Alternative Multiformat Listening Test @ 128 kbps, at SoundExpert with the same contenders
Serge Smirnoff
post Jan 13 2006, 17:46
As Sebastian Mares have practically finished accepting test results from participants I would like to offer for all who care to take part in alternative listening test with the same codec contenders but different sound samples. Testing methodology is also a bit different and makes testing much easier because sound artifacts are clearly audible in most cases. The main task of a listener is to grade annoyance of those artifacts.
Test files could be downloaded from here – ftp://www.soundexpert.info
Each time you click the link you’ll get random test file for one of these codecs:
• Nero AAC 3.1.0.2
• iTunes AAC 6.0.1.3
• LAME 3.97 Beta 2
• Ogg Vorbis AoTuV 4.51 Beta
• WMA Professional 9.1
• Shine 0.1.4 (Low Anchor)
Inside zip file you’ll find brief instruction and form for submitting results. The whole testing procedure is not hard and takes approx. 2-3 min., so you could easily test 5-10 files in one session. Each test file is 2-3 Mb.
Results of this test will appear on this page the same time with Sebastian Mares ones. After that they could be monitored in real time as new participants will add their grades.
Testing methodology used is described here - http://www.soundexpert.info/prozone.htm
Hope, comparison of both tests results will be interesting. If someone has any questions I am glad to answer.
keeping audio clear together - soundexpert.org
Garf
post Jan 14 2006, 16:15
Server Admin
Group: Admin
If you spend more bits on the right coefficients, the time smearing gets less. This is true even if the time resolution is low. Since MP3 is more efficient, it can afford to spend more bits to do this (remember GTune Vorbis?). That's why it's not so clear-cut.
On the page you link though, there's this:
To my mind only MPEG-4 AAC is capable to eliminates all disadvantages of the additional frequency resolution. The result is transparent coding at data rates around 120...130 kbps (instead of 170...180 kbps as MPEGplus). But a
    * high quality MPEG-4 AAC Encoder is much much more difficult to program and to tune than a MPEGplus encoder
I agree strongly with this (it's also true for MP3 vs MP2) and it points that the "theorethical" advantages any format may have can be problematic since they must be used fully and correctly. We have not reached this point with MP3 and it will take much longer with AAC.
That's why I also disagree with the statement that format X must be better than format Y. The implementation is the limiting factor.
This post has been edited by Garf: Jan 14 2006, 16:26
guruboolez
post Jan 14 2006, 16:56
Group: Members (Donating)
QUOTE (Garf @ Jan 14 2006, 04:15 PM)
It's just that Frank Klemm comments are making sense. It's like He-AAC or Parametric Stereo: it outperforms LC-AAC or joint stereo for efficiency at low bitrate. But at higher ones, these tools are leading to artifacts or distortions you won't get with less efficient tools. This sudden change has nothing to do with magic. A sprinter is always a poor 10.000 meters runner.
There are several samples which may be transparent with layer 2 at high bitrate, even if the mp2 encoder is not intensively tuned - or may at least be less distorted than a very high quality implementation of MP3 such LAME. I can ABX castanets at 640 kbps with LAME freeformat, but I'll probably fail with most other formats at half this bitrate.
Implementation has a big part in quality, but some inherent flaw in design could definitely handicap a format. Klemm often criticized layer 3 (and not transform encoders by themselves) design in the past.
Actually, I woudn't exchange one LAME encoded file for 10 mp2 (toolame...) files at 224 kbps. There's maybe less pre-echo (it's not even sure), but there are several other form of distortions.
This post has been edited by guruboolez: Jan 14 2006, 16:57
halb27
post Jan 16 2006, 21:52
QUOTE (guruboolez @ Jan 14 2006, 05:56 PM)
... A sprinter is always a poor 10.000 meters runner. ....
I like this comparison for high / low bitrate encodings.
... I can ABX castanets at 640 kbps with LAME freeformat, but I'll probably fail with most other formats at half this bitrate. ...
As I'm pretty insensitive towards pre-echo would you be so kind to try castanets
with
- Helix -V140 -X2 -HF2 -SBT450 -TX0 -F18600 or similar
- Lame 3.90.3 or 3.91 --abr 270 -b224 -h --lowpass 18600 or similar ?
As I'm considering using bitrates lower than I did before Vorbis comes to my mind again (on my iRiver H140 battery drain with Vorbis unfortunately is rather high but I can compensate for it a bit by using lower bitrates). Can you say something towards aoTuv 4.51 pre-echo behavior for -q7 or -q6?
Thanks in advance.
- Serge Smirnoff   Alternative Multiformat Listening Test @ 128 kbps   Jan 13 2006, 17:46
- - jido   QUOTE (Serge Smirnoff @ Jan 13 2006, 08:46 AM...   Jan 14 2006, 11:26
|- - Serge Smirnoff   QUOTE (jido @ Jan 14 2006, 01:26 PM)So the te...   Jan 14 2006, 12:19
- - loophole   Artificial stimuli? As opposed to music? Isn't...   Jan 14 2006, 12:32
|- - Serge Smirnoff   QUOTE (loophole @ Jan 14 2006, 02:32 PM)Artif...   Jan 14 2006, 12:46
- - DigitalDictator   Interesting to check out the comparisons at other ...   Jan 14 2006, 12:58
|- - Serge Smirnoff   QUOTE (DigitalDictator @ Jan 14 2006, 02:58 P...   Jan 14 2006, 13:46
- - DigitalDictator   QUOTE BTW, are you sure that mp2 has to be worse t...   Jan 14 2006, 14:00
|- - Serge Smirnoff   QUOTE (DigitalDictator @ Jan 14 2006, 04:00 P...   Jan 14 2006, 14:34
|- - Garf   QUOTE (Serge Smirnoff @ Jan 14 2006, 03:34 PM...   Jan 14 2006, 14:52
|- - guruboolez   QUOTE (Garf @ Jan 14 2006, 02:52 PM)QUOTE (Se...   Jan 14 2006, 15:27
|- - Serge Smirnoff   QUOTE (Garf @ Jan 14 2006, 04:52 PM)QUOTE (Se...   Jan 16 2006, 23:29
|- - halb27   QUOTE (Serge Smirnoff @ Jan 17 2006, 12:29 AM...   Jan 16 2006, 23:52
|- - Serge Smirnoff   QUOTE (halb27 @ Jan 17 2006, 01:52 AM)[What a...   Jan 17 2006, 00:03
- - Garf   Note the parts "256kbps", "Often...   Jan 14 2006, 15:36
|- - guruboolez   QUOTE (Garf @ Jan 14 2006, 03:36 PM)Note the ...   Jan 14 2006, 15:46
- - Jan S.   As far as I recall Klemm actually considered to mo...   Jan 14 2006, 15:56
- - Garf   If you spend more bits on the right coefficients, ...   Jan 14 2006, 16:15
|- - guruboolez   QUOTE (Garf @ Jan 14 2006, 04:15 PM)That...   Jan 14 2006, 16:56
|- - halb27   QUOTE (guruboolez @ Jan 14 2006, 05:56 PM)......   Jan 16 2006, 21:52
- - Garf   The problem of PS and SBR is that they are paramet...   Jan 14 2006, 18:13
- - guruboolez   The testing procedure of this second listening tes...   Jan 15 2006, 04:28
|- - Serge Smirnoff   QUOTE (guruboolez @ Jan 15 2006, 06:28 AM)Wha...   Jan 15 2006, 11:37
- - guruboolez   I understand. The procedure is indeed very easy to...   Jan 15 2006, 12:07
|- - Serge Smirnoff   QUOTE (guruboolez @ Jan 15 2006, 02:07 PM)The...   Jan 15 2006, 12:49
- - Sebastian Mares   Just noticed something on the page... QUOTE aac A...   Jan 15 2006, 13:15
|- - Serge Smirnoff   QUOTE (Sebastian Mares @ Jan 15 2006, 03:15 P...   Jan 15 2006, 18:25
- - Ivan Dimkovic   QUOTE So, using layers at higher than sweet spot b...   Jan 16 2006, 23:43
- - Ivan Dimkovic   "Sweet spot" comes from the relatively s...   Jan 17 2006, 00:11
- - Sagittaire   Just my 2 cents ... ;-) 1) Well ... not really 12...   Jan 18 2006, 13:26
- - Gabriel   QUOTE 1) Well ... not really 128 Kbps test but 140...   Jan 18 2006, 13:39
|- - Sagittaire   QUOTE The resulting overall on overall music is ab...   Jan 18 2006, 14:15
- - Alex B   The bitrates were measured with a big amount of co...   Jan 18 2006, 13:45
- - Alex B   BTW, this thread is about the alternative Sound Ex...   Jan 18 2006, 13:58
- - Garf   The ability of a codec to distribute more bits to ...   Jan 18 2006, 14:28
- - pepoluan   Just noticed that on SoundExpert site, the lower b...   Jan 19 2006, 18:01
- - Serge Smirnoff   QUOTE (pepoluan @ Jan 19 2006, 08:01 PM)Consi...   Jan 20 2006, 00:00
RSS Lo-Fi Version Time is now: 28th February 2015 - 01:55
