Alternative Multiformat Listening Test @ 128 kbps, at SoundExpert with the same contenders
Serge Smirnoff
post Jan 13 2006, 17:46
As Sebastian Mares have practically finished accepting test results from participants I would like to offer for all who care to take part in alternative listening test with the same codec contenders but different sound samples. Testing methodology is also a bit different and makes testing much easier because sound artifacts are clearly audible in most cases. The main task of a listener is to grade annoyance of those artifacts.
Test files could be downloaded from here – ftp://www.soundexpert.info
Each time you click the link you’ll get random test file for one of these codecs:
• Nero AAC 3.1.0.2
• iTunes AAC 6.0.1.3
• LAME 3.97 Beta 2
• Ogg Vorbis AoTuV 4.51 Beta
• WMA Professional 9.1
• Shine 0.1.4 (Low Anchor)
Inside zip file you’ll find brief instruction and form for submitting results. The whole testing procedure is not hard and takes approx. 2-3 min., so you could easily test 5-10 files in one session. Each test file is 2-3 Mb.
Results of this test will appear on this page the same time with Sebastian Mares ones. After that they could be monitored in real time as new participants will add their grades.
Testing methodology used is described here - http://www.soundexpert.info/prozone.htm
Hope, comparison of both tests results will be interesting. If someone has any questions I am glad to answer.
keeping audio clear together - soundexpert.org
DigitalDictator
post Jan 14 2006, 14:00
BTW, are you sure that mp2 has to be worse than mp3 at high bitrates?
Am I sure? Absolutely not. I haven't compared them. I was just under the impression that QDesign was a rather poor encoder, but that might have been their mp3 encoder.
Serge Smirnoff
post Jan 14 2006, 14:34
QUOTE (DigitalDictator @ Jan 14 2006, 04:00 PM)
To my impression mp2 by QD is good, at least in comparison with the one from TMPGEnc, which has clearly audible artifacts without any artifacts amplification.
I'm not surprized, if mp2 at 224kbps be better than mp3. It has to be so in theory.
Garf
post Jan 14 2006, 14:52
Server Admin
Group: Admin
QUOTE (Serge Smirnoff @ Jan 14 2006, 03:34 PM)
"What theory would that be?"
MP3 has a much more efficient encoding structure than MPEG Layer 2. This doesn't magically change at high bitrates.
Serge Smirnoff
post Jan 16 2006, 23:29
QUOTE (Garf @ Jan 14 2006, 04:52 PM)
Sorry for being late with the answer, but now after guruboolez posts I could only add the citation from well known paper “MP3 and AAC Explained”:
5.6. Bit-rate versus quality
MPEG audio coding does not work with a fixed compression rate. The user can choose the bit-rate and this way the compression factor. Lower bit-rates will lead to higher compression factors, but lower quality of the compressed audio. Higher bit-rates lead to a lower probability of signals with any audible artifacts. However, different encoding algorithms do have ”sweet spots” where they work best. At bit-rates much larger than this target bit-rate the audio quality improves only very slowly with bit-rate, at much lower bit-rates the quality decreases very fast. The ”sweet spot” depends on codec characteristics like the Huffman codebooks, so it is common to express it in terms of bit per audio sample. For Layer-3 this target bit-rate is around 1.33 bit/sample (i.e. 128 kbit/s for a stereo signal at 48 kHz), for AAC it is around1 bit/sample (i.e. 96 kbit/s for a stereo signal at 48 kHz). Due to the more flexible Huffman coding, AAC can keep the basic coding efficiency up to higher bit-rates enabling higher qualities. Multichannel coding, due to the joint stereo coding techniques employed, is somewhat more efficient per sample than stereo and again than mono coding...
MPEG layers were designed to provide sufficient sound quality and the same time to be efficient in their area of application. For the reason sweet spot of mp1 (384-448 kbps) provides better audio quality than sweet spot of mp2 (192-256 kbps), which is better again than sweet spot of mp3 (112-160 kbps). Due to slow improvements in sound quality at bitrates above sweet spots, there are points where previous layer begins to provide better audio quality (AAC is going to be an exclusion from this rule – time and tests will show). For mp3/mp2 such point is between 224 and 256 kbps.
So, using layers at higher than sweet spot bitrates is inefficient and could be reasonable for compatibility only.
halb27
post Jan 16 2006, 23:52
QUOTE (Serge Smirnoff @ Jan 17 2006, 12:29 AM)
What about vorbis? Vorbis seems to be great from 80 kbps to 256 kbps and more.
What is vorbis' sweet spot?
Serge Smirnoff
post Jan 17 2006, 00:03
QUOTE (halb27 @ Jan 17 2006, 01:52 AM)
[What about vorbis? Vorbis seems to be great from 80 kbps to 256 kbps and more.
Sweet spot concept is true for MPEG family codecs. It may not for others. Vorbis seems to perform efficiently everywhere.
- Serge Smirnoff   Alternative Multiformat Listening Test @ 128 kbps   Jan 13 2006, 17:46
- - jido   QUOTE (Serge Smirnoff @ Jan 13 2006, 08:46 AM...   Jan 14 2006, 11:26
|- - Serge Smirnoff   QUOTE (jido @ Jan 14 2006, 01:26 PM)So the te...   Jan 14 2006, 12:19
- - loophole   Artificial stimuli? As opposed to music? Isn't...   Jan 14 2006, 12:32
|- - Serge Smirnoff   QUOTE (loophole @ Jan 14 2006, 02:32 PM)Artif...   Jan 14 2006, 12:46
- - DigitalDictator   Interesting to check out the comparisons at other ...   Jan 14 2006, 12:58
|- - Serge Smirnoff   QUOTE (DigitalDictator @ Jan 14 2006, 02:58 P...   Jan 14 2006, 13:46
- - DigitalDictator   QUOTE BTW, are you sure that mp2 has to be worse t...   Jan 14 2006, 14:00
|- - Serge Smirnoff   QUOTE (DigitalDictator @ Jan 14 2006, 04:00 P...   Jan 14 2006, 14:34
|- - Garf   QUOTE (Serge Smirnoff @ Jan 14 2006, 03:34 PM...   Jan 14 2006, 14:52
|- - guruboolez   QUOTE (Garf @ Jan 14 2006, 02:52 PM)QUOTE (Se...   Jan 14 2006, 15:27
|- - Serge Smirnoff   QUOTE (Garf @ Jan 14 2006, 04:52 PM)QUOTE (Se...   Jan 16 2006, 23:29
|- - halb27   QUOTE (Serge Smirnoff @ Jan 17 2006, 12:29 AM...   Jan 16 2006, 23:52
|- - Serge Smirnoff   QUOTE (halb27 @ Jan 17 2006, 01:52 AM)[What a...   Jan 17 2006, 00:03
- - Garf   Note the parts "256kbps", "Often...   Jan 14 2006, 15:36
|- - guruboolez   QUOTE (Garf @ Jan 14 2006, 03:36 PM)Note the ...   Jan 14 2006, 15:46
- - Jan S.   As far as I recall Klemm actually considered to mo...   Jan 14 2006, 15:56
- - Garf   If you spend more bits on the right coefficients, ...   Jan 14 2006, 16:15
|- - guruboolez   QUOTE (Garf @ Jan 14 2006, 04:15 PM)That...   Jan 14 2006, 16:56
|- - halb27   QUOTE (guruboolez @ Jan 14 2006, 05:56 PM)......   Jan 16 2006, 21:52
- - Garf   The problem of PS and SBR is that they are paramet...   Jan 14 2006, 18:13
- - guruboolez   The testing procedure of this second listening tes...   Jan 15 2006, 04:28
|- - Serge Smirnoff   QUOTE (guruboolez @ Jan 15 2006, 06:28 AM)Wha...   Jan 15 2006, 11:37
- - guruboolez   I understand. The procedure is indeed very easy to...   Jan 15 2006, 12:07
|- - Serge Smirnoff   QUOTE (guruboolez @ Jan 15 2006, 02:07 PM)The...   Jan 15 2006, 12:49
- - Sebastian Mares   Just noticed something on the page... QUOTE aac A...   Jan 15 2006, 13:15
|- - Serge Smirnoff   QUOTE (Sebastian Mares @ Jan 15 2006, 03:15 P...   Jan 15 2006, 18:25
- - Ivan Dimkovic   QUOTE So, using layers at higher than sweet spot b...   Jan 16 2006, 23:43
- - Ivan Dimkovic   "Sweet spot" comes from the relatively s...   Jan 17 2006, 00:11
- - Sagittaire   Just my 2 cents ... ;-) 1) Well ... not really 12...   Jan 18 2006, 13:26
- - Gabriel   QUOTE 1) Well ... not really 128 Kbps test but 140...   Jan 18 2006, 13:39
|- - Sagittaire   QUOTE The resulting overall on overall music is ab...   Jan 18 2006, 14:15
- - Alex B   The bitrates were measured with a big amount of co...   Jan 18 2006, 13:45
- - Alex B   BTW, this thread is about the alternative Sound Ex...   Jan 18 2006, 13:58
- - Garf   The ability of a codec to distribute more bits to ...   Jan 18 2006, 14:28
- - pepoluan   Just noticed that on SoundExpert site, the lower b...   Jan 19 2006, 18:01
- - Serge Smirnoff   QUOTE (pepoluan @ Jan 19 2006, 08:01 PM)Consi...   Jan 20 2006, 00:00
RSS Lo-Fi Version Time is now: 27th March 2015 - 18:58
