Noncompliant to single wav cuesheet, Any automated tool?
DrGreen
post Feb 16 2006, 00:05
i'm sorry if this was already asked here, but I couldn't found it with search.
Is there any tool that can convert a multiple files noncompliant cuesheet to a single image one?
The reason for this is that I have some albums stored as multiple files with a noncompliant cuesheet with gaps append to the end of previous track. Now I would like to join the files and create one appropriate cuesheet with all gaps preserved.
I've read the EAC CUE Sheets wiki page, and I see that it contains the method for converting, but it's difficult to apply it to a lot of cues by hand.
So I was thinking on some tool, or other clerver and quicker method to do it.
Fandango
post Feb 23 2006, 01:48
The problem is not that the DATE line gets ommitted during converting with CUETool... which is not the case!
foobar simply doesn't interpret the "DATE 1544" line as a YEAR tag... and there's no way of adding a "REM YEAR 1544" or so... that would get ignored, too. tongue.gif Maybe that's fixed in the newer betas... as I said I used 0.9b6 with the old cue sheet interpreter.
If this causes some problems for you later... for example you want the albums of one artist to be in the correct order of release then add the year of the release somewhere in the file path. For example make a folder for every album starting with the year of release, or if you use single files with integrated cue sheets use something like <Artist> - <Year> - <Album title>.flac. Then you can sort the playlist according to the file path automatically and don't have to make it manually when you create a new playlist or messed an old one up.
Oh or maybe ask the fb2k devs politely if they would like to implement this (if they haven't done so already). I mean that the DATE line gets interpreted as a YEAR tag when loading a cue sheet.
This post has been edited by Fandango: Feb 23 2006, 02:31
mmortal03
post Feb 23 2006, 21:38
QUOTE (Fandango @ Feb 22 2006, 07:48 PM)
Yeah, I actually just use the DATE tag as the YEAR tag. Are you saying that foobar2000 cannot read the DATE info from the the cuesheet?
WARNING: Changing of advanced parameters might degrade sound quality. Modify them only if you are expirienced in audio compression!
- DrGreen   Noncompliant to single wav cuesheet   Feb 16 2006, 00:05
- - smz   Good question... Foobar2000 doesn't seems to ...   Feb 16 2006, 02:43
- - Cosmo   The only simple solution involves owning the origi...   Feb 16 2006, 03:54
|- - smz   actually, just burning the non-compliant cuesheet ...   Feb 16 2006, 04:23
- - DrGreen   Thanks for the replies guys, and sorry for the wro...   Feb 16 2006, 12:57
|- - Moitah   QUOTE (DrGreen @ Feb 16 2006, 07:57 AM)maybe ...   Feb 16 2006, 13:12
- - Moitah   I got a good start on it tonight. I should have s...   Feb 17 2006, 11:53
- - Synthetic Soul   You're keen as a jellybean! Will the app ...   Feb 17 2006, 12:52
|- - Moitah   @Synthetic Soul: Yes, it will read a CUE sheet (a...   Feb 17 2006, 22:06
- - Synthetic Soul   Thanks for the reply. Looking forward to playing ...   Feb 17 2006, 22:15
- - DrGreen   Moitah, thank you so much Somehow the mail notif...   Feb 17 2006, 22:33
- - Moitah   [Link removed, see here for updated link] - .NET F...   Feb 18 2006, 01:43
- - DrGreen   Thanks Moitah! I will make some tests and rep...   Feb 18 2006, 12:57
|- - Moitah   @DrGreen: That's strange, usually my hosting i...   Feb 18 2006, 13:15
- - DrGreen   Got it now! Ok, I've made a test rip to d...   Feb 18 2006, 13:52
|- - Moitah   @DrGreen: Full paths don't work right now, I...   Feb 18 2006, 13:57
- - DrGreen   Yeah! I guess we have a winner! Did a qu...   Feb 18 2006, 14:13
- - Moitah   Glad it's working now . I guess the space thi...   Feb 18 2006, 14:17
- - DrGreen   I guess I misunderstood you when you talked about ...   Feb 18 2006, 15:14
- - Moitah   I fixed the full path issue, added the space/under...   Feb 18 2006, 15:17
- - DrGreen   found the problem with my cuesheet. It was a non ...   Feb 18 2006, 15:28
- - liekloo   Wow! Moitah you've done a terrific job...   Feb 20 2006, 22:04
- - mmortal03   Awesome work! Any chance this could be made...   Feb 20 2006, 23:13
|- - Moitah   Thanks for the feedback . @mmortal03: I can fix ...   Feb 20 2006, 23:31
|- - mmortal03   QUOTE (Moitah @ Feb 20 2006, 05:31 PM)Thanks ...   Feb 21 2006, 02:31
- - Moitah   CUE Tools v1.1.0 uses the directory information in...   Feb 21 2006, 15:26
- - mmortal03   The new version works like a charm. One very smal...   Feb 22 2006, 02:52
- - DrGreen   Moitah, this is getting even better Thanks for th...   Feb 22 2006, 13:14
- - DrGreen   I guess you have a little bug on your General.Time...   Feb 22 2006, 19:47
- - Moitah   I thought I tested that... wow, what a stupid bug ...   Feb 22 2006, 20:52
- - DrGreen   You're bug might be stupid... but my solution ...   Feb 22 2006, 21:14
- - Moitah   CUE Tools v1.2.0:Fixes the bug with writing timest...   Feb 22 2006, 23:47
- - Fandango   OMG! Awesome, Moitah. Another useful tools fro...   Feb 22 2006, 23:56
- - mmortal03   Yeah, I mean, if you integrated WAVTools and CUETo...   Feb 23 2006, 00:35
- - Fandango   @mmortal03 Yes, and since WAVTools already suppor...   Feb 23 2006, 00:47
|- - mmortal03   QUOTE (Fandango @ Feb 22 2006, 06:47 PM)@mmor...   Feb 23 2006, 00:56
|- - Fandango   QUOTE (mmortal03 @ Feb 23 2006, 12:56 AM)I un...   Feb 23 2006, 01:22
- - mmortal03   How can I properly store the Date Tag information ...   Feb 23 2006, 01:37
- - Fandango   The problem is not that the DATE line gets ommitte...   Feb 23 2006, 01:48
|- - mmortal03   QUOTE (Fandango @ Feb 22 2006, 07:48 PM)The p...   Feb 23 2006, 21:38
- - Moitah   I think I'm just going to remove those ReplayG...   Feb 23 2006, 19:57
- - Moitah   That said, I threw this together really quick. It...   Feb 23 2006, 20:26
- - Fandango   Yeah I guess you're absolutely right, preservi...   Feb 23 2006, 20:44
- - Cosmo   Nice. Might it be possible to re-introduce a gap ...   Feb 23 2006, 20:51
- - Moitah   @Cosmo: WAV Tools will let you do it either way.   Feb 23 2006, 20:53
|- - Cosmo   QUOTE (Moitah)@Cosmo: WAV Tools will let you do it...   Feb 23 2006, 23:13
- - Fandango   Yes, this is correct for the "old" cue s...   Feb 23 2006, 21:58
|- - mmortal03   QUOTE (Fandango @ Feb 23 2006, 03:58 PM)Yes, ...   Feb 24 2006, 01:21
|- - Martin H   QUOTE (mmortal03 @ Feb 24 2006, 01:21 AM)I do...   Feb 24 2006, 05:47
|- - mmortal03   QUOTE (Martin H @ Feb 23 2006, 11:47 PM)QUOTE...   Feb 25 2006, 20:53
|- - Martin H   QUOTE (mmortal03 @ Feb 25 2006, 08:53 PM)Whic...   Feb 26 2006, 04:11
|- - mmortal03   QUOTE (Martin H @ Feb 25 2006, 10:11 PM)QUOTE...   Feb 26 2006, 09:56
|- - Fandango   QUOTE (mmortal03 @ Feb 26 2006, 09:56 AM)Eith...   Feb 26 2006, 13:36
- - Moitah   I see what you're asking now. Yeah, I think I...   Feb 23 2006, 23:59
- - Moitah   After checking a non-compliant CUE sheet with a ga...   Feb 24 2006, 00:18
|- - Cosmo   QUOTE (Moitah)After checking a non-compliant CUE s...   Feb 24 2006, 16:31
- - Fandango   I got another suggestion concerning the file name ...   Feb 24 2006, 00:28
- - djet   This tool is just a dream! It saved a lot of m...   Feb 24 2006, 02:35
|- - Duble0Syx   QUOTE (djet @ Feb 23 2006, 05:35 PM)As you se...   Feb 24 2006, 03:07
|- - mmortal03   QUOTE (Duble0Syx @ Feb 23 2006, 09:07 PM)QUOT...   Feb 24 2006, 04:51
|- - Duble0Syx   QUOTE (mmortal03 @ Feb 23 2006, 07:51 PM)QUOT...   Feb 24 2006, 06:48
- - Moitah   I have the code working to convert to non-complian...   Feb 24 2006, 18:52
- - brimstone   QUOTE (Duble0Syx @ Feb 24 2006, 06:48 AM)QUOT...   Feb 24 2006, 19:40
- - Moitah   CUE Tools v1.3.0:Added: Conversion to the other 3 ...   Feb 25 2006, 14:20
- - Moitah   I think I am going to add the ability to process t...   Feb 25 2006, 14:31
- - HeadLessException   thanks for this great tool. keep up the good work   Feb 25 2006, 20:20
- - djet   Moitah, what about that PREGAP bug?   Feb 25 2006, 22:53
- - Moitah   I don't consider it a bug. The next version w...   Feb 25 2006, 23:08
|- - djet   QUOTE (Moitah @ Feb 26 2006, 02:08 AM)I don...   Feb 26 2006, 06:54
- - Moitah   The code to process the WAV files is done and test...   Feb 26 2006, 03:33
- - Moitah   I'll think about it. I'd have to test to ...   Feb 26 2006, 07:01
- - Moitah   CUE Tools v1.4.0:Added: Converts the WAV files as ...   Feb 27 2006, 00:12
- - DrGreen   Sweet Just made a couple of tests and it's r...   Feb 27 2006, 00:35
- - Moitah   CUE Tools v1.4.1:Added: Hidden option to write PRE...   Feb 27 2006, 04:15
|- - Vietwoojagig   QUOTE (Moitah @ Feb 27 2006, 04:15 AM)CUE Too...   Feb 27 2006, 12:06
- - Fandango   This is great! As easy as drag and drop now, ...   Feb 27 2006, 07:08
- - mmortal03   It would be awesome to have it eventually handle F...   Feb 27 2006, 08:38
- - Moitah   CUE Tools v1.4.2:Fixed: Extended ASCII characters ...   Feb 27 2006, 17:40
|- - Vietwoojagig   QUOTE (Moitah @ Feb 27 2006, 05:40 PM)Regardi...   Mar 1 2006, 15:59
|- - Vietwoojagig   QUOTE (Moitah @ Feb 27 2006, 05:40 PM)CUE Too...   Mar 7 2006, 10:40
- - Moitah   CUE Tools v1.4.3:Fixed: Small range of extended AS...   Feb 27 2006, 18:42
- - djet   Great!! Thank you!   Feb 27 2006, 23:36
- - Moitah   FLAC input files are now fully supported (output i...   Feb 28 2006, 23:26
- - mmortal03   I am assuming you haven't posted the FLAC deco...   Mar 1 2006, 01:21
- - Moitah   Not yet, it needs more testing. But either tonigh...   Mar 1 2006, 02:04
- - Moitah   CUE Tools v1.5.0:Added: Support for reading audio ...   Mar 1 2006, 04:58
|- - mmortal03   There is something about parenthesis that this new...   Mar 1 2006, 06:28
- - Moitah   Only for FLAC files? You are talking about the fi...   Mar 1 2006, 06:45
- - Moitah   CUE Tools v1.5.1:Fixed: FLAC files weren't bei...   Mar 1 2006, 21:34
|- - mmortal03   QUOTE (Moitah @ Mar 1 2006, 03:34 PM)CUE Tool...   Mar 2 2006, 05:03
- - Moitah   It's okay, the fact that libFLAC didn't ac...   Mar 2 2006, 05:25
- - djet   Is it possible to enable WavPack output?   Mar 2 2006, 16:49
- - Moitah   I'd rather work on FLAC output first, but if I...   Mar 2 2006, 16:51
- - Moitah   I didn't realize there was a POSTGAP command u...   Mar 7 2006, 12:07
- - Fandango   I get this error: "Index length cannot be 0....   Mar 24 2006, 23:09
|- - valnar   QUOTE (Fandango @ Mar 24 2006, 14:09) I g...   May 16 2006, 14:55
|- - Moitah   QUOTE (Fandango @ Mar 24 2006, 18:09) I g...   Jul 5 2006, 07:42
- - Fandango   seems like Moitah's taking a break... ^^   May 27 2006, 18:44
- - Fandango   QUOTE If you rip the CD in single-file mode does E...   Aug 2 2006, 19:04
- - greynol   QUOTE CODETRACK 01 AUDIO INDEX 01 00:00...   Aug 2 2006, 21:04
2 Pages V   1 2 >
Closed TopicStart new topic
RSS Lo-Fi Version Time is now: 1st August 2015 - 20:51
