Do you use FLAC or WAVPACK?, Simple poll on two of the most popular lossless codecs
FLAC [ 325 ] ** [54.99%]
WAVPACK [ 222 ] ** [37.56%]
Neither, I use another losless codec [ 44 ] ** [7.45%]
Total Votes: 718
Badass01
post Apr 23 2006, 13:56
Please also state your reason why...
iGold
post Apr 23 2006, 16:53
FLAC because of wide Linux support and embedded cuesheet metadata block (for my backups I prefer one .flac for one CD).
- Badass01   Do you use FLAC or WAVPACK?   Apr 23 2006, 13:56
- - senab   I use FLAC. Simply because my old DAP (Rio Karma)...   Apr 23 2006, 14:09
- - keytotime   I use WavPack because of the smaller file size and...   Apr 23 2006, 14:11
- - toology   WavPack because of good encoding/decoding speed an...   Apr 23 2006, 14:25
- - Fandango   Wavpack: higher compression   Apr 23 2006, 15:05
- - Maglor   FLAC, because my iAudio supports it. No other reas...   Apr 23 2006, 15:36
- - esa372   I used FLAC for quite a while, but I recently swit...   Apr 23 2006, 15:43
- - vitos   WavPack - because of better compression and hybrid...   Apr 23 2006, 15:45
|- - guruboolez   QUOTE (vitos @ Apr 23 2006, 03:45 PM) Wav...   Apr 23 2006, 16:00
- - jmartis   I've used Wavpack lossy, but I've just acq...   Apr 23 2006, 16:02
- - ffooky   FLAC because it is universally accepted and compat...   Apr 23 2006, 16:06
- - lextune   I use both, for different reasons. I use WavPack ...   Apr 23 2006, 16:11
- - iGold   FLAC because of wide Linux support and embedded cu...   Apr 23 2006, 16:53
- - pepoluan   Between FLAC and WavPack I use FLAC for it's c...   Apr 23 2006, 17:34
- - krmathis   Other -->> Apple Lossless Simply because i...   Apr 23 2006, 18:45
- - Synthetic Soul   This is spooky. I was going to start a new ...   Apr 23 2006, 18:51
|- - Shade[ST]   Wavpack -- I like the name better.   Apr 23 2006, 18:55
- - singaiya   Wavpack for the hybrid feature. I don't use lo...   Apr 23 2006, 19:03
- - Sebastian Mares   WavPack because it's faster.   Apr 23 2006, 19:15
- - slks   FLAC - more support, faster decoding.   Apr 23 2006, 19:24
- - Mo0zOoH   Wavpack: fast decoding, good compression, great su...   Apr 23 2006, 19:32
- - rjamorim   Wavpack. Partially because Bryant is a hell of a g...   Apr 23 2006, 19:34
- - Duble0Syx   I use WavPack. I like the extra compression, alth...   Apr 23 2006, 19:41
- - kwanbis   shouldn't you had inclided monkey, alac, yalac...   Apr 23 2006, 20:01
|- - Synthetic Soul   QUOTE (kwanbis @ Apr 23 2006, 07:01 PM) s...   Apr 23 2006, 20:12
- - gfngfgf   Wavpack, better compression   Apr 23 2006, 20:01
- - My name is Mud   FLAC - partially because my copy of EAC is already...   Apr 23 2006, 20:24
- - Realityfreak   WavPack I like the compression ratio, the decompr...   Apr 23 2006, 20:39
- - Alexxander   FLAC -8 because of the fast decoding speed and nat...   Apr 23 2006, 20:39
- - Menollo   FLAC because: 1. it decodes faster.. (dont know th...   Apr 23 2006, 21:33
|- - shadowking   QUOTE (Menollo @ Apr 23 2006, 12:33 PM) F...   Apr 24 2006, 07:21
- - DreamTactix291   WavPack for a few reasons. Faster compression spee...   Apr 23 2006, 22:04
- - CyberFoxx   Flac, mostly for the better Linux support. Then a...   Apr 23 2006, 23:16
- - fairyliquidizer   I saw an alternative at Ikea called FLATPAC   Apr 23 2006, 23:18
- - rehgf   WavPack, because of better size to decompression s...   Apr 24 2006, 01:07
- - VCSkier   wavpack, largely because of the ability to embed c...   Apr 24 2006, 01:44
- - beto   I switched from Monkey's and FLAC to Wavpack. ...   Apr 24 2006, 02:59
- - jcoalson   can someone fill me in about this supposed "s...   Apr 24 2006, 07:14
|- - guruboolez   QUOTE (jcoalson @ Apr 24 2006, 07:14 AM) ...   Apr 24 2006, 12:11
|- - jcoalson   QUOTE (guruboolez @ Apr 24 2006, 06:11 AM...   Apr 24 2006, 17:06
|- - ChristianHJW   QUOTE (guruboolez @ Apr 24 2006, 11:11 AM...   Apr 25 2006, 16:36
- - kjoonlee   I think he needs (but doesn't want) 32kb~64kb ...   Apr 24 2006, 07:21
- - kjoonlee   No implementations, maybe?   Apr 24 2006, 07:26
|- - user   I started Lossless with Flac some years ago, went ...   Apr 24 2006, 10:40
- - sshd   I use both. Wavpack for the handful of 192k/24bit...   Apr 24 2006, 10:36
- - micimaci   WavPack - speed, warm fuzzy feeling   Apr 24 2006, 10:49
- - shadowking   I use wavpack. It is cutting edge technology, grea...   Apr 24 2006, 13:06
- - tpc   I use monkey and have been for the past few years,...   Apr 24 2006, 13:11
- - Zergen   APE High - I use lossless for archive and listen M...   Apr 24 2006, 13:25
- - yane   Recent convert to Wavpack. I was using FLAC for o...   Apr 24 2006, 13:53
- - zombiewerewolf   I go for Wavpack. It's fast and has better enc...   Apr 24 2006, 14:05
- - laneling   Wavpack is better,I think.   Apr 24 2006, 14:17
- - zepoloo   I find the emphasis on speed and compression somew...   Apr 24 2006, 17:41
|- - guruboolez   QUOTE (zepoloo @ Apr 24 2006, 05:41 PM) T...   Apr 24 2006, 17:57
|- - user   QUOTE (zepoloo @ Apr 24 2006, 06:41 PM) I...   Apr 24 2006, 17:58
||- - Northpole   QUOTE (user @ Apr 24 2006, 11:58 AM) QUOT...   Apr 29 2006, 03:22
|- - My name is Mud   QUOTE (zepoloo @ Apr 24 2006, 09:41 AM) C...   Apr 24 2006, 19:47
- - snookerdoodle   Flac because plugins were available at the time fo...   Apr 24 2006, 18:36
- - Squeller   Wavpack, good speed, better compression, actively ...   Apr 24 2006, 19:31
- - TimYork   WavPack, because I get better compression with a p...   Apr 24 2006, 19:54
|- - Wombat   Flac. Since my hardwareplayer supports it native. ...   Apr 24 2006, 21:09
- - opeth2112   Wavpack - compression ratio mainly. No player tha...   Apr 24 2006, 21:24
- - Badass01   Is it pretty easy to convert from FLAC to Wavpack ...   Apr 24 2006, 22:21
|- - Synthetic Soul   QUOTE (Badass01 @ Apr 24 2006, 09:21 PM) ...   Apr 24 2006, 22:34
||- - valnar   QUOTE (Synthetic Soul @ Apr 24 2006, 01:3...   Apr 24 2006, 23:41
|- - guruboolez   QUOTE (Badass01 @ Apr 24 2006, 10:21 PM) ...   Apr 24 2006, 22:34
- - nyarlathotep   I use WavPack. (Yes I like the red foobar2000 wv i...   Apr 24 2006, 22:31
|- - bryant   QUOTE (nyarlathotep @ Apr 24 2006, 02:31 ...   Apr 25 2006, 05:11
- - Andavari   I use: WavPack (Normal, -m) via Speek's WavPac...   Apr 25 2006, 00:22
- - keytotime   This is the batch file that I use to transcode bet...   Apr 25 2006, 01:29
- - cadash   wavpack, better compression, it is very fast on my...   Apr 25 2006, 01:30
- - ChristianHJW   I love both FLAC and Wavpack. Only reason i am fav...   Apr 25 2006, 02:13
- - Musique-Rabbit   .WV in -h mode.   Apr 25 2006, 02:22
- - Canar   Wavpack, with the -x6 command-line, because I like...   Apr 25 2006, 03:02
- - Cartman_Sr   Not that my opinion counts or anything, but I use ...   Apr 25 2006, 06:49
- - guruboolez   I'm using matroska for most of my videos needs...   Apr 25 2006, 16:51
- - My name is Mud   I thought that Matroska was better suited to A/V n...   Apr 25 2006, 18:48
- - flcpge   FLAC because I'm used to it.   Apr 25 2006, 19:29
- - lex_nasa   Wavpack - better compression and hybrid mode   Apr 27 2006, 12:02
- - Julien   I mostly use Wavpack, not so much for music archiv...   Apr 27 2006, 13:33
- - DARcode   WavPack for speed, compression and hybrid mode.   Apr 27 2006, 19:12
- - Xenion   Wavpack because of its perfect cue-sheet support a...   Apr 28 2006, 01:54
- - miscellanea   past : FLAC for fast decoding. now : WavPack for b...   Apr 28 2006, 02:37
- - mariuszn3   FLAC.. just because I'm keeping all albums in ...   Apr 28 2006, 12:38
- - man   WavPack. Best efficiency, ie. decoding speed vs si...   Apr 28 2006, 13:04
|- - Dhry   As usual, I tried them all. Optim, APE, FLAC, WV e...   Apr 28 2006, 15:37
- - Gregorian   Newbie here & a virgin post! Wavpack rip ...   Apr 28 2006, 19:59
- - xequence   FLAC. I just havnt given any thought to it... And ...   Apr 28 2006, 21:11
- - moi   Using Wavpack. One thing surprised me yesterday th...   Apr 30 2006, 18:00
- - krmathis   moi. A lossless encoder only compress the PCM data...   Apr 30 2006, 18:13
|- - moi   QUOTE (krmathis @ Apr 30 2006, 09:13 AM) ...   Apr 30 2006, 19:29
||- - kanak   QUOTE (moi @ May 1 2006, 12:29 AM) QUOTE ...   Apr 30 2006, 19:45
|- - rjamorim   QUOTE (krmathis @ Apr 30 2006, 02:13 PM) ...   Apr 30 2006, 20:09
|- - krmathis   QUOTE (rjamorim @ Apr 30 2006, 09:09 PM) ...   Apr 30 2006, 20:25
|- - rjamorim   QUOTE (krmathis @ Apr 30 2006, 04:25 PM) ...   Apr 30 2006, 21:23
- - HotshotGG   Both: FLAC for compatability these days though and...   May 1 2006, 23:38
- - geopoul   Wavpack for me ... ...although I like FLAC too. I ...   May 2 2006, 01:52
- - birdie   WMA lossless with no particular reason. Anyway it...   May 2 2006, 04:25
- - Digisurfer   I'm about to change over from Monkey's Aud...   May 2 2006, 07:48
- - PatchWorKs   I use FLAC (for lossless and Vorbis for lossy) ...   May 2 2006, 09:12
2 Pages V   1 2 >
Closed TopicStart new topic
RSS Lo-Fi Version Time is now: 3rd March 2015 - 04:26
