New Adaptec Aspi 4.72
WaldoMonster
post Oct 30 2002, 17:27
http://www.adaptec.com/worldwide/support/d...uct%2fASPI-4.70
netjukebox - the flexible media share
http://www.netjukebox.nl
ak
post Oct 30 2002, 23:37
Musepack Developer
Hmm they've included file with wrong name in distro: aspiinit.exe (or something like that) instead of aspiinst. Bugs happen. smile.gif
BTW what that 'a2' part means: alpha 2? smile.gif
ogg
post Oct 31 2002, 00:50
Adaptec is never good with distributing/installations/documentation.. they ALWAYS goof something up.
One I noticed is in the instructions, they say the files are unzipped by default to \adaptec\.. ok, then they say to install on Windows XP you should run \adaptec\aspi\install.bat. Heh.
mdefranc
post Oct 31 2002, 01:23
Group: Members (Donating)
Has any HA member actually installed this package, verified the update, and then tested to see if it worked?
I ask because aspi changes really trashed my os on some past occasions.
Ardax
post Oct 31 2002, 03:53
Probably not, for the exact reason you've outlined. tongue.gif I'm still happily chugging along with Nero's ASPI layer.
Reiginsei
post Oct 31 2002, 05:48
I downloaded the package, double clicked the setup file which installed to \adaptec. I ran the command INSTALL.BAT XP32, (I'm in WinXPHome), and it said the files were copied correctly. There was no message telling me to reboot, but I rebooted anyways. When I came back into WinXPHome I ran aspichk.exe and it says my aspi version installed is 4.71.2 and it also says WARNING: ASPI component[s] missing. I thought maybe I didn't install it correctly so I went back and ran INSTALL.BAT XP32 and rebooted. Aspichk.exe still says its not installed correctly. I have burnt a data cd in B's Recorder Gold and ripped some tracks from an audio cd with EAC. No problems so far. I'm still not sure if im running on 4.71 or 4.72 though.
sven_Bent
post Oct 31 2002, 08:49
QUOTE (ogg @ Oct 31 2002 - 12:50 AM)
actually they are saying:
"This file extracts by default to the c:\adaptec\ irectory."
If the write code like that, i now understand why aspi 4.70 screwed up so many people's ripping ability.
Sven Bent - Denmark
Case
post Oct 31 2002, 09:38
Group: Developer (Donating)
QUOTE (mdefranc @ Oct 31 2002 - 02:23 AM)
I have installed these, no problems at all. I installed over 4.71 so I don't know if these are unable to set registry settings correctly like 4.7x. If they are, it's easy to fix with this.
Andavari
post Oct 31 2002, 11:28
You have to rename the installer for Win9x/2K machines since the batch file has an error in it pointing to the wrong .exe which doesn't exist -- that is if you use the batch file which isn't necessary on non WinXP machines. Even the docs mention the wrong .exe file name. The ASPI checking program states that it is installed correctly however.
I'll have no way of knowing if it is correct since I use VOB ASAPI in EAC for all my ripping, however when I go to do another backup to CD-RW I guess I'll find out.
System File Checker notes a version change on Windows 98:
C:\WINDOWS\SYSTEM\wnaspi32.dll
Previous ver 4.71 (0001) | New ver 4.71 (0002)
C:\WINDOWS\SYSTEM\IOSUBSYS\apix.vxd
Pervious ver 4.71 (0001) | New ver 4.71 (0002)
Complexity of incoherent design.
R.A.F.
post Oct 31 2002, 23:37
See what happened to me, when I installed those ASPI-drivers from Adaptec:
Hello guys!
Since I installed those nasty ADAPTEC-ASPI-drivers, all things go wrong on my computer. Every time, when I restart my system, all 2 IDE-devices (a CD- and a DVD-burner) disappear from the device-summary of Nero Burning Rom (thereīs only this "image recorder" still listed). And also, the second IDE-device (the dvd-burner) disappears from "Exact Audio Copy". I know how to solve this problem normally, by switching back in EAC to "Native Win 32 Interface for Win 2000/XP". But this function seems also to have been disabled by those ASPI-drivers of ADAPTEC. Now I would like to deinstall those drivers, but this also isnīt possible, as there is a deinstallation-routine (or -exe) missing. Iīm really trapped at the moment. I neither canīt move forward nor back anymore. Does anyone have an advice or suggestings? The only thing I know to do at the moment, is to re-install NERO. Then all devices appear again - but only until the next system-start, then they gone away again. Are the programmers of ADAPTEC totally "locco"?!
- R.A.F. -
P.S.:
I use the latest V4.71 Adaptec-ASPIīs and as OS I have Win XP Pro including the Service-Pack 1 installed.
Update:
I fixed the problem meanwhile. But NOT with those new ASPI-drivers (V4.72) from Adaptec. They are the same shit as the old ones. In my eyes, the programmers of Adaptec are a bunch of lamers. They should better quit their job!
I needed now nearly 1 hour to fix the problem by changing settings and generating keys in the registry , and searching and erasing 2 ASPI-driver-files, which are not needed. Thanks, Case, for the correct link to the fix-instructions!
To all out there: If you want to use alternative ASPIīs then take them from VOB. But all in all I have to say, that thereīs no need to do it, as the native-drivers of Win2000 and XP work without any errors.
My used codecs and settings:
FLAC V1.1.2 -4 / APE V3.99 Update 4 -high / MPC V1.15v --q 5 / LAME V3.97b2 -V2 --vbr-new / OGG aoTuV V4.51 Lancer -q5
dreamliner77
post Oct 31 2002, 23:49
As I like to say, don't try to fix it if it aint broke.
"You can fight without ever winning, but never win without a fight." Neil Peart 'Resist'
WaldoMonster
post Nov 1 2002, 00:05
Now something positive about Adaptec.
I use the Adaptec SCSI-layer since version 4.60 without any problem.
Since version 4.7x it is free to use.
At the moment I use Windows 2000 SP3 with the following software:
(Adaptec 4.72) ASPI32.SYS 4.7.12
(Adaptec 4.72) WOWPOST.EXE 4.6 (1021)
(Adaptec 4.72) WINASPI.DLL 4.6 (1021)
(Adaptec 4.72) WNASPI32.DLL 4.7.12
Golden Hawk CDRWin 3.9B (without the ASPI layer form golden hawk)
Golden Hawk DAO 3.9B
Nero Burning 5.5.9.14
Exact Audio Copy 0.9 beta 4 (ASPI Interface)
ak
post Nov 1 2002, 00:09
Musepack Developer
QUOTE (mdefranc @ Oct 31 2002 - 03:23 AM)
Installed it (win2k sp3), run it, no problems so far (--knockingonwood).
Did you have aspi 460 (or ForceASPI) installed before, or installed 471 on clean ('Adaptec-free') system. AFAIK it doesn't work if you install 4.7x without having 4.60 previously installed. Although it's ok from aspichk's point of view (it says 'installed & functional'), still it doesn't work.
R.A.F.
post Nov 1 2002, 02:12
OK, the story gone like this: About one week ago I installed V4.70 of Adaptecīs ASPIīs. I did this, because in some rare cases, Nero did not recognize my DVD-burner after system-start. So I thought about to install an alternative driver. Unfortunately I choosed the Adaptec-drivers, which were still on my hard-disk, as I did already download them a few months ago. (At that time I did not know, that VOB and Nero also have own ASPI-drivers.) After installing it, my drives disappeared partly (with EAC) and complete (when using Nero) ALWAYS after booting. And as those Adaptec-programmers "forgot" a deinstallation-routine, I was forced to have them forever on my system - I thought. So, I was looking for alternatives. I saw, that these drivers already were from february 2002 (or so), and so I took a look at their web-page for later releases. And there was one: V4.71 from may ī02. So I just installed them over the old ones. - What else should I do, as they even donīt have a possibility for deinstallation. So, "No, the installation wasnīt clean." And today I downloaded those new ASPI-version. - But it also didnīt correct my problems. So I followed the instructions of "ASPI fix when devices not show" (see link above): I deleted the 2 DLLīs "WOWPOST.EXE" and "WINASPI.DLL", as they are not necessary for WinXP. And this reg-fix file, which makes a new query in the registry, i also let ran. - But this all didnīt fix the problem. After each system-start nero did not show any drives for writing on. Only the very last hint:
[QUOTE]".....This has worked on EVERY XP/2K box I've tried. But, if it still doesn't work, try changing "Start"=dword:00000002 to "Start"=dword:00000001 in the .reg file then run it again, and then reboot."[QUOTE]
did solve my systemīs problem.
So, even if I would have installed Adaptecīs ASPIīs on a clean installation, these errors would have appeared, I suppose.
layer3maniac
post Nov 2 2002, 07:51
Post #15
Group: Banned
I'll stick with 4.60. Like Winamp 2, if it ain't broke - don't fix it!
RSS Lo-Fi Version Time is now: 5th August 2015 - 01:23
