7 Pages V   1 2 3 > »
Foo_osd, keyboard shortcut
manudevil
post Mar 28 2006, 17:42
Hello !
I'm using foobar since 0.7 and I like it ! Using Foo_osd too, but I miss some function... With the last port for Foobar 0.9, I don't know how to display OSD with a keyboard shortcut. Is there any way ?
Thanks !
Sites dynamiques : http://www.manudevil.com
lav-chan
post Mar 28 2006, 17:46
No, i noticed that too, i think he got rid of that feature. :/
As an alternative (sort of, depending on how you use it) you can set the OSD to display when you pause the track. That's what i did. Better than nothing.
manudevil
post Mar 28 2006, 17:51
I did it. But I miss this feature.
I hope its great developer will add this again !
djet
post Mar 28 2006, 20:43
I miss it too. You can use built-in fb2k tray notification instead or PrettyPopup component.
manudevil
post Mar 28 2006, 20:48
Yeah, that's right. But I prefer OSD. And I dismissed the tray icon, because of OSD use... so, if there is any maioration possibility of this great plugin it would be nice.
troskal
post Mar 28 2006, 21:04
http://kode54.foobar2000.org
manudevil
post Mar 28 2006, 21:10
Euh... what's up ?
Mafioso
post Mar 30 2006, 14:37
I also would like to use shortcuts for the foo_osd component! In my previous (8.3)setup it was the only way I used it.
btw, can someone tell me the difference between the 'normal' and the gdi+ version?
Please don't mind my bad English.
Foobar2000 PWNGz.. a lot.. hope it stays that way
hypersonic
post Mar 30 2006, 14:58
QUOTE (Mafioso @ Mar 30 2006, 11:37 PM)
it uses microsofts gdi+ graphics library to draw to screen.. no idea what that means for the end user..
manudevil
post Mar 30 2006, 17:41
I've seen no difference, except the GDI+ version need much more resource. Visually, it is quite the same.
patsy
post Mar 30 2006, 20:57
hello
I'm using foobar 0.8.3 and I'm looking for Foo_osd.dll but I only found the 0.9 version
manudevil
post Apr 1 2006, 09:14
Here it is : http://kode54.foobar2000.org/
[Mode prayer on]
Kode54, if you are listening to us,
please add a menu
and a keyboard shortcut possibility
to display your OSD
Thank you !
[/Mode prayer on]
This post has been edited by manudevil: Apr 1 2006, 09:15
manudevil
post Apr 1 2006, 09:18
By the way, here is my OSD code :
$if(%_ispaused%,ffffff|000000'[Pause] ')000000|00FFFF[%artist%]$char(10)
$if(%album%,00ffff|000000%album%) $if(%tracknumber%,#[%disc%/]$num(%tracknumber%,2)) $if(%album% && %tracknumber%,$char(10))
$if(%title%,000000|00FFFF%title%,%_filename%)$char(10)
$if(%_time_total%!=0,%_time_total% $progress(%_time_elapsed_seconds%, %_time_total_seconds%, 20,$char(9835),$char(8226)) $muldiv(%_time_elapsed_seconds%,100,%_length_seconds%)'%'$char(10),%_length%$char(10))
[cfa923|4b2b10Next: %_next%]
The fact is that the progressbar doesn't progress at all. Do you see the same thing ? It is like the %_time_total% couldn't be read at the true beginning of the track...
patsy
post Apr 1 2006, 12:57
QUOTE (manudevil @ Apr 1 2006, 02:14 AM)
here there is only the 0.9 version and I'm looking for the old version for foobar 0.8.3
manudevil
post Apr 6 2006, 22:02
Post #15
Ah. I have this. You can download it here : http://www.manudevil.info/www/download/foo_osd.zip
For the 0.9, nothink new about a keyboard shortcut update ?
This post has been edited by manudevil: Apr 6 2006, 22:03
patsy
post Apr 6 2006, 22:07
Post #16
manudevil
post Apr 6 2006, 22:13
Post #17
4nt1
post Apr 6 2006, 22:48
Post #18
excuse my ignorancce but what is foo_osd ?
is it like pretty pop and toaster?
update
just tested it out, i like this better then pretty popup, its very simple and displays exactly what i want.
This post has been edited by 4nt1: Apr 6 2006, 23:04
Chaser
post Apr 6 2006, 23:05
Post #19
Kind of - but much simpler. It displays a custom string on top of all windows. It stays there for a amount of time and then disappears again (no albumart or such stuff..)
manudevil
post Apr 7 2006, 13:43
Post #20
It is very simple, and so doesn't need any resource.
I miss an hotkey option...
ssamadhi97
post Apr 13 2006, 19:30
Post #21
Group: Developer (Donating)
This feature has been requested several times and the developer will implement it when he feels like it.
No pointless thread bumping please.
(bumping posts have been split)
This post has been edited by ssamadhi97: Apr 13 2006, 19:34
A riddle is a short sword attached to the next 2000 years.
fabiospark
post Jun 25 2006, 15:10
Post #22
Should I use the 'display forever' setting, is there a way to hide the OSD (maybe with an escape or a mouse movement)?
A few feature requests:
- vertical and/or horizontal scrolling (and bouncing) according to available space
- ability to show graphics if there is a particular value into a tag
- auto showing after some time the keyboard and mouse are not used (screeensaver behaviour)
- ability to set a fixed dimension (in pixels) of the background
jon.schaffer
post Jun 25 2006, 22:37
Post #23
Group: Validating
QUOTE (manudevil @ Apr 7 2006, 14:43) *
Another way to do this would be to wait a port of foo_qconfig.
It allows you to add commands in menu. When a command is in a menu, you can assign a shortcut to it. At least, that worked like this in 0.8.3... and this was pretty useful.
thuan
post Jun 26 2006, 00:41
Post #24
Beside the shortcut keys, it seems that %_next% doesn't work either or am I miss something?
Piet
post Jun 26 2006, 06:37
Post #25
QUOTE (thuan @ Jun 26 2006, 01:41) *
In "Default" playback order, it should work, but it will not work with the shuffle modes. At least it behaved like this in the 0.8 version.
7 Pages V   1 2 3 > »
RSS Lo-Fi Version Time is now: 21st April 2015 - 02:42
