[seemingly abandonware] iPod manager, also known as foo_dop
musicmusic
post May 30 2006, 14:38
Columns UI developer
iPod management component for foobar2000 0.9.5+.
Home page with details and download
Notes/FAQs/changelog available here. If you read the notes and FAQs before asking any questions, it will keep me happy smile.gif
When posting problem reports, include:
-Operating system
-iPod/iPhone model and firmware version
This post has been edited by musicmusic: Feb 22 2010, 18:41
musicmusic
post Jun 14 2006, 09:23
QUOTE (david_dl @ Jun 14 2006, 06:11) *
I'm pretty sure my 4G supports non-ascii characters, at least the europeanish ones. It correctly displays all the weird characters in Sigur Rós track names.
But that's not the filename, is it? smile.gif The metadata is usually fine. (In fact, stored in Unicode).
However, one character that my iPod refuses to display in the ARTIST list is ý. I wonder if they fixed that in later models.
Edit: the Mount and Unmount commands used to work fine (I have iPodService installed, and am using firewire,) but now i get:
IDispatch error #56938 Code: -7FFB1F96
I have seen it do that once too, it seems to be slightly temperamental (I didn't change anything from the previous versions). My guess is it has something to do with whether iTunes is running. I have no idea what the error code means right know, because the iPodService uses its own error codes. I'll see if I can work it all out..
Edit: Just tested 0.2.4 on my 4G, seems to work fine, however it messes up the sort order (it's now purely alphabetical, it used to ignore 'The'. Perhaps once this component matures we could configure a custom formatting string for use in sorting the Artist/Albums/Tracks?
Known, mentioned someplace on wiki.
The sort strings I am using are:
            t_index_pattern library_indices[] =
                {library_index_types::title, "%title%"},
                {library_index_types::album_disc_tracknumber_title, "%album%|%discnumber%|$num(%tracknumber%,2)|%title%"},
                {library_index_types::artist_album_disc_tracknumber_title, "%artist%|%album%|%discnumber%|$num(%tracknumber%,2)|%title%"},
                {library_index_types::genre_artist_album_disc_tracknumber_title, "%genre%|%artist%|%album%|%discnumber%|$num(%tracknumber%,2)|%title%"},
                {library_index_types::composer_title, "%composer%|%title%"}
If I make those strings user-configurable, there's some room for user error, since they have to follow a specific pattern. I guess putting it on the advanced prefs page would counter-act that tongue.gif Alternatively I could make each of those fields configurable (TITLE, ALBUM, ..) which would also eliminate that.
The other alternative is not writing the 'sort tables' at all, which seems to give back the normal ordering, but that make browsing the library super-slow (on my 3G at least).
This post has been edited by musicmusic: Jun 14 2006, 09:27
david_dl
post Jun 14 2006, 09:37
QUOTE (musicmusic @ Jun 14 2006, 21:23) *
Advanced prefs page sounds like a good idea; at least then users can have a fiddle and restore the defaults if they break something.
Also, for the soundcheck values, is album or track gain used? Perhaps this could be user configurable, as well as a replaygain 'preamp' value for those with volume limited (european) iPods.
- musicmusic   [seemingly abandonware] iPod manager   May 30 2006, 14:38
- - lav-chan   Seems to work for me so far. I have a 2G iPod i th...   May 30 2006, 14:56
- - Crissaegrim   Sweet, man. I hope you get this one going.   May 30 2006, 15:21
- - unabatedshagie   I've got a 4G nano and it's seems to work ...   May 30 2006, 15:28
- - drbeachboy   I have a 4G 20G iPod, with a foo_pod written 4.7 i...   May 30 2006, 17:09
- - musicmusic   Thanks for tests so far. QUOTE (lav-chan ...   May 30 2006, 17:23
|- - Northpole   Tried your plugin on a 20GB ipod and works good...   May 30 2006, 17:41
|- - lav-chan   QUOTE (musicmusic @ May 30 2006, 08:23) T...   May 30 2006, 18:01
- - musicmusic   QUOTE (lav-chan @ May 30 2006, 17:01...   May 30 2006, 18:27
|- - lav-chan   QUOTE (musicmusic @ May 30 2006, 09:27) O...   May 30 2006, 18:53
- - musicmusic   Your not going to like this.. it seemed to load fi...   May 30 2006, 19:25
- - lav-chan   lol. Okey-dokey.   May 30 2006, 19:26
- - upNorth   foo_dop v0.1 works like a charm with my fifth-gen ...   May 30 2006, 20:02
- - musicmusic   QUOTE (lav-chan @ May 30 2006, 18:26...   May 30 2006, 21:00
- - lav-chan   Mmm... they both do. The two lists mentioned earli...   May 30 2006, 21:09
|- - Dearly   Hi. Posting to state that 0.1.1 loads correctly t...   May 30 2006, 21:35
- - drbeachboy   I can also verify that both 0.1.1 and the Test ver...   May 30 2006, 21:20
- - musicmusic   Thanks for the additional tests people. QUOTE (la...   May 30 2006, 22:19
|- - clunesy   Good work, and good luck. You'll soon make foo...   Jun 1 2006, 23:03
- - Sandman2012   musicmusic: I've got an iPod Mini. As soon as ...   Jun 2 2006, 04:56
- - david_dl   Whoa, works perfectly, and its fast as well. Using...   Jun 2 2006, 06:50
- - magnusak   Works nice with iPod 5G 30GB (firmware v1.1.1) and...   Jun 2 2006, 08:38
- - Bl@ck_warrior   Working perfectly with iPod 3G 20GB with the DB wr...   Jun 2 2006, 09:35
- - musicmusic   0.1.5 released with "Rewrite iPod database...   Jun 2 2006, 19:27
- - Apo   4G, 20gb, tested the rewrite feature. Didn't b...   Jun 2 2006, 21:00
- - drbeachboy   Hi musicmusic, The rewrite on my 4G 20gb was perf...   Jun 3 2006, 00:38
|- - Apo   QUOTE (drbeachboy @ Jun 3 2006, 01:38) Ne...   Jun 3 2006, 16:46
- - elishnevsky   Tried with my iPod Nano 2GB. So far so good. Actua...   Jun 3 2006, 03:19
- - Sandman2012   musicmusic, between this and columns ui I've d...   Jun 3 2006, 06:39
- - musicmusic   Thanks for the tests and feedback people QUOTE (...   Jun 3 2006, 20:05
- - Bl@ck_warrior   One thing that will be great is to have the possib...   Jun 3 2006, 20:21
|- - Apo   QUOTE (Bl@ck_warrior @ Jun 3 2006, 21:21)...   Jun 3 2006, 21:33
|- - Sandman2012   QUOTE (Apo @ Jun 3 2006, 13:33) I think t...   Jun 4 2006, 02:02
- - Bl@ck_warrior   Actually the firmware just use the itunes DB to fi...   Jun 3 2006, 21:53
- - david_dl   However that procedure has been proven to not work...   Jun 3 2006, 22:31
|- - drbeachboy   QUOTE (david_dl @ Jun 3 2006, 17:31) Howe...   Jun 4 2006, 00:05
|- - richard123   QUOTE (david_dl @ Jun 3 2006, 16:31) Howe...   Jun 4 2006, 01:40
- - Mike Giacomelli   I think the file name limit on the ipod's data...   Jun 4 2006, 05:09
- - singaiya   I have a couple of questions: 1. How do you add n...   Jun 4 2006, 16:11
|- - drbeachboy   QUOTE (singaiya @ Jun 4 2006, 11:11) I ha...   Jun 4 2006, 16:48
- - Bl@ck_warrior   1) 2) You can't for the moment   Jun 4 2006, 16:38
- - singaiya   Thanks for the answers. Yes, it reads and rewrites...   Jun 4 2006, 16:53
- - musicmusic   Regarding songs in custom locations: it seems to w...   Jun 5 2006, 00:47
|- - prawns   QUOTE (musicmusic @ Jun 5 2006, 00:47) At...   Jun 5 2006, 09:51
- - Crissaegrim   Wow.. it's finally taking shape. Thank you~ ...   Jun 8 2006, 05:37
- - kode54   And to make it increasingly ridiculous, while stil...   Jun 8 2006, 08:19
- - musicmusic   QUOTE (prawns @ Jun 5 2006, 09:51) I...   Jun 8 2006, 17:30
- - prawns   Ah ok then I don't suppose I'd use the vi...   Jun 8 2006, 19:15
|- - Crissaegrim   QUOTE (prawns @ Jun 8 2006, 13:15) Ah ok ...   Jun 8 2006, 19:53
- - musicmusic   0.1.7 released Details above. For the moment, I ...   Jun 8 2006, 23:09
- - emei   wow, this was so much faster then itunes. thanks s...   Jun 9 2006, 00:14
- - falconfox   I am excited about this plugin. I didn't know ...   Jun 9 2006, 00:39
- - BlindSeer   0.1.7 is running beautifully on my trusty old 2G. ...   Jun 9 2006, 01:32
- - Sandman2012   Just tried 1.7 on my ipod Mini. Successfully wrote...   Jun 9 2006, 02:26
- - drbeachboy   Hi musicmusic, I am having problems with songs sk...   Jun 9 2006, 03:07
- - elishnevsky   Not bat at all for an alpha version Here's on...   Jun 9 2006, 03:13
- - musicmusic   QUOTE (BlindSeer @ Jun 9 2006, 01:32) 0.1...   Jun 9 2006, 09:59
- - Scidd0w   QUOTE (drbeachboy @ Jun 8 2006, 18:07) I ...   Jun 9 2006, 10:12
- - drbeachboy   Hi musicmusic, I can't get foobar to even sta...   Jun 9 2006, 15:06
- - musicmusic   Im not doing anything special at startup so I woul...   Jun 9 2006, 15:27
|- - drbeachboy   QUOTE (musicmusic @ Jun 9 2006, 10:27) Im...   Jun 9 2006, 15:45
|- - drbeachboy   QUOTE (musicmusic @ Jun 9 2006, 10:27) Im...   Jun 9 2006, 17:37
- - musicmusic   QUOTE (drbeachboy @ Jun 9 2006, 15:45) QU...   Jun 9 2006, 16:23
|- - drbeachboy   QUOTE (musicmusic @ Jun 9 2006, 11:23) QU...   Jun 9 2006, 16:37
- - musicmusic   Sounds like its component load order related / rac...   Jun 9 2006, 18:40
|- - drbeachboy   QUOTE (musicmusic @ Jun 9 2006, 13:40) So...   Jun 10 2006, 19:12
- - toology   Is the newer iTunes database format known to you a...   Jun 9 2006, 19:41
- - rectangle   Your wiki states:QUOTE It only supports iPods that...   Jun 10 2006, 02:23
|- - rectangle   QUOTE (rectangle @ Jun 10 2006, 11:23) Yo...   Jun 10 2006, 22:30
- - musicmusic   QUOTE (toology @ Jun 9 2006, 19:41) Is th...   Jun 10 2006, 20:02
- - Demonanya   I'm quite interested in this plugin as the lac...   Jun 10 2006, 22:09
|- - david_dl   QUOTE (Demonanya @ Jun 11 2006, 10:09) I...   Jun 10 2006, 22:32
- - Canar   I'm having intermittent lock-ups while transfe...   Jun 11 2006, 01:18
- - toology   Sorry about the 10gb bit, must have stuck in my he...   Jun 11 2006, 03:27
- - musicmusic   QUOTE (Canar @ Jun 11 2006, 01:18) I...   Jun 11 2006, 10:24
- - Canar   1. Lock-up as in it ceases to transfer files and t...   Jun 11 2006, 15:29
- - musicmusic   Is that really the latest version of foo_dop?   Jun 11 2006, 17:02
- - Demonanya   Will foo_dop eventually support Unicode as the vas...   Jun 11 2006, 18:10
- - musicmusic   Well, of course it supports Unicode, the behaviour...   Jun 11 2006, 23:07
|- - Demonanya   QUOTE (musicmusic @ Jun 11 2006, 23:07) W...   Jun 11 2006, 23:25
- - Canar   Ack, apparently I was still using 1.7. I thought I...   Jun 12 2006, 00:01
- - musicmusic   0.2.2 TEST released. Super-experimental (more so t...   Jun 13 2006, 01:30
- - magnusak   I just tried rewriting my iPod 5G database (origin...   Jun 13 2006, 10:32
- - musicmusic   QUOTE (magnusak @ Jun 13 2006, 10:32) I j...   Jun 13 2006, 11:11
|- - magnusak   QUOTE (musicmusic @ Jun 13 2006, 12:11) Q...   Jun 13 2006, 18:31
- - furious   i am beside myself with excitement over this- i...   Jun 13 2006, 15:12
- - elishnevsky   musicmusic, first of all thank you for the time yo...   Jun 13 2006, 15:28
- - mobyduck   Thanks for your time, musicmusic. I have an ...   Jun 13 2006, 15:52
- - musicmusic   QUOTE (furious @ Jun 13 2006, 15:12) i am...   Jun 13 2006, 16:18
- - furious   <quote> 1. Sync is my main target to impleme...   Jun 13 2006, 17:25
- - musicmusic   QUOTE (magnusak @ Jun 13 2006, 18:31) Exc...   Jun 13 2006, 20:59
|- - magnusak   QUOTE (musicmusic @ Jun 13 2006, 21:59) I...   Jun 14 2006, 11:40
- - elishnevsky   QUOTE (musicmusic @ Jun 13 2006, 11:18) Q...   Jun 13 2006, 23:47
- - musicmusic   QUOTE (elishnevsky @ Jun 13 2006, 23:47) ...   Jun 14 2006, 00:55
|- - david_dl   QUOTE (musicmusic @ Jun 14 2006, 12:55) Q...   Jun 14 2006, 06:11
- - Mike Giacomelli   I was using 2.1, but it wouldn't transfer some...   Jun 14 2006, 04:52
- - musicmusic   QUOTE (david_dl @ Jun 14 2006, 06:11) I...   Jun 14 2006, 09:23
|- - david_dl   QUOTE (musicmusic @ Jun 14 2006, 21:23) Q...   Jun 14 2006, 09:37
- - musicmusic   QUOTE (musicmusic @ Jun 14 2006, 09:23) I...   Jun 14 2006, 11:40
- - musicmusic   QUOTE (magnusak @ Jun 14 2006, 11:40) QUO...   Jun 14 2006, 11:51
40 Pages V   1 2 3 > »
RSS Lo-Fi Version Time is now: 4th July 2015 - 02:48
