should be...   Dec 10 2002, 15:42
- - Phobos   OHH BOY, THOSE NEW SAMPLES ARE MAD!!! ...   Dec 10 2002, 20:14
- - guruboolez   It's hard to find a difference between 2.30 sa...   Dec 10 2002, 20:57
- - Ivan Dimkovic   There is a big difference, at least with NIN_beco...   Dec 10 2002, 21:32
- - guruboolez   I will try. I tried again velved, properly decoded...   Dec 10 2002, 21:43
- - guruboolez   Confirmed. (I'm not dreaming : there is no NIN...   Dec 10 2002, 23:13
- - menno   QUOTE (guruboolez @ Dec 10 2002 - 09:43 PM)Th...   Dec 10 2002, 23:15
- - guruboolez   I downloaded this file : http://www.inf.ufpr.br/~...   Dec 10 2002, 23:27
- - menno   Yes, everything is affected. I'll make sure Ro...   Dec 10 2002, 23:32
- - guruboolez   Thanks. I used CoolEdit for one practical reason. ...   Dec 10 2002, 23:56
- - menno   Ok, new CoolEdit filter is now available from Rare...   Dec 11 2002, 09:30
- - ak   QUOTE (menno @ Dec 11 2002 - 10:30 AM)I also ...   Dec 11 2002, 10:16
- - guruboolez   Thanks, it works fine now. Glad to see that I...   Dec 11 2002, 14:03
- - ff123   QUOTE (guruboolez @ Dec 11 2002 - 05:03 AM)Th...   Dec 11 2002, 16:45
- - rjamorim   I'm going through a similar problem here. Only...   Jun 3 2003, 01:42
- - ff123   rjamorim, Regarding your recent inquiry (2 June 0...   Jun 3 2003, 15:40
- - rjamorim   I did another test. This time, I used another sam...   Jun 3 2003, 21:44
- - ff123   QUOTE (rjamorim @ Jun 3 2003 - 12:44 PM)I did...   Jun 3 2003, 22:04
- - rjamorim   QUOTE (ff123 @ Jun 3 2003 - 06:04 PM)P.S., if...   Jun 3 2003, 22:16
- - ff123   roberto, I got your file. I verified that when I...   Jun 4 2003, 05:22
- - rjamorim   Great news, ff123. Thanks a lot for taking a look ...   Jun 4 2003, 05:37
- - ff123   QUOTE (rjamorim @ Jun 3 2003 - 08:37 PM)Great...   Jun 4 2003, 05:52
- - ff123   BTW, it looks like that field is redundant, and th...   Jun 4 2003, 06:00
- - rjamorim   QUOTE (ff123 @ Jun 4 2003 - 01:52 AM)The prob...   Jun 4 2003, 06:08
- - menno   Hello ff123, Yes FAAD2 used to have a little bug ...   Jun 4 2003, 09:55
- - rjamorim   QUOTE (menno @ Jun 4 2003 - 05:55 AM)But of c...   Jun 4 2003, 18:21
- - ff123   QUOTE (rjamorim @ Jun 4 2003 - 09:21 AM)If th...   Jun 4 2003, 19:23
- - rjamorim   QUOTE (ff123 @ Jun 4 2003 - 03:23 PM)What...   Jun 4 2003, 19:47
- - ff123   Cool. How many samples are you going to try? Sou...   Jun 4 2003, 20:16
- - rjamorim   QUOTE (ff123 @ Jun 4 2003 - 04:16 PM)Cool....   Jun 4 2003, 20:31
- - Tripwire   If you take WMA9, be sure to use both Std and Pro.   Jun 4 2003, 21:33
- - rjamorim   QUOTE (Tripwire @ Jun 4 2003 - 05:33 PM)If yo...   Jun 4 2003, 21:39
- - spoon   How do Codecs with VBR fit in with 128Kbps? to be ...   Jun 4 2003, 22:25
- - rjamorim   QUOTE (spoon @ Jun 4 2003 - 06:25 PM)How do C...   Jun 4 2003, 22:33
- - guruboolez   QUOTE (rjamorim @ Jun 4 2003 - 09:39 PM)QUOTE...   Jun 4 2003, 22:41
- - rjamorim   QUOTE (guruboolez @ Jun 4 2003 - 06:41 PM)The...   Jun 4 2003, 22:52
- - spoon   The profile options for WMApro are 2 channel only ...   Jun 4 2003, 23:04
- - ff123   QUOTE (rjamorim @ Jun 4 2003 - 01:52 PM)QUOTE...   Jun 4 2003, 23:13
RSS Lo-Fi Version Time is now: 2nd July 2015 - 05:26
