15 Pages V  « < 10 11 12 13 14 > »
New FLAC encoder
iGold
post Oct 18 2006, 03:10
Post #276
QUOTE (MedO @ Oct 18 2006, 03:01) *
Signed 16-bit 44100 Hz stereo
samples: 13265868 (0m8.638s)
I thought this was solved?
I submitted bug about it in sourceforce bug tracker after I discovered it was not fixed after 1st try. Justin, are you looking there? rolleyes.gif
Justin Ruggles
post Oct 18 2006, 03:36
Post #277
QUOTE (iGold @ Oct 17 2006, 22:10) *
I missed that one... I've changed the settings so I get an email now when someone posts a new bug. smile.gif I have also updated the status of your bug report.
-Justin
Synthetic Soul
post Oct 18 2006, 13:36
Post #278
My results for Flake SVN r110 wisodev build P3 optimised with RW corpus.
Setting     Ratio     Enc     Dec
0         65.352%    136x    106x
1         62.822%    114x    104x
2         62.661%     98x    104x
3         59.581%     94x     97x
4         59.392%     92x     93x
5         59.292%     90x     96x
6         59.649%     66x     96x
7         59.307%     54x     96x
8         59.132%     49x     95x
8 -m 1    59.115%     83x     94x
8 -v 1    58.747%     47x     93x
9         59.019%     40x     95x
10        59.006%     28x     94x
11        58.758%     22x     83x
12        58.729%      9x     83x
12 -v 1   58.378%      9x     84x
99        58.336%      2x     72x
QUOTE (MedO @ Oct 17 2006, 21:17) *
Something interesting here, I noticed that -5 often gives better results than -6, in fact, the size is often similar to that of -7 and -8. Fiddling with the settings a bit, I noticed that this is because of the setting "order method: estimate" which seems to produce better results than "2-Level" and sometimes better than "4-Level" as well.
I didn't test on many files, so this might be a coincidence, but on the few files I tested the commandline "flake -8 -m 1" was always faster and always produced bitrates similar or better than "flake -8". Might be worth investigating...
These results appear to bear yours out completely. I'm so glad you posted or I would have been really concerned about my -6 results!
I will post results for the other wisodev compiles (normal and org) as well, in the next day or so. I will also post the spreadsheet used to calculate the summaries (uploaded to Google Docs & Spreadsheets).
Edit: Something else of note. In fact two somethings.
Firstly, I should mention that the results above are CPU-only times, where my TAK lossless comparison values are CPU+IO times. I started reporting CPU+IO in that comparison and it's awkward to stop now.
Secondly, the scripts I use to perform my tests use FSUM to check the decoded WAVE files against the MD5 hashes of the source files once all files are decoded. This normally serves me well, but in this instance nearly all files fail the check.
I have done a little checking and it appears to be down to the WAVE header written, which I think is 2 bytes smaller than the source (bear in mind the source files are decoded WavPack files). Again, from my limited understanding, this appears to be down to the ExtraParamSize bytes not being written by the FLAC decoder. From the document I have read it appears that these bytes are not required if no extra parameters are present. Strangely enough though every fourth file or so the hashes do match!
Edit: It seems that, as expected, with the files that do match MD5 hashes, neither have the ExtraParamSize bytes; therefore FLAC is acting consistently, while the source files are not consistent. Maybe this is noticable as most decompressors just return the original WAVE header, whereas FLAC creates its own?
I really have no idea what all this means, but it thought it worth noting. I bit compared a few files that had mismatched MD5s using foobar and the audio is bit-identical, as you would expect.
Here's the report from FSUM for -5 (it's the same for all though).
FAILED MD5 41_30sec.wav
FAILED MD5 ATrain.wav
FAILED MD5 Bachpsichord.wav
OK MD5 Bartok_strings2.wav
FAILED MD5 BeautySlept.wav
FAILED MD5 BigYellow.wav
FAILED MD5 Blackwater.wav
FAILED MD5 bodyheat.wav
OK MD5 chanchan.wav
FAILED MD5 DaFunk.wav
FAILED MD5 death2.wav
OK MD5 Debussy.wav
FAILED MD5 EnolaGay.wav
FAILED MD5 experiencia.wav
FAILED MD5 female_speech.wav
FAILED MD5 FloorEssence.wav
OK MD5 getiton.wav
FAILED MD5 gone.wav
OK MD5 Hongroise.wav
FAILED MD5 Illinois.wav
FAILED MD5 ItCouldBeSweet.wav
FAILED MD5 kraftwerk.wav
FAILED MD5 Layla.wav
OK MD5 Leahy.wav
FAILED MD5 LifeShatters.wav
FAILED MD5 macabre.wav
FAILED MD5 Mahler.wav
FAILED MD5 male_speech.wav
OK MD5 Mama.wav
FAILED MD5 MidnightVoyage.wav
FAILED MD5 mybloodrusts.wav
OK MD5 NewYorkCity.wav
OK MD5 OrdinaryWorld.wav
FAILED MD5 Polonaise.wav
FAILED MD5 Quizas.wav
FAILED MD5 riteofspring.wav
OK MD5 rosemary.wav
FAILED MD5 Scars.wav
OK MD5 SinceAlways.wav
FAILED MD5 thear1.wav
FAILED MD5 TheSource.wav
OK MD5 TomsDiner.wav
OK MD5 trust.wav
OK MD5 Twelve.wav
FAILED MD5 velvet.wav
OK MD5 Waiting.wav
31 checksums failed
This post has been edited by Synthetic Soul: Oct 18 2006, 16:54
I'm on a horse.
Wombat
post Oct 18 2006, 14:17
Post #279
I donīt know the story of flake but now while i test around i am not really thrilled to have the extra options.
These options like l32 or v1 simply brake the standard in my eyes. l32 encoded files donīt play on every hardware and v1 is confusing even winamp and my Squeezebox again when i want to fast forward.
What about *.flak for flake encodings? So everyone knows he may have to reencode to use it properly when he gets such a file by accident.
This may have been discudssed before but i somehow missed that.
With 24bit audio you can listen to silence much louder
MedO
post Oct 18 2006, 16:06
Post #280
QUOTE (Wombat @ Oct 18 2006, 15:17) *
As I understand it, files encoded with -v 1 or -l 32 are standard flac files, not a weird format extension introduced by flake.
bhoar
post Oct 18 2006, 17:10
Post #281
Group: Members (Donating)
QUOTE (Synthetic Soul @ Oct 18 2006, 08:36) *
0 65.352% 136x 106x
1 62.822% 114x 104x
2 62.661% 98x 104x
3 59.581% 94x 97x
4 59.392% 92x 93x
5 59.292% 90x 96x
6 59.649% 66x 96x
7 59.307% 54x 96x
8 59.132% 49x 95x
9 59.019% 40x 95x
10 59.006% 28x 94x
11 58.758% 22x 83x
12 58.729% 9x 83x
99 58.336% 2x 72x
I'd love to see some curves plotted of effort vs. reward (aka price/performance aka "sweet spot").
Looking at the above, -5 seems to be the sweet spot if your rate performance as the most important and "-8 -v 1" the sweet spot if you rate compression as the most important.
-brendan
Hacking CD Robots & Autoloaders: http://hyperdiscs.pbwiki.com/
wisodev
post Oct 18 2006, 17:39
Post #282
QUOTE (Synthetic Soul @ Oct 17 2006, 21:48) *
I have an AMD XP CPU. Should I be looking at /org/flake.exe, /p3/flake.exe or /flake.exe?
.\flake.exe        - ICL Build with PGO Optimizations
.\P3\flake.exe        - ICL Build with PGO & P3 Optimizations
.\ORG\flake.exe        - ICL Build
The P3 is optimized for Pentium III and should work for all processors above P3 specs. It Works very well on Athlon XP processors (I have Athlon XP 2000+). I have in mind to add P4 build but I can't build it on my machine because of PGO optimization that req running the program and my CPU doesn't support P4 builds.
The original (ORG) build is not considered for normal usage only added for speed testing of PGO and PGO&P3 builds. For most CPUs the .\flake.exe build is good and should be used as safest solution.
QUOTE (PrakashP @ Oct 17 2006, 22:46) *
@wisodev
I would be interested what compiler flags you use (and which compiler). Have you added asm to the sources?
All I have added is build enviroment in win32 directory. No assembly optimizations added by me. I have added some small changes to code to build it cleanly under MSVC with Intel compiler. Maybe Justin can add them to official sources (just diff my sources with SVN revision 110 to see what have been changed).
I am using MSVC++ v7.1 and Intel C++ Compiler v8.0.040. This version of Intel compiler works best for me. I have tried newer versions but I can't get better results.
The compiler flags are main reason for speedups of my builds. I am using PGO optimization provided by Intel C++ compiler and for P3 build additionaly /QxK flag is used to enable even more optimizations. More information is avaible when you check the project settings for eacg configuraion (all witch begin with Release, the Debug builds are obviously not optimized ;-).
http://code.google.com/p/wavtoac3encoder/
pest
post Oct 18 2006, 18:08
Post #283
QUOTE (Synthetic Soul @ Oct 18 2006, 14:36) *
You're right. FLAC creates a fresh RIFF/WAVE-Header, but Wavpack for example recreates the original one.
This post has been edited by pest: Oct 18 2006, 18:09
Synthetic Soul
post Oct 18 2006, 20:19
Post #284
QUOTE (wisodev @ Oct 18 2006, 17:39) *
The P3 is optimized for Pentium III and should work for all processors above P3 specs. It Works very well on Athlon XP processors (I have Athlon XP 2000+). <snip> The original (ORG) build is not considered for normal usage only added for speed testing of PGO and PGO&P3 builds. For most CPUs the .\flake.exe build is good and should be used as safest solution.
Thanks for the info wisodev. With that in mind I won't bother with the ORG build. Here's the PGO and PGO+P3 results:
                   |   PGO + P3     |   PGO
Setting     Ratio  |   Enc     Dec  |   Enc     Dec
0         65.352%  |  136x    106x  |  133x    104x
1         62.822%  |  114x    104x  |  110x    106x
2         62.661%  |   98x    104x  |   95x    104x
3         59.581%  |   94x     97x  |   91x     98x
4         59.392%  |   92x     93x  |   90x     96x
5         59.292%  |   90x     96x  |   88x     96x
6         59.649%  |   66x     96x  |   65x     99x
7         59.307%  |   54x     96x  |   52x     98x
8         59.132%  |   49x     95x  |   47x     95x
8 -m 1    59.115%  |   83x     94x  |   80x     93x
8 -v 1    58.747%  |   47x     93x  |   46x     95x
9         59.019%  |   40x     95x  |   39x     96x
10        59.006%  |   28x     94x  |   27x     95x
11        58.758%  |   22x     83x  |   21x     83x
12        58.729%  |    9x     83x  |    8x     81x
12 -v 1   58.378%  |    9x     84x  |    8x     84x
99        58.336%  |    2x     72x  |    2x     72x
View the Google spreadsheet with all values for all files here.
QUOTE (pest @ Oct 18 2006, 18:08) *
Thanks for the confirmation. This makes sense to me.
I'm on a horse.
Synthetic Soul
post Oct 18 2006, 21:07
Post #285
QUOTE (bhoar @ Oct 18 2006, 17:10) *
Not sure if this fits the bill, but I can't think of any other way of displaying it.
I'm on a horse.
Justin Ruggles
post Oct 19 2006, 02:19
Post #286
QUOTE (Wombat @ Oct 18 2006, 09:17) *
The files may confuse some software decoders and skip in some hardware decoders, but I assure you they are 100% valid FLAC files based only on the specification. The issues that occur are not Flake issues, they are due to there being 2 levels of compliance, the subset specification and the full specification. Flake gives a warning when the files do not fall within the subset specification, but all generated files fall within the full specification.
If you're worried about getting a FLAC file which may cause problems, I could try to write a small utility program which would do frame analysis and detect whether a file falls within the subset specification. As for winamp, maybe adding a seektable using metaflac would help?...I don't really know how the winamp plug-in does seeking and I don't use winamp (anymore). I do use xmms, which completely locks up when seeking with the variable bitrate files...no good. Personally, I see these as software bugs, but I can't really blame the makers since that feature of the specification is not implemented by the reference encoder. MPlayer plays & seeks just fine...it uses its own demuxer & FFmpeg's decoder.
On an unrelated note, thanks for all the benchmarks! The graph is great smile.gif Now that I see the results, I'm seriously considering abandoning the "mirror the reference encoder" idea for compression levels. I think trimming it down to just 7 presets corresponding to 0, 1, 5, 8m1, 10, 11, and 99 should pretty much cover what is needed.
-0 for really-fast encoding
-1 for fast encoding
-5 for normal encoding
"-8 -m 1" for high compression
-10 for best compression within subset
-11 for extra compression outside subset (-12 speed loss isn't worth the tiny gain)
-99 for experimental
I would probably get rid of the numbered presets in favor of named presets. What do you all think about this idea?
-Justin
bhoar
post Oct 19 2006, 07:34
Post #287
QUOTE (Synthetic Soul @ Oct 18 2006, 16:07) *
Not sure if this fits the bill, but I can't think of any other way of displaying it...
Actually, that was quite useful. The two points on the encoding line that stood out to me numerically after looking up and down the chart a few times also appear to stand out rather obviously in the chart.
-brendan
wisodev
post Oct 19 2006, 08:01
Post #288
@PrakashP
For PGO&P3 Instrumentation build (Release Instrumentation P3|Win32) I am using this options for ICL:
/GL /Ox /Og /Ob1 /Ot /G7 /GA /QxK /FD /MT /Qc99 /Qprof_genx /Gd /TC
For PGO&P3 Feedback build (Release Feedback P3|Win32) I am using this options for ICL:
/GL /Ox /Og /Ob1 /Ot /G7 /GA /QxK /FD /MT /Qc99 /Qprof_use /Gd /TC
For PGO only build just remove /QxK option.
wisodev
This post has been edited by wisodev: Oct 19 2006, 08:03
Wombat
post Oct 19 2006, 13:03
Post #289
QUOTE (Justin Ruggles @ Oct 19 2006, 03:19) *
Thanks for your answer. I read the first time deeper about flac and switches. I am sure you can penetrate normal flac to the point it doesnīt work on any player also smile.gif
No need for a tool that tests the frames. This -v1 doesnīt seem to need any more decoding power than without so it is time to "correct" the decoders.
btw. this latest wisodev build is awsome fast!
MedO
post Oct 19 2006, 13:14
Post #290
@Synthetic Soul:
Thanks for the tests, it would also be nice to have "-8 -m 1 -v 1" in next time, maybe instead of "-8 -v 1"? This should have a very good compression/encoding time ratio.
This post has been edited by MedO: Oct 19 2006, 13:15
kockroach
post Oct 19 2006, 13:26
Post #291
QUOTE (Synthetic Soul @ Oct 18 2006, 15:07) *
Synthetic Soul,
The plot of the results look great. I was wondering why it is that "-m 1" is only tested on "8". Can it not be used on levels 9 and up? I didn't see anything about that, so I apologize if I missed it. I have to wonder how much it could potentially increase encoding times of those above 9, especially if it can increase 12's encoding time significantly.
guruboolez
post Oct 19 2006, 13:31
Post #292
I tried -10 -m 1 on a single album and it gives a significant boost (~100%) to the encoding speed without decreasing the compression ratio (+1 kbps). This switch looks great!
I also tried -v1, but there's no seeking with foobar2000 (0.9.4.1).
This post has been edited by guruboolez: Oct 19 2006, 13:32
MedO
post Oct 19 2006, 13:46
Post #293
I think "-9 -m 1" ist the same as "-8 -m 1".
"-9" and upward use search methods which are probably better (compression-wise) than "-m 1".
Synthetic Soul
post Oct 19 2006, 14:48
Post #294
QUOTE (MedO @ Oct 19 2006, 13:14) *
@Synthetic Soul:
QUOTE (kockroach @ Oct 19 2006, 13:26) *
I simply used the settings requested by Justin, and added -8 -m 1 as it was mentioned by MedO shortly after, and it was suggested that more info was required (so I thought I may as well add it to the list).
My wife is possibly beginning labour at the moment, so I kind of have other things on my mind. unsure.gif
If I get chance I will try to run the tests requested.
I'm on a horse.
kockroach
post Oct 19 2006, 14:59
Post #295
QUOTE (Synthetic Soul @ Oct 19 2006, 08:48) *
iGold
post Oct 19 2006, 15:29
Post #296
QUOTE (Justin Ruggles @ Oct 19 2006, 07:19) *
I think it's a good idea. And if we really want we always can use cryptic -b -t -l -m -r -s combinations laugh.gif
Synthetic Soul
post Oct 20 2006, 09:18
Post #297
QUOTE (kockroach @ Oct 19 2006, 14:59) *
Thank you. Things are unfortunately going very slowly, so there's no news yet.
Except...
My results for Flake SVN r110 wisodev build P3 optimised with RW corpus, with -8 -m 1 -v 1 and -9 to -12 with -m 1:
0              65.352%    136x    106x
1              62.822%    114x    104x
2              62.661%     98x    104x
3              59.581%     94x     97x
4              59.392%     92x     93x
5              59.292%     90x     96x
6              59.649%     66x     96x
7              59.307%     54x     96x
8              59.132%     49x     95x
8 -m 1 -v 1    58.752%     83x     96x
9              59.019%     40x     95x
9 -m 1         59.115%     85x     96x
10             59.006%     28x     94x
10 -m 1        59.115%     86x    100x
11             58.758%     22x     83x
11 -m 1        58.920%     67x     76x
12             58.729%      9x     83x
12 -m 1        58.920%     67x     76x
99             58.336%      2x     72x
I don't understand the -9 -m 1/-10 -m 1 and -11 -m 1/-12 -m 1 thing, but I'm sure someone does.
This post has been edited by Synthetic Soul: Oct 20 2006, 09:19
I'm on a horse.
MedO
post Oct 20 2006, 12:10
Post #298
QUOTE (Synthetic Soul @ Oct 20 2006, 10:18) *
Well, the only setting that changes between -8, -9 and -10 is the -m switch, and you override that manually, so you get the same results because the settings are identical. The same goes for -11/-12.
Edit: I just saw that -11 -m 1 is bigger than -8 -m 1. I guess the "estimate" search method just isn't optimised for those high predictor orders. Just a guess, I don't know much about FLAC technology...
Edit2: I confused rows in the table... thanks Josef Pohm for the hint. unsure.gif
This post has been edited by MedO: Oct 21 2006, 18:06
JWolf
post Oct 21 2006, 04:17
Post #299
I have a Rio Karma and while it can play FlAKE -12 compressed flac files, it has a lot of trouble seeking with these FLAC files. FLAC 1.1.2_CVS which gets close compression works great with my Rio Karma.
What I'd like to know is what are the best settings for Flake to work with my Rio Karma? I'd like to compare compressions sizes to find out which is better. I was playing around and ended up gettng a larger file that didn't work vs FLAC 1.1.2_CVS.
What setting is it in FLAKE that causes it not to be fully compatible with my Rio? I tried the -v 1 as suggested earlier in the thread to make it compatible with FLAC and that also failed.
Jon
This post has been edited by JWolf: Oct 21 2006, 04:18
Justin Ruggles
post Oct 21 2006, 05:10
Post #300
QUOTE (JWolf @ Oct 20 2006, 23:17) *
Jon
For now the best setting for your Rio would probably be "flake -10". It generates files which are roughly equivalent (compatibility-wise) to "flac -8". Definitely don't use -v 1 since it is probably the most experimental option and has compatibility issues.
edit: to answer your other question more fully, it's probably the max LPC order which is causing problems on the Rio with flake -12 files.
edit2: Given the many questions, for the next release, I will try to make some documentation devoted to compatibility of various features of the FLAC specification and Flake encoding parameters.
-Justin
This post has been edited by Justin Ruggles: Oct 21 2006, 05:17
RSS Lo-Fi Version Time is now: 31st January 2015 - 11:54
