Yalac - Comparisons, How the evaluation release compares to other compressors
TBeck
post Apr 10 2006, 07:30
TAK Developer
Content
In this thread the testers should post comparisons of the preset modes of Yalac (Working name for "Yet another lossless audio compressor") with other lossless compressors.
The results for specific variations of individual encoder options should go into the thread " Yalac Evaluation and optimization".
Guidelines
Please post the exact version number of the compressors. Compression ratio should be specified in percent of the uncompressed file size. Speed figures should be specified as multiple of real time (duration of the test files). A specification of your test system, especially the CPU, would be helpful.
Open end: Feel free to add more results later.
What happened
Bad timing of my introduction (April 1.) forced an early publication of an evaluation release of Yalac, to prove, that it really works. This are results of 8 forum members, who where so kind to test the experimental release for me.
Many thanks!
Goals
Yalac should finally achieve compression ratios on par with Monkey's Audio High. Decoding speed should be at least two times higher than Monkey and never be significantly lower than with FLAC (possibly Yalac will later be integrated into FLAC).
My next steps
The first results i have received from the testers show me some weaknesses of the encoder. That's a good thing, because that means, that there definitely is a chance to increase the compression efficiency! Same is true for the speed; especially the decoder is not fully optimized yet. But it will take some time, before i will come up with an optimized release.
Links to 24 bit files i have used
I think, they are hard to find.
44 KHz, 24 bit
mytek_8X96_24bit_web.wav
Mytek-stereo96adc_evans.wav
Mytek-stereo96adc_ravel.wav
Source: http://www.mytekdigital.com/compare/comparison1.htm
48 KHz, 24 bit
McDougalsMen24bit_48kHz.wav
sister24bit_48kHz.wav
Source: http://ff123.net/samples.html
Or make a better Google search. foosion shows you how: http://www.hydrogenaudio.org/forums/index....ndpost&p=381702
This post has been edited by TBeck: Apr 12 2006, 20:23
audiofreak
post May 16 2006, 03:14
QUOTE (TBeck @ May 15 2006, 14:45) *
QUOTE (Firon @ May 15 2006, 19:53) *
Fast mode is quite impressive in ratio and speed, though I do wish that the high and insane modes compressed a little better, to better compete with Monkey's Audio.
Me to.
But you have to take into account, that those test files aren't fully representative. On my test corpus the difference between FAST and HIGH is significantly bigger than here and yalac is performing slightly better than Monkey HIGH. This may be the other extreme. The truth may lie in between.
Nevertheless i am working on further improvements, especially for those files, were yalac performs worse than monkey. My current evaluations seem to confirm, that an increase of about 0.50 percent for preset high is realistic. It's not easy to give such an estimate: My latest optimizations are providing up to 1.50 percent better compression than Monkey on selected files, but it's not quite clear now, what the average will be.
But one thing is clear: Those new optimizations will not be cheap. They will reduce the encoding speed of HIGH.
And it will take much time until they are fully implemented. The new optimizations show strong interactions with any existing processing unit in yalac. It might be necessary to change big parts of my current codec design to get the most out of the new optimizations.
Perhaps a High, Extra High, and Insane like Monkey's? (keep high, optimized high becomes extra high)
TBeck
post May 17 2006, 02:57
TAK Developer
QUOTE (audiofreak @ May 16 2006, 04:14) *
Yes, i allready thought about an EXTRA preset...
BTW: Would it make sense, to reintroduce a FASTEST preset? I could implement one, which would be about 50 precent faster than FAST (i am evaluating encoding speed without output, because my disk is far too slow). It might compress 1 percent worse than FAST.
Another option would be a 15 percent speed up of FAST with a compression penality of about 0.1 percent.
Possibly not too important, but i am really into speed.
Thomas
Destroid
post May 17 2006, 20:21
I agree the speed aspect is a Yalac specialty.
Since I continue using an older lossless encoder for archival uniformity, I'm interested in compression efficiency -- there's much more to do than wait around encoding! Obviously, when using a "symmetrical" codec such as the one I use, I lose in the long-run with decode speeds that are actually slower than the encoding speed. The reason is more data is being written to disk during a decoding than encoding.
So, in regards to speed:
- Machines like mine using ATA100 I usually max-out at about 82x decoding speed for 16bit 44KHz stereo
- The fastest encoding speed I clocked was about 98x with my outdated codec
- Yalac decodes from all modes at about the maximum ATA performance
- newer SATA drives have no distinguishable advantage over ATA, unless it's the 500+GB 10,000 RPM variety
- any speed enhancements for YALAC Fast(est) encoding should take into account the limitations of average HDD performance, otherwise the performance boost will not be noticed
Given that, I'd love to see the speed increase or a new fastest preset.
For your information, Thomas, the archival encoder I use achieved a speed of 97.83x with a ratio 47.94%, while Yalac 0.06 Fast clocked at 68.11x with an impressive 46.14% ratio with "free" super-fast decompression speed. Good work!
- TBeck   Yalac - Comparisons   Apr 10 2006, 07:30
- - Synthetic Soul   My results can be found at the following address: ...   Apr 11 2006, 18:05
|- - onthejazz   QUOTE (Synthetic Soul @ Apr 11 2006, 12:0...   Apr 12 2006, 04:52
- - Destroid   I had issues with the inability for Yalac to accep...   Apr 12 2006, 03:22
- - Synthetic Soul   Comparison now includes Yalac Fastest.Summary of e...   Apr 12 2006, 22:09
- - Destroid   These are benchmarks with Yalac 0.03 with two albu...   Apr 13 2006, 21:54
|- - TBeck   QUOTE (Destroid @ Apr 13 2006, 10:54 PM) ...   Apr 13 2006, 22:40
- - Destroid   Test #3 - LP recorded to cassette, includes vinyl ...   Apr 18 2006, 01:13
|- - Shade[ST]   Destroid's results prove that YALAC is the bes...   Apr 18 2006, 01:21
|- - Destroid   QUOTE ' date='Apr 18 2006, 12:21 AM' p...   Apr 18 2006, 02:56
- - Synthetic Soul   Garf posted some suggestions for "presets...   Apr 18 2006, 09:47
|- - Destroid   QUOTE (Synthetic Soul @ Apr 18 2006, 08:4...   Apr 18 2006, 11:09
|- - TBeck   QUOTE (Destroid @ Apr 18 2006, 12:09 PM) ...   Apr 18 2006, 11:23
|- - Destroid   QUOTE (TBeck @ Apr 18 2006, 10:23 AM) I a...   Apr 18 2006, 11:49
|- - pest   QUOTE My channel decorrelation obviously needs som...   Apr 18 2006, 12:23
- - vinnie97   I'm still waiting for something to beat LA...   Apr 18 2006, 10:13
- - Firon   I'm really impressed, the fast compression rat...   Apr 18 2006, 11:40
|- - TBeck   QUOTE (Firon @ Apr 18 2006, 12:40 PM) I...   Apr 18 2006, 11:47
- - JB_   Hello, its my 1st post here. Have you guys know th...   Apr 18 2006, 12:01
|- - [proxima]   QUOTE (JB_ @ Apr 18 2006, 01:01 PM) Have ...   Apr 18 2006, 12:18
|- - JB_   QUOTE TTA was considered in previous tests by guru...   Apr 18 2006, 16:31
- - Synthetic Soul   Following my comparison using 16bit 44.1KHz stereo...   Apr 18 2006, 12:11
|- - TBeck   QUOTE (Synthetic Soul @ Apr 18 2006, 01:1...   Apr 18 2006, 14:20
- - Synthetic Soul   Not especially. Is there a compelling reason to i...   Apr 18 2006, 16:42
- - Mo0zOoH   TBeck, Your compressor is actually a BOMB. Right ...   Apr 18 2006, 18:20
- - Synthetic Soul   Out of interest on my part TTA is now included whe...   Apr 18 2006, 18:49
|- - Shade[ST]   QUOTE (Synthetic Soul @ Apr 18 2006, 01:4...   Apr 18 2006, 19:13
- - Synthetic Soul   Yes, that would be possible. Another member previ...   Apr 18 2006, 22:06
|- - Shade[ST]   That second method is evaluating the compresser...   Apr 18 2006, 22:30
- - audiofreak   QUOTE ' date='Apr 18 2006, 02:13 PM' p...   Apr 19 2006, 00:43
|- - Shade[ST]   Good idea. Now make it   Apr 19 2006, 01:19
|- - audiofreak   QUOTE ' date='Apr 18 2006, 08:19 PM' p...   Apr 19 2006, 01:42
- - Synthetic Soul   Well, OK, if anyone can suggest an algorithm that ...   Apr 19 2006, 07:44
- - TBeck   Current Progress you may call it Tom's diary....   Apr 23 2006, 10:50
- - audiofreak   Moderation: Removed unnecessary quote This may so...   Apr 23 2006, 15:19
|- - TBeck   QUOTE (audiofreak @ Apr 23 2006, 04:19 PM...   Apr 24 2006, 02:43
- - Destroid   At last, the first set of monural instrument track...   Apr 24 2006, 18:11
- - TBeck   Current Progress (V0.05) In my last post i asked ...   Apr 26 2006, 04:31
- - Synthetic Soul   Cool, thanks for the update Thomas. I thought I s...   Apr 26 2006, 10:01
- - TBeck   V0.05 is done Changes: - Preset FASTEST is gone....   Apr 29 2006, 11:18
|- - boombaard   QUOTE (TBeck @ Apr 29 2006, 12:18 PM) V0....   Apr 29 2006, 22:58
- - guruboolez   I have a question, related to the fact that I have...   Apr 29 2006, 11:39
|- - Destroid   QUOTE (guruboolez @ Apr 29 2006, 10:39 AM...   Apr 29 2006, 22:29
- - Supacon   It's good to see that you're progressing r...   Apr 29 2006, 18:41
|- - TBeck   QUOTE (Supacon @ Apr 29 2006, 07:41 PM) B...   May 2 2006, 13:31
|- - Shade[ST]   Hello Thomas, Do you think you could slightly int...   May 2 2006, 15:07
|- - TBeck   QUOTE ' date='May 2 2006, 04:07 PM' po...   May 2 2006, 15:38
|- - Shade[ST]   That should be fine.. if no filename is listed, ma...   May 2 2006, 16:40
|- - TBeck   QUOTE ' date='May 2 2006, 05:40 PM' po...   May 2 2006, 16:58
|- - Shade[ST]   Maybe add a target directory option, so that the d...   May 2 2006, 18:23
- - Destroid   The speed up in high mode is there. CODE Occult - ...   Apr 30 2006, 03:07
|- - TBeck   QUOTE (Destroid @ Apr 30 2006, 04:07 AM) ...   May 2 2006, 13:07
- - Destroid   My $0.02 USD, I would like to avoid the wildc...   May 2 2006, 22:28
|- - Shade[ST]   In that case, (infile | --all) (compression option...   May 2 2006, 22:54
|- - TBeck   QUOTE (Destroid @ May 2 2006, 11:28 PM) M...   May 2 2006, 22:55
|- - Destroid   QUOTE Would it be ok for now, if the file extensio...   May 2 2006, 23:57
||- - Synthetic Soul   QUOTE (Destroid @ May 2 2006, 10:57 PM) T...   May 3 2006, 09:55
|- - Synthetic Soul   QUOTE (TBeck @ May 2 2006, 09:55 PM) Quic...   May 3 2006, 09:44
|- - TBeck   QUOTE (Synthetic Soul @ May 3 2006, 10:44...   May 3 2006, 14:25
- - TBeck   Current Progress (V0.06) Sorry if i should talk t...   May 5 2006, 12:28
|- - Shade[ST]   Take your time if you should wish to, but I don...   May 5 2006, 13:22
|- - TBeck   QUOTE ' date='May 5 2006, 02:22 PM' po...   May 5 2006, 13:56
- - Synthetic Soul   I'm not sure what the priority is for testing ...   May 5 2006, 21:10
|- - TBeck   QUOTE (Synthetic Soul @ May 5 2006, 10:10...   May 5 2006, 22:18
|- - Synthetic Soul   QUOTE (TBeck @ May 5 2006, 10:18 PM) Henc...   May 6 2006, 10:08
||- - Shade[ST]   @Synthetic soul : If you make your batch files ava...   May 6 2006, 16:37
|- - TBeck   QUOTE (TBeck @ May 5 2006, 23:18) Most wo...   May 10 2006, 13:21
- - TBeck   V0.06 is done Changes: Compression efficiency an...   May 12 2006, 15:37
|- - Shade[ST]   My exams are now done, I'd be glad to test the...   May 12 2006, 16:31
- - Shade[ST]   On SSE optimization : CODE=== New test ===========...   May 13 2006, 00:49
|- - TBeck   QUOTE ' date='May 13 2006, 01:49' post...   May 13 2006, 01:33
|- - Shade[ST]   It seems my disk caching is quite unstable, then. ...   May 13 2006, 01:48
|- - TBeck   QUOTE ' date='May 13 2006, 02:48' post...   May 13 2006, 01:54
|- - Shade[ST]   These results are actually quite surprising, as th...   May 13 2006, 02:06
|- - TBeck   QUOTE ' date='May 13 2006, 03:06' post...   May 13 2006, 02:29
|- - Shade[ST]   Do the rounding errors mean that the encoding may ...   May 13 2006, 02:38
||- - TBeck   QUOTE ' date='May 13 2006, 03:38' post...   May 13 2006, 02:46
|- - Hyp-X   QUOTE (TBeck @ May 13 2006, 02:29) I am q...   May 15 2006, 16:21
|- - TBeck   QUOTE (Hyp-X @ May 15 2006, 17:21) F...   May 15 2006, 16:33
- - Destroid   A quick comparison between the last two versions u...   May 13 2006, 02:51
|- - TBeck   QUOTE (Destroid @ May 13 2006, 03:51) A q...   May 13 2006, 03:03
- - Destroid   Oops, keep forgetting the sustem specs. I fixed th...   May 13 2006, 03:25
|- - TBeck   QUOTE (Destroid @ May 13 2006, 04:25) Oop...   May 13 2006, 03:33
- - Synthetic Soul   QUOTE (TBeck @ May 13 2006, 01:33) BTW: A...   May 13 2006, 08:03
|- - TBeck   QUOTE (Synthetic Soul @ May 13 2006, 09:0...   May 13 2006, 12:52
- - Synthetic Soul   I hacked the original comparison table to include ...   May 15 2006, 11:09
|- - TBeck   QUOTE (Synthetic Soul @ May 15 2006, 12:0...   May 15 2006, 12:52
|- - TBeck   QUOTE (Synthetic Soul @ May 15 2006, 12:0...   May 15 2006, 13:41
|- - Synthetic Soul   QUOTE (TBeck @ May 15 2006, 13:41) Would ...   May 15 2006, 15:26
|- - TBeck   QUOTE (Synthetic Soul @ May 15 2006, 16:2...   May 15 2006, 15:57
- - Synthetic Soul   Yes, Fast is truely impressive. In the encoder se...   May 15 2006, 16:09
|- - TBeck   QUOTE (Synthetic Soul @ May 15 2006, 17:0...   May 15 2006, 16:17
|- - Synthetic Soul   QUOTE (Synthetic Soul @ May 15 2006, 16:0...   May 15 2006, 18:35
- - Firon   Fast mode is quite impressive in ratio and speed, ...   May 15 2006, 18:53
|- - TBeck   QUOTE (Firon @ May 15 2006, 19:53) Fast m...   May 15 2006, 19:45
- - Synthetic Soul   I have just checked the MD5 hash of all decoded fi...   May 15 2006, 22:20
- - audiofreak   QUOTE (TBeck @ May 15 2006, 14:45) QUOTE ...   May 16 2006, 03:14
- - TBeck   QUOTE (audiofreak @ May 16 2006, 04:14) P...   May 17 2006, 02:57
- - Shade[ST]   QUOTE (TBeck @ May 16 2006, 21:57) BTW: W...   May 17 2006, 05:58
- - Destroid   I agree the speed aspect is a Yalac specialty. Si...   May 17 2006, 20:21
4 Pages V   1 2 3 > »
RSS Lo-Fi Version Time is now: 5th May 2015 - 12:55
