Realtek ALC850 kernel streaming?
Fryguy
post Apr 11 2006, 02:02
Has anyone gotten realtek alc850 (onboard sound on lots of athlon64 nforce3/4 boards) working with foobar? I'm using digital output to a receiver, so I dont' really have any reason to spend the money on the soundcard since it's just passing a digital stream and not really touching it, but I'd like to get kernel streaming working.
Any ideas?
david_dl
post Apr 19 2006, 05:30
Fine, it doesn't sound any different. But it DOES change the data, ever so slightly, and for PCM data, that isn't a problem. HOWEVER, AFAIK some surround encodings (ie. DTS/AC3) work by sending non PCM data through the system to the digital output, where a receiver can correctly interpret it as compressed surround sound. Because it is not PCM data, and kmixer cannot know that, the ever-so-slight modification it makes completely corrupts the data stream and prevents the whole thing working.
TrNSZ
post Apr 19 2006, 06:03
QUOTE (david_dl @ Apr 19 2006, 12:30 AM) *
You obviously did not read a single word I wrote, and if you did, you failed to comprehend the details. Either go back and actually read the thread before responding, or if you read it, read it again.
I made this case very clear already, but I should also stress that any differences in the output may or may not be the result of kmixer, and spreading blatant misinformation (that kmixer will change your output) does no one any good.
It may or may not change your output, depending on many factors, including the hardware and the drivers. Edit: I have personally witnessed DirectSound working to stream DTS to my external DAC. I've done it on many setups. I've seen it with waveout and with kernel streaming and ASIO too. The simple fact here is, that for a variety of reasons, KS is usually NOT the appropriate solution here and it's unsupported for a reason.
You could easily search and find threads from 2003 and earlier that discuss these things in depth.
At this point I give up.
I'm not going to sit around here and post the same things over and over again if no one is capable of reading or using the search function.
This post has been edited by TrNSZ: Apr 19 2006, 06:07
RSS Lo-Fi Version Time is now: 6th May 2015 - 18:58
