NSTL WMA Pro listening test, MS claims test proves WMA Pro > HE-AAC
[JAZ]
post Jan 11 2006, 21:40
QUOTE (gameplaya15143 @ Jan 11 2006, 03:32 AM)
i think they are 'supposed' to represent a % quality.. but they are just high-to-low (or should it say low-to-lower... uh oh.. i better watch out for tos8)
Have you heard problems with a ~240Kbps VBR (Q98) wma 9.1 file to say it is low quality?
Woodinville
post Jan 12 2006, 01:01
QUOTE ([JAZ] @ Jan 11 2006, 12:40 PM)
How about this new report (DBT and all) on WMA Pro quality?
http://www.microsoft.com/windows/windowsme...Comparison.aspx
J. D. (jj) Johnston
Woodinville
post Jan 14 2006, 08:02
I must admit that I am both offended and annoyed by the various insinuations in this thread. Hence, I shall say nothing here, and await evidence of the various insinuations and suggestions.
J. D. (jj) Johnston
Garf
post Jan 14 2006, 10:25
Mad Scientist
Group: Admin
QUOTE (Woodinville @ Jan 14 2006, 09:02 AM)
I'll make 2 factual observations:
1) If I follow the test procedure, the Nero files will be 64kbps LC-AAC, not HE-AAC. In their very detailed description, they simply didn't enable HE-AAC in the settings dialog. You can easily verify this with Nero 7 (even the free demo version should work).
Edit: Since this behaviour seems to have been fixed/may not have existed in the version used, you can ignore this for the sake of argument. I'll replace it by: 1) It seems impossible to verify the test results and setup.
2) They consulted with MS how to set up WMA and got new tools that are apparently not publicly available. They didn't consult with us, and used an old version of the Nero AAC encoder.
This post has been edited by Garf: Jan 14 2006, 16:02
Latexxx
post Jan 14 2006, 14:01
A/V Moderator
QUOTE (Garf @ Jan 14 2006, 11:25 AM)
If this is the case, somebody should contact Microsoft because they can't keep that comparison online if they know that it is completely false. Of course they could still keep it on their page but that would likely be illegel if they keep claiming that the paper proves wma's superiority to he aac.
And doesn't that mean that Microsoft's hyper super ultra new and amazing WMA 10 Pro + is only tied with lc aac instead of he aac.
This post has been edited by Latexxx: Jan 14 2006, 14:03
guruboolez
post Jan 14 2006, 14:09
Group: Members (Donating)
QUOTE (Latexxx @ Jan 14 2006, 02:01 PM)
Illegal? Do you mean that results of a test shouldn't be revealed if one term of the comparison is buggy?
Latexxx
post Jan 14 2006, 14:28
A/V Moderator
QUOTE (guruboolez @ Jan 14 2006, 03:09 PM)
No. But if they really have tested lc aac and know it, they can't keep lying by keeping that document publically available.
guruboolez
post Jan 14 2006, 14:31
QUOTE (Latexxx @ Jan 14 2006, 02:28 PM)
I agree with you. It would be a lie. But in this case, the conducer or the laboratory has clearly set Nero to use HE-AAC. There's apparently a bug in the software, and the conducer can't be responsible of this (and can't necessary notice it while performing the test).
EDIT: emphasis in the quote
This post has been edited by guruboolez: Jan 14 2006, 14:33
Garf
post Jan 14 2006, 14:39
Mad Scientist
Group: Admin
QUOTE (guruboolez @ Jan 14 2006, 03:31 PM)
If you fiddle around in the settings dialog, change some settings, and it clearly says "LC (Low Complexity) AAC", how on earth can you say that "it is clearly set to HE-AAC"?
Where is the bug???
guruboolez
post Jan 14 2006, 15:20
QUOTE (Garf @ Jan 14 2006, 02:39 PM)
Where is the bug???
You should read the testing procedure again. Step#6:
Select "Nero Digital Audio (HE-AAC v.2)....
The person has set Nero to use HE-AAC v.2 as described in the frontend. If the result is LC-AAC, then it would rather look to a bug than a feature.
Garf
post Jan 14 2006, 15:24
Mad Scientist
Group: Admin
QUOTE (guruboolez @ Jan 14 2006, 04:20 PM)
I read the testing procedure and it says that person also went on to the detailed encoder settings and changed them. As I already said, using the defaults, or using a preset, all would have produced a good result.
This post has been edited by Garf: Jan 14 2006, 15:28
RSS Lo-Fi Version Time is now: 4th August 2015 - 07:50
