[seemingly abandonware] iPod manager, also known as foo_dop
musicmusic
post May 30 2006, 14:38
Columns UI developer
iPod management component for foobar2000 0.9.5+.
Home page with details and download
Notes/FAQs/changelog available here. If you read the notes and FAQs before asking any questions, it will keep me happy smile.gif
When posting problem reports, include:
-Operating system
-iPod/iPhone model and firmware version
This post has been edited by musicmusic: Feb 22 2010, 18:41
magnusak
post Jun 13 2006, 10:32
I just tried rewriting my iPod 5G database (originally written with foo_pod, later maintained by iTunes latest version) using foo_dpo 0.2.2 TEST.
The good news:
- It worked.
- foo_dop did a better job than iTunes on some tags (tags from the latest foobar had a strange "blank" character at the end when uploaded with iTunes)
- Playcount and last played were preserved.
- Smart playlists were preserved.
The bad news:
- "Kind" is deleted from all files ("MPEG audio file" etc)
- Podcasts seemed to be converted into normal audio files.
- iTunes (for some strange reason) changed it's setting for maintaining podcasts to "Manual" instead of "Automatic"
Now, after that I tried syncing podcasts again with iTunes, and then adding some files with foo_dop. This worked perfectly with only one small problem: The podcast playlist (automatic itunes) is converted into a normal playlist and then when iTunes is started a new, smart one is created (resulting in two podcast playlist).
Anyway, I'm thrilled. I will start using foo_dop regularly to upload music to my iPod. If you want me to perform any more tests, tell me so here or on mail (i just sent you a mail with my iTunes DB).
Regards,
Magnus
- musicmusic   [seemingly abandonware] iPod manager   May 30 2006, 14:38
- - lav-chan   Seems to work for me so far. I have a 2G iPod i th...   May 30 2006, 14:56
- - Crissaegrim   Sweet, man. I hope you get this one going.   May 30 2006, 15:21
- - unabatedshagie   I've got a 4G nano and it's seems to work ...   May 30 2006, 15:28
- - drbeachboy   I have a 4G 20G iPod, with a foo_pod written 4.7 i...   May 30 2006, 17:09
- - musicmusic   Thanks for tests so far. QUOTE (lav-chan ...   May 30 2006, 17:23
|- - Northpole   Tried your plugin on a 20GB ipod and works good...   May 30 2006, 17:41
|- - lav-chan   QUOTE (musicmusic @ May 30 2006, 08:23) T...   May 30 2006, 18:01
- - musicmusic   QUOTE (lav-chan @ May 30 2006, 17:01...   May 30 2006, 18:27
|- - lav-chan   QUOTE (musicmusic @ May 30 2006, 09:27) O...   May 30 2006, 18:53
- - musicmusic   Your not going to like this.. it seemed to load fi...   May 30 2006, 19:25
- - lav-chan   lol. Okey-dokey.   May 30 2006, 19:26
- - upNorth   foo_dop v0.1 works like a charm with my fifth-gen ...   May 30 2006, 20:02
- - musicmusic   QUOTE (lav-chan @ May 30 2006, 18:26...   May 30 2006, 21:00
- - lav-chan   Mmm... they both do. The two lists mentioned earli...   May 30 2006, 21:09
|- - Dearly   Hi. Posting to state that 0.1.1 loads correctly t...   May 30 2006, 21:35
- - drbeachboy   I can also verify that both 0.1.1 and the Test ver...   May 30 2006, 21:20
- - musicmusic   Thanks for the additional tests people. QUOTE (la...   May 30 2006, 22:19
|- - clunesy   Good work, and good luck. You'll soon make foo...   Jun 1 2006, 23:03
- - Sandman2012   musicmusic: I've got an iPod Mini. As soon as ...   Jun 2 2006, 04:56
- - david_dl   Whoa, works perfectly, and its fast as well. Using...   Jun 2 2006, 06:50
- - magnusak   Works nice with iPod 5G 30GB (firmware v1.1.1) and...   Jun 2 2006, 08:38
- - Bl@ck_warrior   Working perfectly with iPod 3G 20GB with the DB wr...   Jun 2 2006, 09:35
- - musicmusic   0.1.5 released with "Rewrite iPod database...   Jun 2 2006, 19:27
- - Apo   4G, 20gb, tested the rewrite feature. Didn't b...   Jun 2 2006, 21:00
- - drbeachboy   Hi musicmusic, The rewrite on my 4G 20gb was perf...   Jun 3 2006, 00:38
|- - Apo   QUOTE (drbeachboy @ Jun 3 2006, 01:38) Ne...   Jun 3 2006, 16:46
- - elishnevsky   Tried with my iPod Nano 2GB. So far so good. Actua...   Jun 3 2006, 03:19
- - Sandman2012   musicmusic, between this and columns ui I've d...   Jun 3 2006, 06:39
- - musicmusic   Thanks for the tests and feedback people QUOTE (...   Jun 3 2006, 20:05
- - Bl@ck_warrior   One thing that will be great is to have the possib...   Jun 3 2006, 20:21
|- - Apo   QUOTE (Bl@ck_warrior @ Jun 3 2006, 21:21)...   Jun 3 2006, 21:33
|- - Sandman2012   QUOTE (Apo @ Jun 3 2006, 13:33) I think t...   Jun 4 2006, 02:02
- - Bl@ck_warrior   Actually the firmware just use the itunes DB to fi...   Jun 3 2006, 21:53
- - david_dl   However that procedure has been proven to not work...   Jun 3 2006, 22:31
|- - drbeachboy   QUOTE (david_dl @ Jun 3 2006, 17:31) Howe...   Jun 4 2006, 00:05
|- - richard123   QUOTE (david_dl @ Jun 3 2006, 16:31) Howe...   Jun 4 2006, 01:40
- - Mike Giacomelli   I think the file name limit on the ipod's data...   Jun 4 2006, 05:09
- - singaiya   I have a couple of questions: 1. How do you add n...   Jun 4 2006, 16:11
|- - drbeachboy   QUOTE (singaiya @ Jun 4 2006, 11:11) I ha...   Jun 4 2006, 16:48
- - Bl@ck_warrior   1) 2) You can't for the moment   Jun 4 2006, 16:38
- - singaiya   Thanks for the answers. Yes, it reads and rewrites...   Jun 4 2006, 16:53
- - musicmusic   Regarding songs in custom locations: it seems to w...   Jun 5 2006, 00:47
|- - prawns   QUOTE (musicmusic @ Jun 5 2006, 00:47) At...   Jun 5 2006, 09:51
- - Crissaegrim   Wow.. it's finally taking shape. Thank you~ ...   Jun 8 2006, 05:37
- - kode54   And to make it increasingly ridiculous, while stil...   Jun 8 2006, 08:19
- - musicmusic   QUOTE (prawns @ Jun 5 2006, 09:51) I...   Jun 8 2006, 17:30
- - prawns   Ah ok then I don't suppose I'd use the vi...   Jun 8 2006, 19:15
|- - Crissaegrim   QUOTE (prawns @ Jun 8 2006, 13:15) Ah ok ...   Jun 8 2006, 19:53
- - musicmusic   0.1.7 released Details above. For the moment, I ...   Jun 8 2006, 23:09
- - emei   wow, this was so much faster then itunes. thanks s...   Jun 9 2006, 00:14
- - falconfox   I am excited about this plugin. I didn't know ...   Jun 9 2006, 00:39
- - BlindSeer   0.1.7 is running beautifully on my trusty old 2G. ...   Jun 9 2006, 01:32
- - Sandman2012   Just tried 1.7 on my ipod Mini. Successfully wrote...   Jun 9 2006, 02:26
- - drbeachboy   Hi musicmusic, I am having problems with songs sk...   Jun 9 2006, 03:07
- - elishnevsky   Not bat at all for an alpha version Here's on...   Jun 9 2006, 03:13
- - musicmusic   QUOTE (BlindSeer @ Jun 9 2006, 01:32) 0.1...   Jun 9 2006, 09:59
- - Scidd0w   QUOTE (drbeachboy @ Jun 8 2006, 18:07) I ...   Jun 9 2006, 10:12
- - drbeachboy   Hi musicmusic, I can't get foobar to even sta...   Jun 9 2006, 15:06
- - musicmusic   Im not doing anything special at startup so I woul...   Jun 9 2006, 15:27
|- - drbeachboy   QUOTE (musicmusic @ Jun 9 2006, 10:27) Im...   Jun 9 2006, 15:45
|- - drbeachboy   QUOTE (musicmusic @ Jun 9 2006, 10:27) Im...   Jun 9 2006, 17:37
- - musicmusic   QUOTE (drbeachboy @ Jun 9 2006, 15:45) QU...   Jun 9 2006, 16:23
|- - drbeachboy   QUOTE (musicmusic @ Jun 9 2006, 11:23) QU...   Jun 9 2006, 16:37
- - musicmusic   Sounds like its component load order related / rac...   Jun 9 2006, 18:40
|- - drbeachboy   QUOTE (musicmusic @ Jun 9 2006, 13:40) So...   Jun 10 2006, 19:12
- - toology   Is the newer iTunes database format known to you a...   Jun 9 2006, 19:41
- - rectangle   Your wiki states:QUOTE It only supports iPods that...   Jun 10 2006, 02:23
|- - rectangle   QUOTE (rectangle @ Jun 10 2006, 11:23) Yo...   Jun 10 2006, 22:30
- - musicmusic   QUOTE (toology @ Jun 9 2006, 19:41) Is th...   Jun 10 2006, 20:02
- - Demonanya   I'm quite interested in this plugin as the lac...   Jun 10 2006, 22:09
|- - david_dl   QUOTE (Demonanya @ Jun 11 2006, 10:09) I...   Jun 10 2006, 22:32
- - Canar   I'm having intermittent lock-ups while transfe...   Jun 11 2006, 01:18
- - toology   Sorry about the 10gb bit, must have stuck in my he...   Jun 11 2006, 03:27
- - musicmusic   QUOTE (Canar @ Jun 11 2006, 01:18) I...   Jun 11 2006, 10:24
- - Canar   1. Lock-up as in it ceases to transfer files and t...   Jun 11 2006, 15:29
- - musicmusic   Is that really the latest version of foo_dop?   Jun 11 2006, 17:02
- - Demonanya   Will foo_dop eventually support Unicode as the vas...   Jun 11 2006, 18:10
- - musicmusic   Well, of course it supports Unicode, the behaviour...   Jun 11 2006, 23:07
|- - Demonanya   QUOTE (musicmusic @ Jun 11 2006, 23:07) W...   Jun 11 2006, 23:25
- - Canar   Ack, apparently I was still using 1.7. I thought I...   Jun 12 2006, 00:01
- - musicmusic   0.2.2 TEST released. Super-experimental (more so t...   Jun 13 2006, 01:30
- - magnusak   I just tried rewriting my iPod 5G database (origin...   Jun 13 2006, 10:32
- - musicmusic   QUOTE (magnusak @ Jun 13 2006, 10:32) I j...   Jun 13 2006, 11:11
|- - magnusak   QUOTE (musicmusic @ Jun 13 2006, 12:11) Q...   Jun 13 2006, 18:31
- - furious   i am beside myself with excitement over this- i...   Jun 13 2006, 15:12
- - elishnevsky   musicmusic, first of all thank you for the time yo...   Jun 13 2006, 15:28
- - mobyduck   Thanks for your time, musicmusic. I have an ...   Jun 13 2006, 15:52
- - musicmusic   QUOTE (furious @ Jun 13 2006, 15:12) i am...   Jun 13 2006, 16:18
- - furious   <quote> 1. Sync is my main target to impleme...   Jun 13 2006, 17:25
- - musicmusic   QUOTE (magnusak @ Jun 13 2006, 18:31) Exc...   Jun 13 2006, 20:59
|- - magnusak   QUOTE (musicmusic @ Jun 13 2006, 21:59) I...   Jun 14 2006, 11:40
- - elishnevsky   QUOTE (musicmusic @ Jun 13 2006, 11:18) Q...   Jun 13 2006, 23:47
- - musicmusic   QUOTE (elishnevsky @ Jun 13 2006, 23:47) ...   Jun 14 2006, 00:55
|- - david_dl   QUOTE (musicmusic @ Jun 14 2006, 12:55) Q...   Jun 14 2006, 06:11
- - Mike Giacomelli   I was using 2.1, but it wouldn't transfer some...   Jun 14 2006, 04:52
- - musicmusic   QUOTE (david_dl @ Jun 14 2006, 06:11) I...   Jun 14 2006, 09:23
|- - david_dl   QUOTE (musicmusic @ Jun 14 2006, 21:23) Q...   Jun 14 2006, 09:37
- - musicmusic   QUOTE (musicmusic @ Jun 14 2006, 09:23) I...   Jun 14 2006, 11:40
- - musicmusic   QUOTE (magnusak @ Jun 14 2006, 11:40) QUO...   Jun 14 2006, 11:51
40 Pages V   1 2 3 > »
RSS Lo-Fi Version Time is now: 4th August 2015 - 08:50
