IPB
15 Pages V  « < 9 10 11 12 13 > »
New FLAC encoder
guruboolez
post Oct 5 2006, 17:28
Post #251
Group: Members (Donating)
May I suggest to Justin that the first official release of flake should come with a small warning (inside the documentation and/or inside flake.exe with -h switch) about possible hardware players' issues with -11 & -12 setting?
Go to the top of the page
+Quote Post
Josef Pohm
post Oct 5 2006, 17:32
Post #252
Group: Members
QUOTE (Wombat @ Oct 5 2006, 18:22) *
Exactly how you predicted. -10 still is playable. From -11 on it stutters.
To my little knoledge decoding speed of lossless codecs mostly depends on the maximum number of predictor order used.
Flake -5 uses 8 max predictor order, like Flac -5 (and Garf version of Flac).
Flake -8,-9 and -10 uses 12 max predictor order like Flac -8 (and Garf version of Flac).
Flake -11 and -12 uses 32, so it requires much more decoding power.
I hope that's correct.
+Quote Post
jcoalson
post Oct 5 2006, 18:03
Post #253
FLAC Developer
Group: Developer
I think I am going to officially limit the subset to 12-order LPC for 44.1kHz to head off problems like this. with FLAC at that sample rate, using high orders like that is usually a poor tradeoff and letting users do this without a warning is just going to create confusion. this goes for flac too which currently allows -l 32 without a warning.
most of the compression advantage of flake over FLAC 1.1.2 has already been incorporated into FLAC 1.1.3. the extra compression from 32-order LPC is minimal.
Josh
+Quote Post
wisodev
post Oct 5 2006, 20:39
Post #254
Group: Developer
Flake (Win32) from SVN revision 104 available:
Download from my Website
or use direct links:
Download binarys:
flake-svn-r104-win32-bin.zip
Download sources:
flake-svn-r104-win32-src.zip
NOTE: I have added my small patch to code (quality or speed is not affected), can be found here, the sources are already patched (this patch comes from my local subversion repository and is not related with sf.net subversion).
wisodev
http://code.google.com/p/wavtoac3encoder/
+Quote Post
fairway
post Oct 5 2006, 21:50
Post #255
Group: Members
QUOTE (Josef Pohm @ Oct 5 2006, 16:32) *
Though seeking with a flake encoded file is still significantly slower than with a FLAC (reference encoder) encoded file (try it in winamp with the default flac plugin).
+Quote Post
Justin Ruggles
post Oct 6 2006, 02:07
Post #256
Group: Developer
QUOTE (guruboolez @ Oct 5 2006, 12:28) *
Okay, that sounds like a good idea.
QUOTE (jcoalson @ Oct 5 2006, 13:03) *
Cool. Based on this, and the hardware decoding issues, I'll go ahead and add a separate warning for any lpc order over 12 for any sample rate up to 48kHz. Once the official subset standard changes, I'll change Flake's warnings accordingly.
-Justin
+Quote Post
JWolf
post Oct 7 2006, 05:02
Post #257
Group: Members
QUOTE (Wombat @ Oct 5 2006, 11:50) *
Ah, oh. I see a problem. Does -12 take that much processing power or isnīt it 100% compatible to flac 1.1.2 decoding anymore?
My Squeezebox canīt play flake -12 on all titles. It stutters around. Flake -5 for example is fine.
Edit:
The compile Garf offered a while back works flawlessly on the Squeezebox and has higher compression already as standard 1.1.2.
Using the current version of FLAKE, I was able to play -12 compressed files on my Rio Karma with no hiccups.
Jon
+Quote Post
jcoalson
post Oct 7 2006, 07:51
Post #258
FLAC Developer
Group: Developer
QUOTE (jcoalson @ Oct 5 2006, 12:03) *
the new limits: if the sample rate is <=48kHz, max blocksize = 4608 and max LPC order = 12. all the tests I did showed that 32-order LPC got <0.1% more compression (usually a lot less).
http://flac.cvs.sourceforge.net/*checkout*...mat.html#subset
Josh
+Quote Post
wisodev
post Oct 7 2006, 10:15
Post #259
Group: Developer
I have builded a faster FLAKE binary from rev. 104 but it needs some testing.
On one of my test files encoding time has droped from 193.468 seconds (previous r104 build) to 173.906 seconds (test r104 build) using -12 command-line option.
Download test binary:
flake_r104_test.zip
wisodev
+Quote Post
MedO
post Oct 7 2006, 12:25
Post #260
Group: Members
QUOTE (wisodev @ Oct 7 2006, 11:15) *
flake_r104_test.zip
wisodev
Your test compile is a bit faster than mine on my machine (Celeron M 1,4Ghz). I can't give any good values, though, because I already got several seconds difference when running my own build twice, so the measurement is not very reliable.
+Quote Post
Synthetic Soul
post Oct 7 2006, 19:00
Post #261
Group: Super Moderator
QUOTE (wisodev @ Oct 7 2006, 10:15) *
Here's some results for my "FLAC" corpus:
CODE
Setting       R104    R104 Test   Diff
-10       286.726s     274.561s    96%
-11       375.687s     347.035s    92%
-12      1002.105s     914.239s    91%
Edit: Here's the figures for my MinGW compile:
CODE
Setting  MinGW R104   R104 Test   Diff
-10        394.015s    274.561s    70%
-11        486.764s    347.035s    71%
-12       1322.178s    914.239s    69%
I don't think I'll bother anymore! biggrin.gif Excellent work wisodev.
NB: Timings were recorded using TIMER, and CPU-only times are reported.
This post has been edited by Synthetic Soul: Oct 7 2006, 20:32
I'm on a horse.
+Quote Post
Justin Ruggles
post Oct 8 2006, 04:57
Post #262
Group: Developer
QUOTE (jcoalson @ Oct 7 2006, 02:51) *
Josh
Splendid. I have modified the Flake warning message output and the return code of the flake_validate_params function to reflect the new standard.
+Quote Post
iGold
post Oct 11 2006, 21:20
Post #263
Group: Members
I checkout rev.107 from SVN and compile it myself under x86_64 Ubuntu. While encoding disc image I see:
QUOTE
Signed 16-bit 44100 Hz stereo
samples: 116712120 (0m16.961s)
If I try to compile this test code:
CODE
int th, tm, ts, tms;
tms = 116712120 * 1000 / 44100;
I get two "integer overflow" warnings.
I think int is too small here (in flake.c at line 447).
+Quote Post
Justin Ruggles
post Oct 11 2006, 22:14
Post #264
Group: Developer
QUOTE (iGold @ Oct 11 2006, 16:20) *
QUOTE
CODE
Thanks. Fixed.
Also, anyone can submit bug reports on Flake's Sourceforge project page. Getting bug reports via HA makes me feel a little guilty for taking up space with small fixes. They are appreciated either way though. smile.gif
+Quote Post
wisodev
post Oct 12 2006, 19:16
Post #265
Group: Developer
Flake (Win32) from SVN revision 108 available:
Download binarys:
flake-svn-r108-win32-bin.zip
Download sources:
flake-svn-r108-win32-src.zip
wisodev
+Quote Post
Justin Ruggles
post Oct 15 2006, 18:31
Post #266
Group: Developer
QUOTE (Will Fisher @ Sep 22 2006, 20:01) *
although i ran into a couple of problems compiling.
Would it be too much of a problem to put my changes into the code, to keep it portable across compilers?
optimize.c line 219 replaced with: uint32_t bits[32]; (where 32 used to be levels. MSVC doesn't like non-constant sizes for these things.) I am sure that 32 is as large as levels gets.
in encode.c flake_set_defaults, msvc doen't like this syntax:
foo = ((int[]){1,2,3})[2];
so i defined all these "nameless" arrays as ones with names, so it becomes:
int sel[] = {1,2,3};
foo = sel[2];
thanks,
will
Both MSVC issues have now been fixed.
Also, I am almost done with a new website for Flake. The only thing left is API documentation and benchmarks. I am putting in a link to Synthetic Soul's lossless benchmarks, but it would also be nice to have more extensive tests to better illustrate the differences between the compression levels. I'm not so worried anymore about detailed comparisons to the reference encoder because Synthetic Soul's tests give a good enough overview. Since my computer is quite slow, it would really help me out if someone could benchmark the current SVN version of Flake using the rw corpus at all compression levels. Also, adding in tests for "-8 -v 1", "-12 -v 1", and "-99" would be useful. Corpus totals would be better than file-by-file results.
Justin
+Quote Post
Will Fisher
post Oct 16 2006, 10:32
Post #267
Group: Members
QUOTE (Justin Ruggles @ Oct 15 2006, 09:31) *
I have included my enc_flac plugin (sources are attached somewhere in this thread =) built with wisodevs libFlake r108 to the beta branch of Winamp.
If it gets a good response from our beta team and QA department (and I can't see why it wouldn't) maybe we'll put it in a subsequent version of winamp.
+Quote Post
Synthetic Soul
post Oct 17 2006, 16:38
Post #268
QUOTE (Justin Ruggles @ Oct 15 2006, 18:31) *
Has anyone provided this yet?
I don't mind running the tests if no-one else will. My machine isn't hugely fast (Athlon XP 2400+, 512MB RAM, Win2K) but it's OK, and I will need a compile from wisodev as I have proved already that my compiles are far inferior to his.
I'm on a horse.
+Quote Post
wisodev
post Oct 17 2006, 17:43
Post #269
Group: Developer
QUOTE (Synthetic Soul @ Oct 17 2006, 17:38) *
I will provide fresh compile in few hours including new experimental build using P3 optimizations (using only compiler options - not assembly optimized!!!) witch seems to be even faster then the last one.
This post has been edited by wisodev: Oct 17 2006, 17:48
+Quote Post
wisodev
post Oct 17 2006, 20:34
Post #270
Group: Developer
Flake (Win32) from SVN revision 110 available:
Download binarys:
flake-svn-r110-win32-bin.zip
Download sources:
flake-svn-r110-win32-src.zip
wisodev
This post has been edited by wisodev: Nov 29 2006, 17:41
+Quote Post
Synthetic Soul
post Oct 17 2006, 20:48
Post #271
I have an AMD XP CPU. Should I be looking at /org/flake.exe, /p3/flake.exe or /flake.exe?
I'm on a horse.
+Quote Post
MedO
post Oct 17 2006, 21:17
Post #272
Group: Members
Something interesting here, I noticed that -5 often gives better results than -6, in fact, the size is often similar to that of -7 and -8. Fiddling with the settings a bit, I noticed that this is because of the setting "order method: estimate" which seems to produce better results than "2-Level" and sometimes better than "4-Level" as well.
I didn't test on many files, so this might be a coincidence, but on the few files I tested the commandline "flake -8 -m 1" was always faster and always produced bitrates similar or better than "flake -8". Might be worth investigating...
Edit: I just did a short test with the album "Supertramp - Some Things Never Change", comparing the commandlines "-8" and "-8 -m 1".
"-8 -m 1" was of course always way faster, and compressed 8 of the 12 files better than "-8". The differences in bitrate were quite small though, around 0.1-0.2kbps average.
This post has been edited by MedO: Oct 17 2006, 22:16
+Quote Post
PrakashP
post Oct 17 2006, 21:46
Post #273
Group: Members
@wisodev
I would be interested what compiler flags you use (and which compiler). Have you added asm to the sources?
+Quote Post
MedO
post Oct 17 2006, 22:01
Post #274
Group: Members
Also, I still get this time bug when encoding with wisodev's latest build (all binaries show this)
CODE
samples: 13265868 (0m8.638s)
I thought this was solved?
+Quote Post
Justin Ruggles
post Oct 18 2006, 02:47
Post #275
Group: Developer
QUOTE (MedO @ Oct 17 2006, 17:01) *
CODE
I did too...sorry. I just committed a 2nd attempt, which seems to work for me. I just tested it on a 11 million sample wav and it correctly reported around 4 minutes.
-Justin
QUOTE (MedO @ Oct 17 2006, 16:17) *
This is really interesting. My tests resulted in not quite as good compression. It could be coincedence. More testing would be great. The order estimate method is a pretty crude 1st attempt at an idea I got from a paper which dealt with speech compression. It suggested a method using the highest order reflection coefficient above a certain threshold. I've found that the method varies widely depending on the type of audio...I imagine it works well for speech, but would need some tweaking for other types of signals. I had once tried to do some testing using gnuplot output, but my statistical analysis skills aren't really advanced enough to know what to look for...so I have left it at a simple threshold for now.
edit: I also want to note that I could almost always pick out the best order or close to it using visual output from gnuplot, but I could never translate that into a mathematical analysis that worked well. There is definitely potential there though.
-Justin
This post has been edited by Justin Ruggles: Oct 18 2006, 02:53
+Quote Post
0 Members:
RSS Lo-Fi Version Time is now: 27th August 2014 - 13:27
