Mpc Quality Settings For Dolby 2.1 Streams, Is the default --quality 5 insufficient?
atom
post Oct 28 2002, 19:03
Not sure whether this has been addressed before. Had a look through the forums, but could not find anything at first glance.
Something I picked up quite some time ago with MP3 was that the surround channel in a Dolby 2.1 (is that the correct term?) stream contained severe artifacts even with fairly high quality settings.
I experimented with MPC, and found this to also be true to for --quality 5. --quality 6 is significantly better, but I lack the equipment and expertise to truly compare the original with varying quality settings.
My question is: is this reasonable cause for encoding albums at --quality 6 or higher? In my opinion, yes. I have seen mention of other parameters (--ms?) that could possibly provide better stereo encoding (which is where the surround channel data really lives, isn't it?).
Can anyone maybe confirm my findings and comment on whether I'm just being paranoid, or whether it is more appropriate to use other parameters for such streams, in stead of --quality 6?
Note that many albums (especially live shows) seem to have this type of surround channel information; I believe it's either intentional or a side-effect of the way 2.1 decoding interprets the audio.
Dibrom
post Nov 3 2002, 07:01
Founder
Group: Admin
QUOTE (atom @ Oct 30 2002 - 06:05 PM)
The funny thing is that --ms 15 seemed to provide better quality for one particular portion of the sample than --ms 0.  There's a patch at 0.4s to 0.7s that sounds "rougher" on --ms 0 than --ms 15.  Possibly just coincidence.
Here's what Frank has said on this issue quite some time ago:
--ms 0 disables Mid/Side coding. This reduces significantly
quality for signal with high channel correlation.
This effect is called stereo unmasking. First mentioned in 1953.
A related effect is the "cocktail party effect".
--ms 0 should never be used.
Maybe someone should add this to the recommend MPC command lines. CiTay?
- atom   Mpc Quality Settings For Dolby 2.1 Streams   Oct 28 2002, 19:03
- - atom   Have done some more reading and testing. A fairly...   Oct 29 2002, 21:46
- - smok3   some rumble: very interesting, did you test any ot...   Oct 29 2002, 23:14
- - floyd   QUOTE (atom @ Oct 28 2002 - 12:03 PM)Note tha...   Oct 29 2002, 23:31
- - atom   A good example of an album with fairly strong surr...   Oct 30 2002, 17:37
- - Gecko   MPC is designed and tuned only for normal stereo l...   Oct 30 2002, 19:14
- - floyd   QUOTE (atom @ Oct 30 2002 - 10:37 AM)My probl...   Oct 30 2002, 22:15
- - atom   Another happy customer :-) Thanks, Gecko. Your c...   Oct 31 2002, 02:05
- - Trelane   I've been using a "poor man's surroun...   Nov 3 2002, 06:51
- - Dibrom   QUOTE (atom @ Oct 30 2002 - 06:05 PM)The funn...   Nov 3 2002, 07:01
- - CiTay   QUOTE (Dibrom @ Nov 3 2002 - 07:01 AM)Maybe s...   Nov 3 2002, 14:45
- - user   Adding --ms 15 in generally to --quality 5 ... 8 ?...   Nov 30 2002, 15:19
- - liekloo   Yes this is a very interesting topic. I do think ...   Nov 30 2002, 16:58
- - CiTay   We surely shouldn't generally append this swit...   Nov 30 2002, 17:53
- - user   I hope, my words above are not misunderstood, plea...   Nov 30 2002, 18:03
- - CiTay   Got an email from Frank Klemm (you too, user, thx)...   Nov 30 2002, 23:20
- - ssamadhi97   i don't like the term "stereo imaging...   Nov 30 2002, 23:42
- - CiTay   You are right, "surround information" th...   Nov 30 2002, 23:46
- - user   yes, you are right. I don't know, if Frank has...   Nov 30 2002, 23:47
- - user   Adding --ms 15 does not cause artefacts or worse s...   Dec 1 2002, 19:00
- - atom   Hi folks. As is implied in my earlier tests, I DI...   Dec 4 2002, 02:49
- - floyd   hmmm, i have about 15 gigs of mpcs (mostly), and n...   Dec 4 2002, 07:42
- - ProtectYaNeck36   please correct me if i am wrong but, just because ...   Dec 4 2002, 08:04
- - David Nordin   Uhm.. Dolby Surround is just 2 channels where you ...   Dec 4 2002, 08:38
- - floyd   QUOTE (ProtectYaNeck36 @ Dec 4 2002 - 01:04 A...   Dec 4 2002, 23:34
- - Mr. Superbad   I believe NIN's broken was made with DPL in mi...   Dec 5 2002, 00:04
- - atom   After considerably more searching than I anticipat...   Dec 5 2002, 02:59
- - floyd   I agree with you there. Movie soundtracks likely ...   Dec 5 2002, 03:40
- - user   QUOTE (floyd @ Dec 4 2002 - 11:34 PM)QUOTE (P...   Dec 5 2002, 09:24
- - atom   QUOTE (user @ Dec 5 2002 - 12:24 AM)hmm, have...   Dec 9 2002, 03:27
RSS Lo-Fi Version Time is now: 30th July 2015 - 06:33
