IPB
5 Pages V   1 2 3 > »
Closed TopicStart new topic
Noncompliant to single wav cuesheet, Any automated tool?
DrGreen
post Feb 16 2006, 00:05
Post #1
Group: Members
i'm sorry if this was already asked here, but I couldn't found it with search.
Is there any tool that can convert a multiple files noncompliant cuesheet to a single image one?
The reason for this is that I have some albums stored as multiple files with a noncompliant cuesheet with gaps append to the end of previous track. Now I would like to join the files and create one appropriate cuesheet with all gaps preserved.
I've read the EAC CUE Sheets wiki page, and I see that it contains the method for converting, but it's difficult to apply it to a lot of cues by hand.
So I was thinking on some tool, or other clerver and quicker method to do it.
Go to the top of the page
+Quote Post
smz
post Feb 16 2006, 02:43
Post #2
Group: Members
Good question...
Foobar2000 doesn't seems to handle gaps, nor it is possible to "mount" such non-compliant cuesheets into an Alcohol 120% virtual drive. I don't know if it is possible with Daemon Tools.
The ideal would be to have a "virtual burner" that can be seen by EAC and "burn" an image+cuesheet from EAC. I know about EZB Systems Softdisc, but I never tried it and I don't know if its usable from EAC.
Anybody tried it?
... and, BTW, I'm every day happyier to have ripped to Image+Cuesheet ...
Sergio
Sergio
Revox B150 + (JBL 4301B | Sennheiser HD430)
+Quote Post
Cosmo
post Feb 16 2006, 03:54
Post #3
Group: Members
The only simple solution involves owning the original CD. Otherwise, if any software/tool exists that would make this process easy, they're doing a good job of keeping it a secret.
+Quote Post
smz
post Feb 16 2006, 04:23
Post #4
Group: Members
actually, just burning the non-compliant cuesheet to a cd-rw and then re-rip at you heart will suffice...
Sergio
+Quote Post
DrGreen
post Feb 16 2006, 12:57
Post #5
Group: Members
yes, I guess the burn and re-rip solution is the better, and in that case there's no need to actually rip it again, just extract the cue...
I will keep looking for such tool, maybe some good tool-making guy around here will solve the problem meanwhile lalala.gif
+Quote Post
Moitah
post Feb 16 2006, 13:12
Post #6
Group: Members
QUOTE (DrGreen @ Feb 16 2006, 07:57 AM)
Maybe wink.gif. No promises though smile.gif.
This post has been edited by Moitah: Feb 16 2006, 13:12
+Quote Post
Moitah
post Feb 17 2006, 11:53
Post #7
Group: Members
I got a good start on it tonight. I should have something to share soon smile.gif.
+Quote Post
Synthetic Soul
post Feb 17 2006, 12:52
Post #8
Group: Super Moderator
You're keen as a jellybean!
Will the app take a list of files and a non-compliant cuesheet, and return a single file cuesheet calculated from the original cuesheet data and track lengths, or will there be other features?
Is it worth sharing your thoughts now so that users can make requests?
Am I right in remembering that you use C#?
I'm on a horse.
+Quote Post
Moitah
post Feb 17 2006, 22:06
Post #9
Group: Members
@Synthetic Soul: Yes, it will read a CUE sheet (any of the 4 types that EAC makes) and get the track lengths from the WAV files (you'll have to make sure they're present and named properly). Then it will output a single-file CUE sheet, and I could add some of the other types later. It won't mess with the WAV files (splitting/joining) but it's not out of the question in the future. For now you can use WAV Tools to join the files. It's written in C# and will require the .NET Framework v2.0.
+Quote Post
Synthetic Soul
post Feb 17 2006, 22:15
Post #10
Thanks for the reply.
I'm on a horse.
+Quote Post
DrGreen
post Feb 17 2006, 22:33
Post #11
Group: Members
Somehow the mail notifications are not working for me and saw this only now...
+Quote Post
Moitah
post Feb 18 2006, 01:43
Post #12
Group: Members
[Link removed, see here for updated link] - .NET Framework 2.0 required. Source code will be released soon.
Please help me test it by inspecting the new CUE sheet for anything strange. The time calculations should be correct, but look for any out-of-place items (commands other than FILE, TRACK, INDEX, and PREGAP are passed through as-is, hopefully in the right location smile.gif).
This post has been edited by Moitah: Nov 12 2006, 07:55
+Quote Post
DrGreen
post Feb 18 2006, 12:57
Post #13
Group: Members
Thanks Moitah!
I will make some tests and report it back here.
For now I'm getting connection refused on your site. Hopefuly it will come back soon smile.gif
+Quote Post
Moitah
post Feb 18 2006, 13:15
Post #14
Group: Members
@DrGreen: That's strange, usually my hosting is very stable. I can connect to the server via FTP but the HTTP part is down. Anyway, it's now mirrored at my ISP web space: [Link removed, see here for updated link].
+Quote Post
DrGreen
post Feb 18 2006, 13:52
Post #15
Group: Members
Got it now!
Ok, I've made a test rip to disk. Now I'm having a problem. I always have a "Unable to get length of WAV file" error. Checked the files inside cue and they seem to be fine, also tried with full path and got the same error.
Am I missing something here?
btw, are you going to release the source? It would be easier to me to check if is a bug or not.
Thanks mate!
+Quote Post
Moitah
post Feb 18 2006, 13:57
Post #16
Group: Members
@DrGreen: Full paths don't work right now, I'll have to fix that (I'd like to just ignore the directory part, does anyone have the CUE and WAVs in different directories?). When testing I had that problem because EAC doesn't replace spaces with underscores for the filenames inside the CUE sheet, make sure that's not the problem. If that's not it, I'll post a build that will give me more detail about this error (and the source too).
+Quote Post
DrGreen
post Feb 18 2006, 14:13
Post #17
Group: Members
Did a quick test and the calculated cue is exactly the same as EAC one.
The problem was with the spaces. May I ask you why is there such problem?
Anyway, you made my day wink.gif Thanks!
+Quote Post
Moitah
post Feb 18 2006, 14:17
Post #18
Group: Members
Glad it's working now smile.gif. I guess the space thing is a bug in EAC. I'll make it replace spaces with underscores or vice-versa if it can't load the file the first time.
+Quote Post
DrGreen
post Feb 18 2006, 15:14
Post #19
Group: Members
I guess I misunderstood you when you talked about spaces and underscores.
If I use a rip with track names without spaces (Track01...) it works well. Now if I use a rip with proper filenames it will give the error mentioned before.
In both cases the tracknames inside the cue match the tracks filenames.
Here's the cue (of course it is useless without the files but...)
CODE
REM GENRE Jazz
REM DISCID 760D6E09
REM COMMENT "ExactAudioCopy v0.95b3"
PERFORMER "Peter Erskine"
TITLE "As It Is"
FILE "Glebe Ascending.wav" WAVE
 TRACK 01 AUDIO
   TITLE "Glebe Ascending"
   INDEX 01 00:00:00
 TRACK 02 AUDIO
   TITLE "The Lady In The Lake"
   INDEX 00 07:03:21
FILE "The Lady In The Lake.wav" WAVE
   INDEX 01 00:00:00
 TRACK 03 AUDIO
   TITLE "Episode"
   INDEX 00 07:57:67
FILE "Episode.wav" WAVE
   INDEX 01 00:00:00
 TRACK 04 AUDIO
   TITLE "Woodcocks"
   INDEX 00 04:28:35
FILE "Woodcocks.wav" WAVE
   INDEX 01 00:00:00
 TRACK 05 AUDIO
   TITLE "Esperanša"
   INDEX 00 07:12:36
FILE "Esperanša.wav" WAVE
   INDEX 01 00:00:00
 TRACK 06 AUDIO
   TITLE "Touch Her Soft Lips And Part"
   INDEX 00 03:57:23
FILE "Touch Her Soft Lips And Part.wav" WAVE
   INDEX 01 00:00:00
 TRACK 07 AUDIO
   TITLE "Au Contraire"
   INDEX 00 04:52:39
FILE "Au Contraire.wav" WAVE
   INDEX 01 00:00:00
 TRACK 08 AUDIO
   TITLE "For Ruth"
   INDEX 00 10:17:29
FILE "For Ruth.wav" WAVE
   INDEX 01 00:00:00
 TRACK 09 AUDIO
   TITLE "Romeo And Juliet"
   INDEX 00 06:43:46
FILE "Romeo And Juliet.wav" WAVE
   INDEX 01 00:00:00
I'm used to C#, so if you could make the source available I guess I would be able to track down the problem.
Thanks again mate!
+Quote Post
Moitah
post Feb 18 2006, 15:17
Post #20
Group: Members
I fixed the full path issue, added the space/underscore thing, added the ability to drag/drop CUE files onto the path text boxes, and added prompt for overwrite if the output CUE exists. I think it's good enough to call "one-point-oh", so here it is:
+Quote Post
DrGreen
post Feb 18 2006, 15:28
Post #21
Group: Members
found the problem with my cuesheet.
It was a non ASCII character in file Esperanša.wav
+Quote Post
liekloo
post Feb 20 2006, 22:04
Post #22
Group: Members
Moitah you've done a terrific job! There has been a real need for a tool that does what yours does, and I think quite some people will take advantage this. smile.gif
"E S S E N T I A L" Guide for E A C :
http://users.fulladsl.be/spb2267/
+Quote Post
mmortal03
post Feb 20 2006, 23:13
Post #23
Group: Members
Awesome work!
Any chance this could be made to follow the relative subdirectories in the CUE sheet to find the source WAV files? It copies over the information properly linking to the right location, but only if you move them to the directory of the cuesheet temporarily.
Also, might I be the one to request support for FLAC files? I believe a length string is stored inside the FLACs.
WARNING: Changing of advanced parameters might degrade sound quality. Modify them only if you are expirienced in audio compression!
+Quote Post
Moitah
post Feb 20 2006, 23:31
Post #24
Group: Members
Thanks for the feedback smile.gif.
@mmortal03: I can fix that. I'd like to have it check in the same directory as the CUE first, but if that doesn't work I could use the directory provided in the CUE sheet (absolute or relative). As for FLACs, I'll see how much work it would be. Do the filenames inside the CUE sheet have ".flac" or ".wav" extension?
+Quote Post
mmortal03
post Feb 21 2006, 02:31
Post #25
Group: Members
QUOTE (Moitah @ Feb 20 2006, 05:31 PM)
I edit my cue sheets so that they have a ".flac" extension, because EAC doesn't do it on its own.
+Quote Post
5 Pages V   1 2 3 > »
0 Members:
RSS Lo-Fi Version Time is now: 3rd March 2015 - 21:55
