14 Pages V   1 2 3 > »
foo_uie_playlists_dropdown, Playlists Dropdown - Columns UI Extension
mixcherry
post May 16 2006, 23:59
Playlists Dropdown v0.7.6
This plugin displays the playlists in a dropdown list:
Download
Playlists Dropdown
Source code
github.com/karolsarnacki/foo_uie_playlists_dropdown
Some features:
  • Customizable icons.
  • Configurable playlist titles on list.
  • Configurable fonts and colors.
  • Sorting playlists by various criteria.
  • Drag & Drop support.
  • Convenient context-menu.
The list can display various information about playlists (through formatting strings):
  • %title% Name of the playlist.
  • %lock% Present if the playlist is locked (returns name of the lock, for example Autoplaylist or Read-only).
  • %size% Number of items (songs) the playlist contains.
  • %length% Playlist's length (duration), formatted as [WK][D][HH:]MM:SS.
  • %length_hours% Playlist's length (duration), formatted as [HH:]MM:SS.
  • %length_seconds% Playlist's length (duration), in seconds, formatted as an integer.
  • %filesize_natural% Formatted total filesize of the playlist (e.g. 62.1GB or 322KB).
  • %filesize% Total filesize of the playlist in bytes
  • %isplaying% Present if the playlist is currently being played (to be used as a switch for $if()).
  • %isactive% Present if the playlist is active (to be used as a switch for $if()).
  • %list_index% Index of the playlist.
  • %list_total% Total number of playlists.
  • %_list% Special field to separate rendering of control (when it's closed) and the list (to be used as a switch for $if()).
ChangelogTo-do list
  • Customizable overlay icons / Use overlays for locked playlists (?) (0.7.7)
  • Auto-assigning icons to playlists using their name/lock/size etc. (titleformatting?) (0.7.8)
  • In-place rename (0.7.9)
  • Panel version (0.8)
  • Button version (0.8.1)
  • D&D playlists/items inside listbox using LMB
  • Better separators (without empy playlists)
  • Text on separators
  • Use global variables from Columns UI
  • Option to center text
  • FCL import/export (?)
  • Configurable action on playlist delete (go to previously active) (core?)
  • Aggregate functions ($avg('%field%'), $sum(), $min(), $max(), $count()) (?)
  • Playlist filtering (?)
  • Different configurations for different panels (??)
  • Grouping (???)
The Not-to-do list
Please do not discuss / request this:
  • None / Sunken / Grey border
  • Make combo-box editable (e.g. to type and find a playlist)
This post has been edited by mixcherry: Nov 21 2013, 11:39
http://foobar2000.pl/ :: unofficial polish forum
lav-chan
post May 17 2006, 00:37
That's rad.
I don't think i'll use it because i like to be able to see all the play lists at once, but i like what i can see in the picture. The different icons especially are really awesome (even if you can't configure them yet), i wish the regular play-list switcher had that.
Some CC: Just by looking at your screen shot (as in, without actually using it), it looks like you might have an issue with the vertical alignment. Like either the icon or the text isn't centred exactly. :shrug:
gfngfgf
post May 17 2006, 00:44
I haven't tried it out yet, but this is a really great idea. I look forward to using it a lot smile.gif
mixcherry
post May 17 2006, 00:51
I took the icons from foosion's Playlist Switcher plugin (on his approval, of course).
Yup, it might look like that, because font is too small (exactly, 1 pixel too small wink.gif). Icons and text are both verically centered.
This post has been edited by mixcherry: May 17 2006, 00:52
Lyx
post May 17 2006, 00:54
I like the idea of this component alot!
However, one thing which i like about playlist-tabs is how you can manipulate playlists via rightclicking, middleclicking, doubleclicking, etc. - I miss that functionality with this component.
- Lyx
edit: the degree of configurability however seems overkill to me
This post has been edited by Lyx: May 17 2006, 00:57
lav-chan
post May 17 2006, 00:55
QUOTE (mixcherry @ May 16 2006, 15:51) *
Oh? I didn't know he'd made such a plug-in, and i can't seem to find it on his page. Could you link me?
edit: Never mind, i found it. Playlist Manager. :p
Yup, it might look like that, because font is too small (exactly, 1 pixel too small ;)). Icons and text are both verically centered.
I see. MY BAD THEN AIGHT
This post has been edited by lav-chan: May 17 2006, 00:57
mixcherry
post May 17 2006, 01:08
QUOTE (Lyx @ May 17 2006, 01:54) *
Yes, I miss that too tongue.gif I'll try to add these functions as soon as possible.
4nt1
post May 17 2006, 04:50
very cool plugin
also coult it be possible to use global variables from a columns ui config?
have yet to try this out, just wondering if anything needs to be done to allow this
This post has been edited by 4nt1: May 17 2006, 05:53
lav-chan
post May 17 2006, 04:52
I'm pretty sure everything you just said was addressed in the list at the end of the first post.
Crissaegrim
post May 17 2006, 08:16
Very cool plugin, man. Kudos.
mil3s
post May 17 2006, 09:27
Wow. Awesome. Gonna try it now. I never thought anyone would make this when I asked for it a month or so back. smile.gif
roentgen
post May 17 2006, 12:23
and this one I really like...
I'm wonedring... is there some custom sorting available? 'cause I want the drop-down menu to be sorted by name of playlist not by their order on playlist tabs
mazy
post May 17 2006, 14:02
oi, mixcherry, thanks a lot! i was hoping for just a simple dropdown box ... and you came out of the blue with something much more than that! smile.gif
info about my tag guesser script for foo_lua (preview version available):
http://www.hydrogenaudio.org/index.php?showtopic=16987
mazy
post May 17 2006, 17:10
my screenshot:
click for whole pic, 171kb
prawns
post May 17 2006, 17:55
Post #15
QUOTE (mazy @ May 17 2006, 17:10) *
my screenshot:
4nt1
post May 17 2006, 18:55
Post #16
ok one small thing
how do you guys get that playback queue?
I have never seen it before is it a seperate component or am i just missing something very obvious
ok had a play around
found that if i make a playlist
then go Playback - Playback Queue Viewer, I can select a playlist for this to be used for.
there we have it right click on the files you want added then add to playback queue et voila smile.gif
ok it seems there is a limit to the playback queue of 64 tracks is this correct?
This post has been edited by 4nt1: May 17 2006, 19:05
Klato
post May 17 2006, 19:02
Post #17
Where do you get the Playback Queue Viewer? It's not listed in my Playback menu.
This post has been edited by Klato: May 17 2006, 19:13
Anas
post May 17 2006, 19:24
Post #18
You can get foo_pqview by foosion here: http://foosion.foobar2000.org/0.9/
It requires foo_common also available at this page.
Klato
post May 17 2006, 19:58
Post #19
cool thanks Anas
This post has been edited by Klato: May 17 2006, 19:58
Sphix
post May 18 2006, 00:33
Post #20
-foobar2000 + Burrrn + EAC
-HD 80Gb using High QualityVBR MP3s
mixcherry
post May 18 2006, 03:15
Post #21
QUOTE (4nt1 @ May 17 2006, 05:50) *
very cool plugin
QUOTE (Crissaegrim @ May 17 2006, 09:16) *
I'll add this to my to-do list... (it isn't possible right now, but maybe it's as simple as adding 2 lines of code wink.gif we'll see)
QUOTE (mil3s @ May 17 2006, 10:27) *
I never thought it could take me a (whole) month or so to make this plugin wink.gif
QUOTE (roentgen @ May 17 2006, 13:23) *
Thanks for that very interesting idea! I'm working on it now - I've implemented sorting the list by custom 'field' (for example %title% or %playlist_lock%), so you can expect this option in the very next version smile.gif I only have to tidy my code a little bit...
QUOTE (mazy @ May 17 2006, 15:02) *
QUOTE (mazy @ May 17 2006, 18:10) *
my screenshot:
That rocks!! I didn't know you could do such things with my plugin! biggrin.gif
neooffs
post May 18 2006, 04:40
Post #22
very nice plugin...
what about automatic sorting alphabetically?
TY! ;D
deagle32
post May 18 2006, 12:03
Post #23
Hi there,
how do you activate it? I am keen to use this plugin but I can't see how to turn on the dropdown list. I have the plugins from the stable package off foosion's site and am using Columns ui on foobar 0.91.
mixcherry
post May 18 2006, 12:43
Post #24
QUOTE ("neooffs")
As I already menioned in my previous post, I've already implemented sorting functionality. Just wait for new version to be released (in a day or two) smile.gif
QUOTE ("deagle32")
All you need is the latest Columns UI plugin (remember to activate it here: Preferences -> Display -> User interface module /reset/). Then, you can simply add my component to your toolbar (right-mouse-button on toolbar and Toolbars -> Playlists Dropdown) or add it as a panel - using Columns' Layout page (Preferences -> Display -> Columns UI -> Layout).
Squeller
post May 18 2006, 12:52
Post #25
<snipped, has been answered before>
BTW I recommend a reset button to return to the default settings and code.
This post has been edited by Squeller: May 18 2006, 12:54
RSS Lo-Fi Version Time is now: 29th January 2015 - 06:32
