Yalac - Comparisons, How the evaluation release compares to other compressors
TBeck
post Apr 10 2006, 07:30
TAK Developer
Content
In this thread the testers should post comparisons of the preset modes of Yalac (Working name for "Yet another lossless audio compressor") with other lossless compressors.
The results for specific variations of individual encoder options should go into the thread " Yalac Evaluation and optimization".
Guidelines
Please post the exact version number of the compressors. Compression ratio should be specified in percent of the uncompressed file size. Speed figures should be specified as multiple of real time (duration of the test files). A specification of your test system, especially the CPU, would be helpful.
Open end: Feel free to add more results later.
What happened
Bad timing of my introduction (April 1.) forced an early publication of an evaluation release of Yalac, to prove, that it really works. This are results of 8 forum members, who where so kind to test the experimental release for me.
Many thanks!
Goals
Yalac should finally achieve compression ratios on par with Monkey's Audio High. Decoding speed should be at least two times higher than Monkey and never be significantly lower than with FLAC (possibly Yalac will later be integrated into FLAC).
My next steps
The first results i have received from the testers show me some weaknesses of the encoder. That's a good thing, because that means, that there definitely is a chance to increase the compression efficiency! Same is true for the speed; especially the decoder is not fully optimized yet. But it will take some time, before i will come up with an optimized release.
Links to 24 bit files i have used
I think, they are hard to find.
44 KHz, 24 bit
mytek_8X96_24bit_web.wav
Mytek-stereo96adc_evans.wav
Mytek-stereo96adc_ravel.wav
Source: http://www.mytekdigital.com/compare/comparison1.htm
48 KHz, 24 bit
McDougalsMen24bit_48kHz.wav
sister24bit_48kHz.wav
Source: http://ff123.net/samples.html
Or make a better Google search. foosion shows you how: http://www.hydrogenaudio.org/forums/index....ndpost&p=381702
This post has been edited by TBeck: Apr 12 2006, 20:23
Synthetic Soul
post Apr 18 2006, 18:49
Out of interest on my part TTA is now included when specifying All=1
http://synthetic-soul.co.uk/comparison/los...index.asp?All=1
I'm on a horse.
- TBeck   Yalac - Comparisons   Apr 10 2006, 07:30
- - Synthetic Soul   My results can be found at the following address: ...   Apr 11 2006, 18:05
|- - onthejazz   QUOTE (Synthetic Soul @ Apr 11 2006, 12:0...   Apr 12 2006, 04:52
- - Destroid   I had issues with the inability for Yalac to accep...   Apr 12 2006, 03:22
- - Synthetic Soul   Comparison now includes Yalac Fastest.Summary of e...   Apr 12 2006, 22:09
- - Destroid   These are benchmarks with Yalac 0.03 with two albu...   Apr 13 2006, 21:54
|- - TBeck   QUOTE (Destroid @ Apr 13 2006, 10:54 PM) ...   Apr 13 2006, 22:40
- - Destroid   Test #3 - LP recorded to cassette, includes vinyl ...   Apr 18 2006, 01:13
|- - Shade[ST]   Destroid's results prove that YALAC is the bes...   Apr 18 2006, 01:21
|- - Destroid   QUOTE ' date='Apr 18 2006, 12:21 AM' p...   Apr 18 2006, 02:56
- - Synthetic Soul   Garf posted some suggestions for "presets...   Apr 18 2006, 09:47
|- - Destroid   QUOTE (Synthetic Soul @ Apr 18 2006, 08:4...   Apr 18 2006, 11:09
|- - TBeck   QUOTE (Destroid @ Apr 18 2006, 12:09 PM) ...   Apr 18 2006, 11:23
|- - Destroid   QUOTE (TBeck @ Apr 18 2006, 10:23 AM) I a...   Apr 18 2006, 11:49
|- - pest   QUOTE My channel decorrelation obviously needs som...   Apr 18 2006, 12:23
- - vinnie97   I'm still waiting for something to beat LA...   Apr 18 2006, 10:13
- - Firon   I'm really impressed, the fast compression rat...   Apr 18 2006, 11:40
|- - TBeck   QUOTE (Firon @ Apr 18 2006, 12:40 PM) I...   Apr 18 2006, 11:47
- - JB_   Hello, its my 1st post here. Have you guys know th...   Apr 18 2006, 12:01
|- - [proxima]   QUOTE (JB_ @ Apr 18 2006, 01:01 PM) Have ...   Apr 18 2006, 12:18
|- - JB_   QUOTE TTA was considered in previous tests by guru...   Apr 18 2006, 16:31
- - Synthetic Soul   Following my comparison using 16bit 44.1KHz stereo...   Apr 18 2006, 12:11
|- - TBeck   QUOTE (Synthetic Soul @ Apr 18 2006, 01:1...   Apr 18 2006, 14:20
- - Synthetic Soul   Not especially. Is there a compelling reason to i...   Apr 18 2006, 16:42
- - Mo0zOoH   TBeck, Your compressor is actually a BOMB. Right ...   Apr 18 2006, 18:20
- - Synthetic Soul   Out of interest on my part TTA is now included whe...   Apr 18 2006, 18:49
|- - Shade[ST]   QUOTE (Synthetic Soul @ Apr 18 2006, 01:4...   Apr 18 2006, 19:13
- - Synthetic Soul   Yes, that would be possible. Another member previ...   Apr 18 2006, 22:06
|- - Shade[ST]   That second method is evaluating the compresser...   Apr 18 2006, 22:30
- - audiofreak   QUOTE ' date='Apr 18 2006, 02:13 PM' p...   Apr 19 2006, 00:43
|- - Shade[ST]   Good idea. Now make it   Apr 19 2006, 01:19
|- - audiofreak   QUOTE ' date='Apr 18 2006, 08:19 PM' p...   Apr 19 2006, 01:42
- - Synthetic Soul   Well, OK, if anyone can suggest an algorithm that ...   Apr 19 2006, 07:44
- - TBeck   Current Progress you may call it Tom's diary....   Apr 23 2006, 10:50
- - audiofreak   Moderation: Removed unnecessary quote This may so...   Apr 23 2006, 15:19
|- - TBeck   QUOTE (audiofreak @ Apr 23 2006, 04:19 PM...   Apr 24 2006, 02:43
- - Destroid   At last, the first set of monural instrument track...   Apr 24 2006, 18:11
- - TBeck   Current Progress (V0.05) In my last post i asked ...   Apr 26 2006, 04:31
- - Synthetic Soul   Cool, thanks for the update Thomas. I thought I s...   Apr 26 2006, 10:01
- - TBeck   V0.05 is done Changes: - Preset FASTEST is gone....   Apr 29 2006, 11:18
|- - boombaard   QUOTE (TBeck @ Apr 29 2006, 12:18 PM) V0....   Apr 29 2006, 22:58
- - guruboolez   I have a question, related to the fact that I have...   Apr 29 2006, 11:39
|- - Destroid   QUOTE (guruboolez @ Apr 29 2006, 10:39 AM...   Apr 29 2006, 22:29
- - Supacon   It's good to see that you're progressing r...   Apr 29 2006, 18:41
|- - TBeck   QUOTE (Supacon @ Apr 29 2006, 07:41 PM) B...   May 2 2006, 13:31
|- - Shade[ST]   Hello Thomas, Do you think you could slightly int...   May 2 2006, 15:07
|- - TBeck   QUOTE ' date='May 2 2006, 04:07 PM' po...   May 2 2006, 15:38
|- - Shade[ST]   That should be fine.. if no filename is listed, ma...   May 2 2006, 16:40
|- - TBeck   QUOTE ' date='May 2 2006, 05:40 PM' po...   May 2 2006, 16:58
|- - Shade[ST]   Maybe add a target directory option, so that the d...   May 2 2006, 18:23
- - Destroid   The speed up in high mode is there. CODE Occult - ...   Apr 30 2006, 03:07
|- - TBeck   QUOTE (Destroid @ Apr 30 2006, 04:07 AM) ...   May 2 2006, 13:07
- - Destroid   My $0.02 USD, I would like to avoid the wildc...   May 2 2006, 22:28
|- - Shade[ST]   In that case, (infile | --all) (compression option...   May 2 2006, 22:54
|- - TBeck   QUOTE (Destroid @ May 2 2006, 11:28 PM) M...   May 2 2006, 22:55
|- - Destroid   QUOTE Would it be ok for now, if the file extensio...   May 2 2006, 23:57
||- - Synthetic Soul   QUOTE (Destroid @ May 2 2006, 10:57 PM) T...   May 3 2006, 09:55
|- - Synthetic Soul   QUOTE (TBeck @ May 2 2006, 09:55 PM) Quic...   May 3 2006, 09:44
|- - TBeck   QUOTE (Synthetic Soul @ May 3 2006, 10:44...   May 3 2006, 14:25
- - TBeck   Current Progress (V0.06) Sorry if i should talk t...   May 5 2006, 12:28
|- - Shade[ST]   Take your time if you should wish to, but I don...   May 5 2006, 13:22
|- - TBeck   QUOTE ' date='May 5 2006, 02:22 PM' po...   May 5 2006, 13:56
- - Synthetic Soul   I'm not sure what the priority is for testing ...   May 5 2006, 21:10
|- - TBeck   QUOTE (Synthetic Soul @ May 5 2006, 10:10...   May 5 2006, 22:18
|- - Synthetic Soul   QUOTE (TBeck @ May 5 2006, 10:18 PM) Henc...   May 6 2006, 10:08
||- - Shade[ST]   @Synthetic soul : If you make your batch files ava...   May 6 2006, 16:37
|- - TBeck   QUOTE (TBeck @ May 5 2006, 23:18) Most wo...   May 10 2006, 13:21
- - TBeck   V0.06 is done Changes: Compression efficiency an...   May 12 2006, 15:37
|- - Shade[ST]   My exams are now done, I'd be glad to test the...   May 12 2006, 16:31
- - Shade[ST]   On SSE optimization : CODE=== New test ===========...   May 13 2006, 00:49
|- - TBeck   QUOTE ' date='May 13 2006, 01:49' post...   May 13 2006, 01:33
|- - Shade[ST]   It seems my disk caching is quite unstable, then. ...   May 13 2006, 01:48
|- - TBeck   QUOTE ' date='May 13 2006, 02:48' post...   May 13 2006, 01:54
|- - Shade[ST]   These results are actually quite surprising, as th...   May 13 2006, 02:06
|- - TBeck   QUOTE ' date='May 13 2006, 03:06' post...   May 13 2006, 02:29
|- - Shade[ST]   Do the rounding errors mean that the encoding may ...   May 13 2006, 02:38
||- - TBeck   QUOTE ' date='May 13 2006, 03:38' post...   May 13 2006, 02:46
|- - Hyp-X   QUOTE (TBeck @ May 13 2006, 02:29) I am q...   May 15 2006, 16:21
|- - TBeck   QUOTE (Hyp-X @ May 15 2006, 17:21) F...   May 15 2006, 16:33
- - Destroid   A quick comparison between the last two versions u...   May 13 2006, 02:51
|- - TBeck   QUOTE (Destroid @ May 13 2006, 03:51) A q...   May 13 2006, 03:03
- - Destroid   Oops, keep forgetting the sustem specs. I fixed th...   May 13 2006, 03:25
|- - TBeck   QUOTE (Destroid @ May 13 2006, 04:25) Oop...   May 13 2006, 03:33
- - Synthetic Soul   QUOTE (TBeck @ May 13 2006, 01:33) BTW: A...   May 13 2006, 08:03
|- - TBeck   QUOTE (Synthetic Soul @ May 13 2006, 09:0...   May 13 2006, 12:52
- - Synthetic Soul   I hacked the original comparison table to include ...   May 15 2006, 11:09
|- - TBeck   QUOTE (Synthetic Soul @ May 15 2006, 12:0...   May 15 2006, 12:52
|- - TBeck   QUOTE (Synthetic Soul @ May 15 2006, 12:0...   May 15 2006, 13:41
|- - Synthetic Soul   QUOTE (TBeck @ May 15 2006, 13:41) Would ...   May 15 2006, 15:26
|- - TBeck   QUOTE (Synthetic Soul @ May 15 2006, 16:2...   May 15 2006, 15:57
- - Synthetic Soul   Yes, Fast is truely impressive. In the encoder se...   May 15 2006, 16:09
|- - TBeck   QUOTE (Synthetic Soul @ May 15 2006, 17:0...   May 15 2006, 16:17
|- - Synthetic Soul   QUOTE (Synthetic Soul @ May 15 2006, 16:0...   May 15 2006, 18:35
- - Firon   Fast mode is quite impressive in ratio and speed, ...   May 15 2006, 18:53
|- - TBeck   QUOTE (Firon @ May 15 2006, 19:53) Fast m...   May 15 2006, 19:45
- - Synthetic Soul   I have just checked the MD5 hash of all decoded fi...   May 15 2006, 22:20
- - audiofreak   QUOTE (TBeck @ May 15 2006, 14:45) QUOTE ...   May 16 2006, 03:14
- - TBeck   QUOTE (audiofreak @ May 16 2006, 04:14) P...   May 17 2006, 02:57
- - Shade[ST]   QUOTE (TBeck @ May 16 2006, 21:57) BTW: W...   May 17 2006, 05:58
- - Destroid   I agree the speed aspect is a Yalac specialty. Si...   May 17 2006, 20:21
4 Pages V   1 2 3 > »
RSS Lo-Fi Version Time is now: 29th March 2015 - 05:34
