LAME high bitrate files in l3codeca.ax
menno
post Jan 4 2006, 15:46
Nero MPEG4 developer
Group: Developer (Donating)
I found a problem with LAME high bitrate CBR files (256 kbps and 320 kbps only it seems) when playing them back using l3codecx.ax. It happens only when the decoder decodes a frame of silence (where LAME produces some version messages and 0x55 fillup bytes to keep up to a constant bitrate). After that the decoder will not produce sound anymore, but only silence. It also happens when such a silence frame occurs somewhere in the middle of a file.
EDIT: It's not a problem with the ACM filter it's a problem with the DirectShow filter for MP3 decoding that comes with Windows. The version info says: MPEG Layer 3 Audio Decoder version 1.5 (build 50). This filter is called l3codecx.ax, not l3codeca.acm smile.gif
Is this a known problem? Any easy solutions for it? FhG encoded high bitrate CBR files don't have this problem (it fills up with 0xFF and no version messages).
Menno
This post has been edited by menno: Jan 4 2006, 16:21
menno
post Jan 4 2006, 17:14
I think LAME just uses too much buffer size, the decoder probably checks for the buffer size limit, which is perfectly fine.
RSS Lo-Fi Version Time is now: 4th May 2015 - 23:21
