New FLAC encoder
Nayru
post May 26 2006, 13:29
A new FLAC encoder has been developed, which is proposed for inclusion in ffmpeg. The author claims that in high-compression mode, it can compress certain files better than libFLAC.
http://mplayerhq.hu/pipermail/ffmpeg-devel...May/011385.html
HbG
post Sep 11 2006, 01:35
Oh yeah, wisodev's .07 build clocks in at about 29.1x for me with no memory leaks. Slightly slower than the leaky .06'es, but a major improvement nevertheless. Compression is the same. I should mention that i made some slight changes to my system and a reinstall, so there may be inaccuracies with my old benchmark results, but these should be fairly small, probably no more than .1x.
Pipe support still seems disfunctional, i get the following with both wisodev's .07 and justin's original fixed .06:
D:\MP3\Pearl Jam\Pearl Jam - Ten>type test.wav |flake -8 - test.flac
Flake: FLAC audio encoder
(c) 2006  Justin Ruggles
Signed 16-bit 44100 Hz stereo
samples: 23965116
blocksize: 4608
max order: 12
order method: 4-level
stereo method: search
| bytes: 4448
The process tried to write to a nonexistent pipe.
0.08's windows binaries do not work for me. It reads the files but never starts encoding, just throws me back to the commandline, like this:
D:\MP3\Pearl Jam\Pearl Jam - Ten>flake-win32-i586.exe test.wav test.flac
samples: 23965116
All three builds do it. It does parse options and respond to -h, it creates a 0 byte output file.
Also, is there any chance of a changelog?
Like wisodev says, there is improvement and that is most important. Flake has a lot of potential, keep up the good work!
Veni Vidi Vorbis.
wisodev
post Sep 11 2006, 07:38
He, I have found too that 0.08 windows binarys are not working (all of them) even my builds are not working.
When it starts it throws stack overflow error on my machine (Windows XP)
But I have found the source of this problem.
in file encode.c in function
flake_encode_init(FlakeContext *s)
there was changed since version 07 way of handling context (FlacEncodeContext ctx_local;) memory allocation
and this change to local variable is causing under windows stack overflow
    FlacEncodeContext *ctx;
    int i, header_len;
    if(s == NULL) {
        return -1;
    ctx = &ctx_local;
I have changed to method used in 07 (allocating memory at the beginning of the function) and it works OK and do not throws any errors.
wiso
http://code.google.com/p/wavtoac3encoder/
- Nayru   New FLAC encoder   May 26 2006, 13:29
- - kurtnoise   For those who want to test it, I've made a com...   May 26 2006, 14:40
- - jcoalson   it seems like a nice clean interface. some notes:...   May 26 2006, 21:57
|- - Justin Ruggles   Hi, I am the person writing the encoder mentioned ...   Jun 3 2006, 06:14
|- - jcoalson   QUOTE (Justin Ruggles @ Jun 3 2006, 00:14...   Jun 14 2006, 19:46
|- - Justin Ruggles   QUOTE (jcoalson @ Jun 14 2006, 12:46) QUO...   Jun 14 2006, 20:33
- - kurtnoise   Hi Justin, Thank you very much for this work (for...   Jun 3 2006, 16:49
|- - Justin Ruggles   QUOTE (kurtnoise @ Jun 3 2006, 09:49) Tha...   Jun 4 2006, 04:00
|- - kurtnoise   QUOTE (Justin Ruggles @ Jun 4 2006, 05:00...   Jun 4 2006, 07:55
|- - Justin Ruggles   QUOTE (kurtnoise @ Jun 4 2006, 00:55) Thr...   Jun 4 2006, 08:27
- - Justin Ruggles   Hi, I have made a small webpage to post updated ve...   Jun 14 2006, 08:56
- - kurtnoise   Hi Justin, Great stuff...Now, flake 0.4 works fin...   Jun 14 2006, 09:39
- - krmathis   flake dont seem to work correctly on Mac OS X (Pow...   Jun 14 2006, 18:42
|- - Justin Ruggles   QUOTE (krmathis @ Jun 14 2006, 11:42) fla...   Jun 14 2006, 18:49
- - krmathis   Hope you nail this, cause this looks like an inter...   Jun 14 2006, 19:34
- - ggf31416   40.964.828 bytes 16-bit Stereo 44100Hz WAV 3:52 ...   Jun 15 2006, 04:06
|- - Justin Ruggles   QUOTE (ggf31416 @ Jun 14 2006, 21:06) I s...   Jun 15 2006, 07:43
- - Justin Ruggles   Hi, Pre-release 5 is now out. * I hope the PPC en...   Jun 15 2006, 09:47
|- - krmathis   QUOTE (Justin Ruggles @ Jun 15 2006, 10:4...   Jun 15 2006, 17:00
- - Justin Ruggles   Hi all, Sorry to keep posting updates so often. ...   Jun 17 2006, 03:31
- - krmathis   Album: Toto - Legend (in a single file) Playing ti...   Jun 17 2006, 08:45
|- - Justin Ruggles   QUOTE (krmathis @ Jun 17 2006, 01:45) Alb...   Jun 18 2006, 04:20
|- - krmathis   QUOTE (Justin Ruggles @ Jun 18 2006, 05:2...   Jun 18 2006, 07:39
|- - miros   Here are my results for four albums lying around. ...   Jun 18 2006, 08:13
|- - Justin Ruggles   QUOTE (miros @ Jun 18 2006, 01:13) Justin...   Jun 25 2006, 02:14
- - HbG   CODEPearl Jam - Ten (new european version...   Jun 28 2006, 00:58
|- - Justin Ruggles   QUOTE (HbG @ Jun 27 2006, 17:58) CODEPear...   Jun 28 2006, 04:26
- - surf   hello. does this new encoder supports unicode? i c...   Jun 28 2006, 07:56
- - sundance   Justin, I'd also like to join in saying ...   Jun 28 2006, 08:47
|- - Justin Ruggles   Hello, QUOTE (sundance @ Jun 28 2006, 01...   Jun 28 2006, 14:38
|- - HbG   QUOTE (Justin Ruggles @ Jun 28 2006, 05:3...   Jun 28 2006, 14:57
|- - sundance   QUOTE (HbG @ Jun 28 2006, 13:57) ...but i...   Jun 28 2006, 15:25
|- - Justin Ruggles   QUOTE (HbG @ Jun 28 2006, 07:57) QUOTE (J...   Jun 29 2006, 03:06
- - wisodev   Well I am propobly too late but I have builded som...   Jul 4 2006, 19:19
|- - Justin Ruggles   QUOTE (wisodev @ Jul 4 2006, 12:19) Well ...   Jul 4 2006, 23:12
||- - wisodev   QUOTE Thank you! Especially for the win32 bui...   Jul 5 2006, 06:59
|- - HbG   QUOTE (wisodev @ Jul 4 2006, 10:19) Well ...   Jul 7 2006, 21:36
|- - Justin Ruggles   QUOTE (HbG @ Jul 7 2006, 14:36) Oh, one m...   Jul 8 2006, 00:29
- - jcoalson   another thing I would suggest is a big fat warning...   Jul 8 2006, 00:51
|- - Justin Ruggles   QUOTE (jcoalson @ Jul 7 2006, 17:51) anot...   Jul 8 2006, 21:44
- - Justin Ruggles   Hello, I'm posting again here because the FFm...   Jul 17 2006, 02:36
|- - Garf   QUOTE (Justin Ruggles @ Jul 17 2006, 03:3...   Jul 17 2006, 09:43
||- - Justin Ruggles   QUOTE (Garf @ Jul 17 2006, 02:43) QUOTE (...   Jul 17 2006, 10:36
|- - SebastianG   QUOTE (Justin Ruggles @ Jul 17 2006, 03:3...   Jul 18 2006, 09:14
- - krmathis   Great work! Hope you plan to "back-port...   Jul 17 2006, 08:02
- - Garf   Okay, I understand the what and why What's t...   Jul 17 2006, 10:51
|- - Justin Ruggles   QUOTE (Garf @ Jul 17 2006, 03:51) Okay, I...   Jul 17 2006, 21:45
- - jcoalson   I have actually been doing experiments solving the...   Jul 24 2006, 07:04
|- - SebastianG   QUOTE (jcoalson @ Jul 24 2006, 08:04) I h...   Jul 24 2006, 08:27
||- - jcoalson   QUOTE (SebastianG @ Jul 24 2006, 02:27) Q...   Jul 25 2006, 04:49
|- - TBeck   QUOTE (jcoalson @ Jul 24 2006, 08:04) I h...   Jul 24 2006, 16:25
- - HbG   Only noticed this now, it's leaking memory lik...   Sep 9 2006, 21:08
|- - Justin Ruggles   QUOTE (HbG @ Sep 9 2006, 14:08) Only noti...   Sep 9 2006, 23:21
|- - Justin Ruggles   QUOTE (Justin Ruggles @ Sep 9 2006, 16:21...   Sep 10 2006, 00:29
- - HbG   Thanks in advance!   Sep 9 2006, 23:34
- - HbG   That fixed it, thanks. But the speed's now dr...   Sep 10 2006, 12:02
|- - Justin Ruggles   QUOTE (HbG @ Sep 10 2006, 05:02) That fix...   Sep 10 2006, 19:31
- - wisodev   I have build the binary for Win32 (version 07 of f...   Sep 10 2006, 18:35
- - wisodev   QUOTE (Justin Ruggles @ Sep 10 2006, 20:3...   Sep 10 2006, 19:46
- - HbG   Oh yeah, wisodev's .07 build clocks in at abou...   Sep 11 2006, 01:35
|- - Justin Ruggles   QUOTE (HbG @ Sep 10 2006, 18:35) Oh yeah,...   Sep 11 2006, 03:28
|- - wisodev   He, I have found too that 0.08 windows binarys are...   Sep 11 2006, 07:38
- - sundance   Justin, would you consider adding wisodev's ...   Sep 11 2006, 21:55
|- - Justin Ruggles   QUOTE (sundance @ Sep 11 2006, 14:55) wou...   Sep 11 2006, 22:03
- - sundance   Justin, that's really good news. Too bad that...   Sep 11 2006, 22:08
|- - Justin Ruggles   QUOTE (sundance @ Sep 11 2006, 15:08) Jus...   Sep 11 2006, 22:21
|- - Justin Ruggles   Whew...it was accepted. http://sourceforge.net/pro...   Sep 11 2006, 22:49
|- - Justin Ruggles   QUOTE (Justin Ruggles @ Sep 11 2006, 15:4...   Sep 12 2006, 03:27
|- - wisodev   QUOTE For now I have built binaries for Linux, opt...   Sep 12 2006, 07:19
- - jcoalson   "flache" (High-Efficiency? painful?) is ...   Sep 11 2006, 23:25
- - sundance   What do you think about adding some version inform...   Sep 12 2006, 14:03
- - krmathis   Justin. I pulled revision 2 from SVN, and tried to...   Sep 12 2006, 16:14
- - wisodev   FLAKE 0.10 Win32 Build and Sources Download binar...   Sep 12 2006, 17:28
- - lexor   CODE FILE SIZE t_FLAC.flac 321 356 528 t_i686...   Sep 12 2006, 20:19
|- - wisodev   QUOTE CODE FILE SIZE t_FLAC.flac 321 356 528 ...   Sep 13 2006, 06:48
|- - lexor   QUOTE (wisodev @ Sep 13 2006, 01:48) This...   Sep 13 2006, 14:43
|- - wisodev   QUOTE (lexor @ Sep 13 2006, 15:43) QUOTE ...   Sep 13 2006, 19:07
|- - Egor   QUOTE (wisodev @ Sep 14 2006, 01:07) Oh t...   Sep 14 2006, 08:46
|- - wisodev   QUOTE Digit grouping symbol depends on your locale...   Sep 14 2006, 09:18
- - HbG   My run went at 37.00x That's more than three t...   Sep 13 2006, 01:20
- - sundance   wisodev, still one mystery remains: CODEDECODE...   Sep 13 2006, 08:29
|- - wisodev   QUOTE wisodev, still one mystery remains: CODEDEC...   Sep 13 2006, 08:52
- - iGold   I want to write my notes on lack of some features ...   Sep 14 2006, 08:18
- - lexor   hi, I have a somewhat strange request a few pages...   Sep 14 2006, 19:27
- - Madman2003   Is this encoder (flake 0.10) trustworthy for ...   Sep 14 2006, 19:32
- - bukem   FYI: I have just encoded my favorite album of Mar...   Sep 14 2006, 23:17
|- - guruboolez   QUOTE (bukem @ Sep 15 2006, 00:17) I have...   Sep 15 2006, 00:10
|- - bukem   QUOTE (guruboolez @ Sep 14 2006, 15:10) Q...   Sep 15 2006, 12:20
- - Justin Ruggles   QUOTE (Madman2003 @ Sep 14 2006, 12:32) I...   Sep 15 2006, 00:07
- - jcoalson   yes, that level 0-2 limitation was from the early ...   Sep 15 2006, 16:32
- - HbG   I've encoded over a dozen cd's with flake ...   Sep 16 2006, 00:53
- - Synthetic Soul   I have tried running my scripts with wisodev's...   Sep 18 2006, 11:31
|- - wisodev   @Synthetic Soul Can you try running this scripts ...   Sep 18 2006, 13:00
- - sundance   I've been using wiso's flake 0.10 several ...   Sep 18 2006, 12:01
- - Synthetic Soul   I have run my scripts here at work using the i586,...   Sep 18 2006, 13:39
- - Synthetic Soul   OK, I have tested 37.wav with the i586, i686 and w...   Sep 18 2006, 13:53
- - Will Fisher   Hey, I work for Winamp, and I'm very impresse...   Sep 18 2006, 16:15
- - Synthetic Soul   It seems the problem is still evident even in the ...   Sep 18 2006, 16:58
- - HbG   I can encode that sample at -0 just fine, using wi...   Sep 18 2006, 22:59
- - bukem   @Synthetic Soul: Flake 0.10 has failed to compres...   Sep 18 2006, 23:45
4 Pages V   1 2 3 > »
RSS Lo-Fi Version Time is now: 2nd September 2015 - 23:22
