18 Pages V  < 1 2 3 4 > »
Why 24bit/48kHz/96kHz/, If 16bit/44.1kHz is good enough?
Garf
post Dec 30 2005, 15:13
Post #26
Mad Scientist
Group: Admin
QUOTE (boombaard @ Dec 30 2005, 03:37 PM)
how odd.. since the SNR is that much higher, it can't be that they just master it for sacd/dvda and then use that same mastering for cd, since it would, if i'm not mistaken, be clipped much worse than on the 24/bla version..
i wonder what the point of their advertising with 'higher quality' is it's basically just higher volume out of the box tongue.gif
Clipping has to do with maximum sample values, not with SNR.
The differences between CD and other formats are completely irrelevant for that. The clipping is not a technical problem. It's one of being AS LOUD AS POSSIBLE. Mastering engineers are REDUCING the dynamic range. That's yet another reason "better" formats are useless.
boombaard
post Dec 30 2005, 15:46
Post #27
QUOTE (Garf @ Dec 30 2005, 03:13 PM)
yeah.. forgive me for putting that a bit awkwardly, but as i understand it the things clip because of the 'saturation', which is directly linked to the bit depth, correct? and they clip because of the volume being too high, so in that regard sacd should be harder to saturate than redbook cd's.. correct?
jussi
post Dec 30 2005, 15:52
Post #28
well, and what about the HDCD (20bit) technology? what are the other 4bits used for?
William
post Dec 30 2005, 15:54
Post #29
Well, it sounds like these 24bits / whatever kHz are simply marketing gimmicks than really practically useful for the end user.
Garf
post Dec 30 2005, 15:56
Post #30
Mad Scientist
Group: Admin
QUOTE (boombaard @ Dec 30 2005, 04:46 PM)
No, no, no, no....please reread my post. You could have a 2560000 bit format and it would still be able to clip just as easily as a 8 bit wave file, as long as people are trying to make the music as loud as possible.
A CD doesn't store "loudness". The loudness is controlled by the person with the volume know. Given an equal settings, dynamics compression + maximized peak values will give a louder sound. Apparently a lot of people in mastering think this is desirable, so they do just that: maximize the peaks to the maximum the recording format can store, be it 15, 24 or 10000 bits. And very often, they go beyond that (clipping). Adding more bits (more SNR) is helpless against that stupidity. The formats have assloads of headroom but NOBODY USES IT!
This post has been edited by Garf: Dec 30 2005, 16:04
Garf
post Dec 30 2005, 16:00
Post #31
Mad Scientist
Group: Admin
QUOTE (jussi @ Dec 30 2005, 04:52 PM)
HDCD is CD + dither + noiseshaping + a control signal. And it's only 16 bit, which is why it is compatible with CD's.
The dither + noiseshaping will give an effective increase in resolution (marketing claims: 20bit effective). The control signal will prevent clipping in some circumstances (it's a workaround for braindead mastering engineers).
You can do the dithering + noiseshaping on any CD (not just a HDCD) and it will work effectively. But there are few CD's that are properly made like that.
Use the search function if you want to know more.
This post has been edited by Garf: Dec 30 2005, 16:07
Wintershade
post Dec 30 2005, 16:04
Post #32
Sorry for popping in like that, but here's my answer to the main question here...
I do a lot of audio editing (some people call me a "producer"). For my needs, 16/44.1 kHz is far from sufficient - after applying some filters and effects, artifacts are very audible and audio is heavily damaged. This is compensated with higher sampling rates and bit depths - for now I'm content with 32 bit/88.2 kHz audio.
However, this tosses me out from the "end users" basket. Yes, objectively, for the end users 16/44.1 audio is totally sufficient.
Why end users are being presented with "higher-quality" audio now is beyond me, since most of them can't even hear the difference between 192 kbps mp3 and a "common" audio CD.
Cheerz =]
Only the best is good enough.
bug80
post Dec 30 2005, 16:25
Post #33
QUOTE (Wintershade @ Dec 30 2005, 05:04 PM)
I do a lot of audio editing (some people call me a "producer"). For my needs, 16/44.1 kHz is far from sufficient - after applying some filters and effects, artifacts are very audible and audio is heavily damaged. This is compensated with higher sampling rates and bit depths - for now I'm content with 32 bit/88.2 kHz audio.[Cheerz =]
I understand the part about 32 bits per sample (although 24 bit seems sufficient in most cases), but why 88.2 kHz? Do you have many subsequent A/D converters in your recording chain, like I explained above, because I don't think it is of much use if you do all your editing in the digital domain and resample to 44.1 kHz afterwards.
Crissaegrim
post Dec 30 2005, 17:02
Post #34
Definitive answer... Artists record at as high as 192khz. It has to be down-sampled to 44.1khz to fit on a media CD. It just gives you (you = audiophiles) a fuzzy feeling knowing that it's "really close" to the original recording. rolleyes.gif
bug80
post Dec 30 2005, 17:09
Post #35
QUOTE (Crissaegrim @ Dec 30 2005, 06:02 PM)
Most studios know that recording at > 44.1 kHz is pretty useless, unless it is a recording for DVD-A or SACD purposes. All studios I know record simply at 44.1 kHz / 24 bit. There are no artists that I know of that record at 192 kHz to give the end user a fuzzy feeling smile.gif
Axon
post Dec 30 2005, 19:39
Post #36
Group: Members (Donating)
Some DSP algorithms may benefit from a high sampling rate, but strictly speaking, they can all be written to work fine at 44.1, or else the algorithm itself will just include its own resampler to do what it needs to do. (A trivially naive example: suppose you want to make a comb filter in less than 10 taps with a starting freq of 12khz. AFAIK, you can't do that with a 44.1 sampling rate, or else you could do it more easily with 96 than you could with 44.1.)
Low integral resamples (88.2 -> 44.1) are quite a bit easier on the math compared to 96->44.1. It shouldn't make an audible difference but the filters need to be much much more complex for the 96 downsample to be legitimate.
The 44.1khz frequency was chosen because the first PCM machines used (drumroll) analog videotape as its media. The math worked out that at 16 bits of resolution you could cram enough samples into a video frame to get 44.1.
The really ironic thing about 192khz is that the SNR numbers are objectively worse compared to 96khz recording (to say nothing of 44.1). Virtually all ADCs are sigma-delta nowadays anyway, and one of their fundamental characteristics is that you can always trade off frequency for resolution. There are a couple hardware vendors who actively speak out against 192khz recording for this reason.
In fact I'd almost argue that 192khz was just as much driven by hardware vendors than audiophiles. They're already trying to cram DxD down studios' necks. 8 bits at 384khz... yuck.
Lyx
post Dec 30 2005, 19:58
Post #37
Regarding clipping and samplerate: according to a paper i read recently, a higher samplerate can indeed lower the amount of *analogue clipping*. But this can just as well be achieved on 44khz if its recorded with proper level meters (thus, not overcompressed AND then normalized to the maximum). So, the higher samplerate simply acts as a safeguard against malicious mastering practices. Notice that this will only lower the amount of clipping - dynamics will still suffer from overcompression.
Explanation is as following: even if the digital representation of a signal does not clip, it may still clip when its converted back to analogue. As you know, a digital representation of a waveform can simply be visualized as evenly spaced dots. So, only "snapshots" of the signal are stored, not lines or curves. When this representation goes through the DAC it is reconstructed to the real analogue wave - this however does not simply happen by connecting the "dots" with straight lines - instead it is a spline curve. The implication of this is that even if your signal peaks at 100% in the digital representation, it may still go "over the top" when its reconstructed - because the peak values of the digital snapshots are not equal to peak values of the resulting *analogue* signal. A higher samplingrate can lower this effect - but if proper level meters would be used during mastering, then this wouldn't be necessary at all...... of course, that would mean lowering the loudness a bit.... so.....
Raptus
post Dec 30 2005, 20:07
Post #38
>16bit would be necessary if someone wanted to make a recording with dynamics ranging from treshold of hearing to treshold of pain...
While Nyquist states that every signal component below the Nyquist frequency can be preserved realworld filter constraints make the usable bandwidth smaller, CD specs garantee only up to 20Khz. But that is enough. Using higher samplerates though makes implementing the digital reconstruction filter of the DACs less critical, like Axon already mentioned.
NoXFeR
post Dec 31 2005, 00:05
Post #39
On a sidenote; recorders may want higher frequencies if they want the frequencies generated above 22khz (analog) in their production. For instance, I have had interesting results playing back 96khz recordings of cymbals at 44khz. I believe quite some artists use this technique, especially for electronic music.
bug80
post Dec 31 2005, 12:16
Post #40
QUOTE (NoXFeR @ Dec 31 2005, 01:05 AM)
What do you mean? If you playback anything on 44.1 kHz, you will have no energy content above 22.05 kHz, in fact, due to anti-aliasing filtering the roll-off will even start at a lower frequency.
bug80
post Dec 31 2005, 12:23
Post #41
QUOTE (Lyx @ Dec 30 2005, 08:58 PM)
Explanation is as following: [...]
I've read this also. However, I think that this can only be avoided by using a sampling rate of infinity. Doubling the sampling frequency will reduce the number of clipping samples by a factor of two, or so. But it will still happen.
Second, when a producer records at 96 kHz and sees no clipping on his meters, the clipping effect you explained may occur as soon as he/she resamples back to 44.1 kHz for CD. So, it may be better to record at 44.1 kHz from the beginning in this case.
Lyx
post Dec 31 2005, 12:33
Post #42
One more reason to instead simply use proper level meters, and use compressors in a sane way. Actually, just lowering the amount of compression alone would probably make the problem insignificant in practice.
bug80
post Dec 31 2005, 13:33
Post #43
QUOTE (Lyx @ Dec 31 2005, 01:33 PM)
Indeed.
By the way, I thought a little bit longer about this. My question now is: is this clipping effect really a problem in practice? Let's assume the output of a D/A converter is in de range -/+ 1 V. Due to the clipping the output becomes -/+ 1.05 V, for instance. I think no analogue equipment will have a problem with that. Since it is all analogue, the sound will not clip, as it would in the digital domain.
Garf
post Dec 31 2005, 14:20
Post #44
Mad Scientist
Group: Admin
QUOTE (bug80 @ Dec 31 2005, 02:33 PM)
Indeed.
By the way, I thought a little bit longer about this. My question now is: is this clipping effect really a problem in practice? Let's assume the output of a D/A converter is in de range -/+ 1 V. Due to the clipping the output becomes -/+ 1.05 V, for instance..
Huu, no. It will be +-1V and not more. The clipping will add distortion because the wave shape no longer corresponds to the original (has additional HF distortion).
bug80
post Dec 31 2005, 14:23
Post #45
QUOTE (Garf @ Dec 31 2005, 03:20 PM)
Indeed.
Why, because the analogue output of a D/A converter is limited? Why should it be? You may be right, I'm no expert on D/A converters.
edit: We're not talking about conventional clipping here, but clipping due to the D/A conversion, so that's where my question comes from.
This post has been edited by bug80: Dec 31 2005, 14:23
Garf
post Dec 31 2005, 14:26
Post #46
Mad Scientist
Group: Admin
I believe this is wrong, or actually, not really explained as corresponding to reality. The DAC will follow the PCM representation as closely as possible, and thus add all kinds of HF distortion. Following up on the DAC should be an (as perfect as possible) lowpass filter, which will remove them again, and leave a "perfect" signal. This follows directly from DSP sampling theory.
The result of this process is more or less as you explain (though it isn't a spline curve, not in the mathemathical sense).
The problem of constructing the ideal as possible lowpass filter is one argument that is used for higher sampling rates (if you up the sampling rate, you can make a crappier filter and still get the same quality audio). It's a rather crappy argument though, because it's not as if we can't cheaply make good performing ones now!
This post has been edited by Garf: Dec 31 2005, 14:29
kwwong
post Dec 31 2005, 14:30
Post #47
The main reason why sampling rates > 44.1Khz is used is that at the hardware / player, the required transition bandwidth of the analogue low pass anti-aliasing filter is much - much wider and thus a simple low order analogue filter is sufficient. Building a low-order linear phase low pass filter is very simple compare to a high order filter!
It has nothing to do with psychoacoustics but electronics. If the sampling rate is 192 kHz, do not expect to hear above the usual 18 - 20 kHz range.
As for the case of 24 bits, I supposed 16 bits audio isn't enough to represent the entire dynamic range of the human hearing. At its most sensitive region, around 2 - 4 kHz, this dynamic range is actually greater than 100 dB. wink.gif
This post has been edited by kwwong: Dec 31 2005, 14:33
Garf
post Dec 31 2005, 14:31
Post #48
Mad Scientist
Group: Admin
QUOTE (bug80 @ Dec 31 2005, 03:23 PM)
Indeed.
Yes, of course it's limited. In practise it'll be limited to the supply voltage, i.e. 3.3V or something thereabouts.
Edit: Or a bit less depending on design etc. But in any case, the output voltage for sure is hard limited, it won't magically swing outside it's maximum range.
This post has been edited by Garf: Dec 31 2005, 14:34
Garf
post Dec 31 2005, 14:41
Post #49
Mad Scientist
Group: Admin
QUOTE (kwwong @ Dec 31 2005, 03:30 PM)
I know this argument, but does it have any bearing on practise? I mean, is this still a practical problem anywhere? It certainly doesn't seem to be! Even if we can't get the theorethical resolution because of limitations of real world filters, we certainly seem to be able to do well enough very cheaply that the results are perfect in a psychoacoustical sense.
Yes, and the amount of records that actually need such a dynamic range is? One in ten million?
As I already explained, I do not think that we need a dynamic range so far that the lower end of audibility corresponds with a higher end where the hearing of the listener is damaged by anything but very short term exposure. That's not only useless, it's actually dangerous.
This post has been edited by Garf: Dec 31 2005, 14:45
Garf
post Dec 31 2005, 14:51
Post #50
Mad Scientist
Group: Admin
Another thing to consider is that with proper dithering and noiseshaping, the effective resolution at 44.1kHz can be boosted by as much as 15dB. This means that a properly produced CD (unfortunately very few exist, but HDCD are an example) will have an effective SNR of 111dB.
How many ADC or DAC's have you seen that can attain that resolution?
This post has been edited by Garf: Dec 31 2005, 14:54
RSS Lo-Fi Version Time is now: 29th May 2015 - 20:54
