How To Burn An Mp3 - Cd ?, short How To
user
post Oct 24 2002, 19:51
How to burn an mp3 - CD ?
So, here#s the answer:
1. In generally:
Burn as data CD
2. example Nero:
CD-Rom (ISO)
no multisession (for safety, if you have a player, which is not able to read multisession, or the 2nd, 3rd session...)
Mode 1 - ISO Level 2 (should work, level 1 is even safer)
advantage of ISO level 2 is : longer file names
ISO 9660 - Joliet
Disc at once
That's it.
perhaps additionally:
click: verify burned data
www.High-Quality.ch.vu -- High Quality Audio Archiving Tutorials
westgroveg
post Oct 25 2002, 06:47
long file names (65+) you must use Romeo file system or the file names will be cut down . I found my hardware player works better with Romeo anyway so I always use it. This is how I arrange things, it seems the best way to me:
Each album: folder=Artist - Album
file names: Title only
m3u playlist
ID3v1 tags
jpeg front/back covers.
If you extract with, Track number - file name you can setup tag frontend with
%N - %T custom filenames scheme & you don't need to write out every title, track number it’s done auto.
Use Princo CD-R's for highest compatibility (xbox, some standalones)
If you want longest life possible burns Kodak or check this site
From Nero:
Disc-at-Once
This is a write process which does not create links between the individual sessions. The recorder starts by writing the lead-in, which is followed by the data and the lead-out. This process is used primarily by manufacturers of audio CDs.
Disc-at-Once/96 is an extension of Disc-at-Once which gives the software better control of the burning process. This mode is preferable, if it is available.
Track-at-Once
This is a method of writing data which is used for multisession CDs. The CD-RW drive writes all the tracks one after another and does not end the session until this is finished.
Multisession [harder to read, lower compatibility] should be avoided although write strategy is not important as far as compatibility.
- user   How To Burn An Mp3 - Cd ?   Oct 24 2002, 19:51
- - SNYder   What is the difference between disk at once, track...   Oct 24 2002, 20:51
- - fewtch   QUOTE (SNYder @ Oct 24 2002 - 12:51 PM)What i...   Oct 24 2002, 21:26
- - westgroveg   long file names (65+) you must use Romeo file syst...   Oct 25 2002, 06:47
- - SNYder   QUOTE (fewtch @ Oct 24 2002 - 03:26 PM)Disk a...   Oct 25 2002, 11:18
- - fewtch   QUOTE (SNYder @ Oct 25 2002 - 03:18 AM)QUOTE ...   Oct 25 2002, 11:38
- - CiTay   QUOTE (SNYder @ Oct 25 2002 - 12:18 PM)ummm.....   Oct 25 2002, 14:36
- - Zin_Ramu   I'd like to add that before you decide what wh...   Oct 25 2002, 21:32
- - Reset®   And what do you thing about set of character ASCII...   May 14 2003, 14:44
- - Jojo   disk at once/96 also allows you (in case your burn...   May 14 2003, 15:46
|- - andersonmilltexas   QUOTE (Jojo @ May 14 2003, 09:46 AM)disk at o...   Jul 25 2004, 01:59
|- - andersonmilltexas   QUOTE (andersonmilltexas @ Jul 24 2004, 07:59...   Jul 25 2004, 03:15
- - andersonmilltexas   QUOTE (user @ Oct 24 2002, 01:51 PM)How to bu...   Jul 25 2004, 03:31
|- - andersonmilltexas   QUOTE (andersonmilltexas @ Jul 24 2004, 09:31...   Jul 25 2004, 03:33
- - dreamliner77   Let me introduce you to the edit button for your p...   Jul 25 2004, 06:06
- - Slacker   Thank you, I was searching for a solution for my g...   Mar 5 2005, 10:57
- - evereux   This guide may help eliminate your gap. I'm n...   Mar 5 2005, 12:45
- - Slacker   QUOTE (evereux @ Mar 5 2005, 01:45 PM)This gu...   Mar 5 2005, 13:08
RSS Lo-Fi Version Time is now: 19th April 2015 - 04:06
