Nero Releases FREE Reference Quality MPEG-4 Audio Encoder, Nero Releases Command Line MPEG-4 & 3GPP AAC Solution
Ivan Dimkovic
post May 4 2006, 15:13
Nero MPEG4 developer
I am pleased to announce the launch of FREE Reference Quality MPEG-4 Audio solution from Nero, in the command line form!
* First in the world FREE 2-Pass MPEG-4 AAC Encoder
* Support for mono, stereo and multichannel encodings
* Support for sampling rates up to 96 kHz, up to 32-bit Floating-Point PCM input
* Compression Ratios ranging from ultra high (58 CDs fit on one!) to High-End Audio (2.5:1), for absolutely perfect audiophile encodings
* Support for Embedded Album Art (Covers, Booklets, Lyrics!)
* Store Entire Audio Album in a Single .mp4 File with all the Features of an Audio CD embedded inside, but at a fraction of the space!
* Reference Quality MPEG-4 Audio Codec
* Fully Compatible with the Latest Version of the State-of-the-art MPEG-4 Audio Standard (LC-AAC, HE-AAC and HE-AAC v2)
http://www.nero.com/nerodigital/eng/Nero_Digital_Audio.html
This post has been edited by Garf: May 7 2006, 19:46
ozmosis82
post May 4 2006, 19:01
QUOTE (Garf @ May 4 2006, 12:22 PM) *
You can use fractional values.
BTW. Using 2-pass with VBR makes no sense smile.gif VBR will just use how many bits it needs.
QUOTE (edekba @ May 4 2006, 12:26 PM) *
Hmmm using single pass created an audio file of 132kbps while a 2pass was 127kbps. Both sound the same to me ... just curious ...
I was experimenting with 2-pass vs single pass, and I noticed similar results. I had quality set to 0.6, and encoded Thursday's "A City by the Light Divided." Single pass came out around 74.4MB, with a bitrate ~224, whereas 2-pass came to 70.7MB with a bitrate of ~215. Interestingly enough, that's exactly the bitrate I was looking for. Almost every other album I've done w/2-pass averages ~215kbps.
edekba
post May 4 2006, 21:31
QUOTE (ozmosis82 @ May 4 2006, 11:01 AM) *
yeah w/2pass the bitrate comes out more of what i wanted. But Garf said that we shoudlnt do 2pass vbr so i guess i gotta go lower w/the q values.
- Ivan Dimkovic   Nero Releases FREE Reference Quality MPEG-4 Audio Encoder   May 4 2006, 15:13
- - sony666   first thanks and wow checking out edit: fir...   May 4 2006, 15:15
- - yulyo!   thank You Ivan. i do not know how to work with com...   May 4 2006, 15:22
|- - towolf   QUOTE (yulyo! @ May 4 2006, 04:22 PM)...   May 4 2006, 15:34
- - sony666   it crashes whatever I throw at it after showing th...   May 4 2006, 15:26
- - Ivan Dimkovic   QUOTE edit: first run without comandline parameter...   May 4 2006, 15:27
|- - sony666   QUOTE (Ivan Dimkovic @ May 4 2006, 04:27 ...   May 4 2006, 15:29
- - Ivan Dimkovic   Okay thanks for the info - our team will investiga...   May 4 2006, 15:33
- - Ivan Dimkovic   Linux is actually on the way   May 4 2006, 15:44
- - sony666   This is a fantastic release and could be the one f...   May 4 2006, 15:51
- - kurtnoise   Many thanks to the Nero devs...Great stuff btw. ...   May 4 2006, 15:52
|- - Garf   QUOTE (kurtnoise @ May 4 2006, 04:52 PM) ...   May 4 2006, 17:28
|- - kurtnoise   QUOTE (Garf @ May 4 2006, 06:28 PM) QUOTE...   May 4 2006, 17:50
- - halb27   Just tried. It didn't crash, but it doesn...   May 4 2006, 16:00
|- - Pasqui   QUOTE (halb27 @ May 4 2006, 05:00 PM) Jus...   May 4 2006, 16:56
|- - Garf   QUOTE (Pasqui @ May 4 2006, 05:56 PM) QUO...   May 4 2006, 17:23
- - toology   This looks really promising! Will this impleme...   May 4 2006, 16:01
|- - Garf   QUOTE (toology @ May 4 2006, 05:01 PM) Th...   May 4 2006, 17:39
- - enry2k   It is wonderful gift!   May 4 2006, 16:08
- - Leo 69   Can't encode on Athlon XP here. I see an error   May 4 2006, 16:15
- - sizetwo   Yay Will check it out right away. Sounds promi...   May 4 2006, 16:19
- - Synthetic Soul   Erroring here as well; it hangs for a while and th...   May 4 2006, 16:43
- - ozmosis82   Hurrah Ivan! I'm definitely excited about...   May 4 2006, 17:09
- - jimhaddon   works great with mine! P4 @ 4.2Ghz, XP Pro Q...   May 4 2006, 17:13
- - Leo 69   Pasqui QUOTE afaik, SS2 is supported No, it isn...   May 4 2006, 17:20
- - Squeller   I've got some problems with the command line f...   May 4 2006, 17:27
|- - jimhaddon   QUOTE (Squeller @ May 4 2006, 05:27 PM) 1...   May 4 2006, 17:36
|- - Julien   QUOTE (Squeller @ May 4 2006, 06:27 PM) I...   May 4 2006, 17:41
||- - Garf   QUOTE (Julien @ May 4 2006, 06:41 PM) QUO...   May 4 2006, 17:44
|||- - Julien   QUOTE (Garf @ May 4 2006, 06:44 PM) QUOTE...   May 4 2006, 17:54
|||- - rosshmusic   QUOTE QUOTE QUOTE I'm using "-q 0.6 -if...   May 4 2006, 18:29
||- - Squeller   QUOTE (Julien @ May 4 2006, 08:41 AM) I...   May 4 2006, 17:50
|- - Garf   QUOTE (Squeller @ May 4 2006, 06:27 PM) P...   May 4 2006, 18:02
||- - edekba   QUOTE (Garf @ May 4 2006, 10:02 AM) QUOTE...   May 4 2006, 18:17
||- - haregoo   QUOTE (edekba @ May 5 2006, 02:17 AM) I...   May 4 2006, 18:20
|||- - edekba   QUOTE (haregoo @ May 4 2006, 10:20 AM) QU...   May 4 2006, 18:26
|||- - Garf   QUOTE (edekba @ May 4 2006, 07:26 PM) QUO...   May 4 2006, 18:38
||- - Garf   QUOTE I guess that means users should try out diff...   May 4 2006, 18:22
|- - Sebastian Mares   QUOTE (Squeller @ May 4 2006, 06:27 PM) 1...   May 4 2006, 18:06
- - Dzamburu   I aslo don't have sse2 instruction and get sam...   May 4 2006, 17:34
|- - goodnews   How about adding an option to the AAC Encoder util...   May 4 2006, 17:41
|- - Garf   QUOTE (goodnews @ May 4 2006, 06:41 PM) H...   May 4 2006, 17:43
- - ozmosis82   QUOTE (jimhaddon @ May 4 2006, 11:13 AM) ...   May 4 2006, 17:35
- - Digga   thank you developers! this is a nice and muc...   May 4 2006, 17:40
- - Garf   Note that the encoder accepts data from standard i...   May 4 2006, 17:41
- - ozmosis82   QUOTE (jimhaddon @ May 4 2006, 11:36 AM) ...   May 4 2006, 17:43
- - ozmosis82   QUOTE (goodnews @ May 4 2006, 11:41 AM) H...   May 4 2006, 17:45
- - jmartis   It will encode on my computer but doesnt write hea...   May 4 2006, 18:11
|- - Garf   QUOTE (jmartis @ May 4 2006, 07:11 PM) It...   May 4 2006, 18:14
|- - jmartis   QUOTE (Garf @ May 4 2006, 07:14 PM) QUOTE...   May 4 2006, 18:22
- - Dzamburu   what is minimum bitrate for 5.1 encoding   May 4 2006, 18:19
- - AtaqueEG   QUOTE (Ivan Dimkovic @ May 4 2006, 09:13 ...   May 4 2006, 18:53
|- - Garf   QUOTE Can't download. Any mirrors? The server...   May 4 2006, 18:58
|- - AtaqueEG   QUOTE (Garf @ May 4 2006, 12:58 PM) The s...   May 4 2006, 19:16
|- - Garf   QUOTE (AtaqueEG @ May 4 2006, 08:16 PM) Q...   May 4 2006, 19:41
|- - AtaqueEG   QUOTE (Garf @ May 4 2006, 01:41 PM) http:...   May 4 2006, 19:44
|- - halb27   QUOTE (AtaqueEG @ May 4 2006, 08:44 PM) ....   May 4 2006, 21:06
- - ozmosis82   QUOTE (Garf @ May 4 2006, 12:22 PM) You c...   May 4 2006, 19:01
|- - edekba   QUOTE (ozmosis82 @ May 4 2006, 11:01 AM) ...   May 4 2006, 21:31
|- - ozmosis82   QUOTE (edekba @ May 4 2006, 03:31 PM) yea...   May 4 2006, 21:35
|- - edekba   QUOTE (ozmosis82 @ May 4 2006, 01:35 PM) ...   May 4 2006, 21:44
|- - ozmosis82   QUOTE (edekba @ May 4 2006, 03:44 PM) i d...   May 4 2006, 21:47
- - ssjkakaroto   i've have waited a long time for the aac encod...   May 4 2006, 19:13
- - MuncherOfSpleens   I'm assuming that the -q setting is to be used...   May 4 2006, 19:19
|- - Garf   QUOTE (MuncherOfSpleens @ May 4 2006, 08...   May 4 2006, 19:24
- - senab   Great stuff lads. Been needing a good quality gap...   May 4 2006, 19:45
- - brumal   Works wonderfully on my P4. Many thanks to the Ner...   May 4 2006, 19:56
- - Niphlod   perhaps bittorrent sources will resolve the proble...   May 4 2006, 20:14
|- - MuncherOfSpleens   QUOTE (Niphlod @ May 4 2006, 03:14 PM) pe...   May 4 2006, 20:56
|- - MuncherOfSpleens   Sorry. I didn't know it was illegal. I'l...   May 4 2006, 21:05
- - br0adband   Thanks to Ivan and the whole Nero team for this re...   May 4 2006, 20:47
|- - Garf   QUOTE (br0adband @ May 4 2006, 09:47 PM) ...   May 4 2006, 20:59
- - Ivan Dimkovic   AMD problem has been solved, but it will take unti...   May 4 2006, 20:49
- - ozmosis82   QUOTE (br0adband @ May 4 2006, 02:47 PM) ...   May 4 2006, 20:58
- - askoff   Thanks Nero Audio team. This is a realy nice surpr...   May 4 2006, 20:58
- - Ivan Dimkovic   Actually, the bug was not AMD-related, but related...   May 4 2006, 21:03
- - ozmosis82   Is there a change log for Nero's AAC encoder? ...   May 4 2006, 21:05
|- - Garf   QUOTE (ozmosis82 @ May 4 2006, 10:05 PM) ...   May 4 2006, 21:08
- - Ivan Dimkovic   QUOTE Is there a change log for Nero's AAC enc...   May 4 2006, 21:07
- - ozmosis82   QUOTE (Ivan Dimkovic @ May 4 2006, 03:07 ...   May 4 2006, 21:13
- - br0adband   No idea why this is happening (just for me it seem...   May 4 2006, 21:23
|- - Garf   QUOTE (br0adband @ May 4 2006, 10:23 PM) ...   May 4 2006, 21:34
- - AlexanderTG   If I encode my speak audio files with this, is it ...   May 4 2006, 21:27
|- - Garf   QUOTE (AlexanderTG @ May 4 2006, 10:27 PM...   May 4 2006, 21:31
|- - IgorC   It's good to have floating point bitrate. Now ...   May 4 2006, 21:38
|- - Garf   QUOTE (IgorC @ May 4 2006, 10:38 PM) It...   May 4 2006, 21:41
|- - IgorC   QUOTE (Garf @ May 4 2006, 12:41 PM) QUOTE...   May 4 2006, 21:43
- - chichazor   Any mirror to download it? The ftp6 url don't ...   May 4 2006, 21:42
|- - AtaqueEG   QUOTE (chichazor @ May 4 2006, 03:42 PM) ...   May 4 2006, 21:47
- - ozmosis82   To Garf or Ivan: I guess I'm just looking to ...   May 4 2006, 21:43
|- - Garf   QUOTE (ozmosis82 @ May 4 2006, 10:43 PM) ...   May 4 2006, 22:06
- - Ivan Dimkovic   QUOTE I guess I'm just looking to clarificatio...   May 4 2006, 21:51
|- - ozmosis82   QUOTE (Ivan Dimkovic @ May 4 2006, 03:51 ...   May 4 2006, 21:54
- - DARcode   Thank you very much for making this available for ...   May 4 2006, 21:52
- - br0adband   I'd say 2 pass audio encoding is a bit ridicul...   May 4 2006, 21:58
|- - ozmosis82   QUOTE (br0adband @ May 4 2006, 03:58 PM) ...   May 4 2006, 22:08
- - Ivan Dimkovic   QUOTE I'd say 2 pass audio encoding is a bit r...   May 4 2006, 22:01
- - kwanbis   Thanks for the gift. I would include the configura...   May 4 2006, 22:44
- - br0adband   No worries, didn't want my post to come across...   May 4 2006, 22:47
- - chrisgeleven   Is there any shot of this being available for us O...   May 4 2006, 22:54
6 Pages V   1 2 3 > »
RSS Lo-Fi Version Time is now: 25th January 2015 - 22:47
