foo_uie_playlists_dropdown, Playlists Dropdown - Columns UI Extension
mixcherry
post May 16 2006, 23:59
Playlists Dropdown v0.7.6
This plugin displays the playlists in a dropdown list:
Download
Playlists Dropdown
Source code
github.com/karolsarnacki/foo_uie_playlists_dropdown
Some features:
  • Customizable icons.
  • Configurable playlist titles on list.
  • Configurable fonts and colors.
  • Sorting playlists by various criteria.
  • Drag & Drop support.
  • Convenient context-menu.
The list can display various information about playlists (through formatting strings):
  • %title% Name of the playlist.
  • %lock% Present if the playlist is locked (returns name of the lock, for example Autoplaylist or Read-only).
  • %size% Number of items (songs) the playlist contains.
  • %length% Playlist's length (duration), formatted as [WK][D][HH:]MM:SS.
  • %length_hours% Playlist's length (duration), formatted as [HH:]MM:SS.
  • %length_seconds% Playlist's length (duration), in seconds, formatted as an integer.
  • %filesize_natural% Formatted total filesize of the playlist (e.g. 62.1GB or 322KB).
  • %filesize% Total filesize of the playlist in bytes
  • %isplaying% Present if the playlist is currently being played (to be used as a switch for $if()).
  • %isactive% Present if the playlist is active (to be used as a switch for $if()).
  • %list_index% Index of the playlist.
  • %list_total% Total number of playlists.
  • %_list% Special field to separate rendering of control (when it's closed) and the list (to be used as a switch for $if()).
ChangelogTo-do list
  • Customizable overlay icons / Use overlays for locked playlists (?) (0.7.7)
  • Auto-assigning icons to playlists using their name/lock/size etc. (titleformatting?) (0.7.8)
  • In-place rename (0.7.9)
  • Panel version (0.8)
  • Button version (0.8.1)
  • D&D playlists/items inside listbox using LMB
  • Better separators (without empy playlists)
  • Text on separators
  • Use global variables from Columns UI
  • Option to center text
  • FCL import/export (?)
  • Configurable action on playlist delete (go to previously active) (core?)
  • Aggregate functions ($avg('%field%'), $sum(), $min(), $max(), $count()) (?)
  • Playlist filtering (?)
  • Different configurations for different panels (??)
  • Grouping (???)
The Not-to-do list
Please do not discuss / request this:
  • None / Sunken / Grey border
  • Make combo-box editable (e.g. to type and find a playlist)
This post has been edited by mixcherry: Nov 21 2013, 11:39
http://foobar2000.pl/ :: unofficial polish forum
mil3s
post May 31 2006, 14:26
^ For mixcherrys sake I think he should keep it simple. Number 2 and 3 are completly unnecessary imo. Though it should be possible to select a divider.
Number 1 wouldn't be necessary either. A simple '-' could be set to create a divider without any special settings.
This post has been edited by mil3s: May 31 2006, 14:29
- mixcherry   foo_uie_playlists_dropdown   May 16 2006, 23:59
- - lav-chan   That's rad. I don't think i'll use it...   May 17 2006, 00:37
- - gfngfgf   I haven't tried it out yet, but this is a real...   May 17 2006, 00:44
- - mixcherry   Thank you QUOTE The different icons especially a...   May 17 2006, 00:51
|- - lav-chan   QUOTE (mixcherry @ May 16 2006, 15:51) I ...   May 17 2006, 00:55
- - Lyx   I like the idea of this component alot! Howev...   May 17 2006, 00:54
|- - mixcherry   QUOTE (Lyx @ May 17 2006, 01:54) I like t...   May 17 2006, 01:08
- - 4nt1   very cool plugin can't wait until the to do l...   May 17 2006, 04:50
|- - lav-chan   I'm pretty sure everything you just said was a...   May 17 2006, 04:52
- - Crissaegrim   Very cool plugin, man. Kudos.   May 17 2006, 08:16
- - mil3s   Wow. Awesome. Gonna try it now. I never thought an...   May 17 2006, 09:27
- - roentgen   nice... whenever I hear about a new plugin I feel ...   May 17 2006, 12:23
- - mazy   oi, mixcherry, thanks a lot! i was hoping for ...   May 17 2006, 14:02
- - mazy   my screenshot: click for whole pic, 171kb   May 17 2006, 17:10
|- - prawns   QUOTE (mazy @ May 17 2006, 17:10) my scre...   May 17 2006, 17:55
- - 4nt1   ok one small thing how do you guys get that playba...   May 17 2006, 18:55
- - Klato   Where do you get the Playback Queue Viewer? It...   May 17 2006, 19:02
- - Anas   You can get foo_pqview by foosion here: http://foo...   May 17 2006, 19:24
- - Klato   cool thanks Anas   May 17 2006, 19:58
- - Sphix   That's nice   May 18 2006, 00:33
- - mixcherry   QUOTE (4nt1 @ May 17 2006, 05:50) very co...   May 18 2006, 03:15
- - neooffs   very nice plugin... what about automatic sorting ...   May 18 2006, 04:40
- - deagle32   Hi there, how do you activate it? I am keen to ...   May 18 2006, 12:03
|- - Squeller   <snipped, has been answered before> BTW I r...   May 18 2006, 12:52
- - mixcherry   QUOTE ("neooffs")what about automatic so...   May 18 2006, 12:43
- - mixcherry   QUOTE (Squeller)BTW I recommend a reset button to ...   May 18 2006, 13:00
|- - Squeller   QUOTE (mixcherry @ May 18 2006, 04:00) QU...   May 18 2006, 14:10
- - deagle32   Hm, I am using Columns UI and the dropdown option...   May 18 2006, 13:02
- - deagle32   Okay, I fixed it I had the pre-beta version of C...   May 18 2006, 13:41
- - mixcherry   Update to version 0.5.5: QUOTE 20060519 (v0.5.5)A...   May 19 2006, 03:52
- - 81x   Hi mixcherry Very nice plugin, thanks Couple of ...   May 19 2006, 04:45
- - 81x   QUOTE (mixcherry @ May 19 2006, 03:52) Pl...   May 19 2006, 06:05
- - unabatedshagie   I love this plugin, the only thing I'm missing...   May 19 2006, 06:52
- - mixcherry   QUOTE (81x)Very nice plugin, thanksThanks! QUO...   May 19 2006, 08:57
|- - unabatedshagie   QUOTE (mixcherry @ May 19 2006, 08:57) QU...   May 19 2006, 18:22
- - Squeller   Many thanks, mixcherry, esp. for the %length% fiel...   May 19 2006, 10:14
- - NinjaN   Hello mixcherry, Thank you very much for this pl...   May 19 2006, 11:06
|- - gfngfgf   QUOTE (NinjaN @ May 19 2006, 03:06) I wou...   May 19 2006, 13:33
- - NinjaN   No, didn't try that yet... But anyway, I am a...   May 19 2006, 14:40
- - mixcherry   QUOTE (NinjaN)Thank you very much for this plugin...   May 19 2006, 17:22
- - Zimdgre   my screenshot with foo_fullscreen, foo_notaskbar, ...   May 19 2006, 18:04
- - 4nt1   Also is it possible to remove the outer frame like...   May 19 2006, 19:38
|- - Lyx   QUOTE (4nt1 @ May 19 2006, 20:38) Also is...   May 19 2006, 19:54
- - NinjaN   QUOTE (mixcherry @ May 19 2006, 10:22) QU...   May 19 2006, 20:26
- - Zimdgre   I like this plugin, but it'll be better if it ...   May 20 2006, 09:34
- - mixcherry   QUOTE (Zimdgre)I like this plugin, but it'll b...   May 20 2006, 10:44
|- - Zimdgre   QUOTE (mixcherry @ May 20 2006, 17:44) Yo...   May 20 2006, 18:04
- - deagle32   hi mixcherry, this plugin is GREAT ...I have many ...   May 20 2006, 14:26
- - mimeryme   Thanks for this plugin mixcherry! I too was l...   May 20 2006, 16:27
- - deagle32   would it be possible to display the total filesize...   May 21 2006, 07:12
- - Zimdgre   It'll be very handy if we could delete current...   May 21 2006, 14:12
- - neooffs   the component works great, thanks for the dev and...   May 21 2006, 15:30
- - mixcherry   QUOTE (deagle32 @ May 20 2006, 15:26) hi ...   May 21 2006, 18:22
|- - Zimdgre   QUOTE (mixcherry @ May 22 2006, 01:22) QU...   May 22 2006, 13:23
- - deagle32   QUOTE Of course it would be possible smile.gif I...   May 22 2006, 01:00
- - Anas   There is this "Set max height" checkbox ...   May 23 2006, 14:25
- - neomcnasty   Hi mixcherry, first I would like to thank you for ...   May 25 2006, 22:10
- - zoidbergslo   thanks for this great plugin   May 27 2006, 12:49
- - mixcherry   QUOTE (Zimdgre @ May 22 2006, 14:23) Than...   May 28 2006, 16:50
- - gfngfgf   mixcherry: I just tried 0.5.7, and when I left-cli...   May 28 2006, 17:43
- - Bachi-Bouzouk   Hi mixcherry, very nice plugin and useful for my F...   May 29 2006, 12:11
- - mixcherry   Hi Bachi-Bouzouk! Thanks for this bug-report.....   May 29 2006, 13:07
|- - james.miller   very nice plugin, thank you:)   May 29 2006, 13:46
|- - q-stankovic   QUOTE (mixcherry @ May 29 2006, 13:07) Hi...   May 29 2006, 14:38
- - mixcherry   QUOTE (james.miller @ May 29 2006, 14:46)...   May 29 2006, 15:45
- - Bachi-Bouzouk   OOOUUUPPPSSS I forgot the link Sorry!! ...   May 29 2006, 16:09
|- - Zimdgre   QUOTE (Bachi-Bouzouk @ May 29 2006, 23...   May 30 2006, 02:37
- - Bachi-Bouzouk   the bug is not inked to my .fcs .. I updated my p...   May 30 2006, 06:25
- - mil3s   This plugin is coming along great. Nice work mixch...   May 30 2006, 15:07
|- - unabatedshagie   QUOTE (mil3s @ May 30 2006, 15:07) This p...   May 30 2006, 20:06
|- - foosion   QUOTE (unabatedshagie @ May 30 2006, 21:0...   May 30 2006, 23:07
|- - unabatedshagie   QUOTE (foosion @ May 30 2006, 23:07) QUOT...   May 31 2006, 06:08
- - mixcherry   QUOTE (Bachi-Bouzouk @ May 29 2006, 17...   May 31 2006, 12:01
- - mil3s   Yea, dividers like that, almost anyway. Not betwee...   May 31 2006, 12:31
- - mixcherry   Ahh, I see... I like this idea, and I thought abou...   May 31 2006, 13:39
- - mil3s   I like the first alternative.   May 31 2006, 13:47
- - Bachi-Bouzouk   I will send you a personal message in the coming ...   May 31 2006, 13:52
- - mazy   about those dividers, it's not easy task (i.e....   May 31 2006, 14:02
- - mil3s   ^ For mixcherrys sake I think he should keep it si...   May 31 2006, 14:26
- - mazy   well i use empty name for separators (looks good e...   May 31 2006, 15:05
- - xliu5   Don't know if it is a bug or not. The %filesiz...   May 31 2006, 18:10
- - mixcherry   QUOTE (Bachi-Bouzouk @ May 31 2006, 14...   May 31 2006, 19:30
|- - mazy   QUOTE (mixcherry @ May 31 2006, 20:30) Th...   Jun 1 2006, 01:37
- - Sphix   Really nice plugin, thanks!   May 31 2006, 21:49
- - mil3s   What is 'Set max height'?   May 31 2006, 21:57
- - Bachi-Bouzouk   now it works perfectly !! and as the drop...   May 31 2006, 22:00
- - mil3s   Any news?   Jun 4 2006, 10:04
- - mixcherry   QUOTE (mil3s @ May 31 2006, 22:57) What i...   Jun 6 2006, 11:51
- - Zimdgre   I have a request which is not likely would be done...   Jun 6 2006, 15:07
- - unabatedshagie   question, how would I go about chnaging the order ...   Jun 6 2006, 15:20
- - Squeller   A request: Would you please add support for displa...   Jun 6 2006, 15:30
|- - mazy   QUOTE (Squeller @ Jun 6 2006, 16:30) A re...   Jun 6 2006, 17:18
- - roentgen   well... having '-' playlists only to show ...   Jun 6 2006, 15:39
- - mil3s   Thanks mixcherry for the new version. The dividers...   Jun 6 2006, 16:28
|- - gfngfgf   QUOTE (mil3s @ Jun 6 2006, 08:28) * A fas...   Jun 7 2006, 00:39
|- - Squeller   QUOTE (mil3s @ Jun 6 2006, 07:28) QUOTE (...   Jun 7 2006, 07:29
- - 4nt1   yes I too second that for none, grey and sunken......   Jun 6 2006, 19:07
- - mil3s   Squeller: The border as it is now is exactly how i...   Jun 7 2006, 08:26
- - mixcherry   QUOTE (Zimdgre @ Jun 6 2006, 16:07) I hav...   Jun 7 2006, 08:41
- - mil3s   ^Thanks for your replys. Take your time. Looking f...   Jun 7 2006, 09:26
4 Pages V   1 2 3 > »
RSS Lo-Fi Version Time is now: 25th January 2015 - 13:25
