Foo_osd, keyboard shortcut
manudevil
post Mar 28 2006, 17:42
Hello !
I'm using foobar since 0.7 and I like it ! Using Foo_osd too, but I miss some function... With the last port for Foobar 0.9, I don't know how to display OSD with a keyboard shortcut. Is there any way ?
Thanks !
Sites dynamiques : http://www.manudevil.com
bsw11
post Oct 23 2010, 21:44
I cannot seem to change the font color from the green to any other color. Is anyone else having this issue?
I am running W7 X64 with NVIDIA GTX 470 graphics.
OK I figured it out - you have the change the format string - but the color setting should do that as well I would think?
This post has been edited by bsw11: Oct 23 2010, 21:47
- manudevil   Foo_osd   Mar 28 2006, 17:42
- - lav-chan   No, i noticed that too, i think he got rid of that...   Mar 28 2006, 17:46
- - manudevil   I did it. But I miss this feature. I hope its grea...   Mar 28 2006, 17:51
- - djet   I miss it too. You can use built-in fb2k tray noti...   Mar 28 2006, 20:43
- - manudevil   Yeah, that's right. But I prefer OSD. And I di...   Mar 28 2006, 20:48
- - troskal   http://kode54.foobar2000.org   Mar 28 2006, 21:04
- - manudevil   Euh... what's up ?   Mar 28 2006, 21:10
- - Mafioso   I also would like to use shortcuts for the foo_osd...   Mar 30 2006, 14:37
|- - hypersonic   QUOTE (Mafioso @ Mar 30 2006, 11:37 PM)I also...   Mar 30 2006, 14:58
- - manudevil   I've seen no difference, except the GDI+ versi...   Mar 30 2006, 17:41
- - patsy   hello I'm using foobar 0.8.3 and I'm looki...   Mar 30 2006, 20:57
- - manudevil   Here it is : http://kode54.foobar2000.org/ Kode...   Apr 1 2006, 09:14
- - manudevil   By the way, here is my OSD code : CODE$if...   Apr 1 2006, 09:18
- - patsy   QUOTE (manudevil @ Apr 1 2006, 02:14 AM)Here ...   Apr 1 2006, 12:57
|- - yayacek   QUOTE (patsy @ Apr 1 2006, 05:57) QUOTE (...   Jan 27 2010, 02:20
- - manudevil   Ah. I have this. You can download it here : http:/...   Apr 6 2006, 22:02
- - patsy   thanks   Apr 6 2006, 22:07
- - manudevil   You're welcome.   Apr 6 2006, 22:13
- - 4nt1   excuse my ignorancce but what is foo_osd ? is it l...   Apr 6 2006, 22:48
- - Chaser   Kind of - but much simpler. It displays a custom s...   Apr 6 2006, 23:05
- - manudevil   It is very simple, and so doesn't need any res...   Apr 7 2006, 13:43
|- - jon.schaffer   QUOTE (manudevil @ Apr 7 2006, 14:43) I m...   Jun 25 2006, 22:37
- - ssamadhi97   This feature has been requested several times and ...   Apr 13 2006, 19:30
- - fabiospark   Should I use the 'display forever' setting...   Jun 25 2006, 15:10
- - thuan   Beside the shortcut keys, it seems that %_next% do...   Jun 26 2006, 00:41
|- - Piet   QUOTE (thuan @ Jun 26 2006, 01:41) Beside...   Jun 26 2006, 06:37
- - lwiczek   Little refresh - any chances for adding keyboard s...   Dec 10 2006, 23:37
- - mpioner   lwiczek +1   Dec 11 2006, 01:56
- - Piet   1   Dec 11 2006, 09:37
- - jerkface   Any chance of a keyboard shortcut for the "ne...   Aug 6 2007, 16:07
- - blaxima   A shadow effect and hotkey would be great if this ...   Aug 6 2007, 18:22
- - pirlouy   It would be nice if it was able to detect full scr...   May 29 2008, 15:41
|- - lctm   QUOTE (pirlouy @ May 29 2008, 08:41) It w...   Sep 26 2008, 18:02
- - tpijag   If you actually want assistance, you might want to...   Sep 26 2008, 21:35
- - Lyx   This is a bug in the plugin. The only way to actua...   Oct 2 2008, 00:48
- - boombaard   would it be possible to add unicode support to the...   Mar 30 2009, 00:37
|- - kode54   QUOTE (boombaard @ Mar 29 2009, 16:37) wo...   Mar 30 2009, 01:16
- - jabcok   maybe an option to show text only on desktop?   May 19 2009, 21:48
- - odyssey   I like this plugin very much, but for some reason ...   Sep 16 2009, 13:38
- - 2E7AH   I like it too I've made this MailTicker look...   Oct 4 2009, 17:41
|- - asdfkrono   QUOTE (2E7AH @ Oct 4 2009, 12:41) I like ...   Oct 10 2009, 03:45
- - mstram24   this is great and i love the idea of this plugin b...   Nov 26 2009, 04:29
- - nascent   Edit: Just checked for myself and it works fine wi...   Dec 21 2009, 16:30
- - bob00   Is overlay working for you guys in DirectX games? ...   Mar 7 2010, 18:56
- - mstram24   SICK COMPONENT!!! thanks for the cons...   Apr 17 2010, 13:21
- - Valery_Kondakoff   Thanks for foo_osd! There is a question: what...   Apr 24 2010, 10:44
|- - Andreasvb   QUOTE (Valery_Kondakoff @ Apr 24 2010, 10...   Apr 24 2010, 11:42
|- - Valery_Kondakoff   QUOTE (Andreasvb @ Apr 24 2010, 13:42) If...   Apr 24 2010, 14:44
- - 2E7AH   Can we have option for popping on transition end/s...   May 10 2010, 06:07
- - AlexWMF   Hi, I periodically have mistake and crash foobar. ...   Jun 8 2010, 00:00
- - Grave   is there a way to position osd elements on multipl...   Aug 24 2010, 10:18
- - Valery_Kondakoff   With the new Foo_osd update it is possible to use ...   Oct 21 2010, 14:11
- - bsw11   I cannot seem to change the font color from the gr...   Oct 23 2010, 21:44
- - kode54   The color setting does not affect the text color i...   Oct 23 2010, 23:56
|- - Valery_Kondakoff   QUOTE (kode54 @ Oct 24 2010, 01:56) Also,...   Oct 24 2010, 06:15
- - kode54   Aha, GetLastInputInfo should be useful for this pu...   Oct 24 2010, 10:37
|- - Valery_Kondakoff   QUOTE (kode54 @ Oct 24 2010, 12:37) Aha, ...   Oct 24 2010, 12:59
- - kode54   Okay, I've implemented the idle display contro...   Oct 25 2010, 05:56
|- - Valery_Kondakoff   QUOTE (kode54 @ Oct 25 2010, 07:56) I...   Oct 25 2010, 08:29
|- - Valery_Kondakoff   QUOTE (Valery_Kondakoff @ Oct 25 2010, 10...   Oct 25 2010, 08:55
|- - Valery_Kondakoff   Ok, I have set foo_osd to 'Hide until idle, th...   Oct 25 2010, 09:50
- - kode54   Fixed.   Oct 26 2010, 03:29
- - Valery_Kondakoff   Another one issue: when foo_osd is set to 'Hid...   Oct 26 2010, 15:18
- - Valery_Kondakoff   The same happens when FB2000 stops playing reachin...   Oct 26 2010, 22:58
- - kode54   Hiding the overlay through the hide on stop trigge...   Oct 26 2010, 23:57
|- - Valery_Kondakoff   QUOTE (kode54 @ Oct 27 2010, 02:57) Hidin...   Oct 27 2010, 08:52
- - kode54   Yeah, I've fixed that issue as well. Now the i...   Oct 28 2010, 00:44
- - kode54   Bump for working keyboard shortcuts. Sorry, they...   Nov 23 2010, 07:59
- - Ishikawa   Great plugin! I have my title pop-up set how ...   Dec 4 2010, 16:19
- - kode54   There is no automatic wrapping, but you may insert...   Dec 5 2010, 00:06
|- - Ishikawa   QUOTE (kode54 @ Dec 5 2010, 08:06) There ...   Dec 7 2010, 14:21
|- - Valery_Kondakoff   Hi! I'm trying to use the latest foo_osd ...   Feb 4 2011, 11:19
- - kode54   There is no way to make foo_osd blank your entire ...   Feb 4 2011, 14:54
- - Valery_Kondakoff   Oops! Sorry, it seems I was not clear enough: ...   Feb 4 2011, 19:56
- - kode54   I'm amazed it even displays at all when the sc...   Feb 4 2011, 20:42
|- - Tobi7241   ver 1.62 introduced stretching OSD over all virtua...   Mar 29 2011, 14:06
- - Porthos59   Foobar v1.1.2 On-Screen Display v1.68 Is there an...   Feb 5 2011, 21:07
- - Andreasvb   Make sure you have it disabled in all your presets...   Feb 5 2011, 21:12
- - berocent   any possibility to change "... and hide on s...   Feb 28 2011, 11:14
- - kode54   Only if you want to configure the current resoluti...   Mar 29 2011, 14:26
|- - q=P   QUOTE (kode54 @ Mar 29 2011, 08:26) Only ...   Apr 13 2012, 21:57
- - James2000   Hey kode, Since I've configured the OSD to di...   Apr 7 2011, 17:18
- - Perq   Hi there, The option I really miss, is turning who...   Apr 10 2011, 21:55
- - kode54   Auto line wrapping: When I feel like it. Detecting...   Apr 14 2011, 18:53
- - sollniss   Would it be hard to not disable the the OSD with f...   Apr 15 2011, 14:27
- - kode54   fraps and other programs do it by hooking into the...   Apr 16 2011, 05:25
- - Perq   Thanks a lot for answers.   Oct 14 2011, 17:47
- - John2K   Hi kode, thanks for the great plugin! If you...   Jan 8 2012, 10:36
- - kode54   I'll look into implementing that, but it will ...   Jan 25 2012, 08:19
- - John2K   Well I'm obviously not conversant with the act...   Jan 25 2012, 08:43
- - kode54   Okay, so now you can put the overlays on any monit...   Apr 14 2012, 07:39
|- - q=P   Thank you!   Apr 16 2012, 22:17
- - biribiriRG   Is there any way to make the OSD display at all ti...   Apr 18 2012, 00:05
|- - kode54   "Display forever" works as intended here...   Apr 18 2012, 00:33
|- - biribiriRG   QUOTE (kode54 @ Apr 17 2012, 15:33) ...   Apr 18 2012, 00:44
- - tpijag   Tested with On Play event. Works fine here. Fooba...   Apr 18 2012, 00:20
- - tpijag   QUOTE (kode54 @ Apr 17 2012, 18:33) I may...   Apr 18 2012, 00:56
- - kode54   Well, it's the only change I made, but it...   Apr 18 2012, 01:59
- - biribiriRG   love how my issue is completely brushed off/ignore...   Apr 18 2012, 02:52
- - tpijag   Nice attitude toward someone who volunteers time w...   Apr 18 2012, 03:48
2 Pages V   1 2 >
RSS Lo-Fi Version Time is now: 2nd August 2015 - 14:29
