foo_cwb_hooks, No longer compatible/developed.
cwbowron
post Apr 13 2006, 19:04
foo_cwb_hooks adds various functions and variables to global title formatting. It also adds a timestamp action to masstagger scripts, and the ability to run a script on files added to the media library (New File Tagger).
More information on my components page: http://www.bazquux.com/wiki/Foobar2000:Hooks
This post has been edited by cwbowron: May 9 2008, 01:21
There used to be a link to my website here.
Chronial
post Sep 3 2006, 16:10
About the %_replaygain_mode% request:
This can be done rather easily - just check on every playback start (this is the only time the mode can realy change). So you'll have a %_used_replaygain_mode%. The only problem left it that you'd have to refresh all title formatting as this affects all tracks.
If you do so, this would require a config dialog to switch it off.
But even without refreshing it would be useful - as it could be used in track info pannel, prettypop and similar displays.
- cwbowron   foo_cwb_hooks   Apr 13 2006, 19:04
- - Silversight   The download works, but the archive is corrupted.   Apr 13 2006, 19:25
- - foosion   Is there a special reason why this function is not...   Apr 13 2006, 19:26
- - cwbowron   Archive has been fixed. I had forgotten to switch...   Apr 13 2006, 19:32
- - mazy   cwbowron, could you, please add other functions to...   Apr 25 2006, 21:49
- - year98   I would like to request -current playback order   Aug 8 2006, 12:51
- - cwbowron   I added a couple more things today to foo_cwb_hook...   Aug 11 2006, 20:23
|- - Squeller   QUOTE (cwbowron @ Aug 11 2006, 11:23) * a...   Aug 12 2006, 13:06
- - mazy   thank you for this update, cwbowron. what are you ...   Aug 12 2006, 01:44
- - mazy   Squeller, i'm all for new functions in tagz fo...   Aug 12 2006, 16:52
|- - saivert   You could make a component that enables the use of...   Aug 13 2006, 22:35
- - vlada   I'd like to vote for queue index. Please see a...   Aug 15 2006, 00:15
- - cwbowron   After looking into some of the SDK documentation, ...   Aug 15 2006, 18:21
- - vlada   That's sad, that it is not possible to automat...   Aug 16 2006, 12:19
- - Chronial   I don't know if this is possible, but: just re...   Aug 17 2006, 16:17
|- - cwbowron   QUOTE (Chronial @ Aug 17 2006, 11:17) I d...   Aug 17 2006, 16:20
- - cwbowron   I just put up 1.0.3 on my web site, which adds %qu...   Aug 17 2006, 18:07
|- - roentgen   QUOTE (cwbowron @ Aug 17 2006, 20:07) I j...   Aug 17 2006, 19:16
|- - cwbowron   QUOTE (roentgen @ Aug 17 2006, 14:16) QUO...   Aug 17 2006, 19:32
- - Chronial   Great work there I have some more suggestions co...   Aug 17 2006, 19:21
- - q-stankovic   Great thing and thanks, Chris! I tested %que...   Aug 17 2006, 20:56
- - mazy   just wanted to thank you, cwbowron ... this queue ...   Aug 17 2006, 21:58
- - Chronial   I added some stuff and sent it to cwbowron - hope ...   Aug 17 2006, 23:15
|- - bfly   QUOTE (Chronial @ Aug 18 2006, 00:15) I a...   Aug 18 2006, 21:46
|- - cwbowron   QUOTE (bfly @ Aug 18 2006, 16:46) I don...   Aug 18 2006, 21:50
- - vlada   Thanks a lot cwbowron, it works great. The queue i...   Aug 18 2006, 00:05
- - q-stankovic   QUOTE (vlada @ Aug 18 2006, 00:05) But I ...   Aug 18 2006, 13:29
- - cwbowron   I incorporated the changes sent to my by Chronial ...   Aug 18 2006, 13:58
- - bfly   Thanks Christopher, that worked. Great plugin, tha...   Aug 18 2006, 22:16
- - year98   Can playback order variable be possible? I think t...   Aug 19 2006, 10:29
- - vlada   QUOTE (q-stankovic @ Aug 18 2006, 14...   Aug 19 2006, 10:31
|- - cwbowron   QUOTE (vlada @ Aug 19 2006, 05:31) Someti...   Aug 19 2006, 15:17
|- - vlada   QUOTE (cwbowron @ Aug 19 2006, 16:17) Dis...   Aug 19 2006, 15:53
- - thuan   QUOTE Btw. Is it possible to delete a file from a ...   Aug 19 2006, 13:00
- - q-stankovic   Some ideas for new variables and functions: 1. %c...   Aug 20 2006, 14:27
- - Chronial   %cwb_replaygain_mode% is not a good idea - if you ...   Aug 20 2006, 15:52
- - thuan   %cwb_replaygain_mode% is for displaying what mode ...   Aug 21 2006, 01:10
|- - cwbowron   QUOTE (thuan @ Aug 20 2006, 20:10) %cwb_r...   Aug 21 2006, 01:52
|- - foosion   QUOTE (cwbowron @ Aug 21 2006, 02:52) I d...   Aug 21 2006, 09:05
- - thuan   If it's so then maybe it should be call ...   Aug 21 2006, 04:19
- - Squeller   You have introduced two variables for displaying p...   Aug 21 2006, 07:54
- - q-stankovic   QUOTE (Chronial @ Aug 17 2006, 19:21) I h...   Aug 21 2006, 17:35
- - Chronial   unfortunately there is no way to access the name o...   Aug 21 2006, 19:05
|- - Squeller   QUOTE (Chronial @ Aug 21 2006, 10:05) So ...   Aug 22 2006, 17:00
- - rendom   Any ways to get info from specific file from playl...   Aug 21 2006, 19:33
- - cwbowron   Release 1.0.5 * $cwb_datediff(d1,d2) - numb...   Aug 22 2006, 16:37
- - Chronial   %cwb_queue_end_playlist% returns the playlist the ...   Aug 22 2006, 17:27
- - q-stankovic   QUOTE (Chronial @ Aug 22 2006, 17:27) %cw...   Aug 22 2006, 18:15
- - Chronial   CODE$if(%cwb_queueindex%,'['...   Aug 22 2006, 19:39
- - Russell777   Is it possible to get system time even when no tra...   Aug 22 2006, 21:30
|- - cwbowron   QUOTE (Russell777 @ Aug 22 2006, 16:30) I...   Aug 22 2006, 21:39
- - Squeller   So you made it possible for us to access the activ...   Aug 23 2006, 20:36
- - cwbowron   Release 1.0.6 * fixed incorrect way of gettin...   Aug 23 2006, 21:01
- - Russell777   Thank you for this component and for updating it...   Aug 23 2006, 22:03
|- - ktr   QUOTE (Russell777 @ Aug 23 2006, 15:03) T...   Sep 1 2006, 21:24
- - lhaymehr   Could you add system colors to this plugin?   Aug 24 2006, 01:27
|- - Stuart60611   I think it would awesome if you could add hotness ...   Aug 24 2006, 02:19
|- - cwbowron   QUOTE (Stuart60611 @ Aug 23 2006, 21:19) ...   Aug 24 2006, 03:23
|- - Stuart60611   QUOTE (cwbowron @ Aug 23 2006, 21:23) QUO...   Aug 24 2006, 04:16
|- - cwbowron   QUOTE (Stuart60611 @ Aug 23 2006, 23:16) ...   Aug 24 2006, 13:19
|- - Stuart60611   QUOTE (cwbowron @ Aug 24 2006, 07:19) QUO...   Aug 24 2006, 15:58
- - Squeller   cwbowron you are fast, thank you. I am ashamed to ...   Aug 24 2006, 04:55
- - q-stankovic   QUOTE (Stuart60611 @ Aug 23 2006, 21:19) ...   Aug 24 2006, 10:41
- - FofR   I updated the wiki page with the info on the offic...   Aug 24 2006, 15:53
- - q-stankovic   I had some ideas for special functions but don...   Aug 24 2006, 16:03
- - Chronial   No, this is not possible. It would be way to slow...   Aug 24 2006, 17:01
- - cwbowron   Release 1.0.7 * %cwb_next_title% - title of the n...   Sep 1 2006, 17:32
|- - TheTravis   QUOTE (cwbowron @ Sep 1 2006, 19:32) Rele...   Sep 1 2006, 17:35
- - mazy   nice additions, cwbowron! could you add somet...   Sep 1 2006, 19:44
|- - cwbowron   QUOTE (mazy @ Sep 1 2006, 14:44) could yo...   Sep 1 2006, 19:50
|- - mazy   QUOTE (cwbowron @ Sep 1 2006, 20:50) I...   Sep 2 2006, 10:50
- - thuan   Thanks for your handy plugin. Could you do someth...   Sep 2 2006, 01:45
- - q-stankovic   I tried following things without succes: In PT i c...   Sep 2 2006, 21:40
|- - cwbowron   QUOTE (q-stankovic @ Sep 2 2006, 16...   Sep 5 2006, 15:50
|- - Stuart60611   Request. cwb_followcursor.   Sep 11 2006, 04:54
- - Sw!ng   Handy, very handy Component ... THNX !! I...   Sep 3 2006, 10:46
- - Chronial   About the %_replaygain_mode% request: This can be ...   Sep 3 2006, 16:10
- - AsD   Thanks for the plugin. I have 3 requests: 1 cwb_st...   Sep 11 2006, 14:42
- - alphaex32   Would it be possible to add a function that can in...   Sep 11 2006, 17:54
|- - cwbowron   QUOTE (alphaex32 @ Sep 11 2006, 12:54) Wo...   Sep 11 2006, 18:10
- - alphaex32   Would it be possible if it were implemented in col...   Sep 11 2006, 18:20
- - fabiospark   Are all the variables added by cwb_hooks working i...   Sep 11 2006, 19:08
|- - cwbowron   QUOTE (fabiospark @ Sep 11 2006, 14:08) A...   Sep 11 2006, 19:28
- - cwbowron   Release 1.0.8 * %cwb_stopaftercurrent% * ...   Sep 11 2006, 21:56
- - pepoluan   Mods: With all the amazing functions this plugin p...   Sep 11 2006, 22:04
- - Hamallainen   I really like this plugin, especially the playback...   Sep 11 2006, 22:12
|- - Stuart60611   Thanks for creating this wonderful component and a...   Sep 12 2006, 17:36
|- - cwbowron   QUOTE (Stuart60611 @ Sep 12 2006, 12:36) ...   Sep 12 2006, 18:14
- - Chronial   Have you ever tried doing a hardcore full-db refre...   Sep 12 2006, 18:23
|- - foosion   QUOTE (Chronial @ Sep 12 2006, 19:23) I t...   Sep 12 2006, 19:16
- - Chronial   As far as i've seen it, updating the whole Db ...   Sep 12 2006, 21:20
|- - Peter   QUOTE (Chronial @ Sep 12 2006, 22:20) It ...   Sep 12 2006, 21:26
|- - Peter   QUOTE (Chronial @ Sep 12 2006, 22:20) As ...   Sep 12 2006, 22:04
- - Peter   I don't want to get into pointless arguments h...   Sep 12 2006, 21:43
- - Chronial   Well, every user has his own POV regarding reliabi...   Sep 12 2006, 22:04
|- - foosion   QUOTE (Chronial @ Sep 12 2006, 23:04) So ...   Sep 12 2006, 22:33
|- - cwbowron   QUOTE (foosion @ Sep 12 2006, 17:33) That...   Sep 13 2006, 13:31
- - ...Just Elliott   If there's one feature in this, I'm going ...   Sep 13 2006, 22:27
- - alphaex32   I'd just like to restate my suggestion for som...   Sep 13 2006, 23:15
- - Kirya   Please, add %cwb_next_directoryname%. It would be ...   Sep 13 2006, 23:22
5 Pages V   1 2 3 > »
Closed TopicStart new topic
RSS Lo-Fi Version Time is now: 2nd June 2015 - 08:59
