Foo_osd, keyboard shortcut
manudevil
post Mar 28 2006, 17:42
Hello !
I'm using foobar since 0.7 and I like it ! Using Foo_osd too, but I miss some function... With the last port for Foobar 0.9, I don't know how to display OSD with a keyboard shortcut. Is there any way ?
Thanks !
Sites dynamiques : http://www.manudevil.com
kode54
post Mar 29 2011, 14:26
Group: Admin
Only if you want to configure the current resolution for each screen manually. I don't really want to go into detecting the resolution of every desktop or where they are arranged in the virtual desktop space.
Set the position so it only appears on one monitor.
- manudevil   Foo_osd   Mar 28 2006, 17:42
- - lav-chan   No, i noticed that too, i think he got rid of that...   Mar 28 2006, 17:46
- - manudevil   I did it. But I miss this feature. I hope its grea...   Mar 28 2006, 17:51
- - djet   I miss it too. You can use built-in fb2k tray noti...   Mar 28 2006, 20:43
- - manudevil   Yeah, that's right. But I prefer OSD. And I di...   Mar 28 2006, 20:48
- - troskal   http://kode54.foobar2000.org   Mar 28 2006, 21:04
- - manudevil   Euh... what's up ?   Mar 28 2006, 21:10
- - Mafioso   I also would like to use shortcuts for the foo_osd...   Mar 30 2006, 14:37
|- - hypersonic   QUOTE (Mafioso @ Mar 30 2006, 11:37 PM)I also...   Mar 30 2006, 14:58
- - manudevil   I've seen no difference, except the GDI+ versi...   Mar 30 2006, 17:41
- - patsy   hello I'm using foobar 0.8.3 and I'm looki...   Mar 30 2006, 20:57
- - manudevil   Here it is : http://kode54.foobar2000.org/ Kode...   Apr 1 2006, 09:14
- - manudevil   By the way, here is my OSD code : CODE$if...   Apr 1 2006, 09:18
- - patsy   QUOTE (manudevil @ Apr 1 2006, 02:14 AM)Here ...   Apr 1 2006, 12:57
|- - yayacek   QUOTE (patsy @ Apr 1 2006, 05:57) QUOTE (...   Jan 27 2010, 02:20
- - manudevil   Ah. I have this. You can download it here : http:/...   Apr 6 2006, 22:02
- - patsy   thanks   Apr 6 2006, 22:07
- - manudevil   You're welcome.   Apr 6 2006, 22:13
- - 4nt1   excuse my ignorancce but what is foo_osd ? is it l...   Apr 6 2006, 22:48
- - Chaser   Kind of - but much simpler. It displays a custom s...   Apr 6 2006, 23:05
- - manudevil   It is very simple, and so doesn't need any res...   Apr 7 2006, 13:43
|- - jon.schaffer   QUOTE (manudevil @ Apr 7 2006, 14:43) I m...   Jun 25 2006, 22:37
- - ssamadhi97   This feature has been requested several times and ...   Apr 13 2006, 19:30
- - fabiospark   Should I use the 'display forever' setting...   Jun 25 2006, 15:10
- - thuan   Beside the shortcut keys, it seems that %_next% do...   Jun 26 2006, 00:41
|- - Piet   QUOTE (thuan @ Jun 26 2006, 01:41) Beside...   Jun 26 2006, 06:37
- - lwiczek   Little refresh - any chances for adding keyboard s...   Dec 10 2006, 23:37
- - mpioner   lwiczek +1   Dec 11 2006, 01:56
- - Piet   1   Dec 11 2006, 09:37
- - jerkface   Any chance of a keyboard shortcut for the "ne...   Aug 6 2007, 16:07
- - blaxima   A shadow effect and hotkey would be great if this ...   Aug 6 2007, 18:22
- - pirlouy   It would be nice if it was able to detect full scr...   May 29 2008, 15:41
|- - lctm   QUOTE (pirlouy @ May 29 2008, 08:41) It w...   Sep 26 2008, 18:02
- - tpijag   If you actually want assistance, you might want to...   Sep 26 2008, 21:35
- - Lyx   This is a bug in the plugin. The only way to actua...   Oct 2 2008, 00:48
- - boombaard   would it be possible to add unicode support to the...   Mar 30 2009, 00:37
|- - kode54   QUOTE (boombaard @ Mar 29 2009, 16:37) wo...   Mar 30 2009, 01:16
- - jabcok   maybe an option to show text only on desktop?   May 19 2009, 21:48
- - odyssey   I like this plugin very much, but for some reason ...   Sep 16 2009, 13:38
- - 2E7AH   I like it too I've made this MailTicker look...   Oct 4 2009, 17:41
|- - asdfkrono   QUOTE (2E7AH @ Oct 4 2009, 12:41) I like ...   Oct 10 2009, 03:45
- - mstram24   this is great and i love the idea of this plugin b...   Nov 26 2009, 04:29
- - nascent   Edit: Just checked for myself and it works fine wi...   Dec 21 2009, 16:30
- - bob00   Is overlay working for you guys in DirectX games? ...   Mar 7 2010, 18:56
- - mstram24   SICK COMPONENT!!! thanks for the cons...   Apr 17 2010, 13:21
- - Valery_Kondakoff   Thanks for foo_osd! There is a question: what...   Apr 24 2010, 10:44
|- - Andreasvb   QUOTE (Valery_Kondakoff @ Apr 24 2010, 10...   Apr 24 2010, 11:42
|- - Valery_Kondakoff   QUOTE (Andreasvb @ Apr 24 2010, 13:42) If...   Apr 24 2010, 14:44
- - 2E7AH   Can we have option for popping on transition end/s...   May 10 2010, 06:07
- - AlexWMF   Hi, I periodically have mistake and crash foobar. ...   Jun 8 2010, 00:00
- - Grave   is there a way to position osd elements on multipl...   Aug 24 2010, 10:18
- - Valery_Kondakoff   With the new Foo_osd update it is possible to use ...   Oct 21 2010, 14:11
- - bsw11   I cannot seem to change the font color from the gr...   Oct 23 2010, 21:44
- - kode54   The color setting does not affect the text color i...   Oct 23 2010, 23:56
|- - Valery_Kondakoff   QUOTE (kode54 @ Oct 24 2010, 01:56) Also,...   Oct 24 2010, 06:15
- - kode54   Aha, GetLastInputInfo should be useful for this pu...   Oct 24 2010, 10:37
|- - Valery_Kondakoff   QUOTE (kode54 @ Oct 24 2010, 12:37) Aha, ...   Oct 24 2010, 12:59
- - kode54   Okay, I've implemented the idle display contro...   Oct 25 2010, 05:56
|- - Valery_Kondakoff   QUOTE (kode54 @ Oct 25 2010, 07:56) I...   Oct 25 2010, 08:29
|- - Valery_Kondakoff   QUOTE (Valery_Kondakoff @ Oct 25 2010, 10...   Oct 25 2010, 08:55
|- - Valery_Kondakoff   Ok, I have set foo_osd to 'Hide until idle, th...   Oct 25 2010, 09:50
- - kode54   Fixed.   Oct 26 2010, 03:29
- - Valery_Kondakoff   Another one issue: when foo_osd is set to 'Hid...   Oct 26 2010, 15:18
- - Valery_Kondakoff   The same happens when FB2000 stops playing reachin...   Oct 26 2010, 22:58
- - kode54   Hiding the overlay through the hide on stop trigge...   Oct 26 2010, 23:57
|- - Valery_Kondakoff   QUOTE (kode54 @ Oct 27 2010, 02:57) Hidin...   Oct 27 2010, 08:52
- - kode54   Yeah, I've fixed that issue as well. Now the i...   Oct 28 2010, 00:44
- - kode54   Bump for working keyboard shortcuts. Sorry, they...   Nov 23 2010, 07:59
- - Ishikawa   Great plugin! I have my title pop-up set how ...   Dec 4 2010, 16:19
- - kode54   There is no automatic wrapping, but you may insert...   Dec 5 2010, 00:06
|- - Ishikawa   QUOTE (kode54 @ Dec 5 2010, 08:06) There ...   Dec 7 2010, 14:21
|- - Valery_Kondakoff   Hi! I'm trying to use the latest foo_osd ...   Feb 4 2011, 11:19
- - kode54   There is no way to make foo_osd blank your entire ...   Feb 4 2011, 14:54
- - Valery_Kondakoff   Oops! Sorry, it seems I was not clear enough: ...   Feb 4 2011, 19:56
- - kode54   I'm amazed it even displays at all when the sc...   Feb 4 2011, 20:42
|- - Tobi7241   ver 1.62 introduced stretching OSD over all virtua...   Mar 29 2011, 14:06
- - Porthos59   Foobar v1.1.2 On-Screen Display v1.68 Is there an...   Feb 5 2011, 21:07
- - Andreasvb   Make sure you have it disabled in all your presets...   Feb 5 2011, 21:12
- - berocent   any possibility to change "... and hide on s...   Feb 28 2011, 11:14
- - kode54   Only if you want to configure the current resoluti...   Mar 29 2011, 14:26
|- - q=P   QUOTE (kode54 @ Mar 29 2011, 08:26) Only ...   Apr 13 2012, 21:57
- - James2000   Hey kode, Since I've configured the OSD to di...   Apr 7 2011, 17:18
- - Perq   Hi there, The option I really miss, is turning who...   Apr 10 2011, 21:55
- - kode54   Auto line wrapping: When I feel like it. Detecting...   Apr 14 2011, 18:53
- - sollniss   Would it be hard to not disable the the OSD with f...   Apr 15 2011, 14:27
- - kode54   fraps and other programs do it by hooking into the...   Apr 16 2011, 05:25
- - Perq   Thanks a lot for answers.   Oct 14 2011, 17:47
- - John2K   Hi kode, thanks for the great plugin! If you...   Jan 8 2012, 10:36
- - kode54   I'll look into implementing that, but it will ...   Jan 25 2012, 08:19
- - John2K   Well I'm obviously not conversant with the act...   Jan 25 2012, 08:43
- - kode54   Okay, so now you can put the overlays on any monit...   Apr 14 2012, 07:39
|- - q=P   Thank you!   Apr 16 2012, 22:17
- - biribiriRG   Is there any way to make the OSD display at all ti...   Apr 18 2012, 00:05
|- - kode54   "Display forever" works as intended here...   Apr 18 2012, 00:33
|- - biribiriRG   QUOTE (kode54 @ Apr 17 2012, 15:33) ...   Apr 18 2012, 00:44
- - tpijag   Tested with On Play event. Works fine here. Fooba...   Apr 18 2012, 00:20
- - tpijag   QUOTE (kode54 @ Apr 17 2012, 18:33) I may...   Apr 18 2012, 00:56
- - kode54   Well, it's the only change I made, but it...   Apr 18 2012, 01:59
- - biribiriRG   love how my issue is completely brushed off/ignore...   Apr 18 2012, 02:52
- - tpijag   Nice attitude toward someone who volunteers time w...   Apr 18 2012, 03:48
2 Pages V   1 2 >
RSS Lo-Fi Version Time is now: 28th January 2015 - 05:50
